12Gbps 低成本误码测试仪 (BERT),可生成并检查多达 8 个通道的伪随机二元序列 (PRBS)。这一经过验证的设计提供了生成高达 12Gbps 的多通道高速串行位流的便捷方式,并可检查传入的串行位流是否具有位错误。 此设计可用作手持式 BERT,用于评估高速子系统的信号完整性和位错误性能。 Comment | Pattern | Quantity | Components | | | | | | | | | | | | | | | | | | 06031C102JAT2A | 603 | 1 | C59 | CAP, CERM, 1000 pF, 100 V, +/- 5%,X7R, 0603 | | | 06031C182JAT2A | 603 | 1 | C18 | CAP, CERM, 1800 pF, 100 V, +/- 5%,X7R, 0603 | | | 0603YC104JAT2A | 603 | 1 | C21 | CAP, CERM, 0.1 μF, 16 V, +/- 5%,X7R, 0603 | | | 142-0761-881 | Johnson_142-0761-881 | 4 | J6, J7, J9, J10 | Connector, TH, End launch SMA 50 ohm | | | 1902C | Keystone_1902C | 4 | H6, H7, H8, H9 | Standoff, Hex, 0.5L #4-40Nylon" | | | | 1SMB5922BT3G | SMB | 1 | D5 | Diode, Zener, 7.5 V, 550 mW, SMB | | | | 1X8A_81_MXP-S50-0-2/111_NE | H+S_1x8A_81_MXP-S50-0-2_111N | 4 | J4, J5, J8, J11 | Straight PCB plug Pin-in-hole/SMT | | | | 39544-3004 | MOLEX_39544-3004 | 1 | J1 | Terminal Block, 4x1, 5.08mm, TH | | | | 5000 | Keystone5000 | 1 | TP1 | Test Point, Miniature, Red, TH | | | | 6SVPE220MW | CAPSMT_62_E61 | 1 | C30 | CAP, AL, 220 μF, 6.3 V, +/- 20%,0.015 ohm, SMD | | ATS-P2-168-C1-R0 | HSINK_ATS-P2-168-C1-R0 | 1 | H1 | PushPIN? Heat Sink Assembly | | | | BK1608HS600-T | 603 | 1 | FB1 | Ferrite Bead, 60 ohm @ 100 MHz, 0.8A, 0603 | | | BLM18SG121TN1D | 603 | 1 | L1 | Ferrite Bead, 120 ohm @ 100 MHz, 3A, 0603 | | | BSS138 | SOT-23 | 1 | Q1 | MOSFET, N-CH, 50 V, 0.22 A, SOT-23 | | | | C0603C104K4RACTU | 603 | 1 | C68 | CAP, CERM, 0.1 μF, 16 V, +/- 10%,X7R, 0603 | | | C0603C221K5RACTU | 603 | 2 | C64, C73 | CAP, CERM, 220 pF, 50 V, +/- 10%,X7R, 0603 | | | C0603C222K5RACTU | 603 | 1 | C63 | CAP, CERM, 2200 pF, 50 V, +/- 10%,X7R, 0603 | | | C0805C106K8PACTU | 0805_HV | 2 | C8, C14 | CAP, CERM, 10 μF, 10 V, +/- 10%,X5R, 0805 | | | C1005X5R1A104K050BA | 402 | 3 | C20, C31, C112 | CAP, CERM, 0.1 μF, 10 V, +/- 10%,X5R, 0402 | | | C1005X5R1A105K050BB | 402 | 1 | C32 | CAP, CERM, 1 μF, 10 V, +/- 10%, X5R,0402 | | | C1005X5R1A225K050BC | 402 | 2 | C4, C12 | CAP, CERM, 2.2 μF, 10 V, +/- 10%,X5R, 0402 | | | C1005X5R1C105K050BC | 402 | 3 | C19, C110, C111 | CAP, CERM, 1 μF, 16 V, +/- 10%, X5R,0402 | | | C1005X7R1H104K050BB | 402 | 1 | C45 | CAP, CERM, 0.1 μF, 50 V, +/- 10%,C0G/NP0, 0402 | | C1608C0G1H100D080AA | 603 | 1 | C58 | CAP, CERM, 10 pF, 50 V, +/- 5%,C0G/NP0, 0603 | | C1608C0G1H102J080AA | 603 | 1 | C34 | CAP, CERM, 1000 pF, 50 V, +/- 5%,C0G/NP0, 0603 | | C1608C0G1H331F080AA | 603 | 2 | C38, C53 | CAP, CERM, 330 pF, 50 V, +/- 1%,C0G/NP0, 0603 | | C1608C0G1H332J080AA | 603 | 1 | C44 | CAP, CERM, 3300 pF, 50 V, +/- 5%,C0G/NP0, 0603 | | C1608X5R1A106M080AC | 603 | 1 | C33 | CAP, CERM, 10 μF, 10 V, +/- 20%,X5R, 0603 | | | C1608X7R1H104K080AA | 603 | 1 | C47 | CAP, CERM, 0.1 μF, 50 V, +/- 10%,X7R, 0603 | | | C1608X8R1H103K080AA | 603 | 2 | C52, C56 | CAP, CERM, 0.01 μF, 50 V, +/- 10%,X8R, 0603 | | C1608X8R1H472K080AA | 603 | 1 | C57 | CAP, CERM, 4700 pF, 50 V, +/- 10%,X8R, 0603 | | | C2012JB1V226M125AC | 0805_HV | 2 | C54, C55 | CAP, CERM, 22 μF, 35 V, +/- 20%, JB,0805 | | | C2012X5R0J106M125AB | 0805_HV | 1 | C51 | CAP, CERM, 10 μF, 6.3 V, +/- 20%,X5R, 0805 | | | C2012X5R1V226M125AC | 0805_HV | 1 | C37 | CAP, CERM, 22 μF, 35 V, +/- 20%,X5R, 0805 | | | C2012X7R1C105K125AA | 0805_HV | 2 | C28, C70 | CAP, CERM, 1 μF, 16 V, +/- 10%, X7R,0805 | | | C3216X5R1C476M160AB | 1206 | 9 | C35, C36, C39, C40, C41, C42, C43, C49, C50 | CAP, CERM, 47 μF, 16 V, +/- 15%,X5R, 1206 | | | CGB3B1X5R1A475K055AC | 603 | 1 | C46 | CAP, CERM, 4.7 μF, 10 V, +/- 10%,X5R, 0603 | | | CL03A104KP3NNNC | 201 | 28 | C78, C80, C82, C84, C86, C87, C88, C89, C90, C91, C92, C93, C94, C95,C96, C97, C98, C99, C100, C101, C102, C103, C104, C105, C106, C107, C108,C109 | CAP, CERM, 0.1 μF, 10 V, +/- 10%,X5R, 0201 | | | CL05A106MP5NUNC | 0402_70 | 2 | C1, C22 | CAP, CERM, 10 μF, 10 V, +/- 20%,X5R, 0402 | | | CL10A226MP8NUNE | 603 | 2 | C6, C11 | CAP, CERM, 22 μF, 10 V, +/- 20%,X5R, 0603 | | | CRCW04020000Z0ED | 402 | 8 | R28, R29, R30, R31, R32, R33, R35, R36 | RES, 0, 5%, 0.063 W, 0402 | | | | | CRCW040210K0FKED | 402 | 1 | R23 | RES, 10.0 k, 1%, 0.063 W, 0402 | | | | CRCW040210R0JNED | 402 | 1 | R3 | RES, 10, 5%, 0.063 W, 0402 | | | | | CRCW040218R0JNED | 402 | 1 | R7 | RES, 18, 5%, 0.063 W, 0402 | | | | | CRCW04021K00JNED | 402 | 6 | R72, R73, R75, R77, R78, R80 | RES, 1.0 k, 5%, 0.063 W, 0402 | | | | CRCW04021K50FKED | 402 | 1 | R40 | RES, 1.50 k, 1%, 0.063 W, 0402 | | | | CRCW04021K69FKED | 402 | 1 | R20 | RES, 1.69 k, 1%, 0.063 W, 0402 | | | | CRCW04021M20JNED | 402 | 1 | R42 | RES, 1.2 M, 5%, 0.063 W, 0402 | | | | CRCW040220K0JNED | 402 | 2 | R76, R79 | RES, 20 k, 5%, 0.063 W, 0402 | | | | CRCW0402330RJNED | 402 | 1 | R4 | RES, 330, 5%, 0.063 W, 0402 | | | | CRCW040233K0JNED | 402 | 2 | R37, R41 | RES, 33 k, 5%, 0.063 W, 0402 | | | | CRCW040233R0JNED | 402 | 1 | R6 | RES, 33, 5%, 0.063 W, 0402 | | | | | CRCW0402360RJNED | 402 | 1 | R25 | RES, 360, 5%, 0.063 W, 0402 | | | | CRCW04023K57FKED | 402 | 1 | R21 | RES, 3.57 k, 1%, 0.063 W, 0402 | | | | CRCW040247R0JNED | 402 | 1 | R5 | RES, 47, 5%, 0.063 W, 0402 | | | | | CRCW04024K22FKED | 402 | 1 | R24 | RES, 4.22 k, 1%, 0.063 W, 0402 | | | | CRCW040251R0JNED | 402 | 4 | R11, R12, R13, R14 | RES, 51, 5%, 0.063 W, 0402 | | | | | CRCW0402750RJNED | 402 | 25 | R18, R43, R44, R45, R46, R47, R48, R49, R50, R51, R52, R53, R54, R55,R56, R57, R58, R59, R62, R63, R64, R65, R66, R67, R68 | RES, 750, 5%, 0.063 W, 0402 | | | | CRCW06030000Z0EA | 603 | 1 | R82 | RES, 0, 5%, 0.1 W, 0603 | | | | | CRCW060310K0JNEA | 603 | 5 | R8, R9, R10, R60, R61 | RES, 10 k, 5%, 0.1 W, 0603 | | | | | CRCW060312K0JNEA | 603 | 3 | R15, R16, R17 | RES, 12 k, 5%, 0.1 W, 0603 | | | | | CRCW06031K00JNEA | 603 | 2 | R71, R74 | RES, 1.0 k, 5%, 0.1 W, 0603 | | | | CRCW0603200RJNEA | 603 | 2 | R34, R81 | RES, 200, 5%, 0.1 W, 0603 | | | | | CRCW0603270RJNEA | 603 | 1 | R2 | RES, 270, 5%, 0.1 W, 0603 | | | | | CRCW060327K4FKEA | 603 | 1 | R26 | RES, 27.4 k, 1%, 0.1 W, 0603 | | | | CRCW06032K70JNEA | 603 | 2 | R69, R70 | RES, 2.7 k, 5%, 0.1 W, 0603 | | | | CRCW0603390RJNEA | 603 | 1 | R1 | RES, 390, 5%, 0.1 W, 0603 | | | | | CRCW0603392KFKEA | 603 | 1 | R22 | RES, 392 k, 1%, 0.1 W, 0603 | | | | CRCW06033R92FKEA | 603 | 2 | R19, R27 | RES, 3.92, 1%, 0.1 W, 0603 | | | | | CWX813-100.0M | OSC_CWX | 1 | Y1 | OSC 100.0000MHZ 3.3V +-25PPM SMD | | | | DS125DF1610FBE/NOPB | ABB0196A | 1 | U8 | 9.8 to 12.5 Gbps 16-Channel Retimer,ABB0196A | | ECS-240-20-5PX-TR | XTAL_CSM-7X | 1 | Y2 | Crystal, 24.000MHz, 20pF, SMD | | | | EEE-FK1A220R | SM_RADIAL_B | 1 | C69 | CAP, AL, 22 μF, 10 V, +/- 20%, 1.35ohm, SMD | | ERJ-2RKF33R0X | 402 | 2 | R38, R39 | RES, 33.0, 1%, 0.1 W, 0402 | | | | | EVQ-PSD02K | SW_EVQ-PSD02K | 1 | S1 | Switch, Tactile, SPST-NO, SMT | | | | Fiducial | Fiducial10-20 | 3 | FID1, FID2, FID3 | Fiducial mark. There is nothing to buy or mount. | | GRM033R60J223KE01D | 201 | 3 | C81, C83, C85 | CAP, CERM, 0.022 μF, 6.3 V, +/- 10%,X5R, 0201 | | GRM033R61A103KA01D | 201 | 3 | C75, C77, C79 | CAP, CERM, 0.01 μF, 10 V, +/- 10%,X5R, 0201 | | GRM033R71A103KA01D | 201 | 2 | C74, C76 | CAP, CERM, 0.01 μF, 10 V, +/- 10%,X7R, 0201 | | GRM1555C1H101JA01D | 402 | 10 | C3, C5, C7, C9, C10, C13, C15, C24, C25, C26 | CAP, CERM, 100 pF, 50 V, +/- 5%,C0G/NP0, 0402 | | GRM155R61A104KA01D | 402 | 2 | C2, C23 | CAP, CERM, 0.1 μF, 10 V, +/- 10%,X5R, 0402 | | | GRM155R71C104KA88D | 402 | 2 | C66, C67 | CAP, CERM, 0.1 μF, 16 V, +/- 10%,X7R, 0402 | | | GRM155R72A332KA01D | 402 | 1 | C17 | CAP, CERM, 3300 pF, 100 V, +/- 10%,X7R, 0402 | | GRM1885C1H300JA01D | 603 | 2 | C61, C62 | CAP, CERM, 30 pF, 50 V, +/- 5%,C0G/NP0, 0603 | | GRM188R61C474KA93D | 603 | 1 | C65 | CAP, CERM, 0.47 μF, 16 V, +/- 10%,X5R, 0603 | | GRM188R71C103KA01D | 603 | 3 | C29, C48, C71 | CAP, CERM, 0.01 μF, 16 V, +/- 10%,X7R, 0603 | | GRM188R71H563KA93D | 603 | 1 | C16 | CAP, CERM, 0.056 μF, 50 V, +/- 10%,X7R, 0603 | | LG L29K-G2J1-24-Z | LG L29K_GREEN | 8 | D10, D11, D12, D13, D18, D19, D20, D21 | LED, Green, SMD | | | | | | LMK212B7225KG-T | 0805_HV | 2 | C27, C72 | CAP, CERM, 2.2 μF, 10 V, +/- 10%,X7R, 0805 | | | LMX2581SQ/NOPB | RTV0032A | 1 | U1 | LMX2581 Wideband FrequencySynthesizer with Integrated VCO, RTV0032A | LTST-C190GKT | LED_LTST-C190 | 2 | D1, D30 | LED, Green, SMD | | | | | | MSP430F5529IPN | PN0080A_N | 1 | U4 | Mixed Signal MicroController,PN0080A | | | NBXDPA017LN1TAG | ONSC_NBXDPA017 | 1 | Y3 | OSC, 156.25/312.5 MHz, 2.5 to 3.3 V,SMD | | | NY PMS 440 0025 PH | NY PMS 440 0025 PH | 4 | H2, H3, H4, H5 | Machine Screw, Round, #4-40 x 1/4,Nylon, Philips panhead | PJ-002AH-SMT-TR | CUI_PJ-002AH-SMT | 1 | J2 | Power Jack, SMT | | | | | | PrintedCircuit Board | 1 | !PCB1 | Printed Circuit Board | | | | | SML-311UTT86 | SML-31_Red | 18 | D2, D3, D6, D7, D8, D9, D14, D15, D16, D17, D22, D23, D24, D25, D26, D27,D28, D29 | LED, Red, SMD | | | | | | SSF-LXH305GD-TR | SSF-LXH305GD_Green | 1 | D4 | LED, Green, SMD | | | | | | TCA6424ARGJR | RGJ0032A | 1 | U7 | Low-Voltage 24-Bit I2C and SMBus I/OExpander, 24 Outputs, 1.65 to 5.5 V, -40 to 85 degC, 32-pin UQFN (RGJ), Green(RoHS & no Sb/Br) | TPD4E004DRYR | DRY0006A | 1 | U6 | 4-CHANNEL ESD-PROTECTION ARRAY FORHIGH-SPEED DATA INTERFACES, DRY006A | TPS54122RHLT | RHL0024A | 1 | U3 | Dual-Output, 3-A, Quiet Supply withIntegrated DC-DC Converter and Low-Noise LDO, RHL0024A | TPS73533DRBR | DRB0008A | 2 | U2, U5 | 500mA, Low Quiescent Current,Ultra-Low Noise, High PSRR Low-Dropout Linear Regulator, DRB0008A | USB Mini Type B | CONN_USB-Mini-B-1734035-2 | 1 | J3 | Connector, Receptacle, Mini-USB TypeB, R/A, Top Mount SMT | XAL4020-152MEB | XAL4020 | 1 | L3 | Inductor, Shielded, Composite, 1.5μH, 7.12 A, 0.02 ohm, SMD |
