论坛风格切换切换到宽版
发帖 回复
  • 17946阅读
  • 94回复
[Allegro16.6]20层PCB设计XC5VLX30FF676+XC5VLX50FF1153+DAD2000+XCF16PFSG48C 做的DLI /DLP PCB文件共享 [复制链接]
上一主题 下一主题
在线老吴
性别:
帅哥
发帖
15521
金币
156570
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       图酷模式  只看楼主 倒序阅读 使用道具 0楼 发表于: 2018-04-04
重要提示:本版需2级以上才能下载,有些需购买的帖,若没2级请不要购买,购买也下载不了【可充值秒升级】也可发帖,做任务,签到等升级。若已2级以上,忽略本提示
老外就是土豪。这板子要用20层PCB设计 n*4`Tduu^
0=d2_YzSf
voWH.[n^_
Tt;F-
W,q @ww u
pwUXM?$R
Io6/Fv>!
T U%@_vYR
MNT~[Z9L5G
$ /VQsb
6iC>CY3CG
BT5BATTERY_12MM_12MM12MM12MM
D1LED_SM_LED_0603_SML-310MTT86SML-310MTT86SM_LED_0603
D2LED_SM_LED_0603_SML-310VTT86SML-310VTT86SM_LED_0603
D3LED_SM_LED_0603_SML-310VTT86SML-310VTT86SM_LED_0603
D4DIODESCHOTTKY_SM_DIO_SMA_10MQ010MQ060NPBFSM_DIO_SMA
D5DIODESCHOTTKY_SM_DIO_SMA_10MQ010MQ060NPBFSM_DIO_SMA
D6DIODESCHOTTKY_SM_DIO_SMA_10MQ010MQ060NPBFSM_DIO_SMA
D7DIODESCHOTTKY_SM_DIO_SMA_10MQ010MQ060NPBFSM_DIO_SMA
D8DIODEZENER_POWERDI123_10V10VPOWERDI123
D9LED_SM_LED_0603_SML-310MTT86SML-310MTT86SM_LED_0603
D10LED_SM_LED_0603_SML-310MTT86SML-310MTT86SM_LED_0603
D11LED_SM_LED_0603_SML-310MTT86SML-310MTT86SM_LED_0603
D12LED_SM_LED_0603_SML-310MTT86SML-310MTT86SM_LED_0603
D13DIODETS_SM_DIO_SMA_DIODE TSDIODE TSSM_DIO_SMA
D14TPD2E001DRLR_SM_SOT553-5_2_TPD2TPD2E001DRLRSM_SOT553-5_2
D15DIODE_DUAL_CK_AAJ_SM_SOT523_3_BBAV170T-7-FSM_SOT523_3
D16LED_SM_LED_0603_SML-310MTT86SML-310MTT86SM_LED_0603
D17LED_SM_LED_0603_SML-310MTT86SML-310MTT86SM_LED_0603
F1DFM-BEAD_0603_MI0603J680R-10MI0603J680R-10603
F2DFM-BEAD_0603_MI0603J680R-10MI0603J680R-10603
F5FUSE_SM_LITTELFUSE_MRL_FUSEFUSESM_LITTELFUSE_MRL
FB1INDUCTOR_1206_HI1206T500R-10HI1206T500R-101206
FB2INDUCTOR_0603_MI0603J680R-10MI0603J680R-10603
FB3INDUCTOR_0805_BLM21PG600SN1DBLM21PG600SN1D805
FB4INDUCTOR_1206_HI1206T500R-10HI1206T500R-101206
FB5INDUCTOR_1206_HI1206T500R-10HI1206T500R-101206
FB6INDUCTOR_1206_HI1206T500R-10HI1206T500R-101206
FB7INDUCTOR_0805_BLM21PG600SN1DBLM21PG600SN1D805
FB8INDUCTOR_0805_BLM21PG600SN1DBLM21PG600SN1D805
FB9INDUCTOR_0603_MI0603J680R-10MI0603J680R-10603
FB10INDUCTOR_0603_MI0603J680R-10MI0603J680R-10603
FB11INDUCTOR_1206_HI1206T500R-10HI1206T500R-101206
H1HEADER7X2/SM_HDR7X2_87832-142087832-1420HDR7X2
J1UX50-MB-5ST_MOLEX_054819-0589_0054819-0589MOLEX_054819-0589
J2HEADER5X3_TH_HEADER_5X3_HEADERHEADER 5x3TH_HEADER_5X3
J3HEADER10/SM_SM_CONN_MOLX_5326153261-1071SM_CONN_MOLX_532611071
J4HEADER2_JUMPER2_TSW-102-05-F-STSW-102-05-F-SJUMPER2
J5CON3_TH_CONN_3POS_100_CON3CON3TH_CONN_3POS_100
J6HEADER10/SM_SM_CONN_MOLX_5326153261-1071SM_CONN_MOLX_532611071
J7HEADER2_JUMPER2_TSW-102-05-F-STSW-102-05-F-SJUMPER2
J8MICTOR19X2_CONN38_2-767004-22-767004-2CONN38
J9MICTOR19X2_CONN38_2-767004-22-767004-2CONN38
J10HEADER2_JUMPER2_TSW-102-05-F-STSW-102-05-F-SJUMPER2
J11HEADER2_JUMPER2_TSW-102-05-F-STSW-102-05-F-SJUMPER2
J12PJ1-022-SMT_CUI_PJ-047BH_CUIPJCUI PJ-047BHCUI_PJ-047BH
J137840-LVDS-DMD_SM_CONN_8397_BOAR7840-LVDS-DMDSM_CONN_8397_BOARD
J147840-LVDS-DMD_SM_CONN_8397_BOAR7840-LVDS-DMDSM_CONN_8397_BOARD
J15SODIMM-200_SM_SODIMM_59354_SODISODIMM-200SM_SODIMM_59354
J16QSE-060-01_SM_QSE_120_QSE-060-0QSE-060-01SM_QSE_120
J17QSE-060-01_SM_QSE_120_QSE-060-0QSE-060-01SM_QSE_120
J18CONN PWR2X2-P_MOLEX_43045-0412Molex 43045-0412MOLEX_43045-0412
L1INDUCTOR_SM_DO3316P_4.7UH4.7uHSM_DO3316P
L2INDUCTOR_SM_DO3316H_3.3UH3.3uHSM_DO3316H
L3INDUCTOR_SM_DO3316H_3.3UH3.3uHSM_DO3316H
L4INDUCTOR_SM_IND_DT1608C_22UH22uHSM_IND_DT1608C
L5INDUCTOR_SM_IND_DT1608C_22UH22uHSM_IND_DT1608C
L6INDUCTOR_SM_IND_DT1608C_22UH22uHSM_IND_DT1608C
L7INDUCTOR_SM_IND_DT1608C_22UH22uHSM_IND_DT1608C
L8INDUCTOR_SM_SDR0403_4.7UH4.7uHSM_SDR0403
L9INDUCTOR_SM_DO1813H_1.2UH1.2uHSM_DO1813H
L10CHOKECM14_SM_CM14_0805_DLW21HNDLW21HN900SQ2LSM_CM14_0805
MT1MOUNT_HOLE_TH_MTH_140D250P_MOUNMOUNT_HOLETH_MTH_140D250P
MT2MOUNT_HOLE_TH_MTH_140D250P_MOUNMOUNT_HOLETH_MTH_140D250P
MT3MOUNT_HOLE_TH_MTH_140D250P_MOUNMOUNT_HOLETH_MTH_140D250P
MT4MOUNT_HOLE_TH_MTH_140D250P_MOUNMOUNT_HOLETH_MTH_140D250P
Q1FDS3672_8SOIC_FDS3672FDS36728SOIC
Q5MMBTH69L_SOT23_MMBT2369LT1GMMBT2369LT1GSOT23
RN1RSNETWORKX8_SM_RP8X0603_1010SM_RP8X0603
RN2RSNETWORKX8_SM_RP8X0603_1010SM_RP8X0603
RN3RSNETWORKX8_SM_RP8X0603_1010SM_RP8X0603
RN4RSNETWORKX8_SM_RP8X0603_1010SM_RP8X0603
RP5RESISTOR DIP 4A-D_SM_RP4X0603_47SM_RP4X0603
RP6RESISTOR DIP 4A-D_SM_RP4X0603_47SM_RP4X0603
RP7RESISTOR DIP 4A-D_SM_RP4X0603_47SM_RP4X0603
RP8RESISTOR DIP 4A-D_SM_RP4X0603_47SM_RP4X0603
RP9RESISTOR DIP 4A-D_SM_RP4X0603_47SM_RP4X0603
RP10RESISTOR DIP 4A-D_SM_RP4X0603_47SM_RP4X0603
SW1DFM-DIP-SW-8_16SMT_219-8MSTP219-8MSTP16SMT
SW2SWPUSHBUTTON-SPST-2/SM_4PSO_KSKST241GLFS4PSO
SW3SWPUSHBUTTON-SPST-2/SM_4PSO_KSKST241GLFS4PSO
SW4SWSPST_OMRON_A6S-1104-H_SPST ASPST A6S-1104-HOMRON_A6S-1104-H
U1TPS51100_10DGQ_TPS51100TPS5110010DGQ
U2SN74AVC2T45DCU_SM_SN74_SOP8_SN7SN74AVC2T45DCU - NOPOPSM_SN74_SOP8
U3AT45DB642D_SM_TSOP28_468_AT45DBAT45DB642D - NO POPSM_TSOP28_468
U4TPS54316PWPG4_0_20PWP_TPS54316PTPS54316PWPG4_020PWP
U5XC5VLX50FF1153_13_SM_FF1153_XC5XC5VLX50FF1153SM_FF1153
U6SN74AVC2T45DCU_SM_SN74_SOP8_SN7SN74AVC2T45DCU - NOPOPSM_SN74_SOP8
U7TPS546_0_28PWP_TPS54615TPS5461528PWP
U8DFM-XCF08P-FSG48C_48TFBGA_XCF16XCF16PFSG48C48TFBGA
U9EC2700TTS-50_0.000M_OSC4PIN_EC2EC2700TTS-50_0.000MOSC4PIN
U10DFM-XCF08P-FSG48C_48TFBGA_XCF16XCF16PFSG48C48TFBGA
U11XC5VLX30FF676_SM_FF676_XC5VLX30XC5VLX30FF676SM_FF676
U12TPS546_0_28PWP_TPS54614TPS5461428PWP
U13DAD2000_0_TQFP80_DAD2000_0DAD2000_0TQFP80
U14DAD2000_0_TQFP80_DAD2000_0DAD2000_0TQFP80
U15TPS2400_SOT23-5_TPS2400TPS2400SOT23-5
U16TPS61081_SM_TI_DRC10_TPS61081TPS61081SM_TI_DRC10
U17TPS54310PWP_20PWP_TPS54310PWPTPS54310PWP20PWP
U18CY7C68013_128_SM_TPQF128_CYPRESCY7C68013A_128SM_TPQF128_CYPRESS
U19EPROM24LC256_SM_TSSOP8_174_EPREPROM 24LC128SM_TSSOP8_174
U20SN74CB3Q32245_SM_TI_ZKE96_SN74CSN74CB3q32245SM_TI_ZKE96
U21SN74CB3T3253_TSSOP16_SN74CB3T32SN74CB3T3253TSSOP16
U22SN74AUP1G00DBVR_SOT23-5_SN74AUPSN74AUP1G00DBVRSOT23-5
U23TPS3707-DGNG_8MSOP_TPS3707-DGNGTPS3707-DGNG8MSOP
Y5CRYSTAL_SM_XTAL_275X200_24.000M24.000MHzSM_XTAL_275X200
评价一下你浏览此帖子的感受
精彩
感动
搞笑
愤怒
一般
差劲
在线老吴
性别:
帅哥
发帖
15521
金币
156570
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       只看该作者 1楼 发表于: 2018-04-04
只有PCB文件。没有原理图。回复可见 ~yv7[`+Tgg
@9/I^Zk
本部分内容设定了隐藏,需要回复后才能看到(回复后还看不到就刷新一下即可)
j>8DaEfwx
x0j5D
离线i_333333
性别:
帅哥
发帖
6729
金币
3264
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       只看该作者 2楼 发表于: 2018-04-04
非常感谢楼主大神的分享
离线wangy2000
性别:
人妖
发帖
6747
金币
283
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       只看该作者 3楼 发表于: 2018-04-04
大气高手,学习学习,增长知识。
离线mryulou
性别:
人妖
发帖
55
金币
64
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       只看该作者 4楼 发表于: 2018-04-04
离线shuszhao
性别:
帅哥
发帖
17962
金币
36209
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       只看该作者 5楼 发表于: 2018-04-04
老吴出品,必是精品
性别:
帅哥
发帖
347
金币
9
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       只看该作者 6楼 发表于: 2018-04-04
xcIZ'V
离线bingo426
性别:
帅哥
发帖
5491
金币
4497
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       只看该作者 7楼 发表于: 2018-04-04
最后成功的人往往不是最有才华的人,而是那些默默付出直到最后一刻也不放弃的那些人!
在线williamtony
性别:
帅哥
发帖
1567
金币
549
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       只看该作者 8楼 发表于: 2018-04-04
我还在画两层板子
离线ntpcb_pads
性别:
帅哥
发帖
330
金币
234
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       只看该作者 9楼 发表于: 2018-04-04
看一下 好像很厉害
离线电子宅
性别:
人妖
发帖
3750
金币
2444
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       只看该作者 10楼 发表于: 2018-04-04
老吴牛逼啊,这资料逆天
性别:
人妖
发帖
14
金币
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       只看该作者 11楼 发表于: 2018-04-04
大神 EVR! @6@
离线miaomiao
性别:
人妖
发帖
7626
金币
1051
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       只看该作者 12楼 发表于: 2018-04-04
非常感谢楼主大神的分享
离线cityhu
性别:
帅哥
发帖
9152
金币
7291
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       只看该作者 13楼 发表于: 2018-04-04
(MLhaux-
性别:
帅哥
发帖
163
金币
362
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       只看该作者 14楼 发表于: 2018-04-04
快速回复
限150 字节
上一个 下一个
