REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
BT1 | BATTERY_SN2032-1_CR2032-3V_SKT | CR2032-3V_SKT | SN2032-1 |
CON1 | USBX1_USB-CU01_USBTYPE-A | USB Type-A | USB-CU01 |
CON2 | ESATA_CONNECTOR_AMTEC_SATAII_PL | 021-01-2212I | AMTEC_SATAII_PLUG |
CON3 | SDCN24-A0-6012_SDCN24-A0-6012_S | SDCN24-A0-6012 | SDCN24-A0-6012 |
CON4 | CON_1X2_CI0102P1VK0_1X2CON | 1x2 Con | CI0102P1VK0 |
CON5 | MINI_PEX_52PINS_MOLEX-SD-67910- | Mini PEX 52pin | MOLEX-SD-67910-001 |
CON6 | MINI_PEX_52PINS_MOLEX-SD-67910- | Mini PEX 52pin | MOLEX-SD-67910-001 |
CON7 | BH1S-20G_JTAG_HEADER_20_JTAG20 | JTAG 20Pin | HEADER_20 |
CON8 | BH1S-20G_2X10_CON_PS1M85_2X10_1 | 2x10 Pin FemaleHeader SMT | CON_PS1M85_2X10_100MIL_SMT |
CON9 | JG0-0089NL_JG0-0089_JG0-0189NL | JG0-0189NL | JG0-0089 |
CON10 | J0G-0053NL_J0G-0053NL_1X1RJ45 | 1x1 RJ45 | J0G-0053NL |
CON11 | POWER_JACK_KLDX-0202-A_POWER-JA | POWER-JACK | KLDX-0202-A |
CON12 | CD011C70A035_WATB-22DL1P7U_WATB | WATB-22DL1P7U | WATB-22DL1P7U |
D1 | NUP2201MR6T1G_TSOP-6_NUP2201MR6 | NUP2201MR6T1G | TSOP-6 |
D2 | BAT54C_SOT23-1A3C-DIOD_BAT54C | BAT54C | SOT23-1A3C-DIOD |
DPR1 | DPR23_0402X2_23_4.7K | 4.7k | 0402X2_23 |
DPR2 | DPR12_0402X2_12_4.7K | 4.7k | 0402X2_12 |
DPR3 | DPR23_TOLERANCE_0402X2_23_1K | 1k | 0402X2_23 |
DPR4 | DPR12_0402X2_12_0 | 0 | 0402X2_12 |
DPR5 | DPR12_0402X2_12_0 | 0 | 0402X2_12 |
FB1 | FERRITE_BEAD_0805_CIS21J121NE | CIS21J121NE | 805 |
FB2 | FERRITE_BEAD_0603_FB_600OHM | FB_600ohm | 603 |
FB3 | FERRITE_BEAD_0603_FB_600OHM | FB_600ohm | 603 |
FB4 | FERRITE_BEAD_0603_FB_600OHM | FB_600ohm | 603 |
FB5 | FERRITE_BEAD_0603_FB_600OHM | FB_600ohm | 603 |
FB6 | FERRITE_BEAD_0603_FB_600OHM | FB_600ohm | 603 |
FB7 | FERRITE_BEAD_0603_FB_60OHM | FB_60ohm | 603 |
FB8 | FERRITE_BEAD_0805_CIS21J121NE | CIS21J121NE | 805 |
FB9 | FERRITE_BEAD_0805_CIS21J121NE | CIS21J121NE | 805 |
FB10 | FERRITE_BEAD_0805_CIS21J121NE | CIS21J121NE | 805 |
FB11 | FERRITE_BEAD_0603_FB_600OHM | FB_600ohm | 603 |
FB12 | FERRITE_BEAD_0603_FB_600OHM | FB_600ohm | 603 |
FB13 | FERRITE_BEAD_0603_FB_600OHM | FB_600ohm | 603 |
FB14 | FERRITE_BEAD_0603_FB_600OHM | FB_600ohm | 603 |
FB15 | FERRITE_BEAD_0603_FB_600OHM | FB_600ohm | 603 |
FB16 | FERRITE_BEAD_0603_FB_600OHM | FB_600ohm | 603 |
FB17 | FERRITE_BEAD_0805_CIS21J121NE | CIS21J121NE | 805 |
JP1 | HEADER_1X3_JUMP3_HEADER_1X3 | Header_1x3 | JUMP3 |
JP2 | HEADER_1X4_PLUG_1X4_100MIL_RIGH | Header_1x4_90Deg | PLUG_1X4_100MIL_RIGHT |
JP3 | HEADER_1X2_JUMP2_TH_HEADER_1X2 | Header_1x2 | JUMP2_TH |
L1 | INDUCTOR_UNIPAC_FDV0840_6.9UH | 6.9uH | FDV0840 |
L2 | INDUCTOR_UNIPAC_FDV0840_6.9UH | 6.9uH | FDV0840 |
L3 | INDUCTOR_DE2818C_1UH | 1uH | DE2818C |
L4 | INDUCTOR_DE2818C_1UH | 1uH | DE2818C |
L5 | INDUCTOR_UNIPAC_FDV0840_6.9UH | 6.9uH | FDV0840 |
L6 | INDUCTOR_DE2818C_1UH | 1uH | DE2818C |
L7 | INDUCTOR_1210_1UH | 1uH | 1210 |
L8 | INDUCTOR_1210_1UH | 1uH | 1210 |
L9 | INDUCTOR_DE2818C_1UH | 1uH | DE2818C |
LED1 | LED_LED2X1_A264B/G | A264B/G | LED2X1 |
LED2 | LED_LED2X1_A264B/G | A264B/G | LED2X1 |
LED3 | LED_LED2X1_A264B/G | A264B/G | LED2X1 |
LED4 | LED_LED2X1_A264B/G | A264B/G | LED2X1 |
LED5 | LED_LED2X1_A264B/G | A264B/G | LED2X1 |
LED6 | LED_LED2X1_A264B/G | A264B/G | LED2X1 |
LED7 | LED_LED2X1_A264B/G | A264B/G | LED2X1 |
LED8 | LED_LED2X1_A264B/G | A264B/G | LED2X1 |
LED9 | LED_LED2X1_A264B/G | A264B/G | LED2X1 |
LED10 | LED_LED_0603_AC_SMTGREEN | SMT Green | LED_0603_AC |
LED11 | LED_LED_AC-EL15-21-VGC_SMTRED | SMT RED | LED_AC-EL15-21-VGC |
M1 | HOLE_HOLE-7P2X3P4MM_HOLE-7.2X3. | HOLE-7.2x3.4mm | HOLE-7P2X3P4MM |
M2 | HOLE_HOLE-7X3P2MM_HOLE-7X3.2MM | HOLE-7x3.2mm | HOLE-7X3P2MM |
M3 | HOLE_HOLE-7P2X3P4MM_HOLE-7.2X3. | HOLE-7.2x3.4mm | HOLE-7P2X3P4MM |
M4 | HOLE_HOLE-7X3P2MM_HOLE-7X3.2MM | HOLE-7x3.2mm | HOLE-7X3P2MM |
M5 | HOLE_HOLE-7P2X3P4MM_HOLE-7.2X3. | HOLE-7.2x3.4mm | HOLE-7P2X3P4MM |
M6 | HOLE_HOLE-7X3P2MM_HOLE-7X3.2MM | HOLE-7x3.2mm | HOLE-7X3P2MM |
M7 | HOLE_HOLE-7P2X3P4MM_HOLE-7.2X3. | HOLE-7.2x3.4mm | HOLE-7P2X3P4MM |
M8 | HOLE_HOLE-7X3P2MM_HOLE-7X3.2MM | HOLE-7x3.2mm | HOLE-7X3P2MM |
M9 | HOLE_HOLE-5P8X3P2MM_HOLE-5.8X3. | HOLE-5.8x3.2mm | HOLE-5P8X3P2MM |
OSC1 | C71-50-07-8_S_YC6_125.000MHZ | 125.000MHz | S_YC6 |
Q1 | FDC6325L_SOT23_6P_FDC6330 | FDC6330 | SOT23_6P |
Q2 | FDS6680A_SOIC8_FDS6680A_NL | FDS6680A_NL | SOIC8 |
Q3 | FDV301N_SOT23-GSD_FDV301N | FDV301N | SOT23-GSD |
Q4 | BIPOLAR_NPN_TSOT-23B_MMBT2222 | MMBT2222 | TSOT-23B |
Q5 | FDC6325L_SOT23_6P_FDC6330 | FDC6330 | SOT23_6P |
SW1 | SWPUSHBUTTON_SWITCH-IT-1102V_4 | IT-1102VC | SWITCH-IT-1102V_4PINS |
SW2 | SWPUSHBUTTON_SWITCH-IT-1102V_1 | IT-1102V | SWITCH-IT-1102V_4PINS |
T1 | DLW21HN121SQ2_CHOKE_0805_0805US | 0805USB-421ML | CHOKE_0805 |
TP1 | TESTPOINT_TP_SMD-0402_TP_SMD040 | TP_SMD0402 | TP_SMD-0402 |
TP2 | TESTPOINT_TP_SMD-0402_TP_SMD040 | TP_SMD0402 | TP_SMD-0402 |
TP3 | TESTPOINT_TP_SMD-0402_TP_SMD040 | TP_SMD0402 | TP_SMD-0402 |
TP4 | TESTPOINT_TP_SMD-0402_TP_SMD040 | TP_SMD0402 | TP_SMD-0402 |
TP5 | TESTPOINT_HOLE_0P9_TP_TH09 | TP_TH09 | HOLE_0P9 |
TP6 | TESTPOINT_HOLE_0P9_TP_TH09 | TP_TH09 | HOLE_0P9 |
U2 | MAX1693_UMAX10L-0P5MM-BODY3MM_M | MAX1693 | UMAX10L-0P5MM-BODY3MM |
U3 | 88PH830_88PH830_88PH845-BX | 88PH845-Bx | 88PH830 |
U4 | CAT24WC64_DIP8_CAT24C64LI-G | CAT24C64LI-G | DIP8 |
U5 | MT41J256M8HX_BGA78_11P5X9X0P8MM | MT41J256M8HX-15E:D | BGA78_11P5X9X0P8MM |
U6 | PTB3J85-5638N-SC/APC-KES+_PTB3J | PTB3J85-5638N-SC/APC-KES+ | PTB3J88-5638T-SC_ACP |
U7 | MT41J256M8HX_BGA78_11P5X9X0P8MM | MT41J256M8HX-15E:D | BGA78_11P5X9X0P8MM |
U8 | 88PG818_DFN_12_4X3_88PG839-AX | 88PG839-Ax | DFN_12_4X3 |
U9 | 88PH830_88PH830_88PH845-BX | 88PH845-Bx | 88PH830 |
U10 | KW2_88F65XX-Z2_BGA476_19X19_0P6 | 88F6560P-Z2 | BGA476_19X19_0P65_MM |
U11 | 88PG818_DFN_12_4X3_88PG839-AX | 88PG839-Ax | DFN_12_4X3 |
U12 | 88E1545_LQFP128_14X20_0P5MM-EP_ | 88E1545-Zx | LQFP128_14X20_0P5MM-EP_7P0X6P0 |
U13 | 88PH830_88PH830_88PH845-BX | 88PH845-Bx | 88PH830 |
U14 | LM393_SO8_LM393M | LM393M | SO8 |
U15 | SPX5205_SOT23-5_SPX3819M5-L-1.5 | SPX3819M5-L-1.5 | SOT23-5 |
U16 | 88PG818_DFN_12_4X3_88PG839-AX | 88PG839-Ax | DFN_12_4X3 |
U17 | NC7SZ08XXX_SC-70-2X2P1MM_NC7SZ0 | NC7SZ08 | SC-70-2X2P1MM |
U18 | M25P64VMF6P_SOIC16-300MIL_M25P1 | M25P128-VMF6P | SOIC16-300MIL |
U19 | 88PG818_DFN_12_4X3_88PG839-AX | 88PG839-Ax | DFN_12_4X3 |
U20 | NAND04GW3B2DN6E_TS048_NAND04GW3 | NAND04GW3B2DN6E | TS048 |
Y1 | CXA-025000_CXA_SMD_3P2X2P5_25MH | 25MHz | CXA_SMD_3P2X2P5 |
Y2 | CRYSTAL_CS24MOA3020502040_25MHZ | 25MHz | CS24MOA3020502040 |
Y3 | GSX200_GSX-200_32.768KHZ | 32.768KHz | GSX-200 |
