查看: 4093|回复: 14
[Allegro16.6以下] Stratix 10 SX SoC开发套件子卡8层NAND原理图PCB
终身成就奖原创先锋奖特殊贡献奖优秀斑竹奖金点子奖
发表于 2018-12-17 03:04:47 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
SYM_NAME
COMP_DEVICE_TYPE
COMP_VALUE
COMP_TOL
COMP_CLASS
REFDES
0805
CAP_0805_4.7UF
4.7uF
IC
C1
0402
CAP_0402_0.1UF
0.1uF
IC
C2
0805
CAP_0805_4.7UF
4.7uF
IC
C3
0402
CAP_0402_0.1UF
0.1uF
IC
C4
0402
CAP_0402_0.01UF
0.01uF
IC
C5
0402
CAP_0402_0.01UF
0.01uF
IC
C6
0402
CAP_0402_0.01UF
0.01uF
IC
C7
0402
CAP_0402_0.01UF
0.01uF
IC
C8
0603
CAP_0603_22UF
22uF
IC
C11
0402
CAP_0402_0.1UF
0.1uF
IC
C13
0603
CAP_0603_22UF
22uF
IC
C15
0402
CAP_0402_0.1UF
0.1uF
IC
C17
0603
CAP_0603_22UF
22uF
IC
C18
0402
CAP_0402_0.1UF
0.1uF
IC
C20
0603
CAP_0603_22UF
22uF
IC
C23
0402
CAP_0402_0.1UF
0.1uF
IC
C25
0603
CAP_0603_22UF
22uF
IC
C26
0603
CAP_0603_2.2UF
2.2uF
IC
C28
0603
CAP_0603_22UF
22uF
IC
C29
0402
CAP_0402_0.1UF
0.1uF
IC
C31
0402
CAP 39PF 5% 50V 0402_0402_39PF
39pF
IC
C36
0402
39pF
IC
C37
0402
CAP_0402_0.1UF
0.1uF
IC
C38
0603
CAP_0603_2.2UF
2.2uF
IC
C39
0402
CAP_0402_0.1UF
0.1uF
IC
C40
0603
CAP_0603_2.2UF
2.2uF
IC
C41
0402
CAP_0402_0.1UF
0.1uF
IC
C42
0805
CAP_0805_4.7UF
4.7uF
IC
C43
0402
CAP_0402_0.01UF
0.01uF
IC
C44
0402
CAP_0402_0.1UF
0.1uF
IC
C45
0402
CAP_0402_0.1UF
0.1uF
IC
C46
0402
CAP_0402_0.1UF
0.1uF
IC
C47
0402
CAP_0402_0.1UF
0.1uF
IC
C48
0603
CAP_0603_1UF
1uF
IC
C49
0402
CAP_0402_0.1UF
0.1uF
IC
C50
0603
CAP_0603_2.2UF
2.2uF
IC
C51
0402
CAP_0402_0.22UF
0.22uF
IC
C52
0603
CAP_0603_2.2UF
2.2uF
IC
C53
0402
CAP_0402_0.22UF
0.22uF
IC
C54
0402
CAP_0402_0.1UF
0.1uF
IC
C55
0402
CAP_0402_0.1UF
0.1uF
IC
C56
0402
CAP_0402_0.1UF
0.1uF
IC
C59
0402
CAP_0402_0.1UF
0.1uF
IC
C70
0603
CAP_0603_2.2UF
2.2uF
IC
C76
0402
CAP_0402_100PF
100pF
IC
C900
0402
CAP_0402_0.1UF
0.1uF
IC
C909
0603
CAP_0603_22UF
22uF
IC
C914
0603
CAP_0603_22UF
22uF
IC
C915
1206
CAP_1206_10UF
10uF
IC
C917
0402
CAP_0402_0.01UF
0.01uF
IC
C922
C0805
CAP_C0805_10UF
10uF
IC
C924
0402
CAP_0402_0.1UF
0.1uF
IC
C925
C0805
CAP_C0805_10UF
10uF
IC
C927
0603
CAP_0603_22UF
22uF
IC
C928
0402
CAP_0402_1NF
1nF
IC
C929
0402
CAP_0402_120PF
120pF
IC
C930
0402
CAP_0402_0.1UF
0.1uF
IC
C931
0402
CAP_0402_0.1UF
0.1uF
IC
C932
0402
CAP_0402_0.1UF
0.1uF
IC
C933
0402
CAP_0402_0.1UF
0.1uF
IC
C934
0402
CAP_0402_0.1UF
0.1uF
IC
C935
0402
CAP_0402_0.1UF
0.1uF
IC
C936
0402
CAP_0402_0.1UF
0.1uF
IC
C937
0402
CAP_0402_0.1UF
0.1uF
IC
C938
0402
CAP_0402_0.1UF
0.1uF
IC
C939
1808
CAP_1808_1000PF
1000PF
IC
C940
1808
CAP_1808_1000PF
1000PF
IC
C942
0402
CAP_0402_0.1UF
0.1uF
IC
C943
0402
CAP_0402_0.1UF
0.1uF
IC
C944
1206
CAP_1206_47UF
47uF
IC
C949
0402
CAP_0402_0.1UF
0.1uF
IC
C953
C0805
CAP_C0805_10UF
10uF
IC
C954
C0805
CAP_C0805_10UF
10uF
IC
C955
0402
CAP_0402_0.1UF
0.1uF
IC
C956
0603
CAP_0603_2.2UF
2.2uF
IC
C957
0402
CAP_0402_0.22UF
0.22uF
IC
C958
0402
CAP_0402_0.22UF
0.22uF
IC
C959
0402
CAP_0402_0.22UF
0.22uF
IC
C960
0805
CAP_0805_4.7UF
4.7uF
IC
C961
0805
CAP_0805_4.7UF
4.7uF
IC
C962
0402
CAP_0402_0.1UF
0.1uF
IC
C964
0402
CAP_0402_0.1UF
0.1uF
IC
C965
LED_0603
LED_WURTH_LED_0603_GREEN_LED
GREEN_LED
IC
D1
LED_0603
GREEN_LED
IC
D2
LED_0603
GREEN_LED
IC
D3
LED_0603
GREEN_LED
IC
D4
LED_0603
GREEN_LED
IC
D5
QTH-030
HEADER 30X2_0_QTH-030_QTH-030-0
QTH-030-02-L-D-A
IC
J1
CONN_TSW_103_07_L_S
HEADER, 1X3-PIN_CONN_TSW_103_07
HEADER, 1x3-PIN
IC
J2
BEL_L829-1J1T-43
ENET_L829-1J1T-43_2_BEL_L829-1J
ENET_L829-1J1T-43
IC
J3
MINI_USB_SMTB
USB_MINI_B_SMT_MINI_USB_SMTB_US
USB MINI-B-SMT Vertical
IC
J7
HDR2X1_100MIL
CON2_HDR2X1_100MIL_CON2
CON2
IC
J9
CONN_TSW_103_07_L_S
HEADER, 1x3-PIN
IC
J10
CONN_TSW_103_07_L_S
HEADER, 1x3-PIN
IC
J11
IND_0603
IND FERRITE 0603 3A/30 OHMS_IND
3A, 30 Ohm FB
IC
L1
IND_0603
3A, 30 Ohm FB
IC
L2
IND_0603
3A, 30 Ohm FB
IC
L3
IND_0603
3A, 30 Ohm FB
IC
L4
IND_0603
3A, 30 Ohm FB
IC
L5
0402
BEAD_FERRITE_SM_0402_742792780
742792780
IC
L6
0402
742792780
IC
L7
0402
742792780
IC
L8
0402
742792780
IC
L10
0402
742792780
IC
L11
SOT23
NMOS_3PIN_SOT23_FDV305N
FDV305N
IC
Q1
SOT23
FDV305N
IC
Q2
SOT23
FDV305N
IC
Q3
SOT23
FDV305N
IC
Q4
SOT23
FDV305N
IC
Q5
SOT23
FDV305N
IC
Q6
SOT23
FDV305N
IC
Q7
0402
RESISTOR_0402_0
DISCRETE
R1
0402
RESISTOR_0402_4.7K
4.7K
DISCRETE
R2
0402
RESISTOR_0402_4.7K
4.7K
DISCRETE
R4
0402
RESISTOR_0402_33
33
DISCRETE
R6
0402
RESISTOR_0402_4.7K
4.7K
DISCRETE
R7
0402
RESISTOR_0402_220
220
IC
R8
0402
RESISTOR_0402_33
33
DISCRETE
R9
0402
RESISTOR_0402_33
33
DISCRETE
R10
0402
RESISTOR_0402_33
33
DISCRETE
R11
0402
RESISTOR_0402_33
33
DISCRETE
R12
0402
RESISTOR_0402_33
33
DISCRETE
R13
0402
RESISTOR_0402_220
220
IC
R14
0402
RESISTOR_0402_12.1K
12.1K
IC
R15
0402
RESISTOR_0402_DNI
DNI
IC
R16
0402
RESISTOR_0402_4.7K
4.7K
DISCRETE
R17
0402
RESISTOR_0402_10K
10K
IC
R18
0402
RESISTOR_0402_33
33
DISCRETE
R19
0402
RESISTOR_0402_DNI
DNI
IC
R20
0402
RESISTOR_0402_4.7K
4.7K
DISCRETE
R21
0402
RESISTOR_0402_4.7K
4.7K
DISCRETE
R23
0402
RESISTOR_0402_DNI
DNI
IC
R24
0402
RESISTOR_0402_4.7K
4.7K
DISCRETE
R25
0402
RESISTOR_0402_DNI
DNI
IC
R26
0402
RESISTOR_0402_4.7K
4.7K
DISCRETE
R27
0402
RESISTOR_0402_DNI
DNI
IC
R28
0402
RESISTOR_0402_4.7K
4.7K
DISCRETE
R29
0402
RESISTOR_0402_DNI
DNI
IC
R30
0402
RESISTOR_0402_DNI
DNI
IC
R31
0402
RESISTOR_0402_4.7K
4.7K
DISCRETE
R32
0402
RESISTOR_0402_4.7K
4.7K
DISCRETE
R33
0402
RESISTOR_0402_DNI
DNI
IC
R34
0402
RESISTOR_0402_4.7K
4.7K
DISCRETE
R35
0402
RESISTOR_0402_DNI
DNI
IC
R36
0402
RESISTOR_0402_1.87K
1.87K
IC
R39
0402
RESISTOR_0402_0
DISCRETE
R42
0402
RESISTOR_0402_0
DISCRETE
R46
0402
RESISTOR_0402_220
220
IC
R48
0402
RESISTOR_0402_220
220
IC
R49
0402
RESISTOR_0402_10K
10K
IC
R50
0402
RESISTOR_0402_0
DISCRETE
R52
0402
RESISTOR_0402_0
DISCRETE
R53
0402
RESISTOR_0402_0
DISCRETE
R54
0402
RESISTOR_0402_0
DISCRETE
R55
0402
RESISTOR_0402_0
DISCRETE
R56
0402
RESISTOR_0402_0
DISCRETE
R57
0402
RESISTOR_0402_0
DISCRETE
R58
0402
RESISTOR_0402_0
DISCRETE
R59
0402
RESISTOR_0402_0
DISCRETE
R60
0402
RESISTOR_0402_0
DISCRETE
R62
0402
RESISTOR_0402_0
DISCRETE
R64
0402
RESISTOR_0402_0
DISCRETE
R65
0402
RESISTOR_0402_0
DISCRETE
R66
0402
RESISTOR_0402_0
DISCRETE
R67
0402
RESISTOR_0402_0
DISCRETE
R68
0402
RESISTOR_0402_0
DISCRETE
R69
0402
RESISTOR_0402_0
DISCRETE
R72
0402
RESISTOR_0402_0
DISCRETE
R74
0402
RESISTOR_0402_0
DISCRETE
R77
0402
RESISTOR_0402_0
DISCRETE
R79
0402
RESISTOR_0402_10K
10K
IC
R83
0402
RESISTOR_0402_220
220
IC
R86
0402
RESISTOR_0402_220
220
IC
R87
0402
RESISTOR_0402_220
220
IC
R88
0402
RESISTOR_0402_10K
10K
IC
R89
0402
RESISTOR_0402_10K
10K
IC
R90
0402
RESISTOR_0402_10K
10K
IC
R91
0402
RESISTOR_0402_10K
10K
IC
R102
0402
RESISTOR_0402_10K
10K
IC
R103
0402
RESISTOR_0402_10K
10K
IC
R104
0402
RESISTOR_0402_10K
10K
IC
R105
0402
R456
13.3K
IC
R456
R0402
RESISTOR, 0402_R0402_324K
324K
IC
R667
0402
RESISTOR_0402_0
DISCRETE
R668
0402
RESISTOR_0402_10K
10K
IC
R671
0402
RESISTOR_0402_4.7K
4.7K
DISCRETE
R675
0402
RESISTOR_0402_DNI
DNI
IC
R681
0402
RESISTOR_0402_DNI
DNI
IC
R682
0402
RESISTOR_0402_4.7K
4.7K
DISCRETE
R686
0402
RESISTOR_0402_4.7K
4.7K
DISCRETE
R687
0402
RESISTOR_0402_4.7K
4.7K
DISCRETE
R688
0402
RESISTOR_0402_1.00K
1.00K
IC
R698
0402
R_0402_2.61K
2.61K
IC
R699
0402
RESISTOR_0402_4.7K
4.7K
DISCRETE
R5256
0402
RESISTOR_0402_1.00K
1.00K
IC
R5257
0402
RESISTOR_0402_10K
10K
IC
R5258
0402
RESISTOR_0402_1.00K
1.00K
IC
R5259
0402
RESISTOR_0402_4.7K
4.7K
DISCRETE
R5262
0402
RESISTOR_0402_4.7K
4.7K
DISCRETE
R5265
1206
RESISTOR_1206_1M
1M
IC
R5266
1206
RESISTOR_1206_1M
1M
IC
R5268
0402
RESISTOR_0402_1.00K
1.00K
IC
R5269
0402
RESISTOR_0402_DNI
DNI
IC
R5270
0402
RESISTOR_0402_4.7K
4.7K
DISCRETE
R5271
0402
RESISTOR_0402_DNI
DNI
IC
R5275
0402
RESISTOR_0402_33
33
DISCRETE
R5276
0402
RESISTOR_0402_33
33
DISCRETE
R5277
0402
RESISTOR_0402_33
33
DISCRETE
R5278
0402
RESISTOR_0402_10K
10K
IC
R5279
0402
RESISTOR_0402_10K
10K
IC
R5280
0402
RESISTOR_0402_10K
10K
IC
R5281
0402
RESISTOR_0402_10K
10K
IC
R5282
0402
RESISTOR_0402_10K
10K
IC
R5283
0402
RESISTOR_0402_10K
10K
IC
R5284
0402
RESISTOR_0402_10K
10K
IC
R5285
0402
RESISTOR_0402_10K
10K
IC
R5286
0402
RESISTOR_0402_DNI
DNI
IC
R5287
0402
RESISTOR_0402_DNI
DNI
IC
R5288
0402
RESISTOR_0402_33
33
DISCRETE
R5289
0402
RESISTOR_0402_33
33
DISCRETE
R5300
0402
RESISTOR_0402_33
33
DISCRETE
R5301
0402
RESISTOR_0402_33
33
DISCRETE
R5302
0402
RESISTOR_0402_33
33
DISCRETE
R5303
0402
RESISTOR_0402_33
33
DISCRETE
R5304
0402
RESISTOR_0402_33
33
DISCRETE
R5305
0402
RESISTOR_0402_33
33
DISCRETE
R5306
0402
RESISTOR_0402_33
33
DISCRETE
R5307
0402
RESISTOR_0402_33
33
DISCRETE
R5308
0402
RESISTOR_0402_33
33
DISCRETE
R5309
0402
RESISTOR_0402_DNI
DNI
IC
R5310
0402
RESISTOR_0402_1.00K
1.00K
IC
R5311
0402
RESISTOR_0402_1.00K
1.00K
IC
R5312
0402
RESISTOR_0402_10K
10K
IC
R5313
0402
RESISTOR_0402_DNI
DNI
IC
R5314
0402
RESISTOR_0402_DNI
DNI
IC
R5315
0402
RESISTOR_0402_DNI
DNI
IC
R5316
WURTH_6X3P5_TACT_SWITCH
TS-A02SA-2-S100_0_WURTH_6X3P5_T
PB Switch
IC
S1
PB Switch
IC
S2
QFN48
KSZ9031RN_4_QFN48_KSZ9031RN
KSZ9031RN
IC
U1
QFN32-FTDI
FT232R_2_QFN32-FTDI_FT232R
FT232R
IC
U5
SON6
TPD4S012DRYR_SON6_TPD4S012DRYR
TPD4S012DRYR
IC
U6
VFBGA63_SOCKET
MT29F8G16ABBCAH4-IT_1_VFBGA63_S
MT29F8G16ADBDAH4-AIT
IC
U7
VFBGA-153
MTFC8GAKAJCN-4M IT_VFBGA-153_(S
MTFC8GAKAJCN-4M IT
IC
U8
SC70_TI
SN74AUP1G17DCK_SC70_TI_SN74AUP1
SN74AUP1G17DCK
IC
U14
BGA25
LTM4623EV#PBF_BGA25_LTM4623EY#P
LTM4623EY#PBF
IC
U15
DFN-10
EY1501DI-ADJ_DFN-10_EY1501DI-AD
EY1501DI-ADJ
IC
U62
SC70_TI
SN74AUP1G126DCK_SC70_TI_SN74AUP
SN74AUP1G126DCK
IC
U63
SC70_TI
SN74AUP1T17DCKR
IC
U64
SC70_TI
SN74AUP1T17DCKR
IC
U65
SC70_TI
SN74AUP1G17DCK
IC
U68
SC70_TI
SN74AUP1G17DCK
IC
U69
OSC3250
OSC_ALT_OSC3250_25MHZ
25MHz
IC
Y1
OSC7050
OSC_ALT_OSC7050_25MHZ
25MHz
IC
Y2
重要提示:PCB作品文件展下载说明
 楼主| 发表于 2018-12-17 03:05:27 | 显示全部楼层
S10_SOC_NAND_20170215.DSN.rar (541 KB, 下载次数: 0) IO48_NAND_Card_0420b.brd.rar (863 KB, 下载次数: 0)
PADS-181217初级班
发表于 2018-12-17 08:43:16 | 显示全部楼层
  • 签到天数: 6 天
    承接PCB设计
    发表于 2018-12-17 08:44:55 | 显示全部楼层
    无聊
    昨天 08:52
  • 签到天数: 185 天
    1元学习Allegro(1期)
    发表于 2018-12-17 08:46:27 | 显示全部楼层
    1元学习PADS(5期)
    发表于 2018-12-17 08:49:10 | 显示全部楼层
    1 小时前
  • 签到天数: 324 天
    发表于 2018-12-17 08:54:00 | 显示全部楼层
    发表于 2018-12-17 08:55:05 | 显示全部楼层
    社区居民忠实会员社区劳模原创达人最爱沙发终身成就奖特殊贡献奖原创先锋奖优秀斑竹奖
    发表于 2018-12-17 08:56:13 | 显示全部楼层
    发表于 2018-12-17 08:56:58 | 显示全部楼层
