论坛风格切换切换到宽版
发帖 回复
  • 344阅读
  • 3回复
[供应]WIFI7-802.11be/EHT-IPQ9574-IPQ9554-QCN9274-QCN6274 support-320/240MHz and Multi-RU technology [复制链接]
上一主题 下一主题
离线yiyi2023
性别:
人妖
发帖
金币
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       图酷模式  只看楼主 倒序阅读 使用道具 0楼 发表于: 09-28
WIFI7-802.11be/EHT-IPQ9574-IPQ9554-QCN9274-QCN6274 support-320/240MHz and Multi-RU technology L6nsVL&
WiFi7 is the latest generation of WiFi protocol standards, also known as IEEE 802.11be/EHT (Extremely High Throughput). Support for three frequency bands (2.4 GHz, 5 GHz and 6 GHz) to make the most of spectrum resources. dI7rx+L
S#p_Y^A
S m=ln)G=
WiFi 7 introduces 320 MHz ultra-wideband, 4096-QAM, multi-RU and multi-link operations, offering speeds 4.8 times faster than WiFi 6 and 13 times faster than WiFi 5. Unlock more scenes than ever before. _8 K|2$X
DcaKGjp
C "@>NC_
kkHK~(>G
hC<E4+5.,
QwFA0
T^7}Qs9
320MHz channel bandwidth 85|u;Fxf
With the opening of the 6 GHz band to Wi-Fi applications, Wi-Fi 7 supports up to 320 MHz channel bandwidth on the 6 GHz band, It also supports 20/40/80/160 MHz channel bandwidth in the 5 GHz and 6 GHz bands and 20/40 MHz in the 2.4 GHz band. The channel bandwidth of just 320 MHz doubles the maximum speed of Wi-Fi 7 compared to existing Wi-Fi 6/6E. \oxf_4X
Multi-RU A~E S{Zkh
Under the WiFi 6 protocol, each user can only send or receive frames on a specified resource unit (RU), which significantly limits the flexibility of spectrum resource scheduling. To address this issue and further improve spectral efficiency, WiFi 7 allows multiple RU to be assigned to a single user and can be combined to improve transmission efficiency. CfrO1iF
320/240MHz and Multi-RU are two concepts associated with the Wi-Fi 6E (802.11ax) standard. Let me tell you about each of them: *< fJgc"3
320/240MHz: E,?IIRg&
320MHz and 240MHz refer to the wireless spectrum bandwidth available in Wi-Fi 6E. Wi-Fi 6E is an extended version of Wi-Fi 6 (802.11ax), and its biggest feature is the ability to operate in the 6GHz band, which is wider than the traditional 2.4GHz and 5GHz bands and can provide greater bandwidth. #G0'Q2
320MHz and 240MHz refer to the spectrum bandwidth available in the 6GHz band, respectively. 320MHz bandwidth is wider and can provide higher data transmission speeds, but requires more wireless channels to support it. 240MHz is slightly narrower, but still has more bandwidth than the traditional 2.4GHz and 5GHz bands. pl,XS6mB
The 320/240MHz spectrum bandwidth is primarily a feature of Wi-Fi 6E, as it refers to the spectrum bandwidth available on the 6GHz band. Wi-Fi 6 (802.11ax) typically operates in the 2.4GHz and 5GHz bands, and its maximum bandwidth is usually 160MHz. This is why Wi-Fi 6 typically does not use 320/240MHz spectrum bandwidth. NF |[j=?
Multi-RU: c%b|+4 }x
Multi-RU refers to the use of multiple Radio units or Radio links. In Wi-Fi 6E, devices are typically equipped with multiple RF units to support greater spectrum bandwidth and higher performance. M9Sj@ww
Multiple RF units can be used to transmit and receive data simultaneously to improve the throughput and efficiency of the network. This is useful for dealing with high-density network environments and a large number of device connections, as it can alleviate network congestion issues. a $'U?%
Multi-RU technology can also be used to better manage multiple wireless channels to provide more reliable connections and lower latency. jc:=Pe!E
Multi-RU technology is typically used in more complex network environments to support multiple RF units or RF links to improve performance and reliability. While Wi-Fi 6 can also benefit from Multi-RU technology, it is typically more common in large-scale enterprise networks or high-density environments, while Wi-Fi 6 routers used in home or small office networks typically do not feature Multi-RU configurations.+ Txe*$T,(
$d-yG553
Wallys software technology advantages:Wallys has 10 years of experience in software development and is very experienced in uboot, Linux, wifi protocol, wifi performance, OS and other systems. It mainly uses Qualcomm chips to develop important software such as drivers and kernels, and has the ability to modify and compile to meet customers' different wifi functional requirements. Meanwhile, it participates in openwrt organization and code development. wifi5 product DR40x9 has been officially supported by openwrt.Hardware technology advantages:We have a strong hardware design team, and experienced people know that the most difficult part of hardware design is RF circuit design, baseband, etc., while wallys team made 0 error to achieve signal integrity, such as frequency conversion of network card, from 2.4G to 900M, which is a technological breakthrough.Clients: TIP,Facebook, Openwrt, etcEmail:sales@wallystech.comWEB:https://www.wallystech.com/
评价一下你浏览此帖子的感受
精彩
感动
搞笑
愤怒
一般
差劲
离线旧尔一
性别:
人妖
发帖
2211
金币
2122
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       只看该作者 1楼 发表于: 09-29
谢谢分享!
离线晕哥
性别:
人妖
发帖
2202
金币
2480
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       只看该作者 2楼 发表于: 09-29
谢谢分享!
离线weiziushi
性别:
人妖
发帖
2888
金币
2431
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       只看该作者 3楼 发表于: 09-30
快速回复
限150 字节
上一个 下一个
