Genesis_FLI10260方案的双高频头高清液晶电视 bR0 z$~ K<3$>/|
JyfWy MgP6ki1z u`Sg' ro iJr 1w&GL$ ****************以下信息由管理员 @老吴 整理补充******************* #U=}Pv~wM 板子有以下元件和 封装,如有需要可以下载提取使用。 h/AL`$ A4 | VT1Y5CR501B | M-XG-TDQ-6FT/W116H-HX | CN1 | CON4 | M-TJC10-4A-HX | CN3,CN5 | 640456-4 (AMP) | M-TJC3-4A-HX | CN4 | 640456-4 (AMP) | VPHONE | CN6 | SVIDEO JACK | M-S4-HX | CN7 | HLN14H-ND (Digikey) | M-2P14-2.00X2.00-180-HX | CN8 | KOBI-USB-154-2742 | USB-154-2742 | CN9 | AV_OUT | M-AV3-LP-HX | CN10 | AV_IN2 | M-AV3-LP-HX | CN11 | SIDE_AV_IN | M-AV4-L1-HX | CN12 | CON14 | M-TJC10-14A-HX | CN13 | CON5 | M-TJC10-5A-HX | CN14 | CON13 | M-TJC10-14A-HX | CN15 | CON3 | M-TJC10-3A-HX | CN23 | KFO-TX13CB | M-KFO-TX13C-HX | CN27 | 786382-1 | M-DSUB-15A-L-HX | CN33,CN34 | 500254-1941 | M-HDMI-L-HX | CN45 | SJ-3535NG | VPHONE | CN51 | CON6 | M-TJC10-6A-HX | CN52 | PHONE_C | M-CK3-3.5-02-HX | CON5 | DB-9 | DB9_QC | CON8 | 40P-2X20 | M-2P40-2.00X2.00-180-HX | C1,C19,C20,C22,C32,C56, | 47uF/16V | R-CAPAE-D6.3X5.4-HX | C749,C753,C762 | | | C2,C4,C61,C91,C93,C975, | 220uF/16V | R-CAPAE-D8.0X10.2-HX | C980 | | | C3,C5,C861,C862,C863, | 10nF | R-CAPC1608N-HX | C864,C867,C868,C873,C874, | | | C876 | | | C6,C8,C95,C96,C388,C702, | 10uF | R-CAPC2012N-HX | C944,C1009,C1024 | | | C7,C10,C12,C13,C24,C31, | 0.1uF | R-CAPC1608N-HX | C33,C62,C64,C65,C66,C68, | | | C92,C94,C98,C132,C133, | | | C152,C160,C162,C164,C173, | | | C220,C274,C277,C278,C279, | | | C297,C299,C301,C302,C303, | | | C304,C312,C315,C316,C320, | | | C323,C324,C325,C328,C381, | | | C384,C386,C387,C389,C392, | | | C393,C394,C397,C399,C400, | | | C660,C669,C678,C679,C764, | | | C765,C766,C767,C768,C769, | | | C770,C791,C794,C795,C808, | | | C809,C810,C811,C823,C824, | | | C825,C854,C858,C859,C860, | | | C901,C902,C906,C907,C908, | | | C909,C910,C911,C912,C913, | | | C914,C915,C916,C917,C918, | | | C919,C920,C921,C922,C925, | | | C927,C928,C929,C930,C931, | | | C932,C933,C934,C935,C939, | | | C940,C941,C947,C969,C977, | | | C1010 | | | C9,C11,C151,C159,C163, | 100uF/16V | R-CAPAE-D6.3X5.4-HX | C165,C219,C221,C383,C385, | | | C959 | | | C21,C23 | 0.1uF | R-CAPC3216N-HX | C29 | 22uF/16V | R-CAPC2012N-HX | C34,C283,C288,C289,C290, | 10uF/10V/X7R | R-CAPC2012N-HX | C298,C300,C308,C309,C313, | | | C314,C321,C322,C688,C693, | | | C796,C797,C798,C805,C812 | | | C36,C38,C40,C51,C53,C54, | 0.1uF | R-CAPC1005L-HX | C55,C74,C75,C76,C77,C78, | | | C153,C154,C200,C202,C204, | | | C206,C208,C210,C212,C214, | | | C216,C218,C260,C291,C294, | | | C346,C347,C351,C352,C353, | | | C354,C355,C356,C357,C358, | | | C359,C360,C371,C372,C647, | | | C648,C649,C650,C651,C652, | | | C659,C663,C665,C668,C689, | | | C690,C691,C694,C695,C696, | | | C697,C699,C700,C701,C710, | | | C793,C813,C814,C815 | | | C37,C664 | 4.7uF/10V/X7R | R-CAPC3216N-HX | C39,C41,C161,C349,C377, | 1uF/10V/X7R | R-CAPC1608N-HX | C378 | | | C45,C46,C956 | 20pF | R-CAPC1608N-HX | C47 | 33pF | R-CAPC1608N-HX | C48,C49 | 5pF | R-CAPC1005L-HX | C50 | 47uF/16V | R-CAPTE3528N-HX | C52,C84,C86,C87,C101, | 0.01uF | R-CAPC1005L-HX | C103,C105,C107,C109,C111, | | | C113,C115,C118,C120,C122, | | | C124,C126,C128,C130,C134, | | | C136,C155,C156,C176,C177, | | | C178,C180,C182,C184,C186, | | | C188,C190,C192,C194,C196, | | | C199,C201,C203,C205,C207, | | | C209,C211,C213,C215,C217, | | | C292,C293,C373,C374,C375, | | | C376,C653,C654,C655,C656, | | | C657,C658,C661,C662,C666, | | | C667,C801 | | | C57,C67 | 22uF/16V | R-CAPC1608N-HX | C58,C282,C952,C954,C955, | 0.01uF | R-CAPC1608N-HX | C961,C962,C964 | | | C59,C63,C167,C170,C223, | 1nF | R-CAPC1608N-HX | C226 | | | C85,C102,C104,C106,C108, | 1nF | R-CAPC1005L-HX | C110,C112,C114,C116,C119, | | | C121,C123,C125,C127,C129, | | | C131,C181,C183,C185,C187, | | | C189,C191,C193,C195,C197, | | | C255,C256,C348,C361,C362, | | | C363,C364,C365,C366,C367, | | | C368,C802 | | | C88,C89 | 33uF/10V | R-CAPTE3528N-HX | C90,C398 | 220uF | R-CAPAE-D8.0X10.2-HX | C166,C169,C222,C225 | 2.2uF | R-CAPC2012N-HX | C168,C171,C224,C227 | 100pF | R-CAPC1608N-HX | C175,C179,C198,C238,C239, | 10uF/10V/X7R | R-CAPC1608N-HX | C240,C241,C259,C275,C816 | | | C333 | 100 nF | R-CAPC1608N-HX | C350,C369,C370 | 33uF/10V | R-CAPAE-D4.0X5.4-HX | C382 | NU | R-CAPC1608N-HX | C390 | 1n | R-CAPC1608N-HX | C391,C971,C1007,C1008 | 1uF | R-CAPC1608N-HX | C395,C396,C943,C946 | 22 uF | R-CAPAE-D4.0X5.4-HX | C402,C403 | TBD | R-CAPC1608N-HX | C784 | 68pF | R-CAPC1608N-HX | C855 | 47nF | R-CAPC1608N-HX | C856,C857 | 18pF | R-CAPC1608N-HX | C865,C866,C869,C870,C871, | 330pF | R-CAPC1608N-HX | C872,C877,C878 | | | C903,C904 | 100p | R-CAPC1608N-HX | C905,C923,C924,C942 | 47uF | R-CAPAE-D6.3X5.4-HX | C926 | 10uF | R-CAPAE-D4.0X5.4-HX | C948 | 470uF/16V | R-CAPAE-D8.0X10.2-HX | C949,C950,C966,C967 | 47pF | R-CAPC1608N-HX | C953 | OR | R-CAPC1608N-HX | C957,C965,C970 | 470nF | R-CAPC1608N-HX | C958,C990,C993,C996, | 220nF | R-CAPC1608N-HX | C1001 | | | C960 | 100uF | R-CAPAE-D6.3X5.4-HX | C963 | 390pF | R-CAPC1608N-HX | C968 | 1.5nF | R-CAPC1608N-HX | C972 | 47uF/50V | R-CAPAE-D6.3X5.4-HX | C973 | 33nF/50V | R-CAPC1608N-HX | C974 | 10uF/50V | R-CAPAE-D4.0X5.4-HX | C976,C981,C982,C983, | 100nF | R-CAPC1608N-HX | C1013 | | | C984,C994,C998,C1006 | 1u | R-CAPC1608N-HX | C985,C992,C997,C1005 | 470nF/MEF | R-CAPC1608N-HX | C986,C987,C1000,C1003 | 220pF | R-CAPC1608N-HX | C988 | 10pF/47pF | R-CAPC1608N-HX | C989,C991,C999,C1002 | 470pF/CC | R-CAPC1608N-HX | C995 | 330nF | R-CAPC1608N-HX | C1004 | 5pF/100pF | R-CAPC1608N-HX | D1,D829 | 1N4148 | R-SOD3718N-HX | D2,D3 | SR32 | R-SOD3718N-HX | D4,D7 | LED (GREEN) | R-DIOM5326N-HX | D5 | BAT54S | R-SOT3N-0.95-2.80-HX | D6 | CM1213-02 | R-SOT5N-0.95-2.80-HX | D8,D13,D14,D17,D18,D19, | INPAQ_EGA | R-INDC1608N-HX | D20,D23,D25,D28,D29,D30, | | | D31,D32,D35,D36,D37,D38, | | | D39 | | | D9,D10,D11,D42,D43,D44, | ESD | R-INDC1608N-HX | D60,D61,D62,D67,D68,D69, | | | D70,D71,D72,D73,D74,D75, | | | D76,D77,D78,D79,D87 | | | D21,D22,D24 | BAV70 | R-SOT3N-0.95-2.80-HX | D80,D81,D82,D83 | DIODE | R-CAPC1608N-HX | D84,D86 | 1N4148 | R-CAPC1608N-HX | D85 | UPC574 | R-CAPC1608N-HX | D100,D101,D102,D103,D104, | 5.6V | R-CAPC1608N-HX | D105,D107,D108,D109,D110 | | | D801 | VAITIED6060 | M-SHARP-VA1T1ED6060-HX | D802 | LGS_8222_ES2 | R-SQFP129N-G-0.500-16.00X22.00-HX | D803 | K4S641632D | R-TSOP54N-0.800-11.76-HX | D804 | AD9203/SO | R-TSOP28N-0.650-6.40-HX | D824 | 74LVX74/SO | R-TSOP14N-0.650-6.40-HX | D832,D833 | IN4148 | R-SOD3718N-HX | FB1,FB2,FB3,FB4,FB5,FB6, | MI0603J601R-10 | R-INDC1608N-HX | FB7,FB8,FB11,FB12,FB16, | | | FB17,FB24,FB25,FB26,FB27, | | | FB28,FB29,FB32,FB34,FB35 | | | FB9,FB302,FB303,FB304 | 2.2uH | R-INDC2012N-HX | FB301 | 121 | R-INDC1608N-HX | FB305 | 120 Ohm | R-INDC3216N-HX | FB306,FB307,FB308,FB309 | BEAD | R-INDC3216N-HX | F2 | 3A, 0433003.NR | R-INDC3216N-HX | L14,L25,L26,L27,L28 | 33uH/3A | R-SLF10145-HX | L15 | 33uH/3A | R-SLG12080-HX | L18 | Ferrite Bead | R-INDC2012N-HX | L20 | Ferrite Bead | R-INDC3225N-HX | L21,L22,L24 | 10uH | R-INDC3216N-HX | L23 | 470uH | A-L05.0-LGB0812-R-HX | M1,M2,M3,M4,M5,M8 | Mounting Hole | O-FIX-D4.0-M-90-HX | M7,M9,M10,M11,M12,M13, | Mounting Hole | M_HX | M14,M15 | | | Q1,Q22,Q24,Q27,Q28 | 2N7002 | R-SOT3N-0.95-2.80-HX | Q3,Q4,Q5,Q6,Q7,Q8,Q10, | MMBT3904 | R-SOT3N-0.95-2.80-HX | Q13,Q17,Q18,Q25,Q26,Q30, | | | Q31,Q32,Q33,Q34,Q35 | | | Q9 | FDV304P | R-SOT3N-0.95-2.80-HX | Q15 | 3904 | R-SOT3N-0.95-2.80-HX | Q16 | SST3906 | R-SOT3N-0.95-2.80-HX | Q19,Q20,Q21 | 2N3904 | R-SOT3N-0.95-2.80-HX | Q23 | 2SC1815 | R-SOT3N-0.95-2.80-HX | Q29 | MMBT3906 | R-SOT3N-0.95-2.80-HX | RN1,RN3,RN4,RN6,RN12, | 10R | CTS\741X083 | RN13,RN15,RN16,RN17,RN18, | | | RN19,RN20,RN21,RN22,RN23, | | | RN24,RN25,RN26 | | | RN28 | 4.7K | R-RESCA3216-8N-HX | RN29,RN30,RN31,RN32,RN33, | 33 | R-RESCA3216-8N-HX | RN34,RN35,RN36 | | | R1,R2,R83,R84,R129,R131, | 47K | R-RESC1608N-HX | R296,R313,R322,R325,R388, | | | R949,R956,R959,R965,R970 | | | R3 | 330R | R-RESC1608N-HX | R4,R11,R38,R39,R935,R936, | 2K7 | R-RESC1608N-HX | R939,R940 | | | R5,R7,R294,R311 | 1K 1% | R-RESC1608N-HX | R6,R9 | 10R/2W NC | R-RESC1608N-HX | R8,R295 | 27K | R-RESC1608N-HX | R10 | 4.7K 1% | R-RESC1608N-HX | R12 | 200R 1% | R-RESC1608N-HX | R13,R15,R47,R48,R49,R50, | 1K | R-RESC1608N-HX | R51,R52,R92,R93,R94,R101, | | | R102,R103,R104,R115,R116, | | | R144,R145,R218,R390,R405, | | | R484,R485,R488,R489,R490, | | | R491,R835,R845,R847,R850, | | | R851,R856,R857,R858,R859, | | | R864,R865,R968,R969,R985, | | | R986 | | | R16,R27,R28,R29,R40,R41, | 4.7K | R-RESC1608N-HX | R42,R43,R86,R91,R832, | | | R833,R870,R871,R873,R874, | | | R875,R888,R909,R911,R912, | | | R913,R915,R918,R943,R984 | | | R17 | 22R | R-RESC1608N-HX | R18,R19,R881,R948,R955, | 15K | R-RESC1608N-HX | R958,R964 | | | R20 | 6.195K 1% | R-RESC1608N-HX | R21,R22,R23,R24,R25,R30, | 10K | R-RESC1608N-HX | R31,R32,R33,R34,R35,R36, | | | R37,R57,R58,R59,R61,R65, | | | R71,R73,R81,R82,R85,R87, | | | R89,R96,R126,R127,R134, | | | R137,R138,R141,R142,R213, | | | R214,R220,R222,R223,R236, | | | R237,R312,R320,R323,R383, | | | R432,R442,R443,R444,R445, | | | R446,R447,R448,R449,R450, | | | R451,R452,R453,R454,R455, | | | R456,R457,R469,R479,R480, | | | R481,R482,R483,R486,R487, | | | R492,R493,R494,R495,R810, | | | R836,R860,R861,R862,R863, | | | R866,R867,R872,R883,R885, | | | R887,R899,R942,R972,R973, | | | R975,R1000 | | | R26 | 560R | R-RESC1608N-HX | R62,R297,R314 | NM | R-RESC1608N-HX | R68,R69 | 82K | R-RESC1608N-HX | R70,R72,R98,R100,R216, | 0R | R-RESC1608N-HX | R422,R423,R424,R425,R458, | | | R889,R890,R896,R897,R898, | | | R907,R923,R938 | | | R90,R221,R930,R980 | 100K | R-RESC1608N-HX | R97 | 294R 1% | R-RESC1608N-HX | R122,R156,R159,R162,R163, | 20R | R-RESC1608N-HX | R186,R191,R196,R197,R200, | | | R224,R225,R227,R415,R418, | | | R419 | | | R123,R124,R128,R130,R317, | 33K | R-RESC1608N-HX | R318,R321,R324 | | | R125,R319,R397,R402,R900, | 100 | R-RESC1608N-HX | R901,R921,R922,R941 | | | R136,R841,R842,R849,R854, | 100R NC | R-RESC1608N-HX | R855 | | | R139,R431,R465,R466,R478, | 100R | R-RESC1608N-HX | R811,R830,R831,R834,R837, | | | R838,R839,R840,R844,R846, | | | R848,R882,R884,R916,R926 | | | R143 | 10nF | R-RESC1608N-HX | R152,R157,R173,R174,R175, | 75 | R-RESC1608N-HX | R180,R203,R204,R205,R206, | | | R208,R229,R230,R231,R416, | | | R417 | | | R166,R181,R189,R201 | 57.6R 1% | R-RESC1608N-HX | R209,R210 | 30K | R-RESC1608N-HX | R215 | 4.02K | R-RESC1608N-HX | R217,R406 | 0R NC | R-RESC1608N-HX | R306 | 250R 1% | R-RESC1608N-HX | R340 | 1.818K 1% | R-RESC1608N-HX | R387 | 680 | R-RESC1608N-HX | R389 | 300K | R-RESC1608N-HX | R392,R398 | 220 | R-RESC1608N-HX | R396 | 12k | R-RESC1608N-HX | R399 | 470 | R-RESC1608N-HX | R404 | 68 | R-RESC1608N-HX | R438,R439 | 200R | R-RESC1005L-HX | R507,R508,R509,R510 | 2.7K | R-RESC1608N-HX | R827,R868,R869,R893,R894, | NU | R-RESC1608N-HX | R895 | | | R828,R829 | 33 | R-RESC1608N-HX | R852,R853 | 1K NC | R-RESC1608N-HX | R876,R877,R878,R879,R880 | 33R | R-RESC1608N-HX | R886 | 180R | R-RESC1608N-HX | R902 | 120R_NC | R-RESC1608N-HX | R903,R908 | 0_NC | R-RESC1608N-HX | R905,R919 | 1.5K | R-RESC1608N-HX | R906,R947,R954,R963 | 0 | R-RESC1608N-HX | R910 | 6.8K | R-RESC1608N-HX | R914 | 560K_NC | R-RESC1608N-HX | R917 | 680K_NC | R-RESC1608N-HX | R920 | 5.6K | R-RESC1608N-HX | R924,R925,R934 | 22K | R-RESC1608N-HX | R927 | 6.8K_NC | R-RESC1608N-HX | R928 | 2.2K | R-RESC1608N-HX | R929 | 330 | R-RESC1608N-HX | R931 | 68R | R-RESC1608N-HX | R932 | 220R | R-RESC1608N-HX | R933 | 75R | R-RESC1608N-HX | R937 | 47R | R-RESC1608N-HX | R944,R950 | 10 1/4W | R-RESC1608N-HX | R945,R946,R966,R967 | 150K | R-RESC1608N-HX | R951,R952,R960,R961 | 1M | R-RESC1608N-HX | R953,R957 | 10 1/4W | R-RESC1608N-HX | R962 | 10 1/4W | R-RESC1608N-HX | R1001 | 20K | R-RESC1608N-HX | SAW1 | D7262 | M-SAW-P-S-HX | SAW2 | K9455 | M-SAW-P-S-HX | SW1 | RESET SW / PTS635VL39 | M-KAN-C202-H-HX | TP1,TP2,TP3,TP4,TP5,TP6, | TP | O-TP-0.9-HX | TP9,TP11,TP12,TP13,TP14, | | | TP19,TP20,TP21,TP22,TP23, | | | TP24,TP27,TP28,TP35,TP38, | | | TP39,TP40,TP41,TP42,TP43, | | | TP44,TP45,TP46,TP47,TP48, | | | TP49,TP50,TP51 | | | TP7 | T POINT S | O-TP-0.9-HX | TP15 | TP | O-MARK-D1-HX | T1,T2,T3,T4,T5,T6,T7,T8, | Mounting Hole | O-MARK-D1-HX | T9,T10,T11,T12,T13,T14, | | | T15,T16,T17,T18,T19,T20 | | | U1,U4 | DF1117-3.3 | R-SOT4N-2.30-7.00-HX | U2,U3 | MP2270 | R-TSSOP11N-0.500-4.90-HX | U6 | DF1117-ADJ | R-SOT4N-2.30-7.00-HX | U7,U8 | LT1084-1.8 | R-TO4N-2.54-15.24-HX | U9,U10 | EDE5116AFSE-4A_32Mx16 | R-FPGBA84(42+42)-8.0X13.0-0.80-0.50-HX | U11 | 24LC32-SN | R-SOIC08N-1.270-6.00-HX | U12 | FLI10260_16 | R-BGA633(552+81)-37.5X37.5-1.27-0.75-HX | U12 | FLI10260_16 | R-BGA6R-BGA633(552+81)-37.5X37.5-1.27-0.75-HX33(552+81)-37.5X37.5-1.27-0.75-HXBGA-633_R-BGA633(552+81)-37.5X37.5-1.27-0.75-HXCHIP | U13 | 74LCX14/SO | R-SOIC14N-1.270-6.00-HX | U14 | MIC2025-2 | R-SOIC08N-1.270-6.00-HX | U15,U18 | TL062 | R-SOIC08N-1.270-6.00-HX | U17 | S29GL256N11TFI010 Socket and Chip | TSOP56-1420-0.5 | U21 | NAND_K9F5608R0D Socket and Chip | TSOP48-1220-0_5 | U22,U27 | IRF7314 | R-SOIC08N-1.270-6.00-HX | U31 | TFA9810 | R-SOIC32N-1.270-10.32-HX | U32,U33 | MC78M05CDT | R-TO3N-2.28-9.70-HX | U34 | TDA9885T/V3 | R-SOP24N-0.650-7.80-HX | U35,U36 | TC7S04F NC | R-SOT5N-0.95-2.80-HX | U37 | ATMega16L | R-TQFP044N-0.800-12.00X12.00-HX | U38 | LMV7239 | R-SOT5N-0.65-2.10-HX | U39,U47,U50 | 24AA02 | R-SOIC08N-1.270-6.00-HX | X1 | 19.66MHz Crystal | Y-HC49US | X2 | 7.3728 | R-CRYC1405N-HX | X3 | 4MHz | R-CRYC1405N-HX | X4 | OSC | M-DIP4-7.62-180-HX | p4_a1,p4_a2 | YPrBb | M-AV3-LP-HX | p4_b1,p4_b2 | RCA-QUAD | M-AV2-LP-HX | us:V\V
