Bill of Material Report (Condensed)SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_TOL | COMP_CLASS | QUANTITY | REFDES |
0402_MLP | DIODE_TVS_BIDIR_0402_MLP_IC_0.4 | 0402ESDA-MLP | | IC | 6 | TVS1;TVS2;TVS3;U4;U5;U7 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.7MM | 10uF | | DISCRETE | 2 | C1;C37 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_2 | 0.1UF | | DISCRETE | 12 | C2;C6;C9;C15;C20;C22;C35;C47;C52;C58;C59;C62 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 1000pF | | DISCRETE | 1 | C3 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.64M | 0.1UF | 10% | DISCRETE | 15 | C4;C5;C7;C8;C12;C14;C16;C17;C18;C23;C24;C27;C29;C34;C57 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.65M | 4.7uF | | DISCRETE | 2 | C21;C40 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6MM | 1.0UF | | DISCRETE | 5 | C28;C36;C43;C48;C50 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.635 | 22PF | | DISCRETE | 2 | C31;C38 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.016 | 10uF | | DISCRETE | 3 | C13;C45;C63 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9 M | 2.2uF | | DISCRETE | 3 | C26;C56;C65 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1MM_1 | 10uF | 10% | DISCRETE | 1 | C30 |
CON2X10_2P54_TH | CONN_HDR_10X2_CON2X10_2P54_TH_I | CON_2X10 | | IO | 1 | J2 |
CON5_USB_AB_0P65_SM_RA | USB_MINI_AB_RECEPTACLE_CON5_USB | ZX62R-AB-5P | | IO | 2 | J5;J16 |
CON_SKT2X6_TH | CONN_HDR_6X2_CON_SKT2X6_TH_IO_8 | CON 2X6 SKT | | IO | 1 | J24 |
CON_SKT2X8_TH | HDR_2X8_M_CON_SKT2X8_TH_IO_8.76 | CON 2X8 | | IO | 2 | J1;J25 |
HDR102 | CONN_HDR_2X1_HDR102_IO_8.71 MM_ | HDR 1X2 TH | | IO | 4 | J10;J13;J15;J22 |
HDR103 | CONN_HDR_3X1_HDR103_IO_8.65MM_2 | HDR TH 1X3 | | IO | 1 | J9 |
HDR_5X2_FTSH_TH_NSP | CONN_HDR_5X2_HDR_5X2_FTSH_TH_NS | HDR 2X5 | | IO | 2 | J11;J12 |
IND_0805 | BEAD_IND_0805_DISCRETE_1.05 MM_ | 330 OHM | | DISCRETE | 2 | L1;L3 |
IND_1608 | BEAD_IND_1608_DISCRETE_0.95MM_1 | 330 OHM | | DISCRETE | 2 | L2;L4 |
LED4_3P4X3MM_SMT | CLV1A_LED_4P_LED4_3P4X3MM_SMT_I | CLV1A-FKB-CJ1M1F1BB7R4S3 | | IC | 1 | D14 |
LED_0603 | LED_LED_0603_IC_0.67MM_370-7656 | LED GREEN | | IC | 1 | D1 |
LED_0603 | LED_LED_0603_IC_0.9MM_370-75079 | RED | | IC | 1 | D2 |
LQFP64 | MK22FN512_LQFP_64P_LQFP64_IC_1. | MK22FN512VLH12 | | IC | 1 | U15 |
PHTRANS_1P9X1 | PT12_PHTRANS_2P_PHTRANS_1P9X1_I | ALS-PT19-315C/L177/TR8 | | IC | 1 | Q1 |
POWERDI-123_3MMX2MM | DIODE_SCHTKY_POWERDI-123_3MMX2M | DFLS130L-7 | | IC | 10 | D3;D4;D5;D6;D7;D8;D9;D11;D12;D13 |
QFN32_S142EP | PK20DX128V_QFN_32P_QFN32_S142EP | MK20DX128VFM5 | | IC | 1 | U10 |
QFN5X3_0P5_3X3 | FXOS8700CQ_QFN_16P_QFN5X3_0P5_3 | FXOS8700CQ | | IC | 1 | U8 |
QFN8_1P6X1P6MM | 74LVC2T45GM_8P_QFN8_1P6X1P6MM_I | 74LVC2T45GM,125 | | IC | 1 | U1 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.55 MM_ | 4.7K | 1% | DISCRETE | 6 | R2;R7;R22;R26;R29;R32 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.55MM_4 | 10.0K | 5% | DISCRETE | 6 | R3;R15;R18;R20;R24;R31 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7563 | 33 | | DISCRETE | 2 | R4;R16 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7539 | 0 | | DISCRETE | 6 | R17;R19;R21;R30;R81;R82 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7541 | 10.0K | | DISCRETE | 2 | R28;R39 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7579 | 33 | | DISCRETE | 4 | R33;R34;R78;R79 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__1 | 1.0K | 1% | DISCRETE | 1 | R43 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_47 | 10.0K | 1% | DISCRETE | 1 | R46 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4 MM_4 | 15K | 1% | DISCRETE | 1 | R47 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3100 | 31.6K | | DISCRETE | 1 | R50 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.55 M_1 | 100 | 1% | DISCRETE | 1 | R53 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7559 | 100K | | DISCRETE | 2 | R54;R74 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7555 | 1K | | DISCRETE | 2 | R66;R68 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.45 MM_ | 0 | 5% | DISCRETE | 2 | R69;R71 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | 2 | R80;R90 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3078 | 270 | | DISCRETE | 2 | R91;R93 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3080 | 430 | | DISCRETE | 1 | R92 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-3029 | 220 | | DISCRETE | 1 | R1 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7541 | 10K | | DISCRETE | 5 | R5;R12;R14;R36;R59 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | 12 | R23;R35;R37;R40;R42;R49;R52;R55;R62;R86;R88;R89 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7591 | 2.7K | | DISCRETE | 1 | R27 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-75_1 | 10 | | DISCRETE | 1 | R63 |
RC0805_OV | RES_RC0805_OV_DISCRETE_0.7 MM_4 | 180K | 1% | DISCRETE | 1 | R6 |
SC70_3 | MOSFET_N_SC70_3_IC_1.0MM_480-76 | NTS4001NT1G | | IC | 1 | Q2 |
SH0603 | RES_SHORT-2_SH0603_DISCRETE_470 | 0 | | DISCRETE | 2 | SH1;SH507 |
SH_HDR102_BOTTOM | CONN_HDR_2X1_SH_HDR102_BOTTOM_I | HDR 1X2 TH | | IO | 1 | J21 |
SOT223 | LD1117AS18_SOT223_IC_1.8MM_312- | NCP1117ST33T3G | | IC | 1 | U16 |
SOT23-6_A | MIC2005-0.8YM6_SOT23-6_A_IC_1.4 | MIC2005-0.8YM6 | | IC | 1 | U12 |
SW2_SPST_3P5X6P0_5P0 | SW2P_SW2_SPST_3P5X6P0_5P0_IC_5. | EVQ-PE105K | | IC | 1 | SW1 |
SW2_SPST_4X3_SM | SW_SPNO_2P_SW2_SPST_4X3_SM_IC_2 | TL1015AF160QG | | IC | 2 | SW2;SW3 |
TEST_LOOP | TESTLOOP_TEST_LOOP_IO_4.8 MM_21 | TEST POINT WHITE | | IO | 1 | TP21 |
TPAD_030 | TESTLOOP_TPAD_030_IO_0.1MM_211- | TPAD_030 | | IO | 26 | TP1;TP2;TP3;TP4;TP5;TP6;TP7;TP8;TP9;TP10;TP11;TP12;TP13;TP14;TP15;TP16;TP17;TP18;TP20;TP22;TP23;TP24;TP26;TP28;TP29;TP30 |
TP_PTH | TESTLOOP_TP_PTH_IO_0.1 MM_210-7 | TP_PTH | | IO | 1 | TP27 |
UDFN6_0P65_2X2_EP | NCP380-DFN_EP_UDFN6_0P65_2X2_EP | NCP380 | | IC | 1 | U13 |
UDFN6_1X1P5MM | 74LVCH1T45_6P_UDFN6_1X1P5MM_IC_ | 74LVCH1T45 | | IC | 3 | U2;U6;U11 |
ULLGA6_1P45X1_0P5MM | NLU2GU04_ULLGA6_1P45X1_0P5MM_IC | NLX2G14 | | IC | 1 | U9 |
XQFN8_1P45X1P25MM | NTSX2102GU8H_8P_XQFN8_1P45X1P25 | NTSX2102GU8H | | IC | 1 | U3 |
XTAL2-3P2X1P5-SM | XTAL_XTAL2-3P2X1P5-SM_IC_0.9MM_ | 32.768KHZ | | IC | 1 | Y2 |
XTAL3_3P35X1P45_SM | XTAL_CS_XTAL3_3P35X1P45_SM_IC_0 | 8.00MHZ | | IC | 1 | X1 |
XTLOSC4_5X3MM_SM | CRYSTAL_JXS63_XTLOSC4_5X3MM_SM_ | 8MHZ | | IC | 1 | Y1 |
