[Pads_VX.2x] 首发MTK8380 MT8380(MT8370) 智能手机PCB和原理图共享
查看6095 | 回复51 | 2020-9-23 10:49:47 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
NamePCB DecalValuePart Type
ANT1ELJ_SOLDERING_ANTPADAELJ_SOLDERING_ANTPAD
ANT3301ELJ_SOLDERING_ANTPADNCELJ_SOLDERING_ANTPAD
ANT5101ELJ_M08M001-G0G000-WA035R_TP_H3.5_W3.0POGO PINELJ_M08M001-G0G000-WA025R_W1.2L2.7H2.5
ANT5102ELJ_M08M001-G0G000-WA035R_TP_H3.5_W3.0POGO PINELJ_M08M001-G0G000-WA025R_W1.2L2.7H2.5
BEAD1L0402BLM15BD102SN1DBEAD-0402
BEAD6004B0603BLM18BB750SN1B0603-75R
CN6001ELJ_05-0521132-B_USB-CB0.8ELJ_05-0521132-B_USB-CB0.8ELJ_05-0521132-B_USB-CB0.8
CON1MM4829-2702BMHC-310CON-RF-TEST-MM4829-2702B-MURATA
CON3ELJ_YHTKP-1915-W_PHS_H1.9YHTKP-1915-CELJ_YHTKP-1915-W_PHS_H1.9
CON3101MM4829-2702BMHC-310CON-RF-TEST-MM4829-2702B-MURATA
D302SOD323/SMD/MM3Z2V4T1PZ3D4V2H (PRISEMI)TVS-6V2-PZ3D4V2H-ROHM
D2002EMD2-SOD523NC RB520S30RB520S30
D6101SOD123MM1Z5VDIODE_SCHOTTKY_2
D6102SOT23_3BAT54SBAT54S
D6103SOD123MM1Z20VDIODE_SCHOTTKY_2
D6104SOD1231N5819DIODE_SCHOTTKY_2
D6108SOT23_3BAT54SBAT54S
D6109SOD1231N5819DIODE_SCHOTTKY_2
D6201ELJ_EFD3-G9CA/EFC3A-P3CA_2.04X1.64_H0.75ELJ_EFD3-G9CA_2.04X1.64_H0.75
D6202ELJ_EFD3-G9CA/EFC3A-P3CA_2.04X1.64_H0.75ELJ_EFD3-G9CA_2.04X1.64_H0.75
EMI6401FILTER/SMD/TCM0806GDLP0NSC280HL2EMIX21A390FNPE_1
F201DIPLEXER/6P/SMD/DP1608DIPLEXER/6P/SMD/DP1608
FB101L02011K/100mAL0201
H1NC_PTH_HOLE_1.6/3.5MMAANC_PTH_HOLE_1.6/3.5MM
H2NC_PTH_HOLE_1.6/3.5MMNC_PTH_HOLE_1.6/3.5MM
H3NC_PTH_HOLE_1.6/3.5MMNC_PTH_HOLE_1.6/3.5MM
J1ELJ-KS270013ELJ-KS270013
J2RF_TEST_PAD_4MM_ANCRFCON-4MM_A
J3ELJ-KS270013ELJ-KS270013
J102ELJ_HC503-6R-GF_PJ_0.5_H1.0HC503-6R-GFELJ_HC503-6R-GF_PJ_0.5_H1.0
J108ELJ_BAR080T028-NYZ_2P-0.8JP-H1.85NCELJ_BAR080T028-NYZ_2P-0.8JP-H1.85
J109ELJ_BAR080T028-NYZ_2P-0.8JP-H1.85NCELJ_BAR080T028-NYZ_2P-0.8JP-H1.85
J301ELJ-BAT1254001-05YZ_5PIN-1.25JP-H1.9BAT-5PIN-1.25JP-H1.9ELJ-BAT1254001-05YZ_5PIN-1.25JP-H1.9
J601ELJ_PH10-3B05F35B__H2.8ELJ_PH10-3B05F35B_H2.8
J901ELJ_HC503-6R-GF_PJ_0.5_H1.0HC503-6R-GFELJ_HC503-6R-GF_PJ_0.5_H1.0
J2001NC_BAT_CON_3NCNC_BAT_CON_3
J6002ELJ_BAR080T028-NYZ_2P-0.8JP-H1.85NCELJ_BAR080T028-NYZ_2P-0.8JP-H1.85
J6003REC1206NCREC_1206
J6004ELJ_BAR080T028-NYZ_2P-0.8JP-H1.85NCELJ_BAR080T028-NYZ_2P-0.8JP-H1.85
J6101ELJ_0.5-H1.5-30P_ZIF_30PIN_H1.5ELJ_0.5-H1.5-30P_ZIF_30PIN_H1.5ELJ_0.5-H1.5-30P_ZIF_30PIN_H1.5
J6202ELJ_FH26-31S-0.3SHW_ZIF_PH0.6_H1.0ELJ_FH26-31S-0.3SHW_ZIF_PH0.6_H1.0
J6203ELJ_FH26_L_25S_0.3SHW-AFH26ELJ_FH26_L_25S_0.3SHW-A
J6502ELJ_SA-1505-001_SIM_H1.5_QMYELJ_SA-1505-001_SIM_H1.5ELJ_SA-1505-001_SIM_H1.5_QMY
J6503ELJ_SA-1505-001_SIM_H1.5_QMYELJ_SA-1505-001_SIM_H1.5ELJ_SA-1505-001_SIM_H1.5_QMY
J6701ELJ_FH26-31S-0.3SHW_ZIF_PH0.6_H1.0ELJ_FH26-31S-0.3SHW_ZIF_PH0.6_H1.0
L8L/IND/SMD/2520WPN252012H1R5MTL/IND/SMD/2520
L9L0201L / 7.5/ nH / 0402L0201
L201L040222nHL0402
L202L0402NCL0402
L203L040222nHL0402
L205L040222nHL0402
L210L/IND/SMD/25204.7UHL/IND/SMD/2520
L211BEAD0402BLM15AG601SN1BEAD0402
L212BEAD0402BLM15AG601SN1BEAD0402
L213BEAD0402BLM15AG601SN1BEAD0402
L215L/IND/SMD/25204.7UHL/IND/SMD/2520
L6102LCDBACKLIGHT_L_4_4SWPA4018S100MTELLVFG-C_1.4_3.2
MARK1MARK_ALLMARK_ALL
MARK2MARK_ALLMARK_ALL
MARK3MARK_ALLMARK_ALL
MARK4MARK_ALLMARK_ALL
NTC6301R0402NCP15WF104F03RCR0402-NCP15WF104F03RC
Q6101SC-75_SOT-416_DTC114EET1-DNC DTC114YET1SC-75_SOT-416_DTC114EET1-D
Q6102SC-75_SOT-416_DTC114EET1-DNC DTC114YET1SC-75_SOT-416_DTC114EET1-D
Q6103SOT23_3WPM2026IRF5210/TO_6
Q6104SOT23_3MMBT3904NPN_BEC
Q6201SC-75_SOT-416_DTC114EET1-DNC DTC114YET1SC-75_SOT-416_DTC114EET1-D
R702NC_RFSHORTNCNC_RFSHORT
R1003SHORT-R0603SHORT / 0603SHORT-R0603
R1004SHORT-R0603SHORT / 0603SHORT-R0603
R1006CON-PAD-DOTNCCON-PAD-DOT
R1007CON-PAD-DOTNCCON-PAD-DOT
RJ5NC_SHORT_0402NCNC_SHORT_0402
SH2001CON-PAD-DOTNCCON-PAD-DOT
SH6100NC_SHORT_0402NC_SHORT_0402
SH6101NC_SHORT_0402NC_SHORT_0402
U2SAW-SAYRF1G73CA0F0A-2016-1814SAYFP1G95CA0B00SAW-SAYRF1G73CA0F0A-2016-1814
U3CP2155NC CP2155DN10-A1CP2155
U4SAW-SAYRF1G73CA0F0A-2016-1814SAYFP1G95CA0B00SAW-SAYRF1G73CA0F0A-2016-1814
U5SAW-SAYRF1G73CA0F0A-2016-1814SAYFP1G95CA0B00SAW-SAYRF1G73CA0F0A-2016-1814
U6SOT23-5NC/WL2003E33WL2003E
U10SKY77186SKY77762SKY77701_0
U14SKY77186SKY77765SKY77701_0
U15MAX2659MAX2659ELTIC-GPS-LNAP-MAX2659-MAXIM
U20TLE4917-TSOP-6-2NCTLE4917-TSOP-6-2
U105ELJ_DTV_SMT_EW100_6.9X6.9X1MMELJ_DTV_SMT_EW100_6.9X6.9X1MM
U201SOT23_5WD1013EA/TCS4150-ETCS4150-E
U203SOT23_5WD1013EA/TCS4150-ETCS4150-E
U604B8731TDK/B8731B8731
U605SKY77186SKY77761SKY77701_0
U701FAN54015ETA6937CSUFAN54015
U1001MT8380/TFBGA520/P0.4/B0.25/10.2X11U / MT8380MT8380/TFBGA520/P0.4/B0.25/10.2X11
U1002AW8736FCRAW8736FCRAW8736FCR
U1003AW8736FCRAW8736FCRAW8736FCR
U1006SAFEB1G57KE0F00NC SAFEB1G57KE0F00IC-SAW-SAFEB1G57KE0F00-MURATA
U110126M_TCXO_2520TC7L26002015_2016L26421TCXO / 26 / MHz / IT2205AE26M_TCXO_2520TC7L26002015_2016L26421
U1601BMA250NC(BMA250)IC-3-A-ACCELEROMETER-BMA250-BOSCH
U1703BGA169/P0.5/B0.27/THGBM1GXDXEBAI/TOSHIBAQVL Memory / NCBGA169/P0.5/B0.27/THGBM1GXDXEBAI/TOSHIBA
U2001MT6350/VFBGA145/P0.4/B0.25/5.8X5.8MT6350MT6350/VFBGA145/P0.4/B0.25/5.8X5.8
U3101SKY77590SKY77590PA_/_SKY77590_0
U4102FBGA178/SMD/B0.4/3-IN-1LPDDR3 178bFBGA178/SMD/B0.4/3-IN-1
U6101SOT23_6EUP2530/CP2123ST-B1AP3031_0
U6103SOT23_6CP2121ST-B2/TCS23352AP3031_0
U6201CP2155NC CP2155DN10-A1CP2155
U6301MMC3630KJMMC3630KJ
U6302CLI_MPU5400_GYROSCOPE_0.4PTH_3X3X0.9MMCLI_MPU5400_Gyroscope_0.4PTH_3X3X0.9MMCLI_MPU5400_GYROSCOPE_0.4PTH_3X3X0.9MM
U6701SCL1680-ICMULTI-TOUCHGSL1680
VR5ELJ_TVSESD9X5VL-2_SOD-923_H0.45ELJ_TVSESD9X5VL-2_SOD-923_H0.45ELJ_TVSESD9X5VL-2_SOD-923_H0.45
VR301R0402SFI0402-180E10RPP-LFVAR_0402
VR302R0402SFI0402-180E10RPP-LFVAR_0402
VR408MLV0402ESD9B5VVAR_0402
VR409MLV0402ESD9B5VVAR_0402
VR410MLV0402ESD9B5VVAR_0402
VR411R0402ESD9B5VVAR_0402
VR2003SOD323/SMD/MM3Z2V4T1NC ESD56131WPTVSHC3D4V5B
VR6403ELJ_TVSESD9X5VL-2_SOD-923_H0.45ESD9X5VL-2/TRELJ_TVSESD9X5VL-2_SOD-923_H0.45
VR6404ELJ_TVSESD9X5VL-2_SOD-923_H0.45ESD9X5VL-2/TRELJ_TVSESD9X5VL-2_SOD-923_H0.45
VR6405ESD5641D07NC ESD5641D07ESD5641D07
VR6514R0402ESD9B5VVR0402
VR6515R0402NCVR0402
VR6516R0402ESD9B5VVR0402
X60026M_TCXO3225_2520_7M26000028_DSA26MHz  / 7M2600002826M_TCXO3225_2520_7M26000028_DSA
Z3101BALUN/10P/SMD/BD2012BAL / RFBLN2012090BM5T25BAL_/_RFBLN2012090BM5T25
重要提示:PCB作品文件展下载说明
老吴 | 2020-9-23 10:52:38 | 显示全部楼层
这是V2版本PCB和原理图。 V3版本在这里 http://bbs.ntpcb.com/read-htm-tid-163621.html
这个资料网上基本上影子都没有。销售10RMB 。下载请勿发网上,否则封号处理。
MTK8380_V2.zip (3.86 MB, 下载次数: 31)
yfchen1003 | 2020-9-23 11:15:48 | 显示全部楼层
这个定位平板吧,还在用LPDDR3 178球的, 手机一般都是合并DDR+FLASH, 用EMCP这种
木子清风 | 2020-9-23 11:48:57 | 显示全部楼层
bingo426 | 2020-9-23 12:23:27 | 显示全部楼层
最后成功的人往往不是最有才华的人,而是那些默默付出直到最后一刻也不放弃的那些人!
小小路人甲 | 2020-9-23 13:48:32 | 显示全部楼层
mirage | 2020-9-23 13:49:29 | 显示全部楼层
tomtang | 2020-9-23 16:08:21 | 显示全部楼层
luchonghui74 | 2020-9-23 17:58:27 | 显示全部楼层
zhang00963 | 2020-9-23 21:57:51 | 显示全部楼层
