REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
CON5 | HDMI_TYPA_RA_HDMIIISVWS_HDMIJA | HDMIJACK | HDMIIISVWS |
CON10 | MICRO_SD_1_MICRO_SD_TFC08WP01F- | TFC08WP01F-A-R1K-HCN | MICRO_SD |
CON13 | USB_TYPA_USBA_4P_TH_USBAS-00401 | USBAS-00401W003 | USBA_4P_TH |
D2 | LED_LED_0603_BLUELED/Z6 | BLUELED/Z6 | LED_0603 |
D3 | LED_LED-0805_BLUELED/Z8 | BLUELED/Z8 | LED-0805 |
D4 | DIODE_SOD323-AC_1N4148WSQ-7-F | 1N4148WSQ-7-F | SOD323-AC |
D6 | DIODESCHOTTKY13_1_SOD323-AC_B0 | B0530WS-7-F | SOD323-AC |
D7 | DIODESCHOTTKY13_1_SOD323-AC_B0 | B0530WS-7-F | SOD323-AC |
D10 | LIGHT_LED_LED_0603_LEDRED | LEDRED | LED_0603 |
D11 | LIGHT_LED_LED_0603_LEDRED | LEDRED | LED_0603 |
D23 | LED_LED_0603_BLUELED/Z6 | BLUELED/Z6 | LED_0603 |
D24 | LIGHT_LED_LED_0603_LEDRED | LEDRED | LED_0603 |
D25 | LIGHT_LED_LED_0603_LEDRED | LEDRED | LED_0603 |
D26 | LIGHT_LED_LED_0603_LEDRED | LEDRED | LED_0603 |
D27 | LIGHT_LED_LED_0603_LEDRED | LEDRED | LED_0603 |
D28 | LIGHT_LED_LED_0603_LEDRED | LEDRED | LED_0603 |
D29 | LIGHT_LED_LED_0603_LEDRED | LEDRED | LED_0603 |
D32 | DIODE_0_SMC_B540CQ-13-F | B540CQ-13-F | SMC |
D33 | DIODESCHOTTKY_0_DO_214AB_SMCJ3 | SMCJ30CA-AT | DO_214AB |
D34 | BTSS-2P_SOD-323_TESD05FB | TESD05FB | SOD-323 |
D35 | BTSS-2P_SOD-323_TESD05FB | TESD05FB | SOD-323 |
FB16 | INDUCTOR_0_SMD-L0402_BLM15PX121 | BLM15PX121SZ1D | SMD-L0402 |
FB17 | INDUCTOR_0_SMD-L0402_BLM15PX121 | BLM15PX121SZ1D | SMD-L0402 |
FB18 | INDUCTOR_0_SMD-L0402_BLM15PX121 | BLM15PX121SZ1D | SMD-L0402 |
FB19 | INDUCTOR_0_SMD-L0402_BLM15PX121 | BLM15PX121SZ1D | SMD-L0402 |
FL2 | FILTER_TCE1210_SMD4_1_ACM2012_A | ACM2012-121-2P | ACM2012 |
HS1 | HSHOLE_2_HOLD-3X2_2_HSHOLE_D2R | HShole_D2R3 | HOLD-3X2_2 |
HS4 | HSHOLE_2_HOLD-3X2_2_HSHOLE_D2R | HShole_D2R3 | HOLD-3X2_2 |
J1 | MOLEX56579B_0_CRC5001-2_CRC500 | CRC5001-6603FSMK | CRC5001-2 |
J2 | MOLEX56579B_0_CRC5001-2_CRC500 | CRC5001-6603FSMK | CRC5001-2 |
J3 | MOLEX56579B_0_CRC5001-2_CRC500 | CRC5001-6603FSMK | CRC5001-2 |
J4 | MOLEX56579B_0_CRC5001-2_CRC500 | CRC5001-6603FSMK | CRC5001-2 |
J5 | J0G-0001NL_1_RJ45-JXD1-0001NL_J | JXD1-0001NL | RJ45-JXD1-0001NL |
J6 | MOLEX56579B_1_CRC5001-2_CRC500 | CRC5001-6602FSMK | CRC5001-2 |
J7 | MOLEX56579B_1_CRC5001-2_CRC500 | CRC5001-6602FSMK | CRC5001-2 |
J10 | CON2_3_A2001WV-2P_X_A2001WV-2P | X_A2001WV-2P | A2001WV-2P |
J11 | CON5X2-2X2MM-DIP_CON5X2_X_CON5X | X_CON5X2-2X2MM-DIP | CON5X2 |
J15 | MOLEX56579B_1_CRC5001-2_CRC500 | CRC5001-6602FSMK | CRC5001-2 |
J16 | CON2_3_HOLD-2_54MM_X_CON2_3 | X_CON2_3 | HOLD-2_54MM |
J17 | JPN_CD_1318772-1_JPN_CD_1318772 | JPN_CD_1318772-2 | JPN_CD_1318772-1_NEW |
J18 | JPN_CD_2_JPN_CD_1376350_JPN_CD_ | JPN_CD_1376350-2 | JPN_CD_1376350 |
J19 | CON2_3_HOLD-2_54MM_X_CON2_3 | X_CON2_3 | HOLD-2_54MM |
J20 | XH2.54-3TS_XH2_54-3TS_X_XH2.54- | X_XH2.54-3TS | XH2_54-3TS |
J21 | XH2.54-3TS_XH2_54-3TS_X_XH2.54- | X_XH2.54-3TS | XH2_54-3TS |
L2 | L_L0603_BBPY00160808800Y00 | BBPY00160808800Y00 | L0603 |
L3 | L_L0603_BBPY00160808800Y00 | BBPY00160808800Y00 | L0603 |
L10 | L_HEI322525A_1.5UH/HEI322525A-1 | 1.5uH/HEI322525A-1R5M-Q8EW | HEI322525A |
L11 | L_HEI322525A_1.5UH/HEI322525A-1 | 1.5uH/HEI322525A-1R5M-Q8EW | HEI322525A |
L12 | L_L0603_BBPY00160808800Y00 | BBPY00160808800Y00 | L0603 |
L14 | L_L0603_BBPY00160808800Y00 | BBPY00160808800Y00 | L0603 |
L15 | L_HEI322525A_1.5UH/HEI322525A-1 | 1.5uH/HEI322525A-1R5M-Q8EW | HEI322525A |
L16 | L_HEI322525A_1.5UH/HEI322525A-1 | 1.5uH/HEI322525A-1R5M-Q8EW | HEI322525A |
L17 | L_2020BZ_0.1UH/3.6M_OHM/IHLP20 | 0.1uH/3.6m_ohm/IHLP2020BZERR10M01 | 2020BZ |
L18 | L_L0603_10UH/Z6/CL160808T-100K- | 10uH/Z6/CL160808T-100K-N | L0603 |
L19 | L_L-3X3-H2_2.2UH/SCDS2D18HP-2R2 | 2.2uH/SCDS2D18HP-2R2M-N | L-3X3-H2 |
L27 | L_L11X10_10UH | 10uH | L11X10 |
L28 | CMS2-4-R_ACM70V_ACM70V-701-2PL- | ACM70V-701-2PL-TL00 | ACM70V |
L29 | L_L202012_MDMK2020T1R0MMV | MDMK2020T1R0MMV | L202012 |
L30 | L_L202012_MDMK2020T1R0MMV | MDMK2020T1R0MMV | L202012 |
L31 | L_MPI4040_MPI4040R1-4R7-R | MPI4040R1-4R7-R | MPI4040 |
L32 | INDUCTORFERRITE_0603L_BLM18AG1 | BLM18AG102SH1D | 0603L |
L33 | INDUCTORIRON_0_L252012_LQH2HPZ | LQH2HPZ220MJRL/22uH/0.54A | L252012 |
L34 | INDUCTORIRON_0_0603L_BLM18PG22 | BLM18PG221SH1D/220ohm/1.4A | 0603L |
L35 | L_SPM10054T_SPM10054T-220M-HZ | SPM10054T-220M-HZ | SPM10054T |
L36 | INDUCTORFERRITE_0603L_BLM18AG1 | BLM18AG102SH1D | 0603L |
L37 | INDUCTORIRON_0_L252012_LQH2HPZ | LQH2HPZ220MJRL/22uH/0.54A | L252012 |
L38 | INDUCTORIRON_0_0603L_BLM18PG22 | BLM18PG221SH1D/220ohm/1.4A | 0603L |
L39 | INDUCTORFERRITE_0603L_BLM18AG1 | BLM18AG102SH1D | 0603L |
L40 | BEED_2P_0_L303009_LQH3NPN100NG0 | LQH3NPN100NG0/10uH | L303009 |
L41 | BEED_2P_0_0402L_MPZ1005S331ETD2 | MPZ1005S331ETD25 | 0402L |
L42 | BEED_2P_0_0402L_MPZ1005F470ETD2 | MPZ1005F470ETD25 | 0402L |
L43 | INDUCTORFERRITE_0603L_BLM18AG1 | BLM18AG102SH1D | 0603L |
L44 | BEED_2P_0_L303009_LQH3NPN100NG0 | LQH3NPN100NG0/10uH | L303009 |
L45 | BEED_2P_0_0402L_MPZ1005S331ETD2 | MPZ1005S331ETD25 | 0402L |
L46 | BEED_2P_0_0402L_MPZ1005F470ETD2 | MPZ1005F470ETD25 | 0402L |
MH1 | MTHOLE_0_HOLE-3-2MM_X_MTHOLE-3- | X_MTHOLE-3-2mm | HOLE-3-2MM |
MH2 | MTHOLE_0_HOLE-3-2MM_X_MTHOLE-3- | X_MTHOLE-3-2mm | HOLE-3-2MM |
MH3 | MTHOLE_0_HOLE-3-2MM_X_MTHOLE-3- | X_MTHOLE-3-2mm | HOLE-3-2MM |
MH4 | MTHOLE_0_HOLE-3-2MM_X_MTHOLE-3- | X_MTHOLE-3-2mm | HOLE-3-2MM |
OSC1 | XF_1_OSC_3225_SSWK025000IECHE-T | SSWK025000IECHE-T | OSC_3225 |
Q1 | APM2301CAC-TRG_SOT-23_APM2301CA | APM2301CAC-TRG | SOT-23 |
Q2 | APM2300CA_SOT-23_APM2300CA | APM2300CA | SOT-23 |
Q3 | N-MOSFET_0_SOT23-3_2N7002 | 2N7002 | SOT23-3 |
Q4 | AO7800_SC-70-6_UPA672T-T1-A | uPA672T-T1-A | SC-70-6 |
Q5 | APM2300CA_SOT-23_APM2300CA | APM2300CA | SOT-23 |
Q6 | APM2301CAC-TRG_SOT-23_APM2301CA | APM2301CAC-TRG | SOT-23 |
Q13 | NPN_SOT23BEC_2N3904 | 2N3904 | SOT23BEC |
Q27 | DTC114EE_0_SC-75A-213_DTC114EE | DTC114EE | SC-75A-213 |
Q28 | NPN_SOT23BEC_2N3904 | 2N3904 | SOT23BEC |
Q29 | APM2300CA_SOT-23_APM2300CA | APM2300CA | SOT-23 |
Q30 | APM2301CAC-TRG_SOT-23_APM2301CA | APM2301CAC-TRG | SOT-23 |
Q31 | APM2300CA_SOT-23_APM2300CA | APM2300CA | SOT-23 |
Q32 | APM2301CAC-TRG_SOT-23_APM2301CA | APM2301CAC-TRG | SOT-23 |
Q33 | APM2300CA_SOT-23_APM2300CA | APM2300CA | SOT-23 |
Q34 | APM2301CAC-TRG_SOT-23_APM2301CA | APM2301CAC-TRG | SOT-23 |
Q35 | APM2300CA_SOT-23_APM2300CA | APM2300CA | SOT-23 |
Q36 | APM2301CAC-TRG_SOT-23_APM2301CA | APM2301CAC-TRG | SOT-23 |
Q37 | APM2300CA_SOT-23_APM2300CA | APM2300CA | SOT-23 |
Q38 | APM2301CAC-TRG_SOT-23_APM2301CA | APM2301CAC-TRG | SOT-23 |
Q39 | APM2300CA_SOT-23_APM2300CA | APM2300CA | SOT-23 |
TP | TP_TP25-12_CK# | CK# | TP25-12 |
U1 | CV22_441_BALLS_FC_TFBGA_(S1+S2+ | CV22 | 441_BALLS_FC_TFBGA |
U2 | AT25256A_0_VQFN-48P-EP_DS90UB95 | DS90UB954TRGZTQ1 | VQFN-48P-EP |
U4 | VSC8531XMW_QFN48_6X6_VSC8531XMW | VSC8531XMW | QFN48_6X6 |
U5 | RH5RE50AA_25_TDFN8-0_5MM_MAX200 | MAX20071ATAA/V+ | TDFN8-0_5MM |
U6 | MAX96751_1_TQFN-56P-EP_MAX96751 | MAX96751 | TQFN-56P-EP |
U7 | LPDDR4_FBGA200_2_FBGA_200_065MM | MT53D512M32D2DS-046AAT:D | FBGA_200_065MM |
U8 | TC58DVM82A1TG00_0_TSOP48_MT29F4 | MT29F4G08ABADAWP-AATX:D | TSOP48 |
U9 | TS5A3159_DBV0006A_TS5A3159DBVR | TS5A3159DBVR | DBV0006A |
U10 | MAX9296A_1_TQFN-48P-EP_MAX9296A | MAX9296A | TQFN-48P-EP |
U11 | AP2281_SOT26-6P_AP2281-3WG-7 | AP2281-3WG-7 | SOT26-6P |
U12 | LM3525_8SOIC-P1_27_LM3525M-H | LM3525M-H | 8SOIC-P1_27 |
U13 | FS32K144HAT0MLLT_0_LQFP-100P_FS | FS32K144HAT0MLLT | LQFP-100P |
U14 | SGM811-TXKA4/TR_SOT-143_SGM811- | SGM811-TXKA4/TR | SOT-143 |
U15 | MAX96755_1_TQFN-56P-EP_MAX96755 | MAX96755FGTV+MAX96755FGTT | TQFN-56P-EP_MAX96755 |
U26 | TPS22902YFPR_WLCSP4-P0_4_NCP433 | NCP433FCT2G | WLCSP4-P0_4 |
U29 | NCV8705_WDFN6_2X2_NCV8705MTADJT | NCV8705MTADJTCG | WDFN6_2X2 |
U34 | MAX20029_28TQFN-P0_5-EPAD_MAX20 | MAX20029ATIA/V+ | 28TQFN-P0_5-EPAD |
U35 | NVTFS4C10NWFTAG_8WDFN-P0_65_NVT | NVTFS4C10NWFTAG | 8WDFN-P0_65 |
U36 | RH5RE50AA_23_8TDFN-P0_5-EPAD_MA | MAX8902BATA/V+B | 8TDFN-P0_5-EPAD |
U37 | MAX20412CATJ_/V+_32TQFN-P0_5-EP | MAX20412CATJ_/V+ | 32TQFN-P0_5-EPAD |
U38 | NVTFS4C10NWFTAG_8WDFN-P0_65_N_1 | NVTFS4C05NWFTAG | 8WDFN-P0_65 |
U39 | LM3880_SOT-23-6_LM3880QMF-1AC | LM3880QMF-1AC | SOT-23-6 |
U40 | LM3880_SOT-23-6_LM3880QMF-1AC | LM3880QMF-1AC | SOT-23-6 |
U83 | SMD_SOC_FN_CSX750_SMB-125000-7X | SMB-125000-7XL2T4 | CSX750 |
U85 | AP2281_SOT26-6P_AP2281-3WG-7 | AP2281-3WG-7 | SOT26-6P |
U86 | NCV8114ASN250T1G_TSOP5-3_NCV811 | NCV8114ASN250T1G | TSOP5-3 |
U99 | SN74LVC1G08-Q1_DBV_SOT23_SN74LV | SN74LVC1G08-Q1 | DBV_SOT23 |
U100 | MPQ4470GL-AEC1_QFN20_3X4MM_MPQ4 | MPQ4470GL-AEC1 | QFN20_3X4MM |
U101 | TPS62067QDSGRQ1_0_WSON_8P_EP_TP | TPS62067QDSGRQ1 | WSON_8P_EP |
U102 | TPS62067QDSGRQ1_0_WSON_8P_EP_TP | TPS62067QDSGRQ1 | WSON_8P_EP |
U103 | LM53601LQDSXRQ1_1_WSON_10P_LM53 | LM536005QDSXTQ1 | WSON_10P |
U104 | RP111N001D-TR-AE_0_SOT-89-5_RP1 | RP111H331D-T1-AE | SOT-89-5 |
U105 | TJA1043T_SO14_TJA1043T | TJA1043T | SO14 |
Y1 | XTAL-4PIN_0_XTAL-3_2X1_5MM_AH03 | AH03200003 | XTAL-3_2X1_5MM |
Y2 | XTAL-4PIN_XTAL_2016_NX2016SA-24 | NX2016SA-24MHZ-STD-CS | XTAL_2016 |
Y5 | XTAL-4PIN_XTAL_2016_NX2016SA-25 | NX2016SA-25.000MHz-STD-CZS-3 | XTAL_2016 |
Y6 | XTAL-4PIN_XTAL_2016_NX2016SA-25 | NX2016SA-25.000MHz-STD-CZS-3 | XTAL_2016 |
Y7 | XTAL-4PIN_XTAL_2016_NX2016SA-25 | NX2016SA-25.000MHz-STD-CZS-3 | XTAL_2016 |
Y8 | XTAL-4PIN_XTAL_2016_NX2016SA-25 | NX2016SA-25.000MHz-STD-CZS-3 | XTAL_2016 |
Y9 | XTAL-4PIN_0_XTAL-5_0X3_2MM_NX50 | NX5032GA-8.000M-STD-CSU-1 | XTAL-5_0X3_2MM |
