恩智浦iMX6 Rex开发板底板原理图PCB
j yD3Sa3 AwNr}9` x3&gB`j-
Designator | Ht;Rz*} Comment | _Z]l=5d Description | AMjr[!44 @ Footprint | D<69xT, LibRef | Is4,QnY_[ BAT1 | Qz(2Iu{E] CR2032 | @
&N BATTERY LITHIUM COIN 3V 20MM | #epbc K | ':pDlUA CR2032 | nQmHYOF% C1 | #4mRMsW5" 100n | *@' 'OyL CAP CER .10UF 50V X5R 10% 0402 | }
doAeTZ C0402 | 12U]= C1005X5R1H104K | $x'jf?zs! C2 | ;Va(l$zD 10uF | 'r 7[9[ CAP CER 10UF 35V X5R 1206 | Jm<NDE~rw C1206 | :|s;2Y GRM31CR6YA106KA12L | G^t)^iI"' C3 | `z'8"s 100n | buX(mj:& CAP CER .10UF 50V X5R 10% 0402 | |K1S(m<F C0402 | Oq~{HJ{ C1005X5R1H104K | 0RA#Y(IR C4 | + )Qu,%2
1u | n7bVL#Sq[ CAP CER 1.0UF 16V X5R 0402 | Pv5S k8 C0402 | K +vD&Z^ C1005X5R1C105K | +@?Q "B5u} C5 | 8%CznAO"?W 22u | *fc8M(]&d CAP CER 22UF 16V 10% X5R 0805 | 1ARtFR2C{b C0805 | <8 <P, C2012X5R1C226K | @>O7/d?O C6 | "L]v:lg3 100n | zNX=V!$ CAP CER .10UF 50V X5R 10% 0402 | ^5]9B<i[Y C0402 | [Ix6ArY C1005X5R1H104K | XA#qBxp/h C7 | Wd7*7'] 10uF |
Culv/ CAP CER 10UF 35V X5R 1206 | Z~Q5<A9Jz C1206 | )q_,V" GRM31CR6YA106KA12L | e=VSO!(rY C8 | y`zdI_!7 100n | >bV3~m$a+ CAP CER .10UF 50V X5R 10% 0402 | ]\fHc"/ C0402 | o(e(|k
{ C1005X5R1H104K | DL V ny] C9 | LAc60^t1 100n | %TFsk CAP CER .10UF 50V X5R 10% 0402 | m#BXxS#B<_ C0402 | ,|RKM C1005X5R1H104K | #WG}"[ ,c C10 | _qPKdGoM 100n | @lDnD%vZ` CAP CER .10UF 50V X5R 10% 0402 | Ag0
6M U C0402 | eg*a Vb C1005X5R1H104K | O<p=&=TD7 C11 | h$`m0-' 22u |
bMc[0 CAP CER 22UF 16V 10% X5R 0805 | #L!`n)J" C0805 | ,K}"o~z C2012X5R1C226K | A v>v\ :.> C12 | ROTKK8:+: 330u | m<j;f CAP TANT 330UF 6.3V 20% 2917 | l7T?Yx j C2917 | cRKLyb T520D337M006ATE045 | .^A4w;jPU C13 | &V
axv$v} 330u | vWmt<E|e CAP TANT 330UF 6.3V 20% 2917 | Q3i\`-kbb C2917 | VOj7Tz9UD T520D337M006ATE045 | <[ dt2)%L> C14 | h(kPf]0 100n | {=?[:5 CAP CER .10UF 50V X5R 10% 0402 | rx|
,DI C0402 | x$jLB&+ICz C1005X5R1H104K | DW,ERQ^ C15 | lGahwn: 4u7 | =4+2y ' CAP CER 4.7UF 10V 20% X5R 0402 | zfDfy!\2_ C0402 | 7)D[ }UXz C1005X5R1A475M | RU/WI<O C17 | KJ/Gv#Kj 100n | MjQ>&fUK CAP CER .10UF 50V X5R 10% 0402 | OD[=fR|cp C0402 | .I|b9$V C1005X5R1H104K | V1Ft3Msq C18 | ._p2"< 1u | Z/ml,4e CAP CER 1.0UF 16V X5R 0402 | B7qi|Fw C0402 | LR.]&(kyd C1005X5R1C105K | jXmY8||w C19 | 8[@Y`j8 4u7 | OSuQ7V CAP CER 4.7UF 10V 20% X5R 0402 | g3'dkS! C0402 | tol-PJS} C1005X5R1A475M | CEkf0%YJ C20 | Q& d;UVp 10u | }t(5n $go6 CAP CER 10UF 6.3V X5R 20% 0603 | !b0A%1W; C0603 | 8@;R2]Q C1608X5R0J106M | |Z>}#R!,P C22 | BJHWx,v 100n | lhE]KdE3 CAP CER .10UF 50V X5R 10% 0402 | i\
7JQZ C0402 | ' p!&&.% C1005X5R1H104K | qldm"Ul C23 | pdN8hJ 100n | !+Cc^{ CAP CER .10UF 50V X5R 10% 0402 | +#>nOn(B C0402 | vfT
@;` C1005X5R1H104K | Xeja\5zB C24 | {LKW%G7 330u | 9;*B*S~znW CAP TANT 330UF 6.3V 20% 2917 | LhF;A~L C2917 | _W Hi<,- T520D337M006ATE045 | =<(6yu_ C25 |
qOD^P 330u | Mf5*Wjz.Mc CAP TANT 330UF 6.3V 20% 2917 | |w~*p
N0 C2917 | s 64@<oU<" T520D337M006ATE045 | @QpL*F C27 | FS)C<T]t 100n | C.u)2[( CAP CER .10UF 50V X5R 10% 0402 | Ug#B( }/ C0402 | ,{ 0&NX C1005X5R1H104K | Wxj(3lg/ C28 | 4%yeEc;z 100n | { O=_c|u{N CAP CER .10UF 50V X5R 10% 0402 | ze8 MFz'm C0402 | Hjs#p{t[ C1005X5R1H104K | F`gK6;zp C29 | #Ph8? 100n | z6qx9x|Ij CAP CER .10UF 50V X5R 10% 0402 | nYC S %\" C0402 | yJ; ;& C1005X5R1H104K | #="Lr4T C30 | j}}as 100n | 1D"EF CAP CER .10UF 50V X5R 10% 0402 | =td(}3|D
Y C0402 | %gqu7}' C1005X5R1H104K | (A_H[xP C31 | ucLh|}jJ5 100n | p)Ht =~ CAP CER .10UF 50V X5R 10% 0402 | F CfU=4O C0402 | L?(1
[jB4G C1005X5R1H104K | .zW.IM}Z C32 | maQDD* 4u7 | ZQ\O|
n8 CAP CER 4.7UF 10V 20% X5R 0402 | 7W/55ZTmJ C0402 | cKwmtmwB C1005X5R1A475M | Hs.5@ l
C33 | d\ 7OtM 1u | W H+Sd CAP CER 1.0UF 16V X5R 0402 | (iO/@iw C0402 | ,{RWs^W2 C1005X5R1C105K | @G>&Gu;5 C34 | *U,W4>(B 4u7 | 1[?xf4EMG CAP CER 4.7UF 10V 20% X5R 0402 | j4D`Xq2X C0402 | =~$)Ieu C1005X5R1A475M | u&Xn#fh C35 | q+67Wc= 10u | <3{>;^|e CAP CER 10UF 6.3V X5R 20% 0603 | \z-OJ1[F C0603 | x@VZJrQQ C1608X5R0J106M | 1u~.^O}J C37 |
(Vy`u)gG 1u | 7lQ:}& CAP CER 1.0UF 16V X5R 0402 | &K,rNH'R C0402 | 3q (]Dg;v C1005X5R1C105K | B}h8c C38 | >D$NEO^ 1u | +& |
