发帖 回复
返回列表 提醒:附件不能用迅雷等P2P软件下载,否则直下载失败,文件名变成job.xx网页格式,下载点击一次即可,请勿多次连续点击附件
  • 353阅读
  • 13回复
[VX.2x]英特尔瑞星微SOFIA_3G-R 平板电脑PCB文件共享 [复制链接]
上一主题 下一主题
离线armclub
性别:
帅哥
发帖
1137
金币
5719
威望
贡献值
1578
乐币
6030
好评度
55
RMB
402
<私密信息仅自己能看>
重要提示:本版需2级以上才能下载,有些需购买的帖,若没2级请不要购买,购买也下载不了【可充值秒升级】也可发帖,做任务,签到等升级。若已2级以上,忽略本提示
9Q9{>d#"
lj<Sa
tX^6R
NamePCB DecalPart Type
ANAMON1T-07TP_1_T-07_TEST
B4501RES0402/118BEAD_0_RES0402_BLM18PG181SN1
BAT2BATBATTERY_5_BAT_LI_3.7V
CABC1T-07/2TP_1_T-07_TEST/2
CON501CONN_COAX_SMT_2X2CON4_COAX_2X2_MM4829_0_CONN_COA
CON700MM8030-2600MM8030-2600RJ3_3_MM8030-2600_MM
D1SOD323/2DIODE_SCHOTTKY_SOD323_D1206
D2D1206/3D1206/3
D3SOT23/6BAT54S/SOT_0_SOT23_BAT54S
D4SOD323SOD323
D5D1206/2ZC2800E/SOT_1_D1206_18V
D8D1206ZC2800E/SOT_1_D1206_5.6V
D15A1SOT23/7BAT54S/SOT_0_SOT23_BAT54S/2
D200CMP_419/3CMP_419/3
ED53CMP_419/2TVS_CMP_419_ESD9B5VL
ED6501ESD0402ESD0402
ED6502ESD0402ESD0402
FIL1SAW-5PIN_1_1_0_9_0_5SAFFB881MFL0F0A_0_SAW-5PIN_1_1_
FIL300LFB212G45BJ2D721G35605-001
FIL400SAW-5PIN_11_09_05SAFFB1G58KF0F0A_2_SAW-5PIN_11_0
FIL402DPX16BL1608-05K2450_0_DPX16_DPX16595
FIL501SAW-9PIN_2_0_1_6/2SAW-9PIN_2.0_6.6_SAW-9PIN_2_0_1
FIL502SAW-9PIN_2_0_1_6/3SAW-9PIN_2.0_4.6_SAW-9PIN_2_0_1
FIL503SAW-5PIN_1_1_0_9_0_5/2SAFFB942MFM0F0A_2_SAW-5PIN_1_1_
FIL504SAW-9PIN_2_0_1_6SAW-9PIN_2.0_7.6_SAW-9PIN_2_0_1
GNSS_CYCLE1T-07/5TP_1_T-07_20MIL
J6TF13PINTF_SD_SOCKET_1_TF13PIN_TF_SD_SO
J7FPC6PIN/2CON6_8_FPC6PIN_CON6
J8UART-2CON6_1_UART-2_CON6
J11FPC6PINCON6_5_FPC6PIN_CON6
J12VIB-PADCON2_VIB-PAD_E-PAD
J6401CONN_COAX_SMT_2X2/2CON4_COAX_2X2_MM4829_0_CONN_COA/2
J7001PHONE1PHONE1
J7087C1206/5SPEAKER_C1206_SPEAKER/2
J7088C1206/4SPEAKER_C1206_SPEAKER
J7089C1206/3SPEAKER_0_C1206_MIC/2
J7090C1206/2SPEAKER_0_C1206_MIC
J7091C1206SPEAKER_0_C1206_MOTOR
J8504CON24_1/2CON24_RCPT_CAM_BYT_CR_2_CON24_1
J8505CON24_1CON24_RCPT_CAM_BYT_CR_1_CON24_1
J8506CON24CON24_RCPT_CAM_BYT_CR_1_CON24_C
J9400USB-ST-01H5-CACON5_USB_MICRO_AB_MTG4_1_USB-ST
L2IND-3X3INDUCTOR_1_IND-3X3_4.7UH/2A
L61R0201/2R_R0201_0R
L100L2016/4L_0_L2016_VLS201610CX-1R0M/2
L101L2016/3L_0_L2016_VLS201610CX-1R0M
L260L0603/3L0603/3
L261L0603/2L0603/2
L262L0603L0603
L263RES0402/115RES0402/115
L311RES0402/114INDCT_6_0.8NH_3%_300MA_0201_RES
L404RES0402/36RESISTOR_0_RES0402_DNP
L405RES0402/34RESISTOR_0_RES0402_0R/2
L408R0201/3R_R0201_10NH
L503IND0201/18IND_IND0201_1.6NH/2
L504IND0201/16IND_IND0201_1.4NH
L505IND0201/18IND_IND0201_1.6NH/2
L506IND0201/16IND_IND0201_1.4NH
L507IND0201/15IND_IND0201_4.3NH
L508IND0201/15IND_IND0201_4.3NH
L510IND0201/14IND_IND0201_9.1NH
L511IND0201/13IND_IND0201_3.4NH
L512IND0201/12RESISTOR_IND0201_12NH
L513IND0201/19IND_IND0201_2.6NH
L514IND0201/19IND_IND0201_2.6NH
L515IND0201/17IND_IND0201_1.6NH
L516IND0201/17IND_IND0201_1.6NH
L517IND0201/11RESISTOR_IND0201_4.3NH
L518IND0201/10IND_IND0201_3.9NH
L519IND0201/9INDUCTOR_IND0201_6.8NH
L520IND0201/8IND_IND0201_12NH
L521IND0201/7IND_IND0201_3.2NH
L522IND0201/6IND_IND0201_6.2NH
L523IND0201/5IND_IND0201_3.0NH
L524IND0201/4CAP_NP_IND0201_6.8NH
L527IND0201/3CAP_NP_IND0201_5PF
L529IND0201/2RESISTOR_IND0201_0R
L530IND0201RESISTOR_IND0201_1.2NH/DNP
L531L2016/3INDUCTOR_2_L2016_VLS201610HBX-1/3
L532L2016/2INDUCTOR_2_L2016_VLS201610HBX-1/2
L533L2016INDUCTOR_2_L2016_VLS201610HBX-1
L534L2520/3INDUCTOR_2_L2520_VLS252010HBX-R/3
L540IND-4X4INDCT_PWR_2525_8A_2_0.2UH_IND-4
L541R0201/21R_R0201_10NH/2
L542R0201/22R_R0201_DNP/10NH
L543R0201/9R_R0201_0R/4
L559L2520/2INDUCTOR_2_L2520_VLS252010HBX-R/2
L560L2520INDUCTOR_2_L2520_VLS252010HBX-R
L9000SML_4P_43X53_CM_P35HCHOKE_4PIN_ALT_SML_4P_43X53_CM_
LEDDRV1T-07/4TP_1_T-07_TEST/3
PB1PTC0703B/3PTC0703B_PTC0703B_PTC0703B/3
Q6SOT2340852_1_SOT23_8050
Q11SOT23/8SOT23/8
Q12SOT23/4SOT23/4
Q6105SOT_23/2SOT_23/2
Q6106SOT_23NPN_SOT_23_8050
U4SOT26/2G5121_SOT26_TCS3358
U6QFN10_2R000X2R000X0R850SY6822_QFN10_2R000X2R000X0R850_
U20BAG14-16X16AK8975C_0_BAG14-16X16_AK8963C
U46AW8155AW_AW8155FCR_0_AW8155_AW8155FCR
U47AW8155/2AW_AW8155FCR_0_AW8155_AW8155FCR/2
U402RFDIP1608060TM7T62RDALN16_RFDIP1608060TM7T62_RDAL
U501SKY77589SKY77589_8_SKY77589_SKY77589
U503SKY77761/2SKY77768_2_SKY77761_SKY77768
U504SKY77761SKY77761_2_SKY77761_SKY77761
U507QFN68-7X7RK818_5_QFN68-7X7_RK818
U509SOT26RT8514GJ6_0_SOT26_MP1488/PT4117
U51010PIN_DFN_2X2MMA8653FC_0_10PIN_DFN_2X2_DNP/M
U1300TMD2771CM36682_0_TMD2771_TMD2771
U4902B-168P_12X12LPDDR2-32_3_B-168P_12X12_LPDDR2
U5702TSOP1-48NANDFLASH_0_TSOP1-48_NAND_FLASH
U6501SOT_23ESD_ESDA6V8UL_SOT_23_ESD5302F
U8001LCC16_NS_P5MM_SQ3MM_1P01HKXCJK_0_LCC16_NS_P5MM_SQ3MM_1P0
U8401IROCK21X21_05PITCHSOFIA_3G-R_ES1_1.0_IROCK21X21_0
U9012FPC40-PIN140PIN_5_FPC40-PIN1_40PIN
U9013GT91140PIN_3_GT911_GT911
U9014CONN45PIN40PIN_4_CONN45PIN_GT911
U9018A-GOLD620A-GOLD620_7_A-GOLD620_A-GOLD620
U9019BGA169EMMC_FLASH_169_BGA169_EMMC_FLAS
X400CRY-D2016CN2+4_9_CRY-D2016_NT2016SA-38.4
X800CM7V-T1AOSC_4_4_CM7V-T1A_32.768KHZ_CM7V
Y1CRY-MC146CRYSTAL_1_CRY-MC146_32.768K
Y1501CRY4_3R20X2R50X0R80CRYSTAL_4P_CRY4_3R20X2R50X0R80_
?M:>2wl
a"@f< wU~
评价一下你浏览此帖子的感受
精彩
感动
搞笑
愤怒
一般
差劲
您的支持和精彩回复,就是我坚持的动力
离线armclub
性别:
帅哥
发帖
1137
金币
5719
威望
贡献值
1578
乐币
6030
好评度
55
RMB
402
<私密信息仅自己能看>
只看该作者 1楼 发表于: 2019-10-08
PCB是ALLEGRO转换过来的。 所以有不少错误。仅供参考。 a,vS{434J
ZEI,9`t!
回复可见 zw+aZDcV(
本部分内容设定了隐藏,需要回复后才能看到(回复后还看不到就刷新一下即可)
wv3,% lN
您的支持和精彩回复,就是我坚持的动力
在线ortai
性别:
人妖
发帖
49
金币
128
威望
贡献值
乐币
好评度
RMB
<私密信息仅自己能看>
只看该作者 2楼 发表于: 2019-10-08
好想快點升級 <:&vAX L
可以參考大大的線路板
在线wy123
性别:
人妖
发帖
74
金币
61
威望
贡献值
18
乐币
1281
好评度
RMB
34
<私密信息仅自己能看>
只看该作者 3楼 发表于: 2019-10-08
回 armclub 的帖子
armclub:PCB是ALLEGRO转换过来的。 所以有不少错误。仅供参考。
回复可见 x`CjFaE~F
[内容隐藏] 6Z\aJ
 (2019-10-08 21:22)  sJHVnMA
t;O)
有没allegro源档文件分享一下
离线地沟油
性别:
人妖
发帖
4904
金币
3021
威望
100
贡献值
124
乐币
4658
好评度
RMB
<私密信息仅自己能看>
只看该作者 4楼 发表于: 2019-10-08
离线学海无涯
性别:
帅哥
发帖
4097
金币
6052
威望
贡献值
67
乐币
6022
好评度
-2
RMB
<私密信息仅自己能看>
只看该作者 5楼 发表于: 2019-10-09
高级货,厉害。
在线cdl511
性别:
帅哥
发帖
5062
金币
1970
威望
16
贡献值
25
乐币
2107
好评度
RMB
<私密信息仅自己能看>
只看该作者 6楼 发表于: 2019-10-09
看看啦,谢谢分享
离线电子宅
性别:
人妖
发帖
3431
金币
1962
威望
1387
贡献值
566
乐币
17
好评度
RMB
<私密信息仅自己能看>
只看该作者 7楼 发表于: 2019-10-09
多谢分享。
在线bidinghong
性别:
帅哥
发帖
10175
金币
16855
威望
3483
贡献值
1484
乐币
13548
好评度
-114
RMB
<私密信息仅自己能看>
只看该作者 8楼 发表于: 2019-10-09
在线bidezhi7777
性别:
帅哥
发帖
6310
金币
74
威望
贡献值
676
乐币
好评度
RMB
40
<私密信息仅自己能看>
只看该作者 9楼 发表于: 2019-10-09
离线zheshiwo
性别:
帅哥
发帖
1965
金币
411
威望
1086
贡献值
394
乐币
296
好评度
RMB
132
<私密信息仅自己能看>
只看该作者 10楼 发表于: 2019-10-10
多多学习!
离线zqb
性别:
帅哥
发帖
641
金币
720
威望
贡献值
乐币
548
好评度
RMB
<私密信息仅自己能看>
只看该作者 11楼 发表于: 2019-10-10
学习一下
离线wuzhihua2
性别:
人妖
发帖
25
金币
121
威望
贡献值
乐币
好评度
RMB
<私密信息仅自己能看>
只看该作者 12楼 发表于: 2019-11-30
)9,
在线mikewen
性别:
帅哥
发帖
1531
金币
2448
威望
贡献值
乐币
2609
好评度
RMB
<私密信息仅自己能看>
只看该作者 13楼 发表于: 01-21
快速回复
限150 字节
上一个 下一个
