查看: 4192|回复: 15
[Pads_VX.2x] 采用低功耗精密24位ADC的隔离式4mA至20mAHART工业温度和压力
终身成就奖原创先锋奖特殊贡献奖优秀斑竹奖金点子奖
发表于 2018-12-17 02:18:34 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
Name
Part Description
VALUE
TOLERANCE
PCB Decal
PART DESC
C0
CAP
0.01u
± 10%
C0402
Capacitor ceramic, 16V, X7R, 0402
C1
CAP
0.01u
± 10%
C0402
C2
CAP
0.01u
± 10%
C0402
C3
CAP
0.01u
± 10%
C0402
C4
CAP
0.01u
± 10%
C0402
C5
CAP
0.01u
± 10%
C0402
C6
CAP
0.1u
± 10%
C0402
C7
CAP
0.1u
± 10%
C0402
C8
CAP
1u0
± 10%
C0402
Capacitor ceramic, 6.3V, X5R, 0402
C9
CAP
0.1u
± 10%
C0402
C10
CAP
1u0
± 10%
C0402
C11
CAP
0.1u
± 10%
C0402
C12
CAP
0.1u
± 10%
C0402
C13
CAP
0.1u
± 10%
C0402
C14
CAP
0.1u
± 10%
C0402
C15
CAP
0.1u
± 10%
C0402
C16
CAP
0.1u
± 10%
C0402
C17
CAP
0.1u
± 10%
C0402
C18
CAP
0.1u
± 10%
C0402
C19
CAP
1u0
± 10%
C0402
C20
CAP
0.1u
± 10%
C0402
C21
CAP
0.1u
± 10%
C0402
C22
CAP
10u
± 10%
C0805
CAP, MLCC, X5R, 10UF, 16V, 0805
C23
CAP
0.1u
± 10%
C0402
C24
CAP
10u
± 20%
C0603
Capacitor ceramic, 6.3V, X5R, 0603
C25
CAP
0.068u
± 10%
C0402
C26
CAP
0.22u
± 10%
C0402
Capacitor ceramic, 10V, X5R, 0402
C27
CAP
4700p/50V
± 10%
C0603
Capacitor ceramic, 50V, X7R, 0603
C28
CAP
8p2
± 0.25pF
C0402
Capacitor ceramic, 50V, C0G, 0402
C29
CAP
8p2
± 0.25pF
C0402
C30
CAP
150p
± 5%
C0402
C31
CAP
150p
± 5%
C0402
C32
CAP
150p
± 5%
C0402
C33
CAP
1u0
± 10%
C0402
C34
CAP
1u0
± 10%
C0402
C35
CAP
0.01u
± 10%
C0402
C36
CAP
0.01u
± 10%
C0402
C37
CAP
10u
± 20%
C0603
C38
CAP
0.01u
± 10%
C0402
C39
CAP
1u0
± 10%
C0402
C40
CAP
0.01u
± 10%
C0402
C41
CAP
10u
± 10%
C0805
C42
CAP
0.1u
± 10%
C0402
C43
CAP
0.1u
± 10%
C0402
C44
CAP
220pF/3000V
± 5%
1812
CAPACITOR, 1812, 220PF, 3000V, C0G
C45
CAP
220pF/3000V
± 5%
1812
C46
CAP
1u0
± 10%
C0402
C48
CAP
1u0
± 10%
C0402
C50
CAP
DNI
± 10%
C0402
D1
BAS516
BAS516
SOD-523
High-Speed Switching Diode
D2
BAS516
BAS516
SOD-523
D3
DIODE-DO-214AA
SMBJ40CA
DO-214AA
Diode, TVS bipolar, 40V, 600W, DO-214
D4
DIODE-ZENER-BZT55C4V7-GS08
4.7V
MINI-MELF
4.7V Zener Diode
D5
BAS516
BAS516
SOD-523
D6
BAS516
BAS516
SOD-523
D7
DIODE-ZENER-5.1V-0.2W-MM3Z5V1T1G
5.1V,0.2W
SOD-323
Zener Voltage Regulator 5.1V, 0.2W
J1
HDR_2-PIN_R/A_PHOENIX_MC-1.5/2-G-3.81
1x2-pin
Connector, pitch 3.81mm, 2-pin, rightangle
J2
HDR_2-PIN_VERT_PHOENIX_MC-1.5/2-G-3.81
1x2-pin
Connector, pitch 3.81mm, 2-pin, vertical
J3
HEADER08B
2x4-pin
HEADER8-R/A
Header, right angle, pitch 2.54mm,2x4-pin, cut
J4
HEADER4
HEADER4
4-Pin (1x4) SIL 0.1" Pitch Header
J5
CON\POWER8_2.54MM
CON\POWER8_2.54MM
Terminal Block, 2.54MM, 8-Way
J6
HEADER4
HEADER4
J7
CON\5HEADER
SIP-5P
5 WAY IDC HEADER
J8
CON\2HEADER
SIP-2P
5 WAY IDC HEADER
J9
CON\2HEADER
SIP-2P
5 WAY IDC HEADER
J10
HEADER4
HEADER4
J11
CON\2HEADER
SIP-2P
5 WAY IDC HEADER
J12
CON\5HEADER
SIP-5P
5 WAY IDC HEADER
L1
L
1000Z
805
Ferrite bead, 0r4, 1000r@100MHz, 300mA,0805
L2
L
1000Z
805
L3
L
1000Z
805
LED1
LED-0603-RED
RED
LED-0603
LED, red, high intensity @ low power,0603
LK1
JUMPER
SIP-2P
2 Pin (0.1" Pitch) Header &Shorting Shunt
LK2
JUMPER
SIP-2P
NTC
RT
10k
±1%
R0805-0402-COMBO
NTC, 10K, 3435K, 1%, 0402
R0
RES
1K0
±1%
R0402
Resistor, 1%, 0402
R1
RES
1K0
±1%
R0402
Resistor, 1%, 0402
R2
RES
1K0
±1%
R0402
Resistor, 1%, 0402
R3
RES
1K0
±1%
R0402
Resistor, 1%, 0402
R4
RES
1K0
±1%
R0402
Resistor, 1%, 0402
R5
RES
1K0
±1%
R0402
Resistor, 1%, 0402
R6
RES
100R
±1%
R0402
Resistor, 1%, 0402
R7
RES
100R
±1%
R0402
Resistor, 1%, 0402
R8
RES
470R
±1%
R0402
Resistor, 1%, 0402
R9
RES
5K6
±0.05%
R0805
RESISTOR, 5K6, 0.1W, 0.05%, 10ppm/K, 0805
R10
RES
10K
±1%
R0402
Resistor, 1%, 0402
R11
RES
10R
±1%
R0402
Resistor, 1%, 0402
R12
RES
10r
±1%
R0402
Resistor, 1%, 0402
R13
RES
10M
±1%
R0402
Resistor, 1%, 0402
R14
RES
10M
±1%
R0402
Resistor, 1%, 0402
R15
RES
1M0
±1%
R0402
Resistor, 1%, 0402
R17
RES
1M0
±1%
R0402
Resistor, 1%, 0402
R18
RES
1M0
±1%
R0402
Resistor, 1%, 0402
R19
RES
1r5
±1%
R0402
Resistor, 1%, 0402
R21
RES
1M2
±1%
R0402
Resistor, 1%, 0402
R22
RES
1M2
±1%
R0402
Resistor, 1%, 0402
R23
RES
150K
±1%
R0402
Resistor, 1%, 0402
R26
RES
1M0
±1%
R0402
Resistor, 1%, 0402
R27
RES
1M0
±1%
R0402
Resistor, 1%, 0402
R28
RES
5K6
±0.05%
R0805
R29
RES
1M0
±1%
R0402
Resistor, 1%, 0402
R30
RES
4K7
±1%
R0402
Resistor, 1%, 0402
R31
RES
10K
±1%
R0402
Resistor, 1%, 0402
R32
RES
68K
±1%
R0402
Resistor, 1%, 0402
R37
RES
1M0
±1%
R0402
Resistor, 1%, 0402
R38
RES
1K0
±1%
R0402
Resistor, 1%, 0402
R39
RES
1M0
±1%
R0402
Resistor, 1%, 0402
R41
RES
1M0
±1%
R0402
Resistor, 1%, 0402
R43
RES
68K
±1%
R0402
Resistor, 1%, 0402
R44
RES
1M0
±1%
R0402
Resistor, 1%, 0402
R45
RES
1M0
±1%
R0402
Resistor, 1%, 0402
R46
RES
68K
±1%
R0402
Resistor, 1%, 0402
R47
RES
10r
±1%
R0402
Resistor, 1%, 0402
R55
RES
470r
±1%
R0402
Resistor, 1%, 0402
R63
RES
10r
±1%
R0402
Resistor, 1%, 0402
R64
RES
470R
±1%
R0402
Resistor, 1%, 0402
R65
RES
1M0
±1%
R0402
Resistor, 1%, 0402
R66
RES
470R
±1%
R0402
Resistor, 1%, 0402
R67
RES
1M0
±1%
R0402
Resistor, 1%, 0402
R68
RES
1M0
±1%
R0402
Resistor, 1%, 0402
R69
RES
150K
±1%
R0402
Resistor, 1%, 0402
R70
RES
150K
±1%
R0402
Resistor, 1%, 0402
R71
RES
10K
±1%
R0402
Resistor, 1%, 0402
R72
RES
10K
±1%
R0402
Resistor, 1%, 0402
R73
RES
1M0
±1%
R0402
Resistor, 1%, 0402
R74
RES
1M0
±1%
R0402
Resistor, 1%, 0402
R76
RES
1M0
±1%
R0402
Resistor, 1%, 0402
R77
RES
1M0
±1%
R0402
Resistor, 1%, 0402
R78
RES
1M0
±1%
R0402
Resistor, 1%, 0402
S1
SW-PUSH_B3U-1000P
SWITCH
SW-PUSH_B3U-1000P
Switch push button, SMD H1.2×W3×D2.5mm
S3
SW-PUSH_B3U-1000P
RESET
SW-PUSH_B3U-1000P
TR1
TRANSFORMER_MURATA-78615/9C
TRANSFORMER-MURATA-786XX/XC
TRANSFORMER, GENERAL PURPOSE PULSE,MURATA 786XX/XC SERIES
U1A
RL78/G13_LFQFP
RL78/G13
LQFP48
16-bit Microcontroller
U2
AD5421BCPZ
AD5421
LFCSP-32-11
Loop powered 4-20mA DAC, TSSOP28
U3A
AD5700BCPZ
AD5700BCPZ
LFCSP-24
Hart Modem, LFCSP24 4x4mm
U4
PRESSURE-SENSOR-24PCDFA6D
0-30PSID
Pressure Sensor, 0-30psi, differential,PCB
U5
ADG5433BCPZ
LFCSP-16-17-4MM
Triple SPDT Switch
U6
ADP162AUJZ-3.3
TSOT-5
3.3V Linerar Regulator
U7
AD7124-4BCPZ_MY
LFCSP-32
ADC
U9
ADUM1441ARQZ
QSOP-16
Micropower Quad-Channel Digital Isolator
VRES
VRES-M63M103KB30T607
100K
VRES-10MM-M63
Trimmer w.knob, 10x10mm
X1
NPTH-2.7MM
NPTH-2.7MM
X2
NPTH-2.7MM
NPTH-2.7MM
Y1
XTAL_SMD_2PIN
3.6864MHz
HC49_4H_SMX
Crystal SMD
Terminal Block, Pluggable (Insert in J1Connector)
Distributor Web Sites
Bare Board
FEC
www.farnell.com
4 x FEET, (8 X 2.8MM), BLACK, PK56 - onenear each corner
Digikey
www.digikey.com
Board to be placed in suitable sizedAnti-static bag
Analog Devices
www.analog.com
Anti-static bubble wrap
Anixter Comps
www.anixtercomponents.com
Eval Board Box - Small White Box
Bar Code Box Label
重要提示:PCB作品文件展下载说明
 楼主| 发表于 2018-12-17 02:19:29 | 显示全部楼层
CN0382_08_1024.png CN0382_00_1024.png DEMO-AD7124-DZ-PADsSchematic-RebB.rar (50 KB, 下载次数: 14) DEMO-AD7124-DZ-PADsLayout-RevB.pcb.rar (218 KB, 下载次数: 13)
发表于 2018-12-17 07:22:30 | 显示全部楼层
    发表于 2018-12-17 08:28:00 | 显示全部楼层
  • 签到天数: 9 天
    发表于 2018-12-17 08:29:10 | 显示全部楼层
    发表于 2018-12-17 08:51:03 | 显示全部楼层
    到此一游,每日水一帖
    昨天 15:30
  • 签到天数: 184 天
    1元学习PADS(3期)
    发表于 2018-12-17 08:56:27 | 显示全部楼层
    发表于 2018-12-17 08:57:15 | 显示全部楼层
  • 签到天数: 14 天
    社区居民忠实会员社区劳模最爱沙发原创达人终身成就奖特殊贡献奖优秀斑竹奖
    天涯无处 该用户已被删除
    发表于 2018-12-17 09:21:38 | 显示全部楼层
    提示: 作者被禁止或删除 内容自动屏蔽
