pcb文件 8ItCfbqa6 Comment | Description | Designator | Footprint | LibRef | Quantity | 0.1u | 贴片电容 | C1, C2, C3, C5, C6,C7, C8, C11, C12, C13, C14, C15, C16, C17, C18, C19, C20, C21, C23, C24, C64,C66, C69, C73, C74, C75, C76, C77, C78, C79, C80, C81, C82, C88, C89, C91,C93, C95, C96, C97, C98, C101, C119, C120, C121, C124, C125, C126, C127,C128, C129, C130, C131 | 0402_C | 0402 100nF (104) 10%16V, 0402 1.0uF (105) 10% 25V | 53 | 47u | 贴片电容 | C4, C26, C30, C33,C38, C41, C44, C50, C53, C56, C94 | 1206_C | 1206 100nF (104) 10%50V | 11 | 10u | 贴片电容 | C9, C10 | 0603_C | 0603 10nF (103) 10%50V | 2 | 10u | 贴片电容 | C22, C85, C87, C92,C122, C123 | 0402_C | 0402 100nF (104) 10%16V, 0402 1.0uF (105) 10% 25V | 6 | 0.47u | 贴片电容 | C25, C28, C29, C32,C35, C36, C37, C40, C43, C46, C47, C48, C49, C52, C55, C58, C59, C60, C61,C115, C116, C117, C118 | 0402_C | 0402 1.0uF (105) 10%25V | 23 | 4.7u | 贴片电容 | C27, C31, C34, C39,C42, C45, C51, C54, C57, C86, C90, C114 | 0402_C | 0402 1.0uF (105) 10%25V | 12 | 10u | 贴片电容 | C62, C63 | 0805_C | 0805 6.8pF (6R8)0.25pF 50V | 2 | 1u | 贴片电容 | C65 | 0402_C | 0402 1.0uF (105) 10%25V | 1 | 22p | 贴片电容 | C67, C68 | 0402_C | 0402 1.0uF (105) 10%25V | 2 | 22u | 贴片电容 | C70, C71, C72, C102,C104, C105, C107, C108, C110, C111, C113 | 0603_C | 0603 22pF (220) 5%50V, 0603 8.2pF (8R2) 0.25pF 50V | 11 | 12p | 贴片电容 | C83, C84, C99, C100 | 0402_C | 0402 10nF (103) 10%50V | 4 | 15p | 贴片电容 | C103, C106, C109,C112 | 0402_C | 0402 68pF (680) 5%50V | 4 | THD2528-11SD-GF | | CARD1 | TF-SMD_THD2528-11SD-GF | THD2528-11SD-GF | 1 | 蓝灯 0603 | 发光二极管 | D1, D6, D7, D8, D9,D10, D11 | 0603_LED_S1 | 0603 蓝灯 | 7 | PESD15VL1BA,115 | TVS DIODE 15VWM 44VCSOD323 | D2 | FP-SOD323-CA-IPC_C | CMP-14432-000007-1 | 1 | MBR0530 | DIODE SCHOTTKY 30V500MA SOD123 | D3 | FP-425-04-MFG | CMP-2000-05113-2 | 1 | SS34 | Silicon Carbide PowerSchottky Diode, 3300 V, - 0.3 A, -55 to 175 degC, 2-Pin SMD, RoHS, Tape andReel | D4, D5 | GESC-GAP3SLT33-214-2_V | CMP-2000-05135-2 | 2 | 红灯 0603 | 发光二极管 | D12 | 0603_LED_S1 | 0603 红灯 | 1 | MF-MSMF020-2 | PTC RESET FUSE 30V200MA 1812 | F1 | FP-MF-MSMF020-2-MFG | CMP-07400-000027-1 | 1 | JD0-0001NL | CONN MAGJACK 1PORT1000 BASE-T | J1 | FP-JD0-0001NL-MFG | CMP-16436-000001-1 | 1 | 1747981-1 | HDMI Receptacle,Pitch 0.5 mm, 19 Position, Height 6.38 mm, RoHS, Tape and Reel | J2 | TE-1747981-1_V | CMP-1684-00008-1 | 1 | 61301621121 | THT Vertical PinHeader WR-PHD, Pitch 2.54 mm, Dual Row, 16 pins | J3 | 61301621121 | CMP-1502-01097-1 | 1 | 687140149022 | SMT ZIF ConnectorsHinge Type WR-FPC, Horizontal, Bottom Contact, pitch 0.5 mm, 40 pins | J4 | 687140149022 | CMP-1502-01641-1 | 1 | 61400826021 | USB 2.0 Type AReceptacle WR-COM, Stacked Horizontal, THT | J6 | 61400826021 | CMP-1502-03229-1 | 1 | camera | THT Vertical PinHeader WR-PHD, Pitch 2.54 mm, Dual Row, 18 pins | J7 | 61301821121 | CMP-1502-01101-1 | 1 | 434111050826 | WS-TASV SMD TactSwitch 6.0X3.5 mm | K1, K2, K3, K4, K5,K6 | 434111050826 | Switch-3.6*6.1*2.5 | 6 | 8-1437565-1 | SWITCH TACTILESPST-NO 0.02A 15V | K7 | FP-8-1437565-1-MFG | CMP-03407-000016-1 | 1 | 120OHM | 贴片磁珠 | L2 | 0805_L | 0805 100Ω 25% 100MHz | 1 | 2.2u | Wire Wound FerriteInductor for Power Lines 1.5μH ±30% 0.0684Ω 1750mA 1210 | L3 | FP-LQH32PB_N0-MFG | CMP-06042-011622-1 | 1 | 4.7u | SMD Power Inductors15uH ±20% 0.47A 0.612Ω | L4, L5, L6, L7 | FP-NR4010-MFG | CMP-14484-001436-1 | 4 | ST-025BH | AUDIO MAGNETIC XDCR2-4V SMD | LS1 | FP-ST-025BH-MFG | CMP-247804-000002-1 | 1 | TSW-104-08-L-S | 0.025" SQ PostHeader, Through-hole, Vertical, -55 to 125 degC, 2.54 mm Pitch, 4-Pin, Male,RoHS | P1 | SMTC-TSW-104-08-X-S | CMP-1024-00358-1 | 1 | 2N7002 7002 | MOS(场效应管) | Q1, Q2, Q3 | SOT-23(SOT-23-3) | 2N7002 7002 | 3 | 1k | 贴片电阻 | R1 | 0402_R | 0402 0Ω (0R0) 1% | 1 | 10k | 贴片电阻 | R2, R5, R6, R7, R26,R27, R28, R29, R30, R66, R71, R72, R83, R86, R87, R100, R101, R102, R103,R104, R105 | 0402_R | 0402 5.6KΩ (5601) 1%,0402 0Ω (0R0) 1%, 0603 82KΩ (8202) 1% | 21 | 33 | 贴片电阻 | R3, R4, R11, R16,R60, R76, R77, R78, R79 | 0402_R | 0402 5.6KΩ (5601) 1% | 9 | 470 | 贴片电阻 | R8, R12, R19, R31,R45, R47, R96, R97, R98, R99 | 0402_R | 0402 0Ω (0R0) 1%,0402 5.6KΩ (5601) 1% | 10 | 4.7k | 贴片电阻 | R9, R10, R20, R22,R35, R36, R37, R38, R39, R40, R41, R42, R44, R46, R69, R70, R73, R74, R81,R106, R108, R109 | 0402_R | 0402 0Ω (0R0) 1%,0402 5.6KΩ (5601) 1% | 22 | 20k | 贴片电阻 | R13, R14, R15, R17,R18, R65, R67 | 0402_R | 0402 5.6KΩ (5601) 1% | 7 | 100 | 贴片电阻 | R21, R51, R52, R53,R54, R55, R56, R57, R58, R59, R62, R63 | 0402_R | 0402 0Ω (0R0) 1%,0402 5.6KΩ (5601) 1% | 12 | 80.6 | 贴片电阻 | R23, R24 | 0402_R | 0402 0Ω (0R0) 1% | 2 | 240 | 贴片电阻 | R25 | 0402_R | 0402 0Ω (0R0) 1% | 1 | 68k | 贴片电阻 | R32 | 0402_R | 0402 5.6KΩ (5601) 1% | 1 | 150k | 贴片电阻 | R33 | 0402_R | 0402 5.6KΩ (5601) 1% | 1 | 1k | 贴片电阻 | R34, R68 | 0603_R | 0603 82Ω (82R0) 1% | 2 | 0 | 贴片电阻 | R43, R50 | 0603_R | 0603 10KΩ (1002) 1% | 2 | 2.49k | 贴片电阻 | R48 | 0402_R | 0402 5.6KΩ (5601) 1% | 1 | 1 | 贴片电阻 | R49 | 0603_R | 0603 10KΩ (1002) 1% | 1 | 1.5k | 贴片电阻 | R61 | 0402_R | 0402 5.6KΩ (5601) 1% | 1 | 8.06k | 贴片电阻 | R64 | 0402_R | 0402 5.6KΩ (5601) 1% | 1 | 5.1k | 贴片电阻 | R80, R82 | 0603_R | 0603 82KΩ (8202) 1% | 2 | 12k | 贴片电阻 | R84 | 0603_R | 0603 82KΩ (8202) 1% | 1 | 10k | 贴片电阻 | R85 | 0603_R | 0603 10KΩ (1002) 1% | 1 | 100k | 贴片电阻 | R88, R94, R95 | 0402_R | 0402 5.6KΩ (5601) 1% | 3 | 120k | 贴片电阻 | R89 | 0402_R | 0402 5.6KΩ (5601) 1% | 1 | 200k | 贴片电阻 | R90 | 0402_R | 0402 5.6KΩ (5601) 1% | 1 | 453k | 贴片电阻 | R91 | 0402_R | 0402 5.6KΩ (5601) 1% | 1 | 2k | 贴片电阻 | R107 | 0402_R | 0603 82KΩ (8202) 1% | 1 | XC7Z010-1CLG400I | 667 MHz Zynq™-7000 APSoC, 130 PS I/O, 100 FPGA I/O, 400-Ball BGA, Speed Grade 1, Industrial Grade,Pb-Free | U1 | CLG400 | CMP-0363-00008-3 | 1 | W25Q128FVSIG | 3V 128M-Bit SerialFlash Memory with Dual/Quad SPI & QPI, 2.7 to 3.6 V, -40 to 85 degC,8-Pin SOIC, RoHS, Tape and Reel | U2 | WINB-SOIC-8_M | CMP-2000-05005-1 | 1 | MT41K256M16HA-125IT:E | 4Gb DDR3-1600 SDRAM,256Mb x 16, 1.25 ns, 1.35 V, -40 to 95 degC, 96-Ball FBGA | U3 | MICT-HA-96 | CMP-2000-04969-1 | 1 | MT3410LB | | U4, U5, U12, U13 | SOT-23-5 | MT3410LB | 4 | RTL8211E-VB-CG | | U6 | QFN48-6x6 | RTL8211E-VB-CG | 1 | USB3320C-EZK | Highly IntegratedFull Featured Hi-Speed USB 2.0 ULPI Transceiver, 1.8 to 3.3 V, -40 to 85degC, 32-Pin QFN (QFN-3304), RoHS, Tray | U7 | MCHP-QFN-32-5x5_V2 | CMP-0186-00335-1 | 1 | TPS2051BDBVR | Current-Limited,Power-Distribution Switch, 2.7 to 5.5 V, -40 to 85 degC, 5-Pin SOT-23 (DBV),Green (RoHS & no Sb/Br), Tape and Reel | U8 | DBV0005A_L | CMP-2000-07277-1 | 1 | TXB0108PWR | TXB01088-Bit Bidirectional Voltage-Level Translator with Auto-Direction Sensingand Xs.$2 \.XT:B_ +/- 15-kV ESD Protection, 1.2 to 3.6 V, -40 to 85 degC, 20-Pin TSSOP (PW),Green (RoHS & no Sb/Br), Tape and Reel | U9 | PW0020A_L | CMP-2000-07337-1 | 1 | 93LC56BT-I/OT | IC EEPROM 2K SPI 2MHZSOT23-6 | U10 | FP-C04-028-MFG | CMP-0162-00356-2 | 1 | FT4232HL-REEL | IC USB HS QUADUART/SYNC 64-LQFP | U11 | FP-LQFP-64-MFG | CMP-0078-00021-4 | 1 | SL2.1A | | U14 | SOIC-16_150mil | SL2.1A | 1 | AT93C66B-SSHM-T | IC EEPROM 4KBIT SPI2MHZ 8SOIC | U15 | FP-C04-057-SN-MFG | CMP-06313-000039-1 | 1 | U254-051T-4BH83-F1S | | USB1 | MICRO-USB-SMD_U254-051T-4BH83-F1S | Micro-USB | 1 | GT-USB-7010B | | USB2, USB3 | USB-C-SMD_GT-USB-7010B- duplicate | Type-C | 2 | 50MHz | XTAL OSC XO25.0000MHZ CMOS SMD | Y1 | FP-ASE-MFG | CMP-2000-05795-2 | 1 | 33.333MHz | XTAL OSC XO25.0000MHZ CMOS SMD | Y2 | FP-ASE-MFG | CMP-2000-05795-2 | 1 | 25M | CRYSTAL 16.0000MHZ9PF SMD | Y3 | FP-TSX-3225-MFG | CMP-36405-000014-1 | 1 | 12M | CRYSTAL 16.0000MHZ9PF SMD | Y4, Y5, Y6 | FP-TSX-3225-MFG | CMP-36405-000014-1 | 3 | \Nh^Ig 4w?]dDyc% fwar8
i1 附件 J, (U<%n ad工程文件 ZYNQ board.rar (41797 K) 下载次数:31
