在公司用Allegro 17.4 转pads ,安装论坛上的教程,成功转换。 ,$,6%"'"
用自己电脑转(也是Allegro 17.4),设置完用户环境变量,在Allegro 中输入命令时就有问题了。我把错误复制在下面:(文件路径是全英文的) :bLLN
=<.8
c}II"P
skill load "dfl_main.il" 7P`|wNq
t 05zBB
main out A| #9
Please wait...extracting and processingtechnology file +8FlDiP
Deleting Existing Classes File Ly?gpOqu5
Deleting Existing Props File ,%+i}H,3
Deleting Existing Board Items File ?qviJDD|f
Exporting Electrical Constraints... -d+q +l>0
extracting device files g4WN+y`
Error: create_devices command failed! |0?h6
extracting Net Properties 8_MR7'C1hi
extracting Board Extent aClXg-
Cannot open script file; 'D:/Allegro.scr'does not exist. n"dC]&G'
DCprocessWidthTable - DEFAULT width used -hf)%o$
extracting padstacks yWa-iHWC
extracting padstack completed 5MH\Gqe7
extracting Placement Y!LcS48X
leaving placement -X ~VXeg
extracting Device Pads p/B&R@%
devices pads extraction completed #Sj:U1x
extracting Board Areas MfhJb_q`
Loading skillExt.cxt /O1r=lv3Z
(SPMHA1-161): Cannot openthe design because of database problems. Run the dbdoctor command on the designand try to open again. #Al.Itj
(SPMHDB-95): Padstack VIA16 not found.Purging it from DIFF90 constraint set will eliminate warning. +B$o8V
* 2 error(s) generated, viewinterfacelog.txt u@\]r 1
D:/Allegroxuexi/20220607/WATCH_TS35_V2_202205191743-6_MGC/Work/LayoutDB.dfl OutputComplete. [XWY-q#Gg
Generating Padstack HKP FIle. 66x>*
--------------------------- ZPWY0&9
Create .PAD Definitions. j4L )D
Create .HOLE Definitions. HTK79
Create .PADSTACK Definitions. i DV.L
Generating Cell HKP File. Gxu&o%x[
--------------------------- MP\$_;&xB
Info: Database transaction started. `s (A&=g\
Cell HKP Added temp instance of symbol:"ANTENK_FPC03_13" yjODa90!G
Cell HKP Added temp instance of symbol:"LGA-12-2X2X100" &k+G^ !=s#
Cell HKP Added temp instance of symbol:"CRYSTAL-4P-3225-H1A" {O,D9 <
Cell HKP Added temp instance of symbol:"DFN8L-200X200" utxT$1iJn~
Cell HKP Added temp instance of symbol:"QFN52-040-600X600" $v?+X20
Cell HKP Added temp instance of symbol:"QFN20-040-300X300" r3oAP[+n
Cell HKP Added temp instance of symbol:"ANTENK_FPC03_15" -o<L%Y<n2
Cell HKP Added temp instance of symbol:"R0603" 'f9fw^
Cell HKP Added temp instance of symbol:"R0402" cg$@x\fJ
Cell HKP Added temp instance of symbol:"R0805" 5
T1M:~u i
Cell HKP Added temp instance of symbol:"SOT-723" 6RV]9
Cell HKP Added temp instance of symbol:"C0603" {dV#"+
Cell HKP Added temp instance of symbol:"LGA8" sw{,l"]<
Cell HKP Added temp instance of symbol:"C0402" ps1ndGp~#
Current Symbol: C0402 Be+CV">2
Current Symbol: LGA8 0S <;T+WA
Current Symbol: C0603 U7d%*g
Current Symbol: SOT-723 N"MuAUB:K
Current Symbol: R0805 TQDb\d8,f
Current Symbol: TP20 :1"{0gm
Current Symbol: SOD-523 ZcgSVMqEX
Current Symbol: WIFI iva&W
Current Symbol: R0402 hc}dS$=C
Current Symbol: C0201 'awL!P--
Current Symbol: TH120_CR300 <:)T7yVq
Current Symbol: R0603 a<l(zJptG
Current Symbol: R0201 $e#p -z
Current Symbol: ANTENK_FPC03_15 R4G$!6Ld
Current Symbol: QFN20-040-300X300 [$)C(1zY
Current Symbol: QFN52-040-600X600 ',k0_n?t
Current Symbol: DFN8L-200X200 (#FWA<o
Current Symbol: CRYSTAL-4P-3225-H1A bj4cW\b(
Current Symbol: LGA-12-2X2X100 ^& ZlV
Current Symbol: ANTENK_FPC03_13 ri&B%AAc
Cannot open script file;'D:/Allegro.scr' does not exist. z5-vx `
Removing temporarily added symbols.
z"8%W?o>
14 symbols removed. ;
mF-y,E
Creating Net Properties Mw2?U>h1
Creating Net Class )tGeQXVhbJ
---------------------- Al2Exp summary---------------------- cUssF%ud]
Al2Exp - 2 error(s), 6 warning(s) ;:Q 5?zM
Export log file saved at "D:/Allegroxuexi/20220607/WATCH_TS35_V2_202205191743-6_MGC\LogFiles\interfacelog.txt"file B
Jp\a7`;
Run "show log" command to viewlog file AVyO5>w
------------------------------ Done------------------------------- 7ET^,6
Form field label not found +h^>?U,
@ROMHMd}
$wUFHEl
红色标出是错误位置。求大神帮忙看看是哪里问题,谢谢!
