8~-TN1H f~a
7E;y Is3Y>oX REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME | BT1 | BATT_3P_ASSY_THMT-H64324-001,EMPTY,BATT_3P | | BH_H64323001IA | BT2 | BATT_HLDR_2PIN_THMT-A77774-001,IC,BATT_HLDR_2PIN | | BH_A77774001IA | CR1 | DIODE_SHOTTKY_SM-C81938-001,EMPTY,30V,0.5A | 30V | SOD123IB | D1 | DIODE_SCHOTTKY_SM-H64664-001,DIODE,PMEG2005AEL,0.5A | PMEG2005AEL | SCR1006MA | DS1 | LED_A1-H86719-001,LED,BLUE | | SLEDR1608MA | DS2 | LED_A1-D14725-012,IC,GREEN | | SLEDR0603IA | F1 | FUSE_SM-C92281-001,IC,1.5A,6V | | SFU1206IA | FB1 | FERRITE_0603-693286-055,CHIP,600OHM,25%,1A | 600OHM | SFB0603IA | FB2 | FERRITE_0603-G73133-001,CHIP,600OHM,25%,500MA | 600OHM | SFB0603IB | FB3 | FERRITE_0603-G73133-001,CHIP,600OHM,25%,500MA | 600OHM | SFB0603IB | FB4 | FERRITE_0402-A51464-001,CHIP,120OHM,25%,200.1MA | 120OHM | SFB0402IA | J1 | HDR_1X2_TH-D24179-001,HDR,HDR_1X2 | | HDR_TPV_1X2_10IA | J2 | HDR_1X6A_THMT-D24185-001,IC,HDR_1X6 | | HDR_TPV_1X6IA | J3 | CON_1X10_THMT-H76666-001,SKT,CON_1X10 | | HDR_TJV_1X10_100IA | J4 | CON_1X8_THMT-H76665-001,SKT,CON_1X8 | | HDR_TJV_1X8_100IA | J5 | HDR_1X3_THMT-G25849-001,HDR,HDR_1X3 | | HDR_TPV_1X3_10IB | J6 | HDR_1X1_THMT-A57933-003,EMPTY,HDR_1X1 | | HDR_TPV_1X1MA | J7 | USB_UB_SHLD_5P_6M_SM-H31417-001,CONN,USB_UB_SHLD_5P_6M | | USB_SJR_5P_6EM_65MA | J8 | HDR_1X10_TH-H98081-001,HDR,HDR_1X10 | | HDR_TPV_1X10_10IA | J9 | HDR_1X3_THMT-G25849-001,HDR,HDR_1X3 | | HDR_TPV_1X3_10IB | J10 | HDR_1X3_THMT-G25849-001,HDR,HDR_1X3 | | HDR_TPV_1X3_10IB | J11 | HDR_1X3_THMT-G25849-001,HDR,HDR_1X3 | | HDR_TPV_1X3_10IB | J12 | HDR_1X1_THMT-A57933-003,EMPTY,HDR_1X1 | | HDR_TPV_1X1MA | J13 | HDR_1X10_TH-H98081-001,HDR,HDR_1X10 | | HDR_TPV_1X10_10IA | J14 | HDR_1X1_THMT-A57933-003,EMPTY,HDR_1X1 | | HDR_TPV_1X1MA | J15 | HDR_1X2_TH-D24179-001,HDR,HDR_1X2 | | HDR_TPV_1X2_10IA | J16 | HDR_1X1_THMT-A57933-003,EMPTY,HDR_1X1 | | HDR_TPV_1X1MA | J17 | HDR_1X2_TH-D24179-001,HDR,HDR_1X2 | | HDR_TPV_1X2_10IA | J18 | HDR_1X1_THMT-A57933-003,EMPTY,HDR_1X1 | | HDR_TPV_1X1MA | J19 | CON_1X2_TH-H84559-001,CON,CON_1X2 | | HDR_TJV_1X2_50MA | J20 | HDR_1X1_THMT-A57933-003,EMPTY,HDR_1X1 | | HDR_TPV_1X1MA | J21 | HDR_1X3_THMT-G25849-001,HDR,HDR_1X3 | | HDR_TPV_1X3_10IB | J22 | CON_1X8_THMT-H76665-001,SKT,CON_1X8 | | HDR_TJV_1X8_100IA | J23 | CON_1X6_THMT-H76664-001,SKT,CON_1X6 | | HDR_TJV_1X6_100IA | J24 | HDR_1X2_TH-D24179-001,HDR,HDR_1X2 | | HDR_TPV_1X2_10IA | J25 | HDR_1X1_THMT-A57933-003,EMPTY,HDR_1X1 | | HDR_TPV_1X1MA | J26 | HDR_1X3_THMT-G25849-001,HDR,HDR_1X3 | | HDR_TPV_1X3_10IB | J27 | HDR_1X3_THMT-G25849-001,HDR,HDR_1X3 | | HDR_TPV_1X3_10IB | J28 | HDR_1X2_TH-D24179-001,HDR,HDR_1X2 | | HDR_TPV_1X2_10IA | L1 | CHOKE_4P_0504-752402-026,CHIP,80.0OHM,25%,100MA | 80.0OHM | SMI4_10X13MA | L2 | INDUCTOR_2518-H80383-001,IND,47UH,10%,120MA | 47UH | SMI2518MA | L3 | INDUCTOR_0806-G96057-001,INDUCTOR,1.5UH,20%,2A | 1.5uH | SMI0806IA | LB2 | LABEL_SM-A88430-001,LABEL,SERIALNUMBER | | LB_SN_IA | LB7B1 | LABEL_JEDEC_E1_SMT-NA_37330,EMPTY,LABEL_JEDEC_E1 | | LB_E1_IA | LB7B2 | LABEL_JEDEC_B4_SMT-NA_37329,EMPTY,LABEL_JEDEC_B4 | | LB_B4_IA | LB8B1 | LABEL_CHINA_ROHS_10_SMT-NA_37331,EMPTY,LABEL_CHINA_ROHS_10 | | LB_10_IA | LB8B3 | LABEL_SM-NA_26908,EMPTY,WEEE | | LB_WE_MA | Q1 | FET_SM-C81974-001,IC | | SOT23MA | Q2 | DIODE_ESD_DUAL_C_SOT883-H87560-001,DIO,PESD5V0X2UAM,2.5A | PESD5V0X2UAM | LCC3_10X6_35MA | Q3 | FET_SM-C81974-001,IC | | SOT23MA | Q4 | MOSFET_P_SOT23-H87878-001,FET,DMG2305UX | DMG2305UX | SOT23ME | SW1 | SW_SPST_PB_SM-D90553-001,IC,SW_SPST_PB | | SSW2_VP40X30_410MA | SW2 | SW_SPST_PB_SM-D90553-001,IC,SW_SPST_PB | | SSW2_VP40X30_410MA | TP1 | TP_SM-NA_TPC25,EMPTY,TP_C25 | | TP_C25 | TP2 | TP_SM-NA_TPC25,EMPTY,TP_C25 | | TP_C25 | TP3 | TP_SM-NA_TPC25,EMPTY,TP_C25 | | TP_C25 | U1 | 93XX56X_6P_SOT23-G62370-001,IC,93LC56B | | SOT23_6MC | U2 | FT232H_QFP-H15533-001,IC,FT232HL | | QFP48_S70_50MA | U3 | MVL_IP_QFN-TBD_36436,IC,MVL_IP,0.5 | | LCC40_S60_50DFS46MA | U4 | BMC150_LGA-H89773-001,IC,BMC150 | | LCC14_S22_40MA | U5 | TPS63051_VQFN-H94810-001,IC,TPS63051 | | LCC12_S25_50MA | Y1 | XTAL_4P_SM-D71700-024,XTAL,12MHZ,20% | 12MHZ | SMY4_32X25MA | Y2 | XTAL_4P_SM-H67839-001,IC,32.000MHZ,+/-20PPM | 32.000 MHZ | SMY4_32X25MA | Y3 | XTAL_SM-H32064-001,XTAL,32.768KHZ,20PPM | 32.768KHZ | SMY83X51IA |
