查看: 5980|回复: 28
[Allegro16.6以下] Stratix 10 SX SoC开发套件子卡8层OOBE及4个小型子卡原理图PCB
终身成就奖原创先锋奖特殊贡献奖优秀斑竹奖金点子奖
发表于 2018-12-17 03:07:27 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
SYM_NAME
COMP_DEVICE_TYPE
COMP_VALUE
COMP_TOL
COMP_CLASS
REFDES
0805
CAP_0805_4.7UF
4.7uF
IC
C1
0402
CAP_0402_0.1UF
0.1uF
IC
C2
0805
CAP_0805_4.7UF
4.7uF
IC
C3
0402
CAP_0402_0.1UF
0.1uF
IC
C4
0402
CAP_0402_0.01UF
0.01uF
IC
C5
0402
CAP_0402_0.01UF
0.01uF
IC
C6
0402
CAP_0402_0.01UF
0.01uF
IC
C7
0402
CAP_0402_0.01UF
0.01uF
IC
C8
0603
CAP_0603_22UF
22uF
IC
C11
0402
CAP_0402_0.1UF
0.1uF
IC
C13
0603
CAP_0603_22UF
22uF
IC
C15
0402
CAP_0402_0.1UF
0.1uF
IC
C17
0603
CAP_0603_22UF
22uF
IC
C18
0402
CAP_0402_0.01UF
0.01uF
IC
C20
0603
CAP_0603_22UF
22uF
IC
C23
0402
CAP_0402_0.01UF
0.01uF
IC
C25
0603
CAP_0603_22UF
22uF
IC
C26
0603
CAP_0603_2.2UF
2.2uF
IC
C28
0603
CAP_0603_22UF
22uF
IC
C29
0402
CAP_0402_0.1UF
0.1uF
IC
C31
0603
CAP_0603_2.2UF
2.2uF
IC
C32
0402
CAP_0402_0.1UF
0.1uF
IC
C33
0805
CAP_0805_4.7UF
4.7uF
IC
C34
0402
CAP_0402_0.1UF
0.1uF
IC
C35
0402
CAP_0402_0.1UF
0.1uF
IC
C36
0402
CAP_0402_0.1UF
0.1uF
IC
C37
0402
CAP_0402_0.1UF
0.1uF
IC
C38
0805
CAP_0805_4.7UF
4.7uF
IC
C39
0402
CAP_0402_30PF
30pF
IC
C40
0402
CAP_0402_30PF
30pF
IC
C41
0603
CAP_0603_2.2UF
2.2uF
IC
C42
0402
CAP_0402_0.1UF
0.1uF
IC
C43
0402
CAP_0402_0.1UF
0.1uF
IC
C44
0402
CAP_0402_0.1UF
0.1uF
IC
C45
0402
CAP_0402_0.1UF
0.1uF
IC
C46
0402
CAP_0402_0.1UF
0.1uF
IC
C47
0603
CAP_0603_2.2UF
2.2uF
IC
C48
0402
CAP 39PF 5% 50V 0402_0402_39PF
39pF
IC
C53
0402
39pF
IC
C54
0402
CAP_0402_0.1UF
0.1uF
IC
C55
0603
CAP_0603_2.2UF
2.2uF
IC
C56
0402
CAP_0402_0.1UF
0.1uF
IC
C57
0603
CAP_0603_2.2UF
2.2uF
IC
C58
0402
CAP_0402_0.1UF
0.1uF
IC
C59
0805
CAP_0805_4.7UF
4.7uF
IC
C60
0402
CAP_0402_0.01UF
0.01uF
IC
C61
0402
CAP_0402_0.1UF
0.1uF
IC
C62
0402
CAP_0402_0.1UF
0.1uF
IC
C63
1206
CAP_1206_10UF
10uF
IC
C896
1206
CAP_1206_47UF
47uF
IC
C900
1206
CAP_1206_47UF
47uF
IC
C903
0402
CAP_0402_0.1UF
0.1uF
IC
C909
0603
CAP_0603_22UF
22uF
IC
C914
0603
CAP_0603_22UF
22uF
IC
C915
0603
CAP_0603_22UF
22uF
IC
C916
0603
CAP_0603_22UF
22uF
IC
C919
0603
CAP_0603_22UF
22uF
IC
C920
0402
CAP_0402_0.01UF
0.01uF
IC
C921
0402
CAP_0402_0.01UF
0.01uF
IC
C922
0402
CAP_0402_0.01UF
0.01uF
IC
C924
0402
CAP_0402_0.01UF
0.01uF
IC
C925
0402
CAP_0402_0.01UF
0.01uF
IC
C927
0603
CAP_0603_22UF
22uF
IC
C928
0402
CAP_0402_1NF
1nF
IC
C929
0402
CAP_0402_120PF
120pF
IC
C930
0402
CAP_0402_0.01UF
0.01uF
IC
C931
0402
CAP_0402_0.1UF
0.1uF
IC
C932
0402
CAP_0402_0.1UF
0.1uF
IC
C933
0402
CAP_0402_0.1UF
0.1uF
IC
C934
0402
CAP_0402_0.1UF
0.1uF
IC
C935
0402
CAP_0402_0.1UF
0.1uF
IC
C936
0402
CAP_0402_0.1UF
0.1uF
IC
C937
0402
CAP_0402_0.1UF
0.1uF
IC
C938
0402
CAP_0402_0.1UF
0.1uF
IC
C939
1808
CAP_1808_DNI
DNI
IC
C940
1808
CAP_1808_DNI
DNI
IC
C943
0402
CAP_0402_0.1UF
0.1uF
IC
C944
0402
CAP_0402_0.1UF
0.1uF
IC
C945
0402
CAP_0402_0.1UF
0.1uF
IC
C946
0402
CAP_0402_0.1UF
0.1uF
IC
C953
C0805
CAP_C0805_10UF
10uF
IC
C954
C0805
CAP_C0805_10UF
10uF
IC
C955
0402
CAP_0402_0.1UF
0.1uF
IC
C956
0402
CAP_0402_0.1UF
0.1uF
IC
C957
0805
CAP_0805_4.7UF
4.7uF
IC
C958
0805
CAP_0805_4.7UF
4.7uF
IC
C959
0402
CAP_0402_0.1UF
0.1uF
IC
C960
0402
CAP_0402_0.1UF
0.1uF
IC
C961
0402
CAP_0402_0.1UF
0.1uF
IC
C962
0402
CAP_0402_0.1UF
0.1uF
IC
C963
0402
CAP_0402_0.1UF
0.1uF
IC
C964
0402
CAP_0402_0.1UF
0.1uF
IC
C965
TSLP-3-7
D11
ESD5V3U2U
IC
D1
TSLP-3-7
D11
ESD5V3U2U
IC
D2
TSLP-3-7
D11
ESD5V3U2U
IC
D3
LED_0603
LED_WURTH_LED_0603_GREEN_LED
GREEN_LED
IC
D4
LED_0603
GREEN_LED
IC
D5
LED_0603
GREEN_LED
IC
D6
LED_0603
GREEN_LED
IC
D7
LED_0603
GREEN_LED
IC
D8
QTH-030
HEADER 30X2_0_QTH-030_QTH-030-0
QTH-030-02-L-D-A
IC
J1
CONN_TSW_103_07_L_S
HEADER, 1X3-PIN_CONN_TSW_103_07
HEADER, 1x3-PIN
IC
J2
BEL_L829-1J1T-43
ENET_L829-1J1T-43_2_BEL_L829-1J
ENET_L829-1J1T-43
IC
J3
MOLEX-MICRO-USB-47589-001
MICRO_USB_CONN_MOLEX-MICRO-USB-
MICRO_USB_CONN
IC
J4
WURTH_MICRO-SD_CARD
SD_SKT_1_WURTH_MICRO-SD_CARD_MI
MicroSD_skt
IC
J5
MINI_USB_SMTB
USB_MINI_B_SMT_MINI_USB_SMTB_US
USB MINI-B-SMT Vertical
IC
J7
SMT38
2-767004-2_SMT38_MICTOR38P
Mictor38P
IC
J8
HDR2X1_100MIL
CON2_HDR2X1_100MIL_CON2
CON2
IC
J10
C635TC317-01
MOUNTING HOLE_C635TC317-01_MOUN
mounting hole
IC
J11
C635TC317-01
mounting hole
IC
J12
C635TC317-01
mounting hole
IC
J13
IND_0603
IND FERRITE 0603 3A/30 OHMS_IND
3A, 30 Ohm FB
IC
L1
IND_0603
3A, 30 Ohm FB
IC
L2
IND_0603
3A, 30 Ohm FB
IC
L3
IND_0603
3A, 30 Ohm FB
IC
L4
IND_0603
3A, 30 Ohm FB
IC
L5
0402
BEAD_FERRITE_SM_0402_742792780
742792780
IC
L6
0402
742792780
IC
L9
0402
742792780
IC
L10
SOT23
NMOS_3PIN_SOT23_FDV305N
FDV305N
IC
Q1
SOT23
FDV305N
IC
Q2
SOT23
FDV305N
IC
Q3
SOT23
FDV305N
IC
Q4
SOT23
FDV305N
IC
Q5
SOT23
FDV305N
IC
Q6
SOT23
FDV305N
IC
Q7
0402
RESISTOR_0402_0
DISCRETE
R1
0402
RESISTOR_0402_4.7K
4.7K
DISCRETE
R4
0402
RESISTOR_0402_4.7K
4.7K
DISCRETE
R6
0402
RESISTOR_0402_4.7K
4.7K
DISCRETE
R7
0402
RESISTOR_0402_33
33
IC
R8
0402
RESISTOR_0402_220
220
IC
R9
0402
RESISTOR_0402_4.7K
4.7K
DISCRETE
R10
0402
RESISTOR_0402_33
33
IC
R11
0402
RESISTOR_0402_33
33
IC
R12
0402
RESISTOR_0402_33
33
IC
R13
0402
RESISTOR_0402_33
33
IC
R14
0402
RESISTOR_0402_33
33
IC
R15
0402
RESISTOR_0402_220
220
IC
R16
0402
RESISTOR_0402_12.1K
12.1K
IC
R17
0402
RESISTOR_0402_DNI
DNI
IC
R18
0402
RESISTOR_0402_4.7K
4.7K
DISCRETE
R19
0402
RESISTOR_0402_10K
10K
IC
R20
0402
RESISTOR_0402_75
75
IC
R21
0402
RESISTOR_0402_DNI
DNI
IC
R22
0402
RESISTOR_0402_4.7K
4.7K
DISCRETE
R23
0402
RESISTOR_0402_4.7K
4.7K
DISCRETE
R25
0402
RESISTOR_0402_DNI
DNI
IC
R26
0402
RESISTOR_0402_4.7K
4.7K
DISCRETE
R27
0402
RESISTOR_0402_DNI
DNI
IC
R28
0402
RESISTOR_0402_4.7K
4.7K
DISCRETE
R29
0402
RESISTOR_0402_DNI
DNI
IC
R30
0402
RESISTOR_0402_4.7K
4.7K
DISCRETE
R31
0402
RESISTOR_0402_DNI
DNI
IC
R32
0402
RESISTOR_0402_DNI
DNI
IC
R33
0402
RESISTOR_0402_4.7K
4.7K
DISCRETE
R34
0402
RESISTOR_0402_4.7K
4.7K
DISCRETE
R35
0402
RESISTOR_0402_DNI
DNI
IC
R36
0402
RESISTOR_0402_4.7K
4.7K
DISCRETE
R37
0402
RESISTOR_0402_DNI
DNI
IC
R38
0402
RESISTOR_0402_1.87K
1.87K
IC
R39
0402
RES 178K OHM 1% 1/10W 0402_0402
137K
IC
R42
0603
RESISTOR_0603_0
IC
R44
0402
RESISTOR_0402_10K
10K
IC
R45
0603
RESISTOR_0603_0
IC
R46
0603
RESISTOR_0603_0
IC
R47
0603
RESISTOR_0603_1.00K
1.00K
IC
R54
0402
RESISTOR_0402_33
33
IC
R59
0402
RESISTOR_0402_33
33
IC
R60
0402
RESISTOR_0402_33
33
IC
R61
0402
RESISTOR_0402_1M
1M
IC
R62
0402
RESISTOR_0402_8.06K
8.06K
IC
R63
0402
RESISTOR_0402_200K
200K
IC
R66
0805
RESISTOR_0805_0.1
0.1
IC
R67
0603
RESISTOR_0603_499
499
IC
R70
0603
RESISTOR_0603_499
499
IC
R72
0603
RESISTOR_0603_499
499
IC
R73
0603
RESISTOR_0603_499
499
IC
R74
0603
RESISTOR_0603_330
330
IC
R75
0603
RESISTOR_0603_330
330
IC
R76
0402
RESISTOR_0402_DNI
DNI
IC
R78
0402
RESISTOR_0402_DNI
DNI
IC
R79
0402
RESISTOR_0402_1.00K
1.00K
IC
R80
0402
RESISTOR_0402_1.00K
1.00K
IC
R81
0402
RESISTOR_0402_1.00K
1.00K
IC
R82
0402
RESISTOR_0402_1.00K
1.00K
IC
R83
0402
RESISTOR_0402_1.00K
1.00K
IC
R84
0402
RESISTOR_0402_0
DISCRETE
R97
0402
RESISTOR_0402_0
DISCRETE
R101
0402
RESISTOR_0402_220
220
IC
R103
0402
RESISTOR_0402_220
220
IC
R104
0402
RESISTOR_0402_10K
10K
IC
R105
0402
RESISTOR_0402_10K
10K
IC
R106
0402
RESISTOR_0402_10K
10K
IC
R107
0402
RESISTOR_0402_DNI
DNI
IC
R109
0603
RESISTOR_0603_0
IC
R110
0603
RESISTOR_0603_DNI
DNI
IC
R111
0402
RESISTOR_0402_10K
10K
IC
R112
0402
RESISTOR_0402_10K
10K
IC
R113
0402
RESISTOR_0402_10K
10K
IC
R114
0402
RESISTOR_0402_10K
10K
IC
R115
0402
RESISTOR_0402_10K
10K
IC
R116
0402
RESISTOR_0402_0
DISCRETE
R117
0402
RESISTOR_0402_0
DISCRETE
R118
0402
RESISTOR_0402_0
DISCRETE
R119
0402
RESISTOR_0402_0
DISCRETE
R120
0402
RESISTOR_0402_0
DISCRETE
R121
0402
RESISTOR_0402_0
DISCRETE
R122
0402
RESISTOR_0402_0
DISCRETE
R123
0402
RESISTOR_0402_0
DISCRETE
R124
0402
RESISTOR_0402_10K
10K
IC
R125
0402
RESISTOR_0402_220
220
IC
R126
0402
RESISTOR_0402_220
220
IC
R127
0402
RESISTOR_0402_10K
10K
IC
R128
0402
RESISTOR_0402_220
220
IC
R129
0402
RESISTOR_0402_10K
10K
IC
R131
0402
R456
13.3K
IC
R456
0402
RESISTOR_0402_1.00K
1.00K
IC
R612
R0402
RESISTOR, 0402_R0402_324K
324K
IC
R667
0402
RESISTOR_0402_0
DISCRETE
R668
0402
R669
8.25K
IC
R669
0402
RESISTOR_0402_0
DISCRETE
R670
0402
RESISTOR_0402_DNI
DNI
IC
R671
0402
RESISTOR_0402_4.7K
4.7K
DISCRETE
R675
0402
RESISTOR_0402_DNI
DNI
IC
R681
0402
RESISTOR_0402_DNI
DNI
IC
R682
0402
RESISTOR_0402_22
22
IC
R683
0402
RESISTOR_0402_22
22
IC
R684
0402
RESISTOR_0402_330
330
IC
R685
0402
RESISTOR_0402_4.7K
4.7K
DISCRETE
R686
0402
RESISTOR_0402_4.7K
4.7K
DISCRETE
R687
0402
RESISTOR_0402_4.7K
4.7K
DISCRETE
R688
0402
RESISTOR_0402_4.7K
4.7K
DISCRETE
R689
0402
RESISTOR_0402_4.7K
4.7K
DISCRETE
R690
0402
RESISTOR_0402_4.7K
4.7K
DISCRETE
R691
0402
RESISTOR_0402_1.00K
1.00K
IC
R692
0402
RESISTOR_0402_1.00K
1.00K
IC
R693
0402
RESISTOR_0402_4.7K
4.7K
DISCRETE
R694
0402
RESISTOR_0402_4.7K
4.7K
DISCRETE
R695
0402
RESISTOR_0402_4.7K
4.7K
DISCRETE
R696
0402
RESISTOR_0402_4.7K
4.7K
DISCRETE
R697
0402
RESISTOR_0402_1.00K
1.00K
IC
R698
0402
R_0402_2.61K
2.61K
IC
R699
0402
RESISTOR_0402_4.7K
4.7K
DISCRETE
R5262
0402
RESISTOR_0402_4.7K
4.7K
DISCRETE
R5265
1206
RESISTOR_1206_0
IC
R5266
1206
RESISTOR_1206_0
IC
R5269
0402
RESISTOR_0402_DNI
DNI
IC
R5270
0402
RESISTOR_0402_4.7K
4.7K
DISCRETE
R5271
0402
RESISTOR_0402_10K
10K
IC
R5275
0402
RESISTOR_0402_10K
10K
IC
R5276
0402
RESISTOR_0402_DNI
DNI
IC
R5283
0402
RESISTOR_0402_1.00K
1.00K
IC
R5284
0402
RESISTOR_0402_DNI
DNI
IC
R5285
0402
RESISTOR_0402_0
DISCRETE
R5286
0402
RESISTOR_0402_33
33
IC
R5287
0402
RESISTOR_0402_33
33
IC
R5288
0402
RESISTOR_0402_33
33
IC
R5289
0402
RESISTOR_0402_33
33
IC
R5290
0402
RESISTOR_0402_33
33
IC
R5291
0402
RESISTOR_0402_33
33
IC
R5292
0402
RESISTOR_0402_33
33
IC
R5293
0402
RESISTOR_0402_33
33
IC
R5294
0402
RESISTOR_0402_33
33
IC
R5295
0402
RESISTOR_0402_33
33
IC
R5296
0402
RESISTOR_0402_33
33
IC
R5297
0402
RESISTOR_0402_33
33
IC
R5298
0402
RESISTOR_0402_33
33
IC
R5299
0402
RESISTOR_0402_33
33
IC
R5300
0402
RESISTOR_0402_33
33
IC
R5301
0402
RESISTOR_0402_33
33
IC
R5302
0402
RESISTOR_0402_33
33
IC
R5303
0402
RESISTOR_0402_1.00K
1.00K
IC
R5304
0402
RESISTOR_0402_1.00K
1.00K
IC
R5305
0402
RESISTOR_0402_4.7K
4.7K
DISCRETE
R5306
0402
RESISTOR_0402_DNI
DNI
IC
R5307
0402
RESISTOR_0402_0
DISCRETE
R5308
0402
RESISTOR_0402_0
DISCRETE
R5309
0402
RESISTOR_0402_0
DISCRETE
R5311
WURTH_6X3P5_TACT_SWITCH
TS-A02SA-2-S100_0_WURTH_6X3P5_T
PB Switch
IC
S1
PB Switch
IC
S2
QFN48
KSZ9031RN_4_QFN48_KSZ9031RN
KSZ9031RN
IC
U1
TDFN-8
MAX14523B_TDFN-8_MAX14523B
MAX14523B
IC
U3
QFN32
USB3320_QFN32_USB3320
USB3320
IC
U4
TSSOP20
LSF0108PWR_TSSOP20_LSF0108PWR
LSF0108PWR
IC
U5
TPS22902BYFPR
TPS22902BYFPR_TPS22902BYFPR_TPS
TPS22902BYFPR
IC
U6
QFN32-FTDI
FT232R_2_QFN32-FTDI_FT232R
FT232R
IC
U9
SON6
TPD4S012DRYR_SON6_TPD4S012DRYR
TPD4S012DRYR
IC
U10
BGA25
LTM4622EV_BGA25_LTM4622EY
LTM4622EY
IC
U15
DFN-10
EY1501DI-ADJ_DFN-10_EY1501DI-AD
EY1501DI-ADJ
IC
U62
SC70_TI
SN74AUP1G126DCK_SC70_TI_SN74AUP
SN74AUP1G126DCK
IC
U63
SC70_TI
SN74AUP1G17DCK_SC70_TI_SN74AUP
SN74AUP1T17DCKR
IC
U64
SC70_TI
SN74AUP1T17DCKR
IC
U65
SC70_TI
SN74AUP1G17DCK_SC70_TI_SN74AUP1
SN74AUP1G17DCK
IC
U68
SC70_TI
SN74AUP1G17DCK
IC
U69
SC70_TI
SN74AUP1G17DCK
IC
U70
XTAL_ECX-32
CRYSTALSM_ECS_XTAL_ECX-32_24MHZ
24MHz
IC
Y1
OSC3250
OSC_ALT_OSC3250_25MHZ
25MHz
IC
Y2
OSC7050
OSC_ALT_OSC7050_25MHZ
25MHz
IC
Y3
重要提示:PCB作品文件展下载说明
 楼主| 发表于 2018-12-17 03:09:00 | 显示全部楼层
S10_SOC_OOBE_A2.DSN.rar (564 KB, 下载次数: 2) IO48_OOBE_Card_A2_pcb.brd.rar (995 KB, 下载次数: 2) eMMC.rar (1.08 MB, 下载次数: 2) MicroSD.rar (1.11 MB, 下载次数: 2) NAND.rar (1.03 MB, 下载次数: 3) QSPI.rar (972 KB, 下载次数: 2)
1元学习Allegro(2期)
发表于 2018-12-17 07:58:37 | 显示全部楼层
    昨天 09:26
  • 签到天数: 13 天
    发表于 2018-12-17 08:12:33 | 显示全部楼层
    前天 10:50
  • 签到天数: 15 天
    发表于 2018-12-17 08:29:05 | 显示全部楼层
    1元学习Allegro(1期)
    发表于 2018-12-17 08:31:57 | 显示全部楼层
    谢谢分享谢谢分享谢谢分享
    PADS-181217初级班
    发表于 2018-12-17 08:42:34 | 显示全部楼层
    1元学习PADS(5期)
    发表于 2018-12-17 08:42:39 | 显示全部楼层
  • 签到天数: 6 天
    承接PCB设计
    发表于 2018-12-17 08:44:43 | 显示全部楼层
    无聊
    昨天 08:52
  • 签到天数: 185 天
    1元学习Allegro(1期)
    发表于 2018-12-17 08:46:45 | 显示全部楼层
