Bill Of Materials November 28,2016 tQy@d_a=y
Item Quantity Reference Part zMT0ToG
______________________________________________ 7XE/bhe%S
1 1 CN7 FY-3480 $ 1 N_qu
2 1 CN12 RJ-45 cH()Ze-B
3 1 CN205 SATA Holder _LV;q! /j
4 2 CN206,CN701 S-SPIDIF a G^kL
5 3 CN207,CN208,CN702 Vertical single AV M"OXNPkc
6 1 CN401 PCI_Express iPMI$
7 1 CN402 SD_CARD mbBd3y
8 1 CN404 USB V Connector 8>TDrpT}
9 1 CN801 HDMI_CONN Y`QJcC(3
10 1 CN901 NC/POWER JACK u4L&8@
11 3 C39,C616,C617 0.01uF goi5I(yn^
12 201 C199,C201,C202,C203,C204, 0.1uF NTk"W!<Cl2
C205,C206,C207,C208,C209, qlJP2Ig~
C210,C211,C212,C213,C214, [X.sCl|
C215,C216,C217,C222,C223, mnM#NT5]
C224,C225,C226,C231,C232, ?d1H]f<M
C233,C234,C235,C240,C241, CUB= T]
C242,C243,C250,C251,C252, UNcS\t2N
C253,C255,C256,C257,C258, 9l?#ZuGXp
C259,C260,C265,C266,C267, J7BfH,o
C269,C270,C273,C274,C278, Zqke8q
C282,C284,C286,C287,C301, Ti
}Ljp^O
C302,C303,C304,C305,C306, sm-RpZ&|
C307,C313,C314,C315,C316, rrei6$H&
C317,C318,C319,C326,C327, ir<HC 'D[
C328,C329,C330,C331,C332, &ZgB b
C333,C334,C335,C338,C339, 95;q] =U
C340,C341,C342,C344,C345, ~xqRCf{8
C346,C347,C350,C351,C352, xI}h{AF7
C353,C354,C356,C357,C401, \$ L2xd
C402,C403,C404,C405,C406, z#*w Na&@[
C408,C409,C425,C426,C427, [k(oQykq
C428,C612,C613,C614,C627, @cNX\$J
C629,C701,C702,C703,C704, D}l^ow
C705,C706,C707,C708,C709, |s
:b9sfA
C710,C711,C712,C713,C714, ["}0umt
C715,C716,C717,C718,C719, P?dE\Po7
C720,C721,C722,C723,C724, $VYMAk&\
C725,C726,C727,C728,C729, oJy ]n9
C730,C731,C805,C806,C807, pC0l}hnUg
C808,C809,C810,C811,C812, 0t<]Uf
C813,C814,C815,C816,C817, 0"$Ui#r`
C819,C820,C821,C822,C823, T_O\L[]p*
C824,C825,C826,C827,C828, @2-Eky
C829,C830,C831,C832,C833, r#wMd9])
C834,C835,C836,C838,C840, 4flyV -
C841,C842,C843,C844,C845, s.]7c
CY
C847,C853,C854,C855,C856, pS
vDH-
C858,C859,C860,C862,C907, a?CV;9
C908,C920,C925,C930,C935, wE:hl
C937,C938,C939,C940,C946, (Vglcj
C947 `<2y
[<y
13 12 C218,C219,C220,C221,C227, 1uF '/kSUvd
C228,C229,C230,C416,C615, ~M%r.WFpA
C626,C628 TOV531
14 2 C236,C238 100uF/6.3V Bo8+uRF|
15 3 C239,C244,C943 22uF/25V A.m#wY8
16 11 C279,C280,C285,C358,C359, 47uF/10V vRYQ4B4o
C734,C911,C916,C917,C918, 4lH$BIAW
C924 &GcWv+p
17 21 C281,C283,C420,C421,C422, 10uF/16V 7Xm7{`jH
C424,C601,C602,C603,C605, Q4r)TR ,
C608,C801,C802,C803,C804, PhF3' ">
C903,C904,C905,C906,C910, S/& _
C934 A@#9X'C$^
18 1 C417 330pF @yPa9Ug(V
19 3 C618,C619,C620 3.3uF/6.3V e&?o
20 1 C621 1.0uF ET1/oG<@
21 2 C622,C623 2.2nF D+d\<":
22 2 C732,C733 33pF $}r*WZ
23 1 C735 470uF/16V .|$6Pi%!
24 2 C738,C739 2200pF ^ Afq)26D
25 1 C754 NC/47uF/10V x F7C1g(
26 1 C846 NC / 47uF/10V D`PnY&ffT
27 1 C851 NC/0.1uF ~M`QFF
28 1 C857 NC / 0.47uF Zso&.IATng
29 4 C928,C929,C945,C948 22uF/10V 1iEZ9J?
30 1 C931 0.33F/5.5V Supercap )h&s.k
31 2 C932,C933 10pF $w`QQ^\
32 4 C936,C941,C942,C944 1.2nF X*VHi
33 5 D2,D3,D403,D702,D802 BAT54 Q[`J=
34 2 D209,D701 5V10PE &Al9%W
35 2 D401,D402 SRV05-4 M@fUZh
36 8 FB202,FB203,L210,L401, 120 OHM / 2A LGZ5py=xb
L402,L802,L803,L806 *`[dC,+`.
37 11 FB701,FB702,FB703,FB704, 600 OHM {C Qo}@.7
FB705,FB706,FB801,FB802, /`#sp
FB803,FB805,FB806 #z 3tSnmp
38 4 H1,H2,H3,H4 Hole 3mm {ecmOxKP}
39 1 JMP3 JUMPER 2X2 R X:wt
40 1 JMP902 JMPER s`M[/i3Nm
41 2 JMP904,JMP905 JMPER 2X2 3Vj uk7
42 1 J5 NC/Header 20PinX2, 2.0mm EL$"MT}p
43 1 J6 NC/HEADER 3 2mm 2f ]CnD0$
44 1 J8 NC/Header 2x5Pin, 2.0mm Y%:FawR
45 1 J201 Header 4Pin, 2.54mm FCTz>N^p
46 1 J202 Header 7PinX2, 2.54mm ]8KAat~J
47 2 J901,J902 FM_1R5P_2_0mm bs$x%CR
48 1 J903 Molex "mini-fit" :D6"h[7
49 1 J907 Header 4Pin, 2.5mm _,(]T&j #2
50 3 LED1,LED5,LED7 LED-G De,4r(5
51 1 LED4 LED-R U;o[>{L
52 10 L14,L17,L211,L212,L214, 300 OHM 3 G/#OJ
L215,L216,L217,L218,L406 Hi #'h
53 3 L804,L805,L808 NC/120 OHM / 2A fBS`b[x
54 1 L908 2.2uH/2A NKB,D$!~&
55 1 L909 4.7uH/2A WV_y@H_
56 2 L910,L911 3.3uH/2A d)`XG cx{=
57 2 OP2,OP3 PADOPT uZ][#[u
58 1 OSC1 OSC 25MHz ~Fv&z'R
59 2 Q402,Q403 2SC2412K +hL+3`TD#H
60 7 Q404,Q901,Q905,Q907,Q908, AP2305GN g=.~_&O
Q912,Q913 pisjfNT`o
61 1 Q802 2SB1188 0 (jb19
62 1 Q803 2SB1182 MJ'|$b}
63 8 Q902,Q903,Q904,Q906,Q909, FDV301N/SOT23 *F/ uAI^)
Q910,Q911,Q914 j|gv0SI_
w
64 24 R207,R226,R227,R228,R229, 33 5&q@;vR
R253,R254,R255,RP601, Z#YkAQHv5
R634,R635,RP701,RP702, ?F' gh4
RP703,RP712,R716,R717, N+)4]ir>
R818,R819,R820,R821,R822, '0x`Oh&PK
R823,R827 T0n=nC}<
65 3 R12,R908,R909 50K ;K 38I}
66 9 R86,R250,R251,R252,R647, NC / 0 |g]TWKc*
R648,R649,R858,R860 +RS>#zd/=
67 47 R170,R209,R210,R211,R212, 0 4qo4g+
R213,R214,R215,R216,R217, B$qmXA)ze
R235,R236,R244,R401,R422, T5_z^7d
R424,R628,R632,R646,R714, #+Z3!VS
R715,R726,R802,R804,R805, c7T9kV8hS
R813,R814,R815,R825,R851, GgkljF@{}
R853,R856,R861,R862,R863, <(W0N|1v
R864,R866,R902,R903,R905, SvC|"-[mJ
R906,R907,R910,R926,R931, fo~8W`H&
R934,R949 ^ a%U *>P
68 2 R201,R202 1.8K Wh[+cH"M
69 18 R203,R410,R413,R414,R626, 10K :Z(?Ct&8
R629,R633,R722,R826,R837, =$601r
R855,R951,R955,R966,R970, iJ_`ZM.w
R971,R972,R973 x][vd^iW
70 2 R204,R208 NC/1.8K bsVms,&
71 1 R205 5R1 1/2W
3U=q3{%1
72 2 R206,R411 2.2K cC
w,b]
73 21 R221,R222,R223,R239,R240, 75 YAnt}]u!"
R241,R243,R245,R249,R701, L(Q v78F
R702,R703,R704,R705,R706, Q(h,P+
R707,R708,R709,R710,R711, EJY[M
R712 M>J8J*
74 1 R224 5.1K_1% 'JY*K:-
75 4 R230,R231,R232,R233 49.9_1% fVv#|
76 1 R234 475_1% q]q(zUtU
77 2 R237,R957 6.04K_1% 8=ubMqr[
78 7 R242,R246,R247,R402,R854, NC/0 TN3, \qgV
R857,R865 )l*H$8
79 6 R248,R801,R916,R917,R918, 10 7r?O(0>
R919 lM Gz"cym
80 26 R301,R302,R304,R305,R306, 62R 6"Q/Y[y
R307,R308,R309,R310,R311, fEc}c.!5
R312,R313,R314,R315,R316, -H~g+i*J
R317,R318,R319,R320,R321, u.iFlU
R322,R323,R324,R325,R326, #EtS9D'd+
R327 ;>[).fX>/
81 6 R407,R845,R846,R911,R953, 220 )a,-Hc:Vz
R965 E(tdL,m'
82 6 R408,R725,R811,R901,R904, 100K VA.jt}YGE
R942 AWCzu5ve
83 1 R409 200K Mh'QD)28c
84 1 R412 100R xjOy3_Js
85 2 R622,R624 27K 3P Twpq1
86 3 R623,R625,R627 18K f|Kd{ $VO
87 2 R630,R631 150R 3 2Q/4
88 2 R651,R652 470 oQ~Q?o]Ri
89 4 R721,R723,R724,R812 NC / 10K _=B(jJZ
90 1 R807 52.3K ,$5;
91 1 R816 8871% 1/16W uxk&5RY
92 2 R824,R828 4.7K 1/16W #{7=
93 1 R835 1K udB:ys
94 1 R836 15K $1oU^VY
95 1 R838 NC/10K =wK3\rG
96 1 R840 2.49K %*OKhrM
97 2 R932,R933 3.3K &Th/Qv}[
98 4 R936,R938,R940,R941 200K_1% 6}R^L(^M
99 1 R954 47 //KTEAYyy#
100 1 R956 12.1K_1% VA4vAF
101 1 R958 36.5K_1% K @"m0
102 3 R959,R962,R967 2.21K_1% KrVF>bq+
103 1 R960 2.74K_1% is{I5IR\/
104 1 R961 53.6K_1% {>OuxVl??k
105 2 R963,R968 6.98K_1% W-=~Afy
106 2 R964,R969 97.6K_1% 6k"Wy3/
107 2 SW2,SW3 SW TACT NO
hbR;zV|US
108 2 TP1,TP2 TP z_!P0`
109 4 TP3,TP4,TP5,TP6 TP-2 (Z.K3
110 1 U2 CC1100 ]tH/87qJ
111 2 U4,U5 32MX16 DDR2 e%x$Cb:znn
112 1 U7 NC / M25P80 )vOZp&
113 1 U8 M25P128 1Y@6oT
114 1 U9 DS1374U-33 <VB
115 1 U10 LM809-3.3/AP1701F-3.3 T2Cdw\
116 1 U11 NC / M25P128 VJD$nh
#M5
117 1 U12 IR_BLASTER 8kAG EiC
118 1 U13 NC / M41T82 &
