论坛风格切换切换到宽版
发帖 回复
返回列表 提醒:附件不能用迅雷等P2P软件下载,否则直下载失败,文件名变成job.xx网页格式,下载点击一次即可,请勿多次连续点击附件
  • 141阅读
  • 4回复
发一份能过 V4L2 接口 读到摄像头图片信息 并将其保存下来的源码 [复制链接]
上一主题 下一主题
离线旋风炫云
性别:
帅哥
发帖
26
金币
186
威望
贡献值
乐币
871
好评度
RMB
<私密信息仅自己能看>
$#JVI:
#include <fcntl.h> PyxN_agf
#include <stdio.h> d#:J\2V"R
#include <sys/ioctl.h> p}|wO&4h
#include <stdlib.h> wvaIgy%z
#include <linux/types.h> 9.#R?YP$
#include <linux/videodev2.h> ]JPPL4wAT
#include <malloc.h> x  Bw.M{
#include <math.h> &`Z)5Ww
#include <string.h> d*(Bs $De
#include <sys/mman.h> bK;a V&
#include <errno.h> -t'oW*kdL
#include <assert.h> ?F!J@Xn5
u,SZ-2K!7~
#define FILE_VIDEO  "/dev/video0" /~huTKA}
#define JPG "./image%d.jpg" ]%8;c
RW[<e
typedef struct{ n >PM_W
    void *start; Wc;D{p?Lb
    int length; tUF]f6
}BUFTYPE; "(&`muIc
BUFTYPE *usr_buf; X&oy.Roo
static unsigned int n_buffer = 0; N_[ Q.HD"
VD`2lGdF
//set video capture ways(mmap) @5VZ
int init_mmap(int fd) QGG(I7{-
{ j =%-b]
    //to request frame cache, contain requested counts 7t Kft
    struct v4l2_requestbuffers reqbufs; \1'R}B@;
    //request V4L2 driver allocation video cache HwMsP$`q
    //this cache is locate in kernel and need mmap mapping J$*["y`+
    memset(&reqbufs, 0, sizeof(reqbufs)); N%E2BJ?
    reqbufs.count = 4; PH!B /D5G
    reqbufs.type = V4L2_BUF_TYPE_VIDEO_CAPTURE; GJfNO-
    reqbufs.memory = V4L2_MEMORY_MMAP;  pytfsVM
WREGRy
    if(-1 == ioctl(fd,VIDIOC_REQBUFS,&reqbufs)){ i1@gHk
        perror("Fail to ioctl 'VIDIOC_REQBUFS'"); zGz'2, o3
        exit(EXIT_FAILURE); ]!o,S{a&
    } 9],"AjD
\J&#C(pn
    n_buffer = reqbufs.count; 0 3 $ W
    printf("n_buffer = %d\n", n_buffer); 1Klu]J%
    usr_buf = calloc(reqbufs.count, sizeof(BUFTYPE)); TiEJyd`P
    if(usr_buf == NULL){ [z@RgDX v
        printf("Out of memory\n"); h,?Yw+#o"
        exit(-1); n8aiGnd=v
    } P,=J"%a-
zb,`K*Z{
    //map kernel cache to user process ([o:_5/8I
    for(n_buffer = 0; n_buffer < reqbufs.count; ++n_buffer){ x+`3G.
        //stand for a frame 1RHH<c%2n
        struct v4l2_buffer buf; "fd=(& M*l
        memset(&buf, 0, sizeof(buf)); irj}:f;!eF
        buf.type = V4L2_BUF_TYPE_VIDEO_CAPTURE; sswAI|6ou
        buf.memory = V4L2_MEMORY_MMAP; 2;r^~:
        buf.index = n_buffer; iGNKf|8{
         *.Hnt\4|
        //check the information of the kernel cache requested 5z]KkPQ
        if(-1 == ioctl(fd,VIDIOC_QUERYBUF,&buf)) 5j5t?G;d,
        { 4>`w9
            perror("Fail to ioctl : VIDIOC_QUERYBUF"); ]r5Xp#q2
            exit(EXIT_FAILURE); dh`A(B{hfc
        } UpBYL?+L
_Fy:3,(
aKr4E3`
    printf(" buf.length =%d\n", buf.length); ~36XJ
Ggjb86v\
*9^k^h(r&4
        usr_buf[n_buffer].length = buf.length; scwlW b<N
        usr_buf[n_buffer].start = ?IO/zkeXg
            mmap( Yr0i9Qow
                    NULL, 8#-}3~l[
                    buf.length, :$d3a"]
                    PROT_READ | PROT_WRITE, iAhRlQ{Qu
                    MAP_SHARED, RlI qH;n
                    fd, 8Wp1L0$B
                    buf.m.offset )+R3C%
                ); //mmap(0, fbSize, PROT_READ|PROT_WRITE, MAP_SHARED, fd, 0); 7@]hu^)rry
#]^`BQ>
f 2f $aZ
     if(MAP_FAILED == usr_buf[n_buffer].start) J3^Ir [
        { ]2 N';(R
            perror("Fail to mmap"); PmTd+Gj$
            exit(EXIT_FAILURE); 2b1:Tt9
        } ||NCVGJG
n&&y\?n
    printf(" usr_buf[%d].start=0x%x length=0x%x \n" , n_buffer, usr_buf[n_buffer].start ,buf.length); :7*\|2zA
EJY:C9W
|REU7?B
         -ZJ:<
    } JDlIf
    return 0; K?WqAVK
} i?9Lf
Zwl?*t\D
//initial camera device X / "H+l
int init_camera_device(int fd) ] UTP~2N
{ a)b@en;v
    //decive fuction, such as video input VQ`O;n6/`
    struct v4l2_capability cap; f}3bYF
    //video standard,such as PAL,NTSC =z.AQe+
    struct v4l2_standard std; [r'M_foga*
    //frame format EQ-~e
    struct v4l2_format tv_fmt; VNPd L
    //check control IC~D?c0H:
    struct v4l2_queryctrl query; GV/FK{v5
    //detail control value H& +s&F{%
    struct v4l2_fmtdesc fmt; n_hD
    int ret; h~t]WN
    //get the format of video supply bN)?szh&Y
    memset(&fmt, 0, sizeof(fmt)); c8MNo'h
    fmt.index = 0; dno*Usx5d0
    //supply to image capture ['<rfK
    fmt.type = V4L2_BUF_TYPE_VIDEO_CAPTURE; "zc!QHpSd
    // show all format of supply c:5BQr '
    printf("Support format:\n"); Joj8'
    while(ioctl(fd, VIDIOC_ENUM_FMT, &fmt) == 0){ /8R1$7
        fmt.index++; O;"%z*g.
        printf("pixelformat = ''%c%c%c%c''\ndescription = ''%s''\n",fmt.pixelformat & 0xFF, (fmt.pixelformat >> 8) & 0xFF,(fmt.pixelformat >> 16) & 0xFF, (fmt.pixelformat >> 24) & 0xFF,fmt.description); FT6cOMu
    } 9X~^w_cdk
    //check video decive driver capability ~ME=!;<_
    ret = ioctl(fd, VIDIOC_QUERYCAP, &cap); llJ)u!=5
    if(ret < 0){ g!UM8I-$
        perror("Fail to ioctl VIDEO_QUERYCAP"); >6j`ZWab>
        exit(EXIT_FAILURE); n\4+xZr
    } Qfi5fp=f
5`Z#m:+u
    //judge wherher or not to be a video-get device DJ.Ct4
    if(!(cap.capabilities & V4L2_BUF_TYPE_VIDEO_CAPTURE)) HIAd"}^
    { To+{9"$,
        printf("The Current device is not a video capture device\n"); ;RI,zQ
        exit(-1); va.wdk g
    } <rI~+J]s
]]4E)j8
    //judge whether or not to supply the form of video stream V{r@D!}
    if(!(cap.capabilities & V4L2_CAP_STREAMING)) wv$=0zF
    { z?^p(UH
        printf("The Current device does not support streaming i/o\n"); @lI/g
        exit(EXIT_FAILURE); n:+M Nr
    } WUWQcJj
ADDpm-]
    //set the form of camera capture data '*:YC
I{ $|Ed1
,MJZ*"V/3
vL7}0n>tz
    tv_fmt.type = V4L2_BUF_TYPE_VIDEO_CAPTURE; 5P4 >xv[
&nYmVwi?"Q
LO229`ARr|
#if 0 |V& k1{V
    tv_fmt.fmt.pix.width = 640; +?p ;,Z%5
    tv_fmt.fmt.pix.height = 360; 5`J. ic
#else ]_h"2|
li[g =A,
    tv_fmt.fmt.pix.width = 1280; d=pq+
    tv_fmt.fmt.pix.height = 960; lF<(yF5
j:#[voo7
]pt @
#endif $f%_ 4 =
J=sQ].EK
G2rvi=8=
     K;K tx>Z/
    tv_fmt.fmt.pix.pixelformat = V4L2_PIX_FMT_MJPEG; r |(Lb'k
    //V4L2_PIX_FMT_YUYV l"Css~^
    tv_fmt.fmt.pix.field = V4L2_FIELD_INTERLACED; 4PdFq*A
    if (ioctl(fd, VIDIOC_S_FMT, &tv_fmt)< 0) { *KM CU m
        printf("VIDIOC_S_FMT\n"); f%af.cR*
        exit(-1); XjC+kH
        close(fd); D 6(w}W
    } 2Y,s58F
    //initial video capture way(mmap) `CV a`%
    init_mmap(fd); Y#G '[N>
    return 0; SWu=n1J.?H
} 1\BECP+
sXFD]cF
int open_camera_device() 6Z3v]X
{ s=q}XIWK
    int fd; QeK~A@|F&
    //open video device with block sU>*S$X8
    fd = open(FILE_VIDEO, O_RDWR /* required */ | O_NONBLOCK, 0);//打开设备 Eb*DP_
    if(fd < 0){ 0-@waK
        perror(FILE_VIDEO); %n( s;/_
        exit(EXIT_FAILURE); sx9 N8T3n
    } A;kB"Tx
    return fd; kAqk~.
} xKxWtZ0
I++!F,pB
int start_capture(int fd) d;>:<{z@CD
{ /];F4AO5
    unsigned int i; -n6C~Yx
    enum v4l2_buf_type type; i"-j:b:c<
    //place the kernel cache to a queue d{0>R{uac
    for(i = 0; i < n_buffer; i++){ 4m~\S)ad
        struct v4l2_buffer buf; GovGh? X#x
        memset(&buf, 0, sizeof(buf)); 'h:4 Fzo<
        buf.type = V4L2_BUF_TYPE_VIDEO_CAPTURE; 5~qr+la
        buf.memory = V4L2_MEMORY_MMAP; re<"%D
        buf.index = i; 9J<KR #M
X%;,r 2g
        if(-1 == ioctl(fd, VIDIOC_QBUF, &buf)){ sg3%n0Ms.W
            perror("Fail to ioctl 'VIDIOC_QBUF'"); NoMEe<
            exit(EXIT_FAILURE); @wpm;]
        } ( \]_/ W
    } M+Dkn3bx
<)M?qkjb
    //start capture data LnBkd:>}
    type = V4L2_BUF_TYPE_VIDEO_CAPTURE; Tux~4W
    if(-1 == ioctl(fd, VIDIOC_STREAMON, &type)){ R (6Jvub"I
        printf("i=%d.\n", i); TiH(HW|:
        perror("VIDIOC_STREAMON"); I qma vnM#
        close(fd); e Q0bx&
        exit(EXIT_FAILURE); /6>2,S8Ar
    } -QRKDp
    return 0; rt"\\sOlMB
} B64%| S
Y#uf 2>J
;]p#PNQ0
int process_image(void *addr, int length) m0 `wmM
{ :qI myaGQ
    int fd; D@mDhhK_
    static int num = 0; Nz2}Ma 2
    char image_name[20]; L-Z1Xs
\&SP7~-eq
    printf("%s addr = 0x%x  length= %d \n" , __func__,addr,length); :kgwKuhL
 Wkf)4!
    sprintf(image_name, JPG, num++); a-hF/~84S:
!]W6i]p
    if((fd= open(image_name,O_CREAT|O_WRONLY)) == NULL){ J)*y1
3wD6,x-e
         x *(pr5k
        printf("Fail to fopen"); +W-sb5)
        exit(EXIT_FAILURE); F> ..eK
         Ff|?<\x0}A
    } eGZId v1
     S0\:1B
    write(fd,addr, length); Q5baY\"9^
    sync( ); bE0cW'6r
    close(fd); ~bg FU
     t:W`=^
       return 0; x_#yH3kJ
   T"3WB o
   ?eeE[F
  } -Ndd6O[ a5
KWM.b"WnXr
1#XMUbFc
\\BblzGMR
24]O0K
Z#d_<e?
'j>Q7M7q{
.{~ygHQ`f
CI ~+(+q
 _8t{4C
?f:FmgQk
XVE(p3-
4_)@Nq
int read_frame(int fd) ;p) gTQa
{ mR?OSeeB
    struct v4l2_buffer buf; v;irk<5
    unsigned int i; ig3uY#
    memset(&buf, 0, sizeof(buf)); zPZy#7/A
=p ^Sn,t
   printf("%s run   place 1 \n",__func__); 4WU 6CN
Z-Zox-I1}-
     >|mmJ4T
    buf.type = V4L2_BUF_TYPE_VIDEO_CAPTURE; WY  #pzBA
    buf.memory = V4L2_MEMORY_MMAP; -&%#R_RV
    //put cache from queue eCdMDSFO3
    if(-1 == ioctl(fd, VIDIOC_DQBUF,&buf)){ vxY7/_]
        perror("Fail to ioctl 'VIDIOC_DQBUF'"); "m(HQ5e)*
        exit(EXIT_FAILURE); nTp?
    } ]#KZ W)M
NgQ {'H[Y
    assert(buf.index < n_buffer); OlQ7Yi>
    //read process space's data to a file n*hHqZl
    printf("buf.index=%d\n",buf.index); xLX:>64'o>
<LH(>
    process_image(usr_buf[buf.index].start, buf.bytesused);  E*i <P
89?AcZ.D
^0c:ro
    printf("%s run   place 2 \n",__func__); J_<ENs-
FNtcI7
    if(-1 == ioctl(fd, VIDIOC_QBUF,&buf)){ !Zlvz%X
        perror("Fail to ioctl 'VIDIOC_QBUF'"); =X]$J@j
        exit(EXIT_FAILURE); <Hig,(=`.
    } j)]mN$Sa:
0Evq</
[C.Pzo
    printf("%s run   place 3 \n",__func__); eBlVb*nmq
     BbnY9"
    return 1; X70G@-w
} d>VerZZU
u#ag|b/C:
int mainloop(int fd) rs`H':a/
{ *&^`Uk,[
    int count =20; uR"(0_
-[^aWNqyJ
    while(count-- > 0) now\-XrS
    { #EgFB}>1
        for(;;) ? L|m:A`
        { $&OoxC
            fd_set fds; 8%@7G*
            struct timeval tv; &>XIK8*
            int r; [yJcM [p\
[f!sBJ!
            printf("count = %d \n", count); t n>$5}^;
         =TE6R 0b
            FD_ZERO(&fds); h}nceH0s3d
            FD_SET(fd,&fds); aq@/sMn
4en[!*
            /*Timeout*/ QI0d:7!W1
            tv.tv_sec = 200; Lp`q[Z*
            tv.tv_usec = 0; f,wB.MN
            r = select(fd + 1,&fds,NULL,NULL,&tv); /\q1,}M
tg_v\n
            if(-1 == r) 2WE_NEpJI
            { _e E(P1
                if(EINTR == errno) pdUrVmW"'
                    continue; 1O"7%Pvw
                perror("Fail to select"); 7j8nDX<
                exit(EXIT_FAILURE); 8vjaQ5
            } tF}Vs}
!yI , ~`Z
            if(0 == r) Ei2hI
            { &-mPj82R
                fprintf(stderr,"select Timeout\n"); FJ#:RC
                exit(-1); ~G+o;N,V
            } 'Y Bz?l9
38ChS.(
            if(read_frame(fd)) qq9fZZb
                break; |j3mI\ANF
        } uQIa"u7
    } A%qlB[!:
    return 0; EZlcpCS
} ?nZQTO7
@Fv"j9j-3G
void stop_capture(int fd) //9Ro"
{ !#wd~: H
    enum v4l2_buf_type type; w 4-E@>%
    type = V4L2_BUF_TYPE_VIDEO_CAPTURE; ]k &Y )
    if(-1 == ioctl(fd,VIDIOC_STREAMOFF,&type)) 8FYcUvxfT
    { >|1.Z'r/
        perror("Fail to ioctl 'VIDIOC_STREAMOFF'"); )FVW/{NF@q
        exit(EXIT_FAILURE); wcDHx#~
    } nG hFYQl
    return; <!gq9
} +o^b ,!
x;w&JS1 V
void close_camera_device(int fd) fbgq+f`\
{ a7KP_[_(
    unsigned int i; A14}
    for(i = 0;i < n_buffer; i++) cK6M8:KW
    { RR R'azT
        if(-1 == munmap(usr_buf.start,usr_buf.length)){ 8#b>4 Dx
            exit(-1); $Pv;>fHu
        } =iF}41a
    } o_C j o
    free(usr_buf); `3GC}u>}
7v\K,P8
    if(-1 == close(fd)) =23JE'^=
    { U,q ]
        perror("Fail to close fd"); S,A\%:Va
        exit(EXIT_FAILURE); OJ0Dw*K<
    } 94Wf ]
    return; k=L(C^VP
} ?fF{M%i-%
G4DuqN~2m
int main() ^,F8 ha
{ N]qX^RSb
(9R;a np
Pt<lHfd
    int fd; 2' fg
    fd = open_camera_device(); Q(Uj5aX
    init_camera_device(fd); O :P%gz4
    start_capture(fd); E5@U~|V[
    mainloop(fd); PW a!7n#A
    stop_capture(fd); 'U=D6X%V9m
    close_camera_device(fd); O{WJi;l
'Y`.0T[&
   7I.7%m,g
    return 0; 5<1,`Bq@
} ;533;(d* o
评价一下你浏览此帖子的感受
精彩
感动
搞笑
愤怒
一般
差劲
离线thanky0u58
性别:
人妖
发帖
6375
金币
10268
威望
45
贡献值
3803
乐币
1721
好评度
RMB
<私密信息仅自己能看>
只看该作者 1楼 发表于: 03-12
离线郑先生
性别:
帅哥
发帖
2564
金币
2099
威望
17
贡献值
42
乐币
2240
好评度
RMB
<私密信息仅自己能看>
只看该作者 2楼 发表于: 03-13
离线snrkhn
性别:
帅哥
发帖
1271
金币
1689
威望
贡献值
124
乐币
978
好评度
RMB
<私密信息仅自己能看>
只看该作者 3楼 发表于: 03-13
离线playflash
性别:
帅哥
发帖
127
金币
128
威望
贡献值
32
乐币
132
好评度
RMB
<私密信息仅自己能看>
只看该作者 4楼 发表于: 03-31
谢谢分享。楼主做出实物了吗
快速回复
限150 字节
上一个 下一个
