发帖 回复
返回列表 提醒:附件不能用迅雷等P2P软件下载,否则直下载失败,文件名变成job.xx网页格式,下载点击一次即可,请勿多次连续点击附件
  • 1318阅读
  • 47回复
[Allegro16.6]TMS320DM642 +SAA7121H+LXT971ALC+TVP5150AM1PBS PCB文件共享 [复制链接]
上一主题 下一主题
离线armclub
性别:
帅哥
发帖
1137
金币
5719
威望
贡献值
1578
乐币
6056
好评度
55
RMB
404
<私密信息仅自己能看>
重要提示:本版需2级以上才能下载,有些需购买的帖,若没2级请不要购买,购买也下载不了【可充值秒升级】也可发帖,做任务,签到等升级。若已2级以上,忽略本提示
Te-p0x?G.
PR@6=[|d
>5CK&6
REFDESCOMP_DEVICE_TYPESYM_NAME
D1MT48LC4M32B2TG_7-410923012803,BMIC_TSOP86_400_S
D2MT48LC4M32B2TG_7-410923012803,BMIC_TSOP86_400_S
D3AM29LV320D-AM29LV320DT90ETSOP12X20-48
D4TPS5430-TI_TPS5420DDA,TI_R_PDSBTI_R_PDSO_G8_S
D5TMS320DM642PBGA27X27FE548-1R00
D7LXT971ALC-LXT971ALC,IN_LQFP64_BIN_LQFP64_S
D8MAX3485EXXA-MAX3485ECSA,MAX_SOBMAX_SO8_S
D9PH_SAA7121H-SAA7121H,PHI_QFP44BPHI_QFP44_S
D10MAX706TCSA-431723070609,MAX706BMAX_SO8_S
D11AT24C04AN_10SI_2V7-41172324040BAT_8S1_S
D12DS1302S-460123130209,DAL_SOIC8BDAL_SOIC8_200_S
D13TPS5430-TI_TPS5420DDA,TI_R_PDSBTI_R_PDSO_G8_S
DB2TL16C752B-430843000111,TI_PT_SBTI_PT_S
FU1R452_X-351405004003,R452 004,LALTF_R452_S
G1ESA14.31818F20D33SCO2-5R0X11R5-V
G2ESA14.31818F20D33SCO2-5R0X11R5-V
G3U-F-3.072M-20_HLXCO2-5R0X11R5-V
G5S-F-25.000M-30CO2-5R0X11R5-V
G6CRYSTAL_SHIELD-CRYSTAL_SHIELD,BCO2_3R0X9R0_R
GJ1OC_XXXXX-50MHZ,341655000071,OCBTTN_OC70_50_13_S
GJ2OC_XXXXX-133MHZ,341651330081,OBTTN_OC70_50_13_S
GJ3OC_XXXXX-25MHZ,341612500071,OCBTTN_OC70_50_13_S
GJ4OC_XXXXX-4MHZ,341614000061,OCEBTTN_OC70_50_13_S
GJ5OC_XXXXX-50MHZ,341655000071,OCBTTN_OC70_50_13_S
HL1BT113DGREEN-330920260113,JH_BTBJH_BT113D_T
HL2BT113DGREEN-330920260113,JH_BTBJH_BT113D_T
HL3BT113DGREEN-330920260113,JH_BTBJH_BT113D_T
L1NL252018T-2R7J_TDK2520L-M
L2MPZ2012SXA-600,322560460101,MPATDK_MPZ2012_S
L3NL252018T-2R7J_TDK2520L-M
L4MPZ2012SXA-600,322560460101,MPATDK_MPZ2012_S
L5NL252018T-2R7J_TDK2520L-M
L6MPZ2012SXA-600,322560460101,MPATDK_MPZ2012_S
L7MPZ2012SXA-600,322560460101,MPATDK_MPZ2012_S
L8NL252018T-2R7J_TDK2520L-M
L10CDH74-220LC,22UIND2SM-7R3X8R0-1
L13MPZ2012SXA-600,322560460101,MPATDK_MPZ2012_S
L14MPZ2012SXA-600,322560460101,MPATDK_MPZ2012_S
L15MPZ2012SXA-600,322560460101,MPATDK_MPZ2012_S
L17MPZ2012SXA-600,322560460101,MPATDK_MPZ2012_S
L18CDH74-220LC,22UIND2SM-7R3X8R0-1
LB1MPZ2012SXA-600,322560460101,MPATDK_MPZ2012_S
MT1MOUNT_HOLE-THC6R00D3R30HOLE_M_6R00D3R30
MT2MOUNT_HOLE-THC6R00D3R30HOLE_M_6R00D3R30
MT3MOUNT_HOLE-THC6R00D3R30HOLE_M_6R00D3R30
MT4MOUNT_HOLE-THC6R00D3R30HOLE_M_6R00D3R30
MT5MOUNT_HOLE-THC6R00D3R30HOLE_M_6R00D3R30
MT6MOUNT_HOLE-THC6R00D3R30HOLE_M_6R00D3R30
S1DPL-04SW8TM-9R7X12R0-1
S2DTSA6-5KSW4TM-7R4X12R4-1
S3DPL-04SW8TM-9R7X12R0-1
T1H1102-322401110201,PU_H1102_S,BPU_H1102_S
TPB3TESTPOINT-TPSTPS
U1TI_TVP5150AM1PBS-**,PBS32,TI_TBPBS32
U2TI_TVP5150AM1PBS-**,PBS32,TI_TBPBS32
U3SINGLE_BNC_3-SINGLE_BNC_3,GXDZBGXDZ_BNC_KWE_3_T
V1MBRS120T3-332400102001,ON_SMB_BON_SMB_CASE403A_S
V2MBRS120T3-332400102001,ON_SMB_BON_SMB_CASE403A_S
VT1LT1117CST-3.3SOT223
X1MARK-MARK_C0150S0300M_S,MARK-MAMARK_C0150S0300M_S
X2MARK-MARK_C0150S0300M_S,MARK-MAMARK_C0150S0300M_S
X3STD_2R54_2X7-201DS-2*40_2X7CON20VP2R54-2X7TM
X6ECH381R-03P_DINKLECON20VP3R81-3TM
X9BATTERY_SOCKET-CR1220-2CR1220-2
X10MARK-MARK_C0150S0300M_S,MARK-MAMARK_C0150S0300M_S
XB1MARK-MARK_C0150S0300M_S,MARK-MAMARK_C0150S0300M_S
XB2MARK-MARK_C0150S0300M_S,MARK-MAMARK_C0150S0300M_S
XB3MARK-MARK_C0150S0300M_S,MARK-MAMARK_C0150S0300M_S
XCP1SINGLE_BNC_3-SINGLE_BNC_3,GXDZBGXDZ_BNC_KWE_3_T
XCP2SINGLE_BNC_3-SINGLE_BNC_3,GXDZBGXDZ_BNC_KWE_3_T
XM5DT_TEST-**,DT_TEST,DT-TEST-DT_ADT_TEST
XS2406549_1-246140654901,406549-1BAMP_406549_1_T
XS3DC_JACK-**,GXDZ_SD_DC_4002_300BGXDZ_SD_DC_4002_300
Z1ACF451832_T-342418322307,TDK_ABTDK_ACF451832_S
评价一下你浏览此帖子的感受
精彩
感动
搞笑
愤怒
一般
差劲
您的支持和精彩回复,就是我坚持的动力
离线armclub
性别:
帅哥
发帖
1137
金币
5719
威望
贡献值
1578
乐币
6056
好评度
55
RMB
404
<私密信息仅自己能看>
只看该作者 1楼 发表于: 2019-09-11
PCB文件共享 ZD&F ,2v
DMPC_XM.7z (889 K) 下载次数:8 {?yVA
您的支持和精彩回复,就是我坚持的动力
性别:
帅哥
发帖
8373
金币
9182
威望
987
贡献值
134
乐币
7213
好评度
-5
RMB
<私密信息仅自己能看>
只看该作者 2楼 发表于: 2019-09-11
     支持
离线rate2014
性别:
帅哥
发帖
312
金币
304
威望
贡献值
乐币
390
好评度
RMB
<私密信息仅自己能看>
只看该作者 3楼 发表于: 2019-09-11
不错的资料,感谢分享。
离线非凡
性别:
帅哥
发帖
504
金币
927
威望
贡献值
56
乐币
648
好评度
RMB
<私密信息仅自己能看>
只看该作者 4楼 发表于: 2019-09-11
不错
离线wangy2000
性别:
人妖
发帖
2892
金币
34
威望
贡献值
乐币
378
好评度
RMB
<私密信息仅自己能看>
只看该作者 5楼 发表于: 2019-09-11
收藏谢谢分享
在线cdl511
性别:
帅哥
发帖
5078
金币
1980
威望
16
贡献值
25
乐币
2132
好评度
RMB
<私密信息仅自己能看>
只看该作者 6楼 发表于: 2019-09-11
不错的资料,感谢分享。
离线cityhu
性别:
帅哥
发帖
3484
金币
2688
威望
9
贡献值
乐币
75
好评度
-4
RMB
<私密信息仅自己能看>
只看该作者 7楼 发表于: 2019-09-11
谢谢分享 a+a6P5kJ
离线yyh135m
性别:
帅哥
发帖
1275
金币
2192
威望
贡献值
232
乐币
1227
好评度
9
RMB
<私密信息仅自己能看>
只看该作者 8楼 发表于: 2019-09-11
在线andyhh
性别:
帅哥
发帖
814
金币
766
威望
贡献值
乐币
714
好评度
RMB
<私密信息仅自己能看>
只看该作者 9楼 发表于: 2019-09-11
0(!D1G{ul
离线bidinghong
性别:
帅哥
发帖
10195
金币
16902
威望
3483
贡献值
1484
乐币
13573
好评度
-114
RMB
<私密信息仅自己能看>
只看该作者 10楼 发表于: 2019-09-11
离线ljbhander
性别:
帅哥
发帖
228
金币
117
威望
贡献值
乐币
344
好评度
RMB
<私密信息仅自己能看>
只看该作者 11楼 发表于: 2019-09-11
     ,牛牛牛
离线allegro
性别:
帅哥
发帖
2003
金币
29
威望
44
贡献值
399
乐币
37
好评度
RMB
<私密信息仅自己能看>
只看该作者 12楼 发表于: 2019-09-11
离线kanxue_nmg
性别:
帅哥
发帖
2011
金币
2874
威望
78
贡献值
198
乐币
2792
好评度
RMB
47
<私密信息仅自己能看>
只看该作者 13楼 发表于: 2019-09-11
离线minghuang
性别:
帅哥
发帖
3246
金币
5162
威望
贡献值
26
乐币
2050
好评度
RMB
<私密信息仅自己能看>
只看该作者 14楼 发表于: 2019-09-11
看看怎么样的。
快速回复
限150 字节
上一个 下一个
