PADS软件:PADS VX.2
kRX?o'U~C 想自己
学习一下高速线路板,但是LOGIC转
PCB时就出现了问题,U1封装转不到PCB中,在PCB中的
封装是我手动加入的。
|%F4`gz8KP LOGIC转PCB时,用ECO TO PCB,会出现警告,但我
原理图上已经连接上,不知道是什么。
$>yfu=]? Test.pcb (289 K) 下载次数:0 Test.sch (103 K) 下载次数:0 RU6c 8>" d-tg^Ot#
S|LY U!IWZ Single/Zero Pin Net Warnings
(F.w?f4B3 ----------------------------
xJ. kd
Tr Net FLASH_CS1 has less than two pins in PCB net list file.
1>L'F8" Net FLASH_D1 has less than two pins in PCB net list file.
Pz:,de~5Qm Net FLASH_CS0 has less than two pins in PCB net list file.
lfC]!=2%~8 Net FLASH_D0 has less than two pins in PCB net list file.
* O?Yp%5NH Net FALSH_DQS/EMMC_CLKO has less than two pins in PCB net list file.
\>lA2^Ef Net FLASH_D5 has less than two pins in PCB net list file.
2?Jw0Wq5D Net FLASH_WP/EMMC_PWREN has less than two pins in PCB net list file.
zYY]+)k? Net FLASH_D6 has less than two pins in PCB net list file.
R@tEC)Zn Net FLASH_D3 has less than two pins in PCB net list file.
SvvNk Net FLASH_D2 has less than two pins in PCB net list file.
eQ8t.~5;- ."B{U_P& 原理图零件图和PCB的封装都是用本坛高手已经做好的,我下载来直接使用,正常来说应该没有问题的。各位大侠帮忙看一下是什么原因转不成功,如何处理?谢谢
