:D\M.A
Industry Standard Serial Interface rF'_YYpr>
- IS25WP064A: 64Mbit/8Mbyte \Z{6j&;
- 256 bytes per Programmable Page ,9SBGxK5`
- Supports standard SPI, Fast, Dual, Dual 2f2Vy:&O_
I/O, Quad, Quad I/O, SPI DTR, Dual I/O {ZP0%MD
DTR, Quad I/O DTR, and QPI ^`XQ>-wWue
- Supports Serial Flash Discoverable ]|KOc& y:I
Parameters (SFDP) 0<d9al|J
High Performance Serial Flash (SPI) Ka%u#};
- 50MHz Normal and 133Mhz Fast Read (S3\O `5
- 532 MHz equivalent QPI <$7HX/P
- DTR (Dual Transfer Rate) up to 66MHz 7:awUoV8f
- Selectable Dummy Cycles #;4<dDVy
- Configurable Drive Strength >NwS0j$j@
- Supports SPI Modes 0 and 3 >c
%*:a
- More than 100,000 Erase/Program Cycles k]K][[s`
- More than 20-year Data Retention C^oj/}^
Flexible & Efficient Memory Architecture =BW;n]ls
- Chip Erase with Uniform: Sector/Block r{R879
Erase (4/32/64 Kbyte) O~D>F*_^j
- Program 1 to 256 Bytes per Page L?:.8k`d
- Program/Erase Suspend & Resume g-)izPX
Efficient Read and Program modes hA 1_zKZ
- Low Instruction Overhead Operations ~U"puEftbs
- Continuous Read 8/16/32/64-Byte Burst 4}-{sS}MP
Wrap i286 J.
- Selectable Burst Length h]WPWa)M
- QPI for Reduced Instruction Overhead ^k{b8-)W<
- AutoBoot Operation )zn`qaHK@e
Low Power with Wide Temp. Ranges '9@} =pE
- Single 1.65V to 1.95V Voltage Supply G)5R
iRcs
- 4 mA Active Read Current (typ.) w1>uD]
- 8 µA Standby Current (typ.) `_"F7Czn
- 1 µA Deep Power Down (typ.) iR(=<>
- Temp Grades: 8);G'7O
Extended: -40°C to +105°C -(~OzRfYi
Auto Grade (A3): -40°C to +125°C :]]#X
~J
Advanced Security Protection B L^?1x
- Software and Hardware Write Protection %BBM%Lj
- Power Supply Lock Protection vT1StOx<V
- 4x256-Byte Dedicated Security Area Kd,8PV*_
with OTP User-lockable Bits Y8l
8B>
- 128 bit Unique ID for Each Device MuI>ZoNF
(Call Factory) d-%bRGo/
Industry Standard Pin-out & Packages(1) 4{zz-4=
- M =16-pin SOIC 300mil {~*^jS']5
- B = 8-pin SOIC 208mil ,ICn]Pdz@
- T = 8-contact USON 4x3mm xOY
%14%Y
- K = 8-contact WSON 6x5mm LZR
x>q^
- L = 8-contact WSON 8x6mm (Call Factory) B:X,vE
- G= 24-ball TFBGA 4x6 ARRAY r%=} e++^%
- H = 24-ball TFBGA 5x
