jI<_(T
#include <stdio.h> 4Bt)t#0
#include <stdlib.h> TnQW~_:
6X!jNh$oF
= U[$i"+
#include <sys/mman.h> 3[ xHY@c
O]61guxro
#include <sys/types.h> b8Hzl!zO
#include <sys/stat.h> 3bQq
Nk
#include <fcntl.h> 4`Jf_C
8;,|z%rS"
#include <sys/ioctl.h> )a%E $`
#include <linux/types.h> sG^{
cn
#include <string.h> O2U}jHsd
~Qf\DTM&
I<Mb/!TQ
lc]cs D
typedef struct /**** BMP file header structure ****/ _c(h{dn
{ 4RH>i+)pS\
unsigned int bfSize; /* Size of file */ P5GV9SA
unsigned short bfReserved1; /* Reserved */ G6xNR
unsigned short bfReserved2; /* ... */ +Z]}ce
u"
unsigned int bfOffBits; /* Offset to bitmap data */ 6:?mz;oP
} MyBITMAPFILEHEADER; ?>gr9w\
hb9HVj
u7 <VD
vjA!+_I6
.*z$vl
typedef struct /**** BMP file info structure ****/ sN) xNz
{ [lu+"V,<LJ
unsigned int biSize; /* Size of info header */ w?Cho</Xu
int biWidth; /* Width of image */ *Y!RU{w+Z
int biHeight; /* Height of image */ '+c@U~d*7
unsigned short biPlanes; /* Number of color planes */ /Kd'!lMuz
unsigned short biBitCount; /* Number of bits per pixel */ 46B'Ec
unsigned int biCompression; /* Type of compression to use */ ]Z52L`k
unsigned int biSizeImage; /* Size of image data */ Oh,Xjel
int biXPelsPerMeter; /* X pixels per meter */ 9S l5jn
int biYPelsPerMeter; /* Y pixels per meter */ !Fs<r)j
unsigned int biClrUsed; /* Number of colors used */ pOhjq#}
unsigned int biClrImportant; /* Number of important colors */ +6^hp-G7
} MyBITMAPINFOHEADER; ,F+,A].wG
.z*}%,G
9hJ
a K
typedef unsigned char BYTE; =F5zU5`i
PI"6d)S2
k?1e+ \
-<e_^
typedef struct tagRGBQUAD{ Yjl:i*u/
$4^h>x
BYTE rgbBlue;//蓝色的亮度(值范围为0-255) ,D&-.`'E
BYTE rgbGreen;//绿色的亮度(值范围为0-255) 1Ve~P"w
BYTE rgbRed;//红色的亮度(值范围为0-255) \6pQ&an
BYTE rgbReserved;//保留,必须为0 .B'ws/%5\
}RGBQUAD; }1Q>A 5e
@4Q/J$
xqauSW
n;~'W*Ln0
void SaveBmp(const char *filename,unsigned char *rgbbuf,int width,int height) kjt(OFh'Y+
{ }Nma %6PfV
MyBITMAPFILEHEADER bfh; o> &-B.zq
MyBITMAPINFOHEADER bih;
^b^buCYw
PWO5R]
k7(lwEgNG
/* Magic number for file. It does not fit in the header structure due to alignment requirements, so put it outside */ Ds{DVdqA$c
unsigned short bfType=0x4d42; M<Y{Cs
bfh.bfReserved1 = 0; ?=HoU3
bfh.bfReserved2 = 0; Wq?vAnLbk
bfh.bfSize = 2+sizeof(MyBITMAPFILEHEADER) + sizeof(MyBITMAPINFOHEADER)+width*height*3; ,L-V?B(UQ
bfh.bfOffBits = 0x36; zy|h1.gd
Z!4B=?(
bih.biSize = sizeof(MyBITMAPINFOHEADER); \VypkbE+
bih.biWidth = width; }C$D-fH8sW
bih.biHeight = height;
1DN
bih.biPlanes = 1; ?KE:KV[Y
bih.biBitCount = 24; zQ(`pld
bih.biCompression = 0; jHV)
TBr
bih.biSizeImage = 0; "s@q(J
bih.biXPelsPerMeter = 5000; Pj5:=d8z(
bih.biYPelsPerMeter = 5000; ~K
('t9|
bih.biClrUsed = 0; `1#Z9&bO
bih.biClrImportant = 0; Hr \vu`p$
e488}h6#m
$2a_!/
H8m[:K]_H
D}N4*L1
FILE *file = fopen(filename, "wb"); x Vw1
if (!file) /4upw`35]
{ cqcH1aSv
printf("Could not write file\n"); Cn_r?1{W
return; z+^9)wg9
} V}FH5z
lbh7`xCR
/*Write headers*/ fVi[mH0=+
fwrite(&bfType,sizeof(bfType),1,file); n-1
fwrite(&bfh,sizeof(bfh),1, file); |\)Y,~;P
fwrite(&bih,sizeof(bih),1, file); ?/(*cA
Fw^^sB
fwrite(rgbbuf,width*height*3,1,file); O@skd2
fclose(file); +6L.a3&(b
6t'.4SR
=>O{hT^F
gm1RQ^n,@.
dki3(
} H)Z$j&S{
3(:?Z-iKe
.Vs|&c2im
w,X J8+B
int main() 7UUu1"|a|
{ Vygh|UEo
(aB:P03
unsigned char *buffer; Pu'lp
O
int length,imagesize; SjcX|=S
:zpT Gk8Z
int fd,width,height; V=Z%y$1Bc
4I.)>+8V
}s8xr>
fd = open("k1.bmp", O_RDONLY); EEvi_Z932
if (fd == -1) { C\0,D9
printf("Unable to open file '\n"); jPg[LZQ'
return; g O8~$Aj
} cVSns\QO
xX8c>p
imagesize = lseek(fd, 0, SEEK_END); MYVb !
printf("imgsize=%d \n",imagesize); YI]/gWeu
lseek(fd, 0, SEEK_SET); AU;Iif6
46H@z=5
fS%B/h=
buffer = malloc(imagesize); _6]tbni?v
ZR8y9mx2"
if (buffer == NULL) { 8mO_dQ
printf("Unable to allocate memory for MJPEG image\n"); bKh}Y`
return; 2Ic)]6z
R
} I}awembw g
Jt)J1CAYo
read(fd,buffer, imagesize); GxE`z6%[
close(fd); dx.Jv/Mb
tn |H~iF{
SaveBmp("test.bmp", buffer+0x36 ,640, 360); _9S"rH[
C k/DV
"M,Hm!j
return 0; Ol;"}3*Z*
4UN|`'c
r_o\72
tnq ZlS
} ifmX<'(9A
1b@]^Ue
+5%ncSJx
linux 下编译命令: ?` 2z8uD/
K'[kl'
gcc bmp.c -o bmp >B.KI}dE
1TgD;qX
运行: @J6V,
./bmp (运行前先将 k1.bmp copy到运行目录下, 运行后可发现有test.bmp 文件生成 ) UAC"jy1D
cxIAI=JK
