Reading file -- C:\PADS Projects\padsnet.asc X
VH(zJ
*Not valid pin name for part type LED1.2 kcNPdc
M15.1 R38.2 LED1.2 LED13.2 LED11.2 0d0ga^O
*Not valid pin name for part type LED9.2 $(yi+v
LED9.2 LED7.2 LED5.2 LED3.2 S8.1 3Zp q#
*Not valid pin name for part type LED16.2 #rz!d/)Q
S4.1 LED16.2 GND1.1 LED17.2 $p}q,f.
*Not valid pin name for part type LED1.1 \ZSq ZDq
LED1.1 LED2.2 PVQn$-aq1
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal $$$27798 ':=20V
*Not valid pin name for part type LED2.1 B'PS-Jr
LED2.1 R1.1 %r(qQM.Pl
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal $$$27800 /p}pdXS
*Not valid pin name for part type LED3.1 P+e {,~o
LED3.1 LED4.2 :pvVm>
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal $$$27817 W:}t%agis
*Not valid pin name for part type LED4.1 :$XlYJrjK
LED4.1 R5.1 cw_B^f8^
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal $$$27818 tI.ho
*Not valid pin name for part type LED5.1 u0Z MrIJ
LED5.1 LED6.2 ,RAP_I!_x
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal $$$27851 Ty;^3
*Not valid pin name for part type LED17.1 AJoP3Zv|?
R2.1 LED17.1 LCD1.35 +mO/9m
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal $$$4391 ]4FAbY2'h
*Not valid pin name for part type LED6.1 +R8dy
LED6.1 R9.1 `0W+(9}
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal $$$27852 {XnBj}C
*Not valid pin name for part type LED7.1 }Os7[4RW
LED7.1 LED8.2 ,s,AkH
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal $$$27853 ,OkI0[
*Not valid pin name for part type LED8.1 g6][N{xW0
LED8.1 R10.1 7VLn$q]:
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal $$$27854 a\p`J 9Z@
*Not valid pin name for part type LED9.1 JFkx=![
LED9.1 LED10.2 Z|3[Y@c\
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal $$$27860 X9&>.?r
*Not valid pin name for part type LED10.1 @k-GyV-v
LED10.1 R11.1 OskQ[
e0
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal $$$27861 zgxMDLH
*Not valid pin name for part type LED11.1 +N|t:8qaf
LED11.1 LED12.2 j}G9+GX~,
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal $$$27862 pT:6A[&
*Not valid pin name for part type LED12.1 %^u
e
LED12.1 R12.1 }C
JK9*Z
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal $$$27863 pA\"Xe&
*Not valid pin name for part type LED13.1 ABq#I'H#@2
LED13.1 LED14.2 @[TSJi
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal $$$27864 LS<*5HWX
*Not valid pin name for part type LED14.1 GCxmqoQ
LED14.1 R13.1 q9Lq+4\
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal $$$27865 _6aI>b#yL
*Not valid pin name for part type LED15.2 )qD V3
LED15.2 LED16.1 #Xi9O.
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal $$$3708 6""i<oR
*Not valid pin name for part type LED15.1 - G=doP0
R17.1 LED15.1 tR?)C=4,
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal $$$28154 zRm@ |IT
Warning: deleting signal $$$27798 PD^Cj?wm
Warning: deleting signal $$$27800 d(, M
Warning: deleting signal $$$27817 T>5N$i
Warning: deleting signal $$$27818 }~v0o#
I
Warning: deleting signal $$$27851 U@LIw6B!KL
Warning: deleting signal $$$4391 '*K%\]
Warning: deleting signal $$$27852 }#Kl6x
Warning: deleting signal $$$27853 i~{ 0>"9
Warning: deleting signal $$$27854 |O*?[|`H
Warning: deleting signal $$$27860 G~f|Sx
Warning: deleting signal $$$27861 #*"I?B/fd8
Warning: deleting signal $$$27862 X/D%
cQ6
Warning: deleting signal $$$27863 {YIVi:4q
Warning: deleting signal $$$27864 EB
p(^rj
Warning: deleting signal $$$27865 07vzVsQ}p
Warning: deleting signal $$$3708 K6nNrd}p:
Warning: deleting signal $$$28154 h-%RSei5
**INPUT WARNINGS FOUND** |u[@g`Z
#\6k_toZ
`bNLmTS
1@q"rPE^
x!fRT.,}
搞了一下午都没搞好,网上有说LED管脚不对,什么A,K对1,2什么的,我看了下,都是1,2,请高人指点下
