论坛风格切换切换到宽版
发帖 回复
  • 374阅读
  • 48回复
[VX.2x]GM8210 做的8CH DVR  NVR 监控录像机PCB和原理图 [复制链接]
上一主题 下一主题
在线老吴
性别:
帅哥
发帖
13667
金币
26812
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       图酷模式  只看楼主 倒序阅读 使用道具 0楼 发表于: 09-12
重要提示:本版需2级以上才能下载,有些需购买的帖,若没2级请不要购买,购买也下载不了【可充值秒升级】也可发帖,做任务,签到等升级。若已2级以上,忽略本提示
mV.26D<c
~j[mME}
3bagL)'iz
Rts.jm>[
NamePCB DecalPart TypeValue
B1RB12/8CHOKE_WB-PHENOLICNC(Bell)
BAT1BATTERY_SD_100_ACR2032_HOLDERCR2032_Holder
CN1CONRA_4P_200POWER_CON_HD_5.08MM_DIP_4PPower_CON_HD
CN2POWER_20MATX_CONN_4_1.2MM_DIP_20PNC(ATX)
CN3JP2_250_IPOWER_CON_2.54MM_DIP_2PNC(Power_CON,2P)
CN4CN10X2_1272X10P_MALE_DIP_1.272X10P_1.27M
CN5CN10X2_1272X10P_MALE_DIP_1.272X10P_1.27M
CN7MTD_CN_SATA_7P_LSATA_180D_DOWN_DIP_7PSATA1_HOST_DIP
CN8MTD_CN_SATA_7P_LSATA_180D_DOWN_DIP_7PSATA1_HOST_DIP
CN9MTD_CN_SATA_7P_LSATA_180D_DOWN_DIP_7PSATA1_HOST_DIP
CN10MTD_CN_SATA_7P_LSATA_180D_DOWN_DIP_7PSATA1_HOST_DIP
CN18DB15_FLDB15_90D_FEMALE_DIP_15PDB15_F
CN19SIP1.27-7PSIP6_0NC(1.25mmx7)
CN45RCAX2_JACKRCA_JACK_90D_W+R_DIP_3PRCA_JACK,90D,W+R,DIP_3P
CN99MTD_CN_SATA_7P_LSATA_180D_DOWN_DIP_7PSATA1_HOST_DIP
CN100MTD_CN_SATA_7P_LSATA_180D_DOWN_DIP_7PSATA1_HOST_DIP
CN101MTD_CN_SATA_7P_LSATA_180D_DOWN_DIP_7PSATA1_HOST_DIP
CN102MTD_CN_SATA_7P_LSATA_180D_DOWN_DIP_7PSATA1_HOST_DIP
CN103MTD_CN_SATA_7P_LSATA_180D_DOWN_DIP_7PSATA1_HOST_DIP
CN104DB15_FLX2DB15_F_FLX2_0NC(CON-DUAL_DB15/F)
CN105BNC_MCI_750_2X1BNC(2_LAYERS)_MCI-7126-750HMBNC(2 layers)_MCI-7126-75OHM
CN106BNC_MCI_750_2X1BNC(2_LAYERS)_MCI-7126-750HMBNC(2 layers)_MCI-7126-75OHM
CN107BNC_75OHM_BO_JIANGBNC_JACK_90D_4R_DIP_1NC(BNC_JACK,90D,7065NR702BF003B,DIP)
CN108BNC_MCI_750_2X1BNC(2_LAYERS)_MCI-7126-750HMBNC(2 layers)_MCI-7126-75OHM
CN109BNC_MCI_750_2X1BNC(2_LAYERS)_MCI-7126-750HMBNC(2 layers)_MCI-7126-75OHM
CN110BNC_75OHM_BO_JIANGBNC_JACK_90D_4R_DIP_1NC(BNC_JACK,90D,7065NR702BF003B,DIP)
CON1CN_HDMI_19_050CON-19-HDMI-NS-J_1HDMI-R/A-SMT
D1D_LL34SK34_D_LL34SK34
D2D_LL34SK34_D_LL34SK34
D3D_LL34SK34_D_LL34SK34
D4MTD_D_LL34IN4148IN4148
D15D_LL34SK34_D_LL34NC(SK34)
D18ESD_10P_050INPAQ_TVW_DF10_0NC(HDMI_ESD_Protection)
D19ESD_10P_050INPAQ_TVW_DF10_0NC(HDMI_ESD_Protection)
D88VHZ0603VH0603M240CGT2R5_2_0.5PFVH0603M240CGT2R5,2.5pF
D107EGA0402EGA10402V05AH_1EGA10402V05AH_0.2pF
D108MTD_D_LL34IN4148IN4148
D112MTD_D_LL34IN4148IN4148
D113SOT26SRV05NC(SRV05)
D115SOT26SRV05NC(SRV05)
D117SOT26SRV05NC(SRV05)
D118SOT26SRV05NC(SRV05)
D119SOT26SRV05NC(SRV05)
D120SOT26SRV05NC(SRV05)
D128D_P0080DIODE_BREAKDOWN_1NC(P0080)
D129D_P0080DIODE_BREAKDOWN_1NC(P0080)
D130D_P0080DIODE_BREAKDOWN_1NC(P0080)
D131SOT26SRV05NC(SRV05)
F1FUSE-DIP2FUSE-4A_DIPFUSE-4A_DIP
F2FUSE-DIP2FUSE-4A_DIPNC(FUSE-4A_DIP)
F3PS_S3_45320.5A_POLY_SWITCH_SMD45320.5A,SMD_4532
FB1L0402100M_120H[_200MA_SMD0402_2100M,120
FB279L0402100M_120H[_200MA_SMD0402_3SMD0402
H9HOLE_3MM+PAD+VIAHOLE_3MM+PAD+VIAHOLE-SCREW
J2SIP_3P_2001X3P_MALE_DIP_2.01X3P_2.0M
J3SIP2P-300SIP_1NC(POWER_SWICTH)
J5SIP_4P1X4P_MALE_DIP_2.541X4P_2.54M
J6SIP_4P1X4P_MALE_DIP_2.541X4P_2.54M
J7SIP_4P1X4P_MALE_DIP_2.541X4P_2.54M
J10MTD_PJ20_3PDC_POWER_JACK_2.0_DIP_3PDC-Jack
J13SIP_2P_1271X2P_MALE_DIP_1.27NC(1X2P_1.27M)
J17SIP_2P1X2P_MALE_DIP_2.54_21X2P_2.54M
J23RJ45-LED-3RJ45_2RJ45_0
J26SIP4P_100MILCON4NC(USB-2.54)
J27SIP4P_100MILCON4NC(USB-2.54)
J28USB-SINGLE-90SINGLE_USBSINGLE_USB
J29AL_DIP2X8_300MILCON16ANC(ALARM_DIP2X8)
J30SIP10P_100MILCON10NC(CON10)
J31FPC2X8-1.0CON16NC(DB25_28)
J32RJ45-LED-3RJ45_0RJ45_0
J33CN_USB_AI_TACTUSB_A_180_DIPUSB_A_180_DIP
J34CN_USB_AI_TACTUSB_A_180_DIPUSB_A_180_DIP
J35CN_USB_AI_TACTUSB_A_180_DIPNC(USB_A_180_DIP)
J41SIP_3P_2001X3P_MALE_DIP_2.01X3P_2.0M
J42SIP_2P1X2P_MALE_DIP_2.54_31X2P_2.54M
J43CN6X22X6P_MALE_DIP_2.542X6P_2.54M
JP1SIP_2P1X2P_MALE_DIP_2.541X2P_2.54M
K1REL_SRS20-2051-DPST_0NC(4CSRS-05VDC-SL)
L1L_GSSR210UH/3.8A-_GSSR2-104P-100N10uH/3.8A/35mohm
L2L_GSSR23.3UH/6A-_GSSR2-104P-3R3MN3.3uH/6A/13mohm
L3L_GSSR210UH/3.8A-_GSSR2-104P-100N10uH/3.8A/35mohm
L4L_GSSR210UH/3.8A-_GSSR2-104P-100N10uH/3.8A/35mohm
L5L_GSSR21UH/6_0.5A-_GSSR2-104P-1R0N1uH/6.5A/10mohm
L6L0402_MTD_ANTIPAD5.6NH_0.3A_FD0.3NH_SMD_L04025.6nH
L20L0402_MTD_ANTIPAD5.6NH_0.3A_FD0.3NH_SMD_L04025.6nH
LED1LED0603RED_SMD0603RED
LED2LED0603GREEN_SMD0603GREEN
LED3LED0603GREEN_SMD0603GREEN
LED4LED0603GREEN_SMD0603_2GREEN
LED8LED0603GREEN_SMD0603_2GREEN
MIC1MICMIC-MICROPHONE0MIC-EM5BPS
PB1SW_PB4PPUSH_BOTTOM_DIPPush Button
PT1SJO_8MILPCB_TRACE_W_8MILPCB_Trace,W_8mil
PT2SJO_8MILPCB_TRACE_W_8MILPCB_Trace,W_8mil
PT9SJO_0402PCB_TRACE_0402PCB_Trace,0402
PT17SJO_0603PCB_TRACE_0603PCB_Trace,0603
PT18SJO_0603PCB_TRACE_0603PCB_Trace,0603
Q18SOT23MMBT3904_SOT23_1MMBT3904
Q23SOT23MMBT3904_SOT23_1MMBT3904
Q24SOT23-MOS2N7002_SOT23_02N7002
Q25SOT23-MOS2N7002_SOT23_02N7002
Q28SOT23MMBT3904_SOT23_1MMBT3904
Q47SOT23-MOS2N7002_SOT23_02N7002
Q48SOT23MMBT3904_SOT23_1MMBT3904
Q49SOT23MMBT3904_SOT23_1MMBT3904
Q50SOT23MMBT3904_SOT23_1MMBT3904
Q54SOT23MMBT3904_SOT23_1MMBT3904
SW1SW_SPDT3_1SLIDE_SWITCH_DIP_3PSW-SPDT3
T1HC5000_24P_P0.99_W19.6H5008NLH5008NL
TP1SIP_1P_127TESTPOINT_DIP_1.27NC(TP_1.27)
U1BGA825_065_25X25GM8210_FCBGA825_10GM8210,FCBGA825
U2HEATSINK_38X38HP-RE1112291A_5NC(GM8210_HeatSink_37x43x23)
U3SOT23G691L293T73U_SOT23G691L293T73U
U4SOIC8_150DS1307_SOIC8DS1307
U6SOP8+EPADMP1484_SOP8_0MP1484,SOP8
U7SOT25G9141T11U_SOT25_0G9141T11U
U8QFN14_050NB637_QFN14NB637,QFN14
U9SOP8+EPADMP1484_SOP8_0MP1484,SOP8
U10SOP8+EPADMP1484_SOP8_0MP1484,SOP8
U11QFN14_050NB637_QFN14NB637,QFN14
U12DDR3_FBGA_X16_9X15P5K4B1G1646G-BCK00DT-1600K4B2G1646G-BCK00DT
U13DDR3_FBGA_X16_9X15P5K4B1G1646G-BCK00DT-1600K4B2G1646G-BCK00DT
U14DDR3_FBGA_X16_9X15P5K4B1G1646G-BCK00DT-1600K4B2G1646G-BCK00DT
U15DDR3_FBGA_X16_9X15P5K4B1G1646G-BCK00DT-1600K4B2G1646G-BCK00DT
U16TSOP48_12X20K9F1G08U0B(128MBX8)_TSOP48_0NAND FLASH K9F1G08U0B(128Mbx8)
U17SOP16_300MX25L25735FMI-10G_SOP16MX25L25735FMI-10G/MX25L128,SOP16
U19SOIC8_150MAX485_SOIC8NC(MAX485,SOIC8)
U20SOIC16_6.274HC165_1NC(74HC165)
U33SOT223G1117-25T63UFG1117-25T63UF
U35GM8312_100GM8312_TFBGA256_2GM8312_TFBGA256
U36SOT25G916-120T1UF_SOT25NC(G916-120T1Uf)
U56MSOP10_050_30X49+EPADG2997B_MSOP-10(FD)_0G2997B
U57MSOP10_050_30X49+EPADG2997B_MSOP-10(FD)_0G2997B
U64QFN64_050_9X9IP1001IP1001
U65SOT223S-1117A18-R3T1U3_0S-1117A18
U66SOT223S-1117A12S-1117A12
U67SOT25SN74LVC1G08DBVR_SOT25SN74LVC1G08DBVR_SOT25
U69TQFN32_040+EPADIP101GR_0IP101GR
U70T16-H1102TNK-1309Z-BT16B03TNK-1309Z-BT16B03
U71SOT26HY437_SOP8_1NC(SOT23-6L)
U72SOT8978L05_0NC(78L05)
U94QFN64_050_9X9_JMB321C_QFN64JMB321C_QFN64
U95SOP8_210_MTD_JMMX25L12835_SOIC8SPI Flash_128Mb_MX25L12835F,SOIC8
U96SOT223S-1117A12S-1117A12
U97CX25930_31Z_080CX25930_366P_ENGCX25930-31Z
U99CX25930_31Z_080CX25930_366P_ENGCX25930-31Z
U101SOT25OPA340/SOT_0AD8605
X1OSC4_SMD_50X3212_1.288MHZ_OSC_50PPM_SMD5X3TXC_12.288MHz_7C12200011
Y1XTAL_UP12MHZ_CRY_30PPM_49US12MHz
Y2XTAL_SMD_50X3212.288MHZ_CRY_30PPM_SMD_5X3_2NC(12.288MHz)
Y3XTAL4_232.768KHZ_CRY_30PPM_SIZE_2X632.768KHz
Y4XTAL_UP12MHZ_CRY_30PPM_49US_2NC(12MHz)
Y7XTAL_UP25MHZ_CRY_30PPM_49US25MHz
Y8OSC4_SMD_50X3230MHZ_OSC_30PPM_SMD5X3_0NC(30MHz)
Y9XTAL_SMD_50X3230MHZ_CRY_30PPM_SMD_5X3NC(27MHz)
Y10XTAL_SMD_50X3230MHZ_CRY_30PPM_SMD_5X3NC(27MHz)
评价一下你浏览此帖子的感受
精彩
感动
搞笑
愤怒
一般
差劲
在线老吴
性别:
帅哥
发帖
13667
金币
26812
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       只看该作者 1楼 发表于: 09-12
PCB 原理图 GERBER等一起打包 c6LPqPcN
本部分内容设定了隐藏,需要回复后才能看到(回复后还看不到就刷新一下即可)
x_#'6H\1ga
离线zspdeyc
性别:
人妖
发帖
777
金币
14
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       只看该作者 2楼 发表于: 09-13
离线2592047508
性别:
帅哥
发帖
2749
金币
1920
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       只看该作者 3楼 发表于: 09-13
离线nj20044
性别:
帅哥
发帖
3036
金币
2953
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       只看该作者 4楼 发表于: 09-13
离线shuszhao
性别:
帅哥
发帖
13546
金币
25611
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       只看该作者 5楼 发表于: 09-13
离线cityhu
性别:
帅哥
发帖
5543
金币
3994
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       只看该作者 6楼 发表于: 09-13
rNk'W,FU
离线kanxue_nmg
性别:
人妖
发帖
4517
金币
5532
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       只看该作者 7楼 发表于: 09-13
离线nongfu88
性别:
帅哥
发帖
552
金币
402
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       只看该作者 8楼 发表于: 09-13
离线io357
性别:
人妖
发帖
1802
金币
5164
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       只看该作者 9楼 发表于: 09-13
离线renjiawu
性别:
人妖
发帖
1095
金币
874
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       只看该作者 10楼 发表于: 09-13
谢谢
离线a272468515
性别:
人妖
发帖
144
金币
137
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       只看该作者 11楼 发表于: 09-13
了解一下
离线kn1986
性别:
帅哥
发帖
2671
金币
3148
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       只看该作者 12楼 发表于: 09-13
   学习学习,谢谢分享…
离线thanky0u58
性别:
帅哥
发帖
10115
金币
14756
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       只看该作者 13楼 发表于: 09-13
性别:
人妖
发帖
1995
金币
3776
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       只看该作者 14楼 发表于: 09-13
快速回复
限150 字节
上一个 下一个
