c2Up<#t SYM_NAME | -A)/CFIZ COMP_DEVICE_TYPE | M =6 COMP_VALUE | ?v$1Fc55 COMP_TOL | oPC
qv COMP_CLASS | @+(a{%~7y REFDES |
4 ky/a1y- C7343-84X118 | SS"Z>talw CAP 47UF TAN 10V 20% EIA_D_0_C7 | Ufv0Xj 220uF | W;ADc2#) | f<l.%B IC | 2hFj+Ay C1 |
;%Rp=&J C603-35X45 | Ops""#Zi CAP NP_5_C603-35X45_NO-POP | _VI3b$ NO-POP | 06fs,!Q@ | xqLIs:* IC | GL8 N!, C2 |
!)h?2#V8; C402-25 | O*-sSf CAP 100NF CERMC 16V 10% 603_C40 | \aB"D=P\ok 0.1uF | i=j4Wg ,{J | *&vi3#ur IC | 'QxPQcU C3 |
g0"KCX C402-25 | o!}/&
'( CAP 100NF CERMC 16V 10% 603_C40 | ]-tAgNzl% 0.1uF | rKr2 K' | jS'hs>Ot IC | 5H
|<h C4 |
V9<CeTl' C7343-84X118 | +d/^0^(D\5 CAP 47UF TAN 10V 20% EIA_D_0_C7 | dX;G[\ 220uF | H\ONv=}7I | 8!VFb+ IC | "i/3m'<2 C5 |
?,Zc{ C603-35X45 | C!J6"j CAP NP_5_C603-35X45_NO-POP | AAld2"r NO-POP | )0xEI | 8WRxM%gsH IC | uq_h8JH$ C6 |
lp%i%*EQ* C603-35X45 | 8I|2yvhP CAP NP_5_C603-35X45_0.1UF | jj*e.t:F 0.1uF | et0yS%7+?@ | N~@VZbS(6 IC | 7z4u?>pne* C7 |
{;j@-=pV C603-35X45 | +)7Yqh#$ CAP NP_1_C603-35X45_0.1UF | o= N_0. 0.1uF | }%I)bU | d( +E0 IC | *) ?Fo C8 |
)./.rtP|4 C603-35X45 | g w`}eA$ CAP NP_5_C603-35X45_0.1UF | hg=BXe4: 0.1uF | ~TEKxgU | O`W&`B(*k IC | l\Or.I7n
C9 |
Al(u|LbQ C603-35X45 | 1WMwTBHy+ CAP NP_5_C603-35X45_0.1UF | ]VS$ ?wD 0.1uF | U?:<clh | 58 Rmq/6s IC | V`z2F'vT C10 |
Sk 10"D B/ C603-35X45 | W!G2$e6 CAP NP_5_C603-35X45_0.1UF |
C6`<SW 0.1uF | WxFrqUz | @43o4, IC | T c{]w?V C11 |
KU}HVM{ C603-35X45 | C4ut!I # CAP NP_1_C603-35X45_0.1UF | P"WnU'+ 0.1uF | ^v].mV/ | ,lly=OhKb IC | {%;KkC8=R C12 |
&JpFt^IHi C603-35X45 | t"@:a
Y" CAP NP_5_C603-35X45_0.1UF | .h8%zB#|i 0.1uF |
ToHCS/J59 | d#9"_{P IC | }Rc8\, C13 |
@Pc]qu C603-35X45 | "A_WU| CAP NP_5_C603-35X45_0.1UF | Q(2X$7iRq 0.1uF |
Bjz\L0d | =e)[?{H IC | aQEMCWxZ C14 |
Svmyg] C603-35X45 | 2\z"6 CAP NP_5_C603-35X45_0.1UF | _r}oYs%1 0.1uF | LyB$~wZx~@ | [k9aY$baT^ IC | 2>l:: 8Pp C15 |
>_biiW~x : C603-35X45 | Aghcjy|j CAP NP_5_C603-35X45_0.1UF | |Aw(v6 0.1uF | "kKIVlC | !j)H!|R IC | "b!QE2bRO C16 |
_=_]Yx C1206-40X70 | cf|<~7 CAP 22UF CERMC 16V 20% 1206_C12 | kQ$Q}3f 22uF | .d5|Fs~B | "9-duDg IC | +OF(CcA^ C17 |
g]V}azLr C1206-40X70 | D4m2*%M CAP 22UF CERMC 16V 20% 1206_C12 | S#X$QD 22uF | ~4wbIE_rN | ,XW6W&vR; IC | NBR6$n C18 |
qB_MDA C603-35X45 | *_$%Tv.] CAP NP_C603-35X45_0.001UF | .BXZ\r` 0.001uF | 3R?7&oXvH | }}?L'Vby IC | :YB:)wV,P C19 |
_VR Sdr5 C603-35X45 | <}%>a@ CAP NP_5_C603-35X45_0.1UF | r +;C}[E 0.1uF | YizJT0$ | RC8{QgaI IC | "JSg/optc C20 |
vhEPk2wD, C603-35X45 | 0K,*FdA CAP NP_1_C603-35X45_0.1UF | WZRrqrjq 0.1uF | f3-=?Z | Q/iaxY# IC | TeQWrms C21 |
FpfOxF6A3 C1206-40X70 | A$W,#`E CAP 10UF CERMC 6.3V 20% 1206_C1 | ]?^m;~MQZ 10uF | MyuFZ7Q4$ | K3?7Hndf2 IC | !1dCk/D&)8 C22 |
tCK%vd% C603-35X45 | C$)#s{* CAP NP_4_C603-35X45_0.1UF | :n>m">4 0.1uF | r M'snW) | PF@<>NO+W IC | &oYX093di C23 |
Gw3|"14 C1206-40X70 | @g""*T1:$ CAP NP_4_C1206-40X70_10UF | Ol"p^sqwj 10uF | 8;.WX | +"T?., IC | R{@WlkG} C24 |
-sGfpLy<6 C1206-40X70 | (ui"vLk8PP CAP 22UF CERMC 16V 20% 1206_C12 | of8/~VO 22uF | " 9 h]P^ | M'HmVg4' IC | }9>W41 C25 |
vgHMVzxj C603-35X45 | ;-@^G
3C: CAP NP_1_C603-35X45_0.1UF | WU{G_Fqaz 0.1uF | Gs.id^Sf | [1dlV/ IC | F^&_O*" C26 |
c5<M=$ C603-35X45 | pb}QP CAP NP_5_C603-35X45_0.1UF | 2>.B*P 0.1uF | 5>"$95D | +l2{EiQw IC | UbJ_'>hK 6 C27 |
Gu|}ax" C603-35X45 | =cM\o{ q CAP NP_5_C603-35X45_0.1UF | jUZ84Gm{ 0.1uF | 4iRcmsP | ]gHw;ry IC | d"Hh9O}6 C28 |
\!t/< C603-35X45 | $=TFTSO CAP NP_5_C603-35X45_0.1UF | |9jeOV}/ 0.1uF | eL#pS= | STL_#|[RM IC | l^%Ez?-:s C29 |
7$a,pNDw C1206-40X70 | n4Ry)O[. CAP 10UF CERMC 6.3V 20% 1206_C1 | OCa74)( 10uF | g,7`emOX | ~0!s5 IC | My76]\Psh C30 |
{2}O\A C603-35X45 | - ~T LI&[ CAP 18PF CERMC 50V 5% 603_C60_1 | ZTVX5"#Q 33pF | *ELbz}Q | >jME
== U0 IC | 6OF&Q`*4 C31 |
sikG}p0mx< C1206-40X70 | EQ-r CAP 10UF CERMC 6.3V 20% 1206_C1 | <6)Ogv", 10uF | z^T/kK3I | QnME|j\ IC | S2kFdx*Zf C32 |
p2GkI/6)uu C603-35X45 | 6FiI\ CAP NP_5_C603-35X45_0.1UF | 'mXf8 0.1uF | (q59cA w~X | WOrz7x IC | (Gp/^[.%& C33 |
btJ:Wt} C603-35X45 | *R m>bLI CAP NP_5_C603-35X45_0.1UF | ']WS@MbJ 0.1uF | y$Sn3_9 V | a"EX<6" IC | 7;jwKA;k C34 |
}KEyJj3"DA C603-35X45 | )pJ}
$[6 CAP NP_5_C603-35X45_0.1UF | )gYsg 0.1uF | P
hs4]! | T@GT=1E) IC | 7#SXqyP[ C35 |
1N{}G$'Go C603-35X45 | eY)ugq>' CAP NP_5_C603-35X45_0.1UF | qT$;ZV
# 0.1uF |
s!X@ l | T!0o(Pp< IC | zc01\M C36 |
ON.C%-T- C402-25 | `w` f[dU- CAP 100NF CERMC 16V 10% 603_C40 | fb3(9 0.1uF | "SJp9s3 | h+<vWo}H IC | S.pL^Ru C37 |
+!h~T5Ck C402-25 | SR)G!9z_/ CAP 100NF CERMC 16V 10% 603_C40 | Ri=:=oF( 0.1uF | |T\`wcP`q | OJ^kESrm8 IC | AiKja>Fl< C38 |
^aYlu0Wm C603-35X45 | rp^=vfW CAP 18PF CERMC 50V 5% 603_C60_1 | )c!7V)z 33pF | }K':tX? | _uwM%M; IC | Yef=HSzo C39 |
r@b M3V_o C603-35X45 | tIn
dve CAP NP_5_C603-35X45_0.1UF | & mwQj<Z 0.1uF | v;m`d{(i2 | _/(DEF+G IC | .'foS>W=t C40 |
J<hqF4z C603-35X45 | $/*19e~ CAP NP_4_C603-35X45_NO-POP | cq:<,Ke NO-POP | KZrg4TEVi | t6u>_She IC | DQ%bcXs C41 |
qaJ$0,]H+ C603-35X45 | " kp+1sG8 CAP NP_1_C603-35X45_0.1UF | H4RqOI 0.1uF | p[oR4 HWr | lw+Y_; IC | BNi6I\wa C42 |
6d~[j<@2 C603-35X45 | )(bAi CAP NP_1_C603-35X45_0.1UF | vge4&H3a& 0.1uF | ^4MRG6G | bd|ZhRsL IC | cPaz- C43 |
(h{"/sR C1206-40X70 | 03N|@Tu CAP 10UF CERMC 6.3V 20% 1206_C1 | 1. A@5* Q 10uF | D+4oV6}~ | P+ejyl, IC | '`s\_Q)hG_ C44 |
7x>\/l( C603-35X45 | Pgug!![ CAP 100NF CERMC 16V 10% 603_C60 | $-^
;Jl 100nF | {ovt
6C | BjX*Gm6l IC | Dh+<|6mx C45 |
`L~gERW# C1206-40X70 | uwI$t[ CAP 10UF CERMC 6.3V 20% 1206_C1 | \B/!}Tn; 10uF | Y @(izC&h | \7V[G6'{ IC | Gx)U~L$B C46 |
&VPfI C603-35X45 | #(pY~\ CAP 39PF CERMC 50V 5% 603_C603- | o|7ztpr 33pF | c"*xw8| | cQzUR^oq, IC | mETGYkPUa C47 |
d\O*Ol*/v C603-35X45 | 2^aXXPC CAP 39PF CERMC 50V 5% 603_C603- | m>FP&~2 33pF | "udA-;!@& | F ?N+ __o IC | kR0/jEz
C C48 |
R)ep1X^ C603-35X45 | Wf!u?nH.5 CAP NP_1_C603-35X45_0.1UF | J;DTh ]z?: 0.1uF | }1kZF{KD<[ | Sdzl[K/} IC | X_HU?Q_N C49 |
Cfr2~w C603-35X45 |
E!EENg CAP 1.0UF CERMC 25V 10% 603_C60 | dDrzO*a\ 1uF | #1)#W6 h\ | Q30TR IC | j^5VmG C50 |
H |%'$oWp C603-35X45 | .;J6)h CAP 10UF CERMC 6.3V 20% 1206_C6 | B;64(Vsa8 1uF | Xk>YiV",? | )+ (GE IC | ]q`'l_O C51 |
MA,7|s
C402-25 | a7U`/* CAP NP_1_C402-25_22PF | 'O^<i`8U] 22pF | S*l=FRFI | WSxE/C|[ IC | X..<U}e C52 |
C2;Hugm4 C603-35X45 | wh2Ljskda8 CAP 10UF CERMC 6.3V 20% 1206_C6 | ET0^_yk 1uF | jn]:*i;i | $!goM~pZ IC | M@]@1Q.p C53 |
bLsN?_jy C1206-40X70 | fR&x5Ika0 CAP 10UF CERMC 6.3V 20% 1206_C1 | YH,u*.I^/ 10uF | /l` "@ | F\2<q$Zn+ IC | kXN8hU}iq C54 |
TcpaZ
'x C1206-40X70 | BHf7\+Ul CAP 10UF CERMC 6.3V 20% 1206_C1 | ^wlo;.8Y 10uF | aZ'(ar: | *"d['V3 IC | Gp0yRT. C55 |
y=&^=Zh[ C1206-40X70 | 'FM_5`& CAP 10UF CERMC 6.3V 20% 1206_C1 | PiJ>gDx 10uF | ms6dl-_t | 24I\smO IC | GK&R,q5} C56 |
E_H.!pr
C1206-40X70 | a v"dJm CAP 10UF CERMC 6.3V 20% 1206_C1 | "ph[)/u; 10uF | FT6~\9m( | 2O(= 2X IC | xM:9XhH1 C57 |
7v
V~O@JP C1206-40X70 | (R]b'3,E$ CAP 10UF CERMC 6.3V 20% 1206_C1 | 5ajd$t 10uF | bScW<DZJ- | a8 .x=j< IC | *?~&O.R" C58 |
LMaY}m> C402-25 | mvu$ CAP NP_C402-25_0.1UF | <O3,b:vw 0.1uF | oAF#bj_f | 6&KcO:}- IC | o&RNpP* C59 |
@r/f C402-25 | ;Dp<|n CAP NP_C402-25_0.001UF | /DX6Hkkj % 0.001uF | 4tlLh`-8 | ;4<!vVf e IC | _i2guhRs*Q C60 |
BM[jF=0 C402-25 | $O9,Gvnxx CAP NP_C402-25_0.1UF | do DpTwvh 0.1uF | W[qQDn!r | Xcb'qU!2-^ IC | !"SuE)WM C61 |
Su]p6B C402-25 | &+" )~2
+ CAP NP_C402-25_0.1UF | T7Qw1k 0.1uF | b,lIndj# | UF;iw IC | 2`pg0ciX ( C62 |
%Krf,H C402-25 | i\C~]K~O! CAP NP_C402-25_NO-POP | tr<0NV62> NO-POP | eT@,QA(3 | cIg+^Tl IC | w">-r}HnJ C63 |
u&r+ylbsI C1206-40X70 | cm`x;[e6l CAP P_0_C1206-40X70_22UF | 7 ;SI= 22uF | =6xxZy[ | )26_7.| IC | <CN+VXF C64 |
`J-&Y2_/k C1206-40X70-POL | kmM->v CAP P_0_C1206-40X70-POL_10UF | 7i88iT 10uF | gUrXaD# | x%%OgO+> IC | `:kI@TPI_C C65 |
Bn5$TiTcl C1206-40X70-POL | ,2]a<0m CAP P_0_C1206-40X70-POL_10UF | /EV _Y|(- 10uF | 6.k>J{GG | p_qJI@u8 IC | #_'|
TT>p# C66 |
MXrh[QCU) C7343-84X118 | et}%E9 CAP 220UF TAN 10V 20% EIA_D_C73 | !1xX)XD4y 220uF | A x'o|RE)x | BL H~`N3U IC | ehyCAp0oI C67 |
hi^t zpy C1206-40X70-POL | @"L*! CAP P_0_C1206-40X70-POL_10UF | O_^t u?x 10uF | b>f{o_ | x?RYt4 S IC | oETl?Vt C68 |
+K7oyZg C1206-40X70-POL | tVhf1TH# CAP P_0_C1206-40X70-POL_10UF | tlcNGPa 10uF | #L9F\ <K | TyN]P a IC | M7\yEi"* C69 |
y\zRv(T= C1206-40X70 | hv#|dI=kZR CAP 10UF CERMC 6.3V 20% 1206_C1 | _!E)a 10uF | aW(Hn[}^ | ';3#t(J; IC | D\k'Eez C71 |
i?B(I4a!G C1206-40X70 | rA[wC%% CAP 10UF CERMC 6.3V 20% 1206_C1 | .?)gn]# 10uF | XY!0yAK(! | `,$PRN"] IC | w=QW8q? C72 |
Jo4iWJpK C7343-84X118 | vY2^*3\<D CAP 220UF TAN 10V 20% EIA_D_C73 | \&b1%Asyz 220uF | BTDUT%Yfg | H,0Io IC | l9#@4Os C73 |
WnL7 A:sZ C3528-64X112 | N^%7 CAP 10UF CERMC 6.3V 20% 1206_C3 | B;c2gu
10uF,16V | `XrF , | +\U#:gmw IC | z~Is
E8 C74 |
JXq l=/% C402-25 | 6D/K=- CAP 100NF CERMC 16V 10% 603_C_2 | ]4eIhj? 100nF | ]? %*3I | $u%7]]Y^\ IC | #TPS?+( C75 |
Z~v-@ C402-25 | X{ f#kB]w CAP .1 UF 10% 0603_C402-25_.1UF | s5J?,xu .1uF | [^0 S#,L | 4KB>O)YNg' IC | +{L=cWA" C76 |
RiiwsnjC C402-25 | Qm>2,={h CAP .1 UF 10% 0603_C402-25_.1UF | q#\4/Dt .1uF | <g1=jG:7k | 0bl 8J5Ar5 IC | nR8r$2B+t C77 |
U5ME`lN*` C1206-40X70-POL | xl ,(=L] CAP_0_C1206-40X70-POL_10UF | 1C+d&U 10uF | >>%E?'9A | |syvtS{ IC | qh#?a' C78 |
p mUG`8SY C402-25 | [Zne19/ CAP .1 UF 10% 0603_C402-25_.1UF | #AF.1;(k .1uF | #j4RX:T*[ | +*Zjo&pc IC | c]68$;Z7 C79 |
98XlcI# C402-25 | {ep.So6 CAP .1 UF 10% 0603_C402-25_.1UF | r<5i .1uF | p(.z#o# | 97vQM IC | _~bG[lX ! C80 |
" 2Q*- C402-25 | J*4T|#0 CAP .1 UF 10% 0603_C402-25_.1UF | nrKir .1uF | Ynl Zyw! | n;e.N:p IC | th%T(D5n C81 |
3jjV
bm C402-25 | "f:_(np, CAP 100NF CERMC 16V 10% 603_C40 | {
t@7r 0.1uF | x9\]C'*sO | ,j(S'Pw IC | 7V-uQ)* C82 |
?*&5`Xh C402-25 | \. YJs"<3 CAP NP_C402-25_0.1UF | EbnV"]1 0.1uF | Y_/w}HB | BHt9$$Z| IC | 3|BB#; C83 |
@T%8EiV C402-25 | <Aqo['] CAP .1 UF 10% 0603_C402-25_.1UF | Bdm05}c@u .1uF | O% 8>siU | kL"Y>@H IC | ~p
x2kHZ C84 |
G
UK%RC8 C603-35X45 | {_ {zs!r CAP NP_5_C603-35X45_0.01UF | F#a'N c9 0.01uF | !M}ZK( | PAXm IC | Pr3>}4M C85 |
K{0 gkORF C402-25 | QBjvbWoIG( CAP 100NF CERMC 16V 10% 603_C40 | 7
lu_E.Bv 0.1uF | @s0 mX3P | ]v l?J IC | uOPLJ?% C86 |
uQg& |
