查看: 4368|回复: 61
[Allegro17.4以下] XC6SLX25-3FTG256 软硬结合的PCB文件共享
此广告位出租
发表于 2022-3-5 14:03:15 | 显示全部楼层 |阅读模式
D1LED_LEDC2012X120N_DISCRETE_GREEN_EMA-00002256V22GREENLEDC2012X120N
D2LED_LEDC2012X120N_DISCRETE_GREEN_EMA-00002256V22GREENLEDC2012X120N
D3LED_LEDC2012X120N_DISCRETE_GREEN_EMA-00002256V22GREENLEDC2012X120N
D4LED_LEDC2012X120N_DISCRETE_GREEN_EMA-00002256V22GREENLEDC2012X120N
D5DIODE_A_NC_C_SOT95P230X109-3N_DISCRETE_MMBD4148_EMA-00002334V22MMBD4148SOT95P230X109-3N
J1BNC-4_SMB_90_IO_901-9894-RFX_PSL-00000003901-9894-RFXSMB_90
J2BNC-4_SMB_90_IO_901-9894-RFX_PSL-00000003901-9894-RFXSMB_90
J3BNC-4_SMB_90_IO_901-9894-RFX_PSL-00000003901-9894-RFXSMB_90
J5USB3A_FEMALE_USB3A_FEMALE_IO_AU-Y1005-3-R_PSL-00000013AU-Y1005-3-RUSB3A_FEMALE
J6CONN_C1367550_6_C-1367550-6_IO_(S1+S2+S3+S4+S5+S6)_6367550-6_PSL-000000386367550-6C-1367550-6
J7CONN_DIMM_200_C_1_1473005_1_J1_IO_(S1+S2+S3+S4)_1473005-1_PSL-000000431473005-1C_1_1473005_1_J1
L1IND_INDC2520X220N_DISCRETE_47NH_EMA-00005369V2247nHINDC2520X220N
L2IND_INDC2520X220N_DISCRETE_47NH_EMA-00005369V2247nHINDC2520X220N
L3INDUCTOR3_TOROID01_3_DISCRETE_INDUCTOR3_PSL-00000031INDUCTOR3TOROID01_3
L4INDUCTOR3_TOROID01_3_DISCRETE_INDUCTOR3_PSL-00000031INDUCTOR3TOROID01_3
L5IND_INDC2520X220N_DISCRETE_1.0UH_EMA-00005259V221.0uHINDC2520X220N
L6IND_INDC1005X60N_DISCRETE_6.8NH_EMA-00005230V226.8nHINDC1005X60N
L7IND_IND_CENTRAL_1008_DISCRETE_56NH_EMA-00005035V2256nHIND_CENTRAL_1008
L8IND_IND_CENTRAL_1008_DISCRETE_56NH_EMA-00005035V2256nHIND_CENTRAL_1008
L9IND_IND_CENTRAL_1008_DISCRETE_56NH_EMA-00005035V2256nHIND_CENTRAL_1008
L10IND_IND_CENTRAL_1008_DISCRETE_56NH_EMA-00005035V2256nHIND_CENTRAL_1008
LCD1LCD-EA-8081-A3N_LCD_EA_8081-A3N-B_DISCRETE_S1D13742F01A200_PSL-00000046S1D13742F01A200LCD_EA_8081-A3N-B
LCD2LCD-EA-8081-A3N_LCD_EA_8081-A3N-B_DISCRETE_S1D13742F01A200_PSL-00000046S1D13742F01A200LCD_EA_8081-A3N-B
P1HDR_2X7_M_SAMTEC_TST-107-XX-X-D_IO_TST-107-01-G-D_EMA-00006288V22TST-107-01-G-DSAMTEC_TST-107-XX-X-D
P2HDR_1X8_M_MOLEX_53261-8_FITNAIL_IO_53261-0819_EMA-00006083V2253261-0819MOLEX_53261-8_FITNAIL
P3HDR_1X8_M_MOLEX_53261-8_FITNAIL_IO_53261-0819_EMA-00006083V2253261-0819MOLEX_53261-8_FITNAIL
Q1BJT_NPN_BEC_SOT95P230X109-3N_DISCRETE_2N2222AUB_PSL-000000212N2222AUBSOT95P230X109-3N
Q2MOSFET_I_EN_GSD_TO230P950X240-3N_DISCRETE_MMBFJ310LT1G_PSL-00000024MMBFJ310LT1GTO230P950X240-3N
Q3BJT_NPN_BEC_TO92_DISCRETE_2N3866_PSL-000000252N3866TO92
Q4BJT_NPN_BEC_SOT95P240X114-3N_DISCRETE_KST3904_EMA-00004866V22KST3904SOT95P240X114-3N
Q5BJT_NPN_BEC_SOT95P240X114-3N_DISCRETE_KST3904_EMA-00004866V22KST3904SOT95P240X114-3N
Q6BJT_NPN_BEC_SOT95P240X114-3N_DISCRETE_KST3904_EMA-00004866V22KST3904SOT95P240X114-3N
Q7BJT_NPN_BEC_SOT95P240X114-3N_DISCRETE_KST3904_EMA-00004866V22KST3904SOT95P240X114-3N
Q8BJT_PNP_BCE_SOT95P230X109-3N_DISCRETE_2N3905_PSL-000000222N3905SOT95P230X109-3N
Q9BJT_NPN_BEC_TO230P950X240-3N_DISCRETE_2N5179-NRC_PSL-000000232N5179-NRCTO230P950X240-3N
RN1RES_NET_8_RESNET_8_DISCRETE_47OHMS_PSL-0000003447OhmsRESNET_8
RN2RES_NET_8_RESNET_8_DISCRETE_100OHM_PSL-00000011100OhmRESNET_8
RN3RES_NET_8_RESNET_8_DISCRETE_100OHM_PSL-00000011100OhmRESNET_8
SW1SWDIP-4/SM_SOIC254P1077X800-8M_DISCRETE_76HPSB04GWRT_PSL-0000002776HPSB04GWRTSOIC254P1077X800-8M
SW2SW_SPST_13_24_SW_EVQ-PH_NO_GND_DISCRETE_EVQPH_EMA-00004784EVQPHSW_EVQ-PH_NO_GND
U1DEMOG_INTERFACE_FT256_IC_(S1+S2+S3+S4+S5+S6)_XC6SLX25-3FTG256_PSL-00000032XC6SLX25-3FTG256FT256
U2DEMOG_COPROC_FT256_IC_(S1+S2+S3+S4+S5+S6)_XC6SLX25-3FTG256_PSL-00000033XC6SLX25-3FTG256FT256
U3LM78L05_SO8_SOIC127P600X175-8N_IC_L78L08ACD13TR_PSL-00000009L78L08ACD13TRSOIC127P600X175-8N
U4AD9850_SOP65P780X200-28N_IC_AD9850BRSZ_PSL-00000010AD9850BRSZSOP65P780X200-28N
U5VREG_TGND_TO254P1410X464-4N_IC_LM340_EMA-00007000V22LM340TO254P1410X464-4N
U6FCT16245_SOP50P810X110-48N_IC_74ALVT16245DGG,118_PSL-00000016_0_0_0_074ALVT16245DGG,118SOP50P810X110-48N
U774-245_20P_SOIC127P1028X265-20N_IC_74ACT245_EMA-00006591V2274ACT245SOIC127P1028X265-20N
U8FCT16245_SOP50P810X110-48N_IC_74ALVT16245DGG,118_PSL-00000016_0_0_0_074ALVT16245DGG,118SOP50P810X110-48N
U9FCT16245_SOP50P810X110-48N_IC_74ALVT16245DGG,118_PSL-00000016_0_0_0_074ALVT16245DGG,118SOP50P810X110-48N
U10XCF01SVOG20_XCF01SVOG20_IC_XCF01SVOG20C_PSL-00000005XCF01SVOG20CXCF01SVOG20
U11XCF01SVOG20_XCF01SVOG20_IC_XCF01SVOG20C_PSL-00000030XCF01SVOG20CXCF01SVOG20
U12MT47H64M16_MT47H128M_IC_(S1+S2)_MT47H64M16HR-3:GTR_PSL-00000002MT47H64M16HR-3:GTRMT47H128M
U13MT47H64M16_MT47H128M_IC_(S1+S2)_MT47H64M16HR-3:GTR_PSL-00000002MT47H64M16HR-3:GTRMT47H128M
U22FF_D_8X_OE3S_20P_SOIC127P1032X265-20AN_IC_74HCT574_EMA-00007307V2274HCT574SOIC127P1032X265-20AN
U29LTM8025_LTUMODULE7X11_IC_LTM8025EV#PBF_PSL-00000026LTM8025EV#PBFLTUMODULE7X11
U30LTM8025_LTUMODULE7X11_IC_LTM8025EV#PBF_PSL-00000026LTM8025EV#PBFLTUMODULE7X11
U31LTM8025_LTUMODULE7X11_IC_LTM8025EV#PBF_PSL-00000026LTM8025EV#PBFLTUMODULE7X11
U32TLC5602A_SOIC127P1028X265-20N_IC_TLC5602CDWR_PSL-00000028TLC5602CDWRSOIC127P1028X265-20N
U33DG419A_SOG0508WG244L225_IC_DG419CY+_PSL-00000008DG419CY+SOG0508WG244L225
U34TLE2037A_TO99_IC_TLE2037AQDRG4Q1_PSL-00000007TLE2037AQDRG4Q1TO99
U35TLC5602A_SOIC127P1028X265-20N_IC_TLC5602CDWR_PSL-00000028TLC5602CDWRSOIC127P1028X265-20N
U36DG419A_SOG0508WG244L225_IC_DG419CY+_PSL-00000008DG419CY+SOG0508WG244L225
U37TLE2037A_TO99_IC_TLE2037AQDRG4Q1_PSL-00000007TLE2037AQDRG4Q1TO99
U38FF_D_8X_OE3S_20P_SOIC127P1032X265-20AN_IC_74HCT574_EMA-00007307V2274HCT574SOIC127P1032X265-20AN
U39FF_D_8X_OE3S_20P_SOIC127P1032X265-20AN_IC_74HCT574_EMA-00007307V2274HCT574SOIC127P1032X265-20AN
U40UPD431000AGW-B15_SOJ127P866X375-32N_IC_UPD431000AGW-B15_PSL-00000035UPD431000AGW-B15SOJ127P866X375-32N
U41UPD431000AGW-B15_SOJ127P866X375-32N_IC_UPD431000AGW-B15_PSL-00000035UPD431000AGW-B15SOJ127P866X375-32N
U42UPD431000AGW-B15_SOJ127P866X375-32N_IC_UPD431000AGW-B15_PSL-00000035UPD431000AGW-B15SOJ127P866X375-32N
U43UPD431000AGW-B15_SOJ127P866X375-32N_IC_UPD431000AGW-B15_PSL-00000035UPD431000AGW-B15SOJ127P866X375-32N
U44UPD431000AGW-B15_SOJ127P866X375-32N_IC_UPD431000AGW-B15_PSL-00000035UPD431000AGW-B15SOJ127P866X375-32N
U45UPD431000AGW-B15_SOJ127P866X375-32N_IC_UPD431000AGW-B15_PSL-00000035UPD431000AGW-B15SOJ127P866X375-32N
U46UPD431000AGW-B15_SOJ127P866X375-32N_IC_UPD431000AGW-B15_PSL-00000035UPD431000AGW-B15SOJ127P866X375-32N
U47UPD431000AGW-B15_SOJ127P866X375-32N_IC_UPD431000AGW-B15_PSL-00000035UPD431000AGW-B15SOJ127P866X375-32N
U4874-245_20P_SOIC127P1028X265-20N_IC_74ACT245_EMA-00006591V2274ACT245SOIC127P1028X265-20N
U49MAX6711_SOT343N_IC_MAX6711S_EMA-00006895V22MAX6711SSOT343N
U50NBC12429_QFN50P500X500X100-33N_IC_NBC12429AMNR4G_PSL-00000017NBC12429AMNR4GQFN50P500X500X100-33N
U51TPS51200_DRC10_2P4X1P65_IC_TPS51200DRCR_PSL-00000036TPS51200DRCRDRC10_2P4X1P65
XTAL1OSC_SEL383_OSCSC254P500X700X200-6N_DISCRETE_100MHZ_EMA-00005837V22100MHzOSCSC254P500X700X200-6N
Y1OSC4_24NC_OSCCC350X600X120N_DISCRETE_20MHZ_EMA-00005829V2220MHzOSCCC350X600X120N
此广告位出租
此广告位出租
 楼主| 发表于 2022-3-5 14:04:34 | 显示全部楼层
PCB文件。回复可见下载
游客,如果您要查看本帖隐藏内容请回复
此广告位出租
    1 小时前
  • 签到天数: 111 天
    发表于 2022-3-5 14:44:14 | 显示全部楼层
    发表于 2022-3-5 14:59:02 | 显示全部楼层
    1 小时前
  • 签到天数: 54 天
    发表于 2022-3-5 15:54:32 | 显示全部楼层
    无聊
    2024-9-13 08:51
  • 签到天数: 39 天
    社区居民忠实会员社区劳模终身成就奖特殊贡献奖原创先锋奖优秀斑竹奖
    发表于 2022-3-5 17:20:59 | 显示全部楼层
    昨天 15:12
  • 签到天数: 111 天
    发表于 2022-3-5 17:32:50 | 显示全部楼层
    昨天 15:12
  • 签到天数: 111 天
    发表于 2022-3-5 17:33:21 | 显示全部楼层
    发表于 2022-3-5 18:15:00 | 显示全部楼层
    3 天前
  • 签到天数: 63 天
    5万
    发表于 2022-3-5 18:34:03 | 显示全部楼层
    论坛开启做任务可以
    额外奖励金币快速赚
    积分升级了
