CPU1: Broadcom BCM63138 (1 GHz, 2 cores) _R74/|
CPU2: Quantenna QT3840BC (500 MHz, 2 cores) /cfHYvnz
FLA1: 128 MiB (Micron MT29F1G08ABAEAWP:E) $)*xC!@6X
FLA2: 64 KiB (Winbond W25X05CL) :Fw?{0
RAM1: 256 MiB (Samsung K4B2G1646E-BCK0) ;Iq5|rzDn
RAM2: 128 MiB (ESMT M15F1G1664A-ADBG2R) uNbIX:L,
kOipH |.x
Expansion IFs: Mini PCIe, USB 2.0, USB 3.0 !
=WcF5
Mini PCIe slots: 1 Ea]T>4
USB ports: 2
AS|Rd+. WI1 module: Actiontec PEQ840H <KLg0L<W WI1 module IF: Mini PCIe (oversized)
a5?A!k\2 WI1 chip1: Quantenna QT3840BC
C3}Aq8$6 WI1 chip2: Quantenna QT2518B
RZh}: WI1 802dot11 protocols: an+ac
}9CrFTbx; WI1 MIMO config: 4x4:4
dB3N%pB^ WI1 antenna connector: U.FL
A(+:S"|@ WI2 chip1: Broadcom BCM43602
hVUIBJ/5(- WI2 802dot11 protocols: bgn
S+ebO/$> WI2 MIMO config: 3x3:3
DA=1KaJ . WI2 antenna connector: U.FL
<hv7s,i
ETH chip1: Broadcom BCM63138 lzDdD3Ouc
Switch: Broadcom BCM63138 =}R~0|^
LAN speed: 10/100/1000 o&$hYy"<.L
LAN ports: 4 tD-gc''H
WAN speed: 10/100/1000 nxQ}&n
WAN ports: 1
_~A~+S}
abgn+ac
9m8ee&, ? )_7U Pp*}R2 继续 Tpzw=bC^ Q2c*.Y 小芯片ZW0301
