#include "24l01.h" @SX%?
mk8G
#include "delay.h" ]9bh+
#include "spi.h" 2<`gs(oxXe
qg) Af
WM~J,`]J
const u8 TX_ADDRESS[TX_ADR_WIDTH]={0x34,0x43,0x10,0x10,0x01}; //发送地址 Requ.?!fG;
const u8 RX_ADDRESS[RX_ADR_WIDTH]={0x34,0x43,0x10,0x10,0x01}; //发送地址 iKR8^sj7S
A>rW Go.{E
//初始化24L01的IO口 NgDZ4&L
void NRF24L01_Init(void) _47j9m]f
{ TWl(\<&+)
RCC->APB2ENR|=1<<2; //使能PORTA口时钟 xCmI7$uQ#
RCC->APB2ENR|=1<<4; //使能PORTC口时钟 vV$hGS(f~
GPIOA->CRL&=0XFFF0000F; //PA2,3,4输出,PA1输入 8`R +y
GPIOA->CRL|=0X00033380; ?=pZmvQg
GPIOA->ODR|=0XF<<1; //PA1.2.3.4 输出1 yg-L^`t+B5
GPIOC->CRL&=0XFFF0FFFF; //PC4输出 h^.tomg8
GPIOC->CRL|=0X00030000; ^Yg|P&e(;
GPIOC->ODR|=1<<4; //上拉 a:(: :m
SPI1_Init(); //初始化SPI $?CBX27AV
//针对NRF的特点修改SPI的设置 ai<MsQQ:=
SPI1->CR1&=~(1<<6); //SPI设备失能 ebl)6C
SPI1->CR1&=~(1<<1); //空闲模式下SCK为0 CPOL=0 Y ;~~?[6
SPI1->CR1&=~(1<<0); //数据采样从第1个时间边沿开始,CPHA=0 rU2YMghE
SPI1->CR1|=1<<6; //SPI设备使能 (}/.4xE
NRF24L01_CE=0; //使能24L01 [F BCz>
NRF24L01_CSN=1; //SPI片选取消 zx_O"0{5
Y7W1$he
//检测24L01是否存在 76u/WC>B
//返回值:0,成功;1,失败 3_R
u8 NRF24L01_Check(void) #buV;!_!E?
{ ]iE.fQ?;J
u8 buf[5]={0XA5,0XA5,0XA5,0XA5,0XA5}; ~t.WwxY+
u8 i; :!Y?j{sGU
SPI1_SetSpeed(SPI_SPEED_8); //spi速度为9Mhz(24L01的最大SPI时钟为10Mhz) JYVxdvq1
NRF24L01_Write_Buf(NRF_WRITE_REG+TX_ADDR,buf,5);//写入5个字节的地址. N c&i) qh
NRF24L01_Read_Buf(TX_ADDR,buf,5); //读出写入的地址 ]Lb?#S
for(i=0;i<5;i++)if(buf!=0XA5)break; Wzf1-0t
if(i!=5)return 1;//检测24L01错误 ~T p8>bmSR
return 0; //检测到24L01 :DJ7d
} ="'P=Xh!8
//SPI写寄存器 BC$;b>IUA
//reg:指定寄存器地址 G2[IO $
//value:写入的值 *]E7}bqb
u8 NRF24L01_Write_Reg(u8 reg,u8 value) 4/-))F&s
{ #?b^B~ #
u8 status; 0F0Q=dZ
NRF24L01_CSN=0; //使能SPI传输 4,*^QK
status =SPI1_ReadWriteByte(reg);//发送寄存器号 6yl;o_6:
SPI1_ReadWriteByte(value); //写入寄存器的值 %t5BB$y
NRF24L01_CSN=1; //禁止SPI传输 zb~MF_ &gE
return(status); //返回状态值 -'p@ lk
} 5shu76
//读取SPI寄存器值 A 4W
//reg:要读的寄存器 E;GR;i{t
u8 NRF24L01_Read_Reg(u8 reg) L->f=
8L
{ SJ WP8+
u8 reg_val; ]ZryY
EB
NRF24L01_CSN = 0; //使能SPI传输 #@\NdW\
SPI1_ReadWriteByte(reg); //发送寄存器号 XnI
;7J
reg_val=SPI1_ReadWriteByte(0XFF);//读取寄存器内容 ~&j`9jdOj
NRF24L01_CSN = 1; //禁止SPI传输 fO|~Oz<S
return(reg_val); //返回状态值 fj
t_9-.
} ,O&PLr8cJ?
//在指定位置读出指定长度的数据 ]Re~V{uh
//reg:寄存器(位置) C +?@iMh
//*pBuf:数据指针 mP$G9R
//len:数据长度 U3j~}H.D1
//返回值,此次读到的状态寄存器值 c]>&6-;rf
u8 NRF24L01_Read_Buf(u8 reg,u8 *pBuf,u8 len) >2Qqa;nx|
{ ID)gq_k[8,
u8 status,u8_ctr; :kiO
NRF24L01_CSN = 0; //使能SPI传输 y!6:
status=SPI1_ReadWriteByte(reg);//发送寄存器值(位置),并读取状态值 4{pemqS*
for(u8_ctr=0;u8_ctr<len;u8_ctr++)pBuf[u8_ctr]=SPI1_ReadWriteByte(0XFF);//读出数据 dj'8x48H2W
NRF24L01_CSN=1; //关闭SPI传输 j'40>Ct=i
return status; //返回读到的状态值 h3d\MYO)B
} noUZ9M|hz
//在指定位置写指定长度的数据 K%TKQ<R|
//reg:寄存器(位置) [ls ?IFg
//*pBuf:数据指针 )x:j5{>(
//len:数据长度 k@";i4}A
//返回值,此次读到的状态寄存器值 C}P
\kDM
u8 NRF24L01_Write_Buf(u8 reg, u8 *pBuf, u8 len) 5 *pN<S
{ aEqI51I
u8 status,u8_ctr; !|:q@|-
NRF24L01_CSN = 0; //使能SPI传输 ;`PkmAg
status = SPI1_ReadWriteByte(reg);//发送寄存器值(位置),并读取状态值 JJHvj=9'o
for(u8_ctr=0; u8_ctr<len; u8_ctr++)SPI1_ReadWriteByte(*pBuf++); //写入数据 Y\z\{JW
NRF24L01_CSN = 1; //关闭SPI传输 GWqY$YT
return status; //返回读到的状态值 F/od,w9_
} FPUR0myCU
//启动NRF24L01发送一次数据 B%g :Z
//txbuf:待发送数据首地址 zI:5I @ X
//返回值:发送完成状况 #HuA(``[d
u8 NRF24L01_TxPacket(u8 *txbuf) B?ob{K@
{ WKIiJ{@L
u8 sta; 7fTg97eF
SPI1_SetSpeed(SPI_SPEED_8);//spi速度为9Mhz(24L01的最大SPI时钟为10Mhz) ,f0g|5yDf
NRF24L01_CE=0; qD%&\ZT
NRF24L01_Write_Buf(WR_TX_PLOAD,txbuf,TX_PLOAD_WIDTH);//写数据到TX BUF 32个字节 $E,DxDT
NRF24L01_CE=1;//启动发送 %FWfiFV|<
while(NRF24L01_IRQ!=0);//等待发送完成 ]|LaMMD
sta=NRF24L01_Read_Reg(STATUS); //读取状态寄存器的值 YG1`%,OW`
NRF24L01_Write_Reg(NRF_WRITE_REG+STATUS,sta); //清除TX_DS或MAX_RT中断标志 S}[:;p?F`
if(sta&MAX_TX)//达到最大重发次数 Nx (pJp{S
{ gL}Y5U+s
NRF24L01_Write_Reg(FLUSH_TX,0xff);//清除TX FIFO寄存器 8(/f!~
return MAX_TX; #M^Yh?~%w
} ;$L!`"jn
if(sta&TX_OK)//发送完成 ;ld~21#m
{ {ZM2WFpE
return TX_OK; RGA*7
} -zLI!F 0
return 0xff;//其他原因发送失败 v?TJ!o
} s&`XK$p
//启动NRF24L01发送一次数据 YB3=ij!K
//txbuf:待发送数据首地址 8Gg/M%wq9U
//返回值:0,接收完成;其他,错误代码 EbYH?hPo
u8 NRF24L01_RxPacket(u8 *rxbuf) VrE5^\k<a
{ y^46z(I
u8 sta; Cl.T'A$
SPI1_SetSpeed(SPI_SPEED_8); //spi速度为9Mhz(24L01的最大SPI时钟为10Mhz) j"sO<Q{6%
sta=NRF24L01_Read_Reg(STATUS); //读取状态寄存器的值 h5JwB<8
NRF24L01_Write_Reg(NRF_WRITE_REG+STATUS,sta); //清除TX_DS或MAX_RT中断标志 })SdaZ
if(sta&RX_OK)//接收到数据 )$4DH:WN
{ "3 oU
(RA
NRF24L01_Read_Buf(RD_RX_PLOAD,rxbuf,RX_PLOAD_WIDTH);//读取数据 1`_)%Y[ZJ
NRF24L01_Write_Reg(FLUSH_RX,0xff);//清除RX FIFO寄存器 &FF. Ddt{
return 0; {bW3%iU
} Z:$b)+2:\
return 1;//没收到任何数据 ,wo"(E!4e
} }Q^a.`h
//该函数初始化NRF24L01到RX模式 |B$\3,
//设置RX地址,写RX数据宽度,选择RF频道,波特率和LNA HCURR \` ^Tbn:
//当CE变高后,即进入RX模式,并可以接收数据了 }/r%~cZ
void NRF24L01_RX_Mode(void) W8h\ s {
{ gbf=H8]
NRF24L01_CE=0; p}7&x[fTLk
NRF24L01_Write_Buf(NRF_WRITE_REG+RX_ADDR_P0,(u8*)RX_ADDRESS,RX_ADR_WIDTH);//写RX节点地址 xi. KD
{1DYXKe
NRF24L01_Write_Reg(NRF_WRITE_REG+EN_AA,0x01); //使能通道0的自动应答 rK)
NRF24L01_Write_Reg(NRF_WRITE_REG+EN_RXADDR,0x01); //使能通道0的接收地址 ld?.o/
NRF24L01_Write_Reg(NRF_WRITE_REG+RF_CH,40); //设置RF通信频率 "$pgmf2
NRF24L01_Write_Reg(NRF_WRITE_REG+RX_PW_P0,RX_PLOAD_WIDTH);//选择通道0的有效数据宽度 }/0dfes
NRF24L01_Write_Reg(NRF_WRITE_REG+RF_SETUP,0x0f); //设置TX发射参数,0db增益,2Mbps,低噪声增益开启 azc:C
NRF24L01_Write_Reg(NRF_WRITE_REG+CONFIG, 0x0f); //配置基本工作模式的参数;PWR_UP,EN_CRC,16BIT_CRC,接收模式 V>92/w.fe
NRF24L01_CE = 1; //CE为高,进入接收模式 :=eUNH
} kK|+W,
//该函数初始化NRF24L01到TX模式 xF|*N<9(</
//设置TX地址,写TX数据宽度,设置RX自动应答的地址,填充TX发送数据,选择RF频道,波特率和LNA HCURR {leG~[d
//PWR_UP,CRC使能 " z'!il#
//当CE变高后,即进入RX模式,并可以接收数据了 'k Z1&_{
//CE为高大于10us,则启动发送. mxA )r5sx
void NRF24L01_TX_Mode(void) 0w. _}Cz
{ i4rF~'h@
NRF24L01_CE=0; NP*0WT_gB
NRF24L01_Write_Buf(NRF_WRITE_REG+TX_ADDR,(u8*)TX_ADDRESS,TX_ADR_WIDTH);//写TX节点地址 E2kRt'~N
NRF24L01_Write_Buf(NRF_WRITE_REG+RX_ADDR_P0,(u8*)RX_ADDRESS,RX_ADR_WIDTH); //设置TX节点地址,主要为了使能ACK ,x.)L=Cx8
?+=|{{l
NRF24L01_Write_Reg(NRF_WRITE_REG+EN_AA,0x01); //使能通道0的自动应答 beZ| i 1:
NRF24L01_Write_Reg(NRF_WRITE_REG+EN_RXADDR,0x01); //使能通道0的接收地址 yLOLv6g~e
NRF24L01_Write_Reg(NRF_WRITE_REG+SETUP_RETR,0x1a);//设置自动重发间隔时间:500us + 86us;最大自动重发次数:10次 H5 hUY'O
NRF24L01_Write_Reg(NRF_WRITE_REG+RF_CH,40); //设置RF通道为40 Yb{t!KL
NRF24L01_Write_Reg(NRF_WRITE_REG+RF_SETUP,0x0f); //设置TX发射参数,0db增益,2Mbps,低噪声增益开启 nn%xN\~<
NRF24L01_Write_Reg(NRF_WRITE_REG+CONFIG,0x0e); //配置基本工作模式的参数;PWR_UP,EN_CRC,16BIT_CRC,接收模式,开启所有中断 !T. @
NRF24L01_CE=1;//CE为高,10us后启动发送 K({,]<l5
} Lta\AN!c
*S_Iza #&x
}8#Czo jt
[`\Qte%UH
Vnb#N4vR
IuW10}"9
(C@@e'e
F
&}V65
{hR2NUm
cSk}53
MV\zwH
