\C h01LR" 一键修改/还原默认字体 字体问题解决.zip (2 K) 下载次数:2 l {>j8Ln win10一键还原默认字体_重启OK: ?Ve IlD r$}C<a[U @echo off
?%}!_F`h% +a1iZ bh >nul 2>&1 "%SYSTEMROOT%\system32\cacls.exe" "%SYSTEMROOT%\system32\config\system"
-!:5jfT" F_jHi0A if '%errorlevel%' NEQ '0' (
G0Qw&
mqF ~IS8DW$; echo 请求管理员权限...
kMMgY? 7K:V<vX5 goto UACPrompt
R]iV;j| z+yIP ?s}( ) else ( goto gotAdmin )
Cl]?qH*: Xa?O)Bq. :UACPrompt
h%Nd89// -6HwGfU echo Set UAC = CreateObject^("Shell.Application"^) > "%temp%\getadmin.vbs"
yy7(')wKO EZ]4cd/i echo UAC.ShellExecute "%~s0", "", "", "runas", 1 >> "%temp%\getadmin.vbs"
4^F%bXJ) k[;)/LfhS "%temp%\getadmin.vbs"
^hmV?a:Y "4)N]Nj exit /B
r~j
[Qm"CJ #e|o"R;/` :gotAdmin
]A'{DKR yXJ25Axb if exist "%temp%\getadmin.vbs" ( del "%temp%\getadmin.vbs" )
h<`aL;.g kz7FQE reg add HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows" "NT\CurrentVersion\Fonts /v Microsoft" "YaHei" "^&" "Microsoft" "YaHei" "UI" "(TrueType) /t reg_sz /d msyh.ttc /f
4JAz{aw'b 1 _?8 OU reg add HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows" "NT\CurrentVersion\Fonts /v Microsoft" "YaHei" "Bold" "^&" "Microsoft" "YaHei" "UI" "Bold" "(TrueType) /t reg_sz /d msyhbd.ttc /f
)Y7H@e\1 ~Ld5WEp k3 reg add HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows" "NT\CurrentVersion\Fonts /v Microsoft" "YaHei" "Light" "^&" "Microsoft" "YaHei" "UI" "Light" "(TrueType) /t reg_sz /d msyhl.ttc /f
oS fr5
i =9GALoGL reg delete HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows" "NT\CurrentVersion\FontSubstitutes /v Microsoft" "YaHei /f
J rx^ tQ|c.`)W reg delete HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows" "NT\CurrentVersion\FontSubstitutes /v Microsoft" "YaHei" "UI /f
F@i>l{C &q-&%~E@ win10一键修改默认字体_重启OK: i/x |c!E i6'=]f'{ @echo off
<l{oE?N uL`#@nI >nul 2>&1 "%SYSTEMROOT%\system32\cacls.exe" "%SYSTEMROOT%\system32\config\system"
1;ttwF>G7 yYA*5
7^A if '%errorlevel%' NEQ '0' (
V]F D'XAl {aY) Qv} echo 请求管理员权限...
gyw=1q+ y2jv84
M goto UACPrompt
DM^0[3XuV5 A@}5'LzL ) else ( goto gotAdmin )
'"B $oBs%.Jp :UACPrompt
yE8D^M|g An.
A1y echo Set UAC = CreateObject^("Shell.Application"^) > "%temp%\getadmin.vbs"
-V/y~/]J Lv%3 jj echo UAC.ShellExecute "%~s0", "", "", "runas", 1 >> "%temp%\getadmin.vbs"
8;@y\0 qVC+q8 "%temp%\getadmin.vbs"
\f9WpAY FS1\`#Bm) exit /B
r%U6,7d=) 8z`ZHn3= :gotAdmin
GW,EyOE+~ o[ZjXLJzV if exist "%temp%\getadmin.vbs" ( del "%temp%\getadmin.vbs" )
a{kJ`fK .4zzPD$1 reg add HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows" "NT\CurrentVersion\Fonts /v Microsoft" "YaHei" "^&" "Microsoft" "YaHei" "UI" "(TrueType) /t reg_sz /d simsun.ttc /f
fDy*dp4z "ko*-FrQ reg add HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows" "NT\CurrentVersion\Fonts /v Microsoft" "YaHei" "Bold" "^&" "Microsoft" "YaHei" "UI" "Bold" "(TrueType) /t reg_sz /d simsun.ttc /f
z%8`F%2 sFpg reg add HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows" "NT\CurrentVersion\Fonts /v Microsoft" "YaHei" "Light" "^&" "Microsoft" "YaHei" "UI" "Light" "(TrueType) /t reg_sz /d simsun.ttc /f
q/EX`%U 8^UF0>`' reg add HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows" "NT\CurrentVersion\FontSubstitutes /v Microsoft" "YaHei /t reg_sz /d SimSun /f
)U %`7(bN m!FuC=e reg add HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows" "NT\CurrentVersion\FontSubstitutes /v Microsoft" "YaHei" "UI /t reg_sz /d SimSun /f
/wJ#-DZ
