REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME | ANT6001 | ANT_JACK | ant_jack | ANT_JACK | CM1 | C1210 | 47uf/16v | C1210 | D2106 | SOD_323 | b5819ws | SOD_323 | D2107 | SOD_323 | b5819ws | SOD_323 | D2301 | DO214AC | ss34 | DO214AC | D2302 | DO214AC | ss34 | DO214AC | D2303 | SMB8J12A | smb8j12/smb8j12a | SMB8J12A | D8201 | SOD_323 | b5819ws | SOD_323 | D8202 | SOD_323 | b5819ws | SOD_323 | D8906 | SOD_123 | bzt52c5v1 | SOD_123 | ED21 | SOT23 | nc/esda6v8ul/azc199-02s | SOT23 | ED22 | SOT23 | nc/esda6v8ul/azc199-02s | SOT23 | ED23 | SOT23 | nc/esda6v8ul/azc199-02s | SOT23 | ED24 | SOT23 | nc/esda6v8ul/azc199-02s | SOT23 | ED42 | E0402N | esd9b5v | E0402N | ED43 | E0402N | esd9b5v | E0402N | ED44 | E0402N | esd9b5v | E0402N | ED500 | DFN1006P2E | az5825-01f | DFN1006P2E | ED1854 | ESD0402 | esd5451n | ESD0402 | ED2201 | E0402 | esd5v3u1u | E0402 | ED7004 | E0402 | nc/esd5451n | E0402 | ED7005 | E0402 | nc/esd5451n | E0402 | ED7006 | E0402 | esd5451n | E0402 | ED23012 | ESD0402 | esd5311n | ESD0402 | EDP1 | FPC30PIN-0D5-DOWN | fpc30pin-0d5-down | FPC30PIN-0D5-DOWN | FB1 | L0603D | nc/90r-100m | L0603D | FB2 | L0603D | nc/90r-100m | L0603D | FB13 | L0603 | 600r/100m | L0603 | FB7002 | L0603 | blm18pg181sn1 | L0603 | FB7200 | R0603 | 0r | R0603 | FB8801 | L0603D | 90r-100m | L0603D | FB8802 | L0603D | 90r-100m | L0603D | FB8803 | L0603D | 90r-100m | L0603D | FB8804 | L0603D | 90r-100m | L0603D | FB8901 | L0603D | 90r-100m | L0603D | GPIO | PH-8A_2MM | ph-8a_2mm | PH-8A_2MM | H1 | HOLD3_5 | hole | HOLD3_5 | H2 | HOLD3_5 | hole | HOLD3_5 | H3 | HOLD3_5 | hole | HOLD3_5 | H4 | HOLD3_5 | hole | HOLD3_5 | HD1 | HDMI_19P_A | hdmi_a | HDMI_19P_A | ID | PH-2A_2MM | ph-2a_2mm | PH-2A_2MM | J1 | DC-091 | dc12v | DC-091 | J2 | TF_CARD-MICRO | tf_sd_socket | TF_CARD-MICRO | J4 | PJ-395D | pj-395d | PJ-395D | J18 | SIM-SPPN08-X0-1X80 | sim-sppn08-x0-1x80 | SIM-SPPN08-X0-1X80 | J8902 | HOLE_PAD_40P_0D9_0D45 | hole_pad_40 | HOLE_PAD_40P_0D9_0D45 | JP1 | RJ45_110 | rj45s | RJ45_110 | L7 | IND-6X6 | 5.5uh/3a | IND-6X6 | L8 | IND-6X6 | 5.5uh/3a | IND-6X6 | L9 | IND_3X3 | 2.2uh/1a | IND_3X3 | L10 | IND-6X6 | 5.5uh/3a | IND-6X6 | L11 | L0603 | blm18pg181sn1 | L0603 | L12 | IND-6X6 | 5.5uh/3a | IND-6X6 | L6001 | IND_303012 | 4.7uh | IND_303012 | LED6 | LED0603 | led | LED0603 | MI1 | FPC30PIN-0D5-DOWN | fpc30pin-0d5-down | FPC30PIN-0D5-DOWN | OTG | USB_A_30 | otg_a_30 | USB_A_30 | POWER | PH-2A_2MM | ph_2d0_2pin | PH-2A_2MM | Q9 | SOT23 | nc/8050 | SOT23 | Q2100 | SOT23 | wpm3407 | SOT23 | Q2101 | SOT_23 | wpm2341-3/tr | SOT_23 | Q2102 | SOT_23 | s8050 | SOT_23 | Q2105 | SOT_23 | s8050 | SOT_23 | Q2106 | SOT_23 | s8050 | SOT_23 | Q2110 | SOT23 | wpm3407 | SOT23 | Q8205 | SOT_323 | 2sk3018 | SOT_323 | Q8206 | SOT_323 | 2sk3018 | SOT_323 | Q8207 | SOT_323 | 2sk3018 | SOT_323 | RECOVER | PH-2A_2MM | ph_2d0_2pin | PH-2A_2MM | RESET | PH-2A_2MM | ph_2d0_2pin | PH-2A_2MM | RTC-POWER | PH-2A_2MM | ph_2d0_2pin | PH-2A_2MM | SPEAKER | PH-4A_2MM | ph_2d0_4pin | PH-4A_2MM | TP | PH-8A_2MM | ph-8a_2mm | PH-8A_2MM | U19 | SOIC24 | h5007(pulse) | SOIC24 | U20 | QFN48_6X6-RTL8211E | rtl8211e-vb-cg | QFN48_6X6-RTL8211E | U28 | TEF2012A4X101MT | tef2012a4x101mt | TEF2012A4X101MT | U30 | TEF2012A4X101MT | tef2012a4x101mt | TEF2012A4X101MT | U43 | TSOT23-8 | mp2315 | TSOT23-8 | U44 | TSOT23-8 | mp2315 | TSOT23-8 | U45 | TSOT23-8 | mp2315 | TSOT23-8 | U46 | TSOT23-8 | mp2315 | TSOT23-8 | U66 | MINI-PCIE | mini-pcie | MINI-PCIE | U2100 | SOT23 | me082/ce8808n33m | SOT23 | U2206 | SOT_23_5 | pt5108e23e-30 | SOT_23_5 | U2208 | SOT_23_5 | pt5108e23e-18 | SOT_23_5 | U2210 | SOT23 | ce6301a-50 | SOT23 | U4101 | QFN6X6_40-PAM8610 | pam8610 | QFN6X6_40-PAM8610 | U6001 | MD44_AP6XXX_13RX15RX1R5 | ap6354/ap6356s | MD44_AP6XXX_13RX15RX1R5 | U7200 | QFN48_6X6 | alc5640/alc3224 | QFN48_6X6 | U8201 | SON10_2R50X1R00X0R50 | tpd4e05u06 | SON10_2R50X1R00X0R50 | U8801 | SOT_23_5 | sy6280aac | SOT_23_5 | U8802 | SOT_23_5 | sy6280aac | SOT_23_5 | U8803 | SON10_2R50X1R00X0R50 | tpd4e05u06 | SON10_2R50X1R00X0R50 | U8804 | SOT_23_5 | sy6280aac | SOT_23_5 | U8805 | SOT_23 | esd5302f | SOT_23 | U8806 | SOT_23_5 | sy6280aac | SOT_23_5 | U8809 | SOT_23 | esd5302f | SOT_23 | U8810 | SOT_23 | esd5302f | SOT_23 | U8811 | SOT_23 | esd5302f | SOT_23 | U8812 | SOT_23 | esd5302f | SOT_23 | U8813 | SOT_23 | esd5302f | SOT_23 | U8907 | SON10_2R50X1R00X0R50 | tpd4e05u06 | SON10_2R50X1R00X0R50 | U8909 | SOT_23 | esd5302f | SOT_23 | U23024 | SSOP16 | max3221eeae+ | SSOP16 | U23030 | LPQFN48 | fe2.1 | LPQFN48 | U23032 | PAD_270P_0D9_0D45 | pad_270 | PAD_270P_0D9_0D45 | U23033 | PHD_2MM_20P | phd_2d0_20pin | PHD_2MM_20P | U23034 | PHD_2MM_4P | phd_2d0_4pin | PHD_2MM_4P | U23035 | PH-2A_2MM | ph_2d0_2pin | PH-2A_2MM | U23036 | PH-6A_2MM | ph-2d0-6pin | PH-6A_2MM | U23037 | PHD_2MM_4P | phd_2d0_4pin | PHD_2MM_4P | UART2 | PH-4A_2MM | ph_2d0_4pin | PH-4A_2MM | UART4 | PH-4A_2MM | ph_2d0_4pin | PH-4A_2MM | USB1 | USB_A_30 | usb_a_30 | USB_A_30 | USB3 | PH-4A_2MM | ph_2d0_4pin | PH-4A_2MM | USB4 | PH-4A_2MM | ph_2d0_4pin | PH-4A_2MM | USB5 | PH-4A_2MM | ph_2d0_4pin | PH-4A_2MM | USB6 | PH-4A_2MM | ph_2d0_4pin | PH-4A_2MM | USB7 | PH-4A_2MM | ph_2d0_4pin | PH-4A_2MM | VCC12 | PH-4A_2MM | ph-4a_2mm | PH-4A_2MM | Y3 | CRY-D3225 | 25mhz-30ppm | CRY-D3225 | Y1102 | CRY4_3R20X2R50X0R80 | 12mhz10ppm | CRY4_3R20X2R50X0R80 | Y6001 | CRY4_3R20X2R50X0R80 | 37.4mhz | CRY4_3R20X2R50X0R80 |
本帖子中包含更多资源
x
