REFDES | COMP_DEVICE_TYPE | VALUE | SYM_NAME |
D21 | D_A_0_R-SOD3718N-HX_1N5819HW | 1N5819HW | R-SOD3718N-HX |
D22 | D_A_0_R-SOD3718N-HX_1N5819HW | 1N5819HW | R-SOD3718N-HX |
D26 | SMD0805-050_R-INDC3216N-HX_0.75 | 0.75A | R-INDC3216N-HX |
D47 | BAV99/SOT_R-SOT3N-095-280-HX_BA | BAV99/SOT | R-SOT3N-095-280-HX |
D48 | SMD0805-050_R-INDC3216N-HX_0.75 | 0.75A | R-INDC3216N-HX |
D49 | D_A_0_R-SOD3718N-HX_1N5819HW/NC | 1N5819HW/NC | R-SOD3718N-HX |
DU1 | DDR3_1_R-FBGA96-900X1330-080-04 | DDR3-FBGA96 | R-FBGA96-900X1330-080-045-HX |
DU2 | DDR3_1_R-FBGA96-900X1330-080-04 | DDR3-FBGA96 | R-FBGA96-900X1330-080-045-HX |
J14 | RJ-45-8-LED_0_M-A-1-RJ08STB1N-0 | RJ-45+LED | M-A-1-RJ08STB1N-02-HX |
J18 | SIP3_0_M-TJC10-3A-HX_SIP3 | SIP3 | M-TJC10-3A-HX |
J20 | DB19S4_R-DC1R019JD1-HX_DB19S4 | DB19S4 | R-DC1R019JD1-HX |
J31 | SW-4-HX_2_M-PS-22E10-HX_PS-22E1 | PS-22E10 | M-PS-22E10-HX |
J32 | BNC_1_R-TC-6_SERIES-HX_1073371 | 1073371 I-PEX | R-TC-6_SERIES-HX |
J33 | BNC_1_R-TC-6_SERIES-HX_1073371 | 1073371 I-PEX | R-TC-6_SERIES-HX |
L2 | INDUCTOR_1_R-NR4018-HX_2.2UH | 2.2uH | R-NR4018-HX |
L4 | INDUCTOR_R-INDC1608N-HX_0R | 0R | R-INDC1608N-HX |
L5 | L-HX_R-LQH3NPNG0L-HX_4.7UH | 4.7uH | R-LQH3NPNG0L-HX |
L26 | L-HX_R-NR6045-HX_10.0UH | 10.0 uH | R-NR6045-HX |
L30 | L-HX_R-INDC1608N-HX_BLM18PG121S | BLM18PG121SN1 | R-INDC1608N-HX |
L37 | INDUCTOR_1_R-NR4018-HX_2.2UH | 2.2uH | R-NR4018-HX |
L38 | INDUCTOR_1_R-NR4018-HX_2.2UH | 2.2uH | R-NR4018-HX |
L40 | L-HX_R-INDC1608N-HX_BLM18PG12_1 | BLM18PG121SN1/NC | R-INDC1608N-HX |
LB29 | LB_R-INDC1608N-HX_LB | LB | R-INDC1608N-HX |
LB69 | INDUCTOR_1_R-INDC1608N-HX_FB100 | FB100R/2A | R-INDC1608N-HX |
N7 | AIC2354-GV5TR-HX_R-SOT5N-095-28 | PAM2312 | R-SOT5N-095-280-HX |
N8 | SY8089A_1_R-SOT6N-095-280-HX_FP | FP6373 | R-SOT6N-095-280-HX |
N11 | MAX809RD_R-SOT3N-095-280-HX_SGM | SGM803RXN3/NC | R-SOT3N-095-280-HX |
N15 | SY8089A_1_R-SOT6N-095-280-HX_FP | FP6373 | R-SOT6N-095-280-HX |
N27 | AP3031_6_R-SOT6N-095-280-HX_FR9 | FR9801 | R-SOT6N-095-280-HX |
N28 | SY8089A_1_R-SOT6N-095-280-HX_FP | FP6373 | R-SOT6N-095-280-HX |
N29 | AP2127-HX_R-SOT5N-095-280-HX_AP | AP2127K-ADJ/NC | R-SOT5N-095-280-HX |
N32 | IRM_M-HS0038B8-180-HX_IRM | IRM | M-HS0038B8-180-HX |
N33 | ADXL345-HX_2_R-XG-HDWB-8C-HX_RT | RTL8821AU/NC | R-XG-HDWB-8C-HX |
Q1 | NPN-HX_R-SOT3N-095-280-HX_MMBT3 | MMBT3904LT1 | R-SOT3N-095-280-HX |
Q4 | PMOS_0_R-SOT3N-095-280-HX_AO342 | AO3423-PMOS | R-SOT3N-095-280-HX |
Q6 | NPN-BEC_R-SOT3N-095-280-HX_NPN- | NPN-BEC | R-SOT3N-095-280-HX |
Q9 | NPN-BEC_R-SOT3N-095-280-HX_NPN- | NPN-BEC | R-SOT3N-095-280-HX |
Q11 | NPN-HX_R-SOT3N-095-280-HX_MMBT3 | MMBT3904LT1 | R-SOT3N-095-280-HX |
Q12 | NPN-HX_R-SOT3N-095-280-HX_MMBT3 | MMBT3904LT1 | R-SOT3N-095-280-HX |
Q18 | NPN-HX_R-SOT3N-095-280-HX_MMBT3 | MMBT3904LT1 | R-SOT3N-095-280-HX |
Q19 | NPN-HX_R-SOT3N-095-280-HX_MMBT3 | MMBT3904LT1 | R-SOT3N-095-280-HX |
Q24 | FETP-GSD_R-SOT3N-095-280-HX_PMO | PMOS-GSD | R-SOT3N-095-280-HX |
Q25 | NPN-BEC_R-SOT3N-095-280-HX_NPN- | NPN-BEC | R-SOT3N-095-280-HX |
Q26 | NPN-BEC_R-SOT3N-095-280-HX_NP_1 | NPN-3904 | R-SOT3N-095-280-HX |
Q27 | FETP-GSD_R-SOT3N-095-280-HX_PMO | PMOS-GSD | R-SOT3N-095-280-HX |
Q28 | FETN-GSD_R-SOT3N-095-280-HX_2N7 | 2N7002K(NMOS) | R-SOT3N-095-280-HX |
Q29 | FETP-GSD_R-SOT3N-095-280-HX_PMO | PMOS-GSD | R-SOT3N-095-280-HX |
Q30 | NPN-BEC_R-SOT3N-095-280-HX_3904 | 3904 | R-SOT3N-095-280-HX |
RV5 | SMD_BEAD_FB0603_0_R-RESC1005L_1 | ESD/NC | R-RESC1005L-HX |
RV6 | SMD_BEAD_FB0603_0_R-RESC1005L_1 | ESD/NC | R-RESC1005L-HX |
RV13 | RV-HX_R-INDC1005L-HX_ICVL051803 | ICVL0518030FR | R-INDC1005L-HX |
RV20 | SMD_BEAD_FB0603_0_R-RESC1005L-H | ESD | R-RESC1005L-HX |
RV21 | SMD_BEAD_FB0603_0_R-RESC1005L-H | ESD | R-RESC1005L-HX |
RV22 | SMD_BEAD_FB0603_0_R-RESC1005L-H | ESD | R-RESC1005L-HX |
RV23 | SMD_BEAD_FB0603_0_R-RESC1005L-H | ESD | R-RESC1005L-HX |
RV24 | SMD_BEAD_FB0603_0_R-RESC1005L-H | ESD | R-RESC1005L-HX |
RV25 | SMD_BEAD_FB0603_0_R-RESC1005L-H | ESD | R-RESC1005L-HX |
RV26 | RV-HX_R-INDC1005L-HX_ICVL0518_1 | ICVL0518030FR =P<7tsSuoK /ESD3V3U4ULC | R-INDC1005L-HX |
S1 | FIX-D400-HX_O-FIX-D290-M-HX_D4 | D4 | O-FIX-D290-M-HX |
S2 | FIX-D400-HX_O-FIX-D290-M-HX_D4 | D4 | O-FIX-D290-M-HX |
SW7 | SWITCH_0_M-KAN-C501-H-HX_EXIT | EXIT | M-KAN-C501-H-HX |
T2 | 000-7090-37R_R-SOIC16N-127-940- | 000-7090-37R | R-SOIC16N-127-940-HX |
TP1 | T_POINT_R_O-TP-100-HX_VDD-CPUFB | VDD-CPUFB | O-TP-100-HX |
TP2 | T_POINT_R_O-TP-100-HX_GND-CPUFB | GND-CPUFB | O-TP-100-HX |
TP3 | T_POINT_R_O-TP-100-HX_JTAG-SEL0 | JTAG-SEL0 | O-TP-100-HX |
TP4 | T_POINT_R_O-TP-100-HX_JTAG-SEL1 | JTAG-SEL1 | O-TP-100-HX |
TP5 | T_POINT_R_O-TP-100-HX_CPUX-TDI | CPUX-TDI | O-TP-100-HX |
TP6 | T_POINT_R_O-TP-100-HX_CPUX-TCK | CPUX-TCK | O-TP-100-HX |
TP7 | T_POINT_R_O-TP-100-HX_CPUX-TDO | CPUX-TDO | O-TP-100-HX |
TP8 | T_POINT_R_O-TP-100-HX_CPUX-TMS | CPUX-TMS | O-TP-100-HX |
U1 | H3-BGA3XX_12_R-BGA347-1400X1400 | H3-BGA3XX_11 | R-BGA347-1400X1400-065-030-HX |
U4 | CS0806U_R-SOT6N-095-280-HX_CS08 | CS0806U/AOZ8905 | R-SOT6N-095-280-HX |
U10 | EMMC5_0_BGA169_R-FBGA169-1200X1 | EMMC5_0_BGA169 | R-FBGA169-1200X1600-050-030-HX |
U11 | NAND_FLASH_X8_R-TSSOP48N-050-20 | NC-NAND FLASH X8 | R-TSSOP48N-050-2000-HX |
U26 | MP1484-HX_0_R-SON11N-050-250X25 | AOZ8314/AZ3033-04F/NC | R-SON11N-050-250X250-WGED-HX |
U29 | FSUSB30-HX_2_R-SON10N-050-250X1 | IP4283CZ10 | R-SON10N-050-250X100-HX |
U30 | FSUSB30-HX_2_R-SON10N-050-250X1 | IP4283CZ10 | R-SON10N-050-250X100-HX |
U52 | SGM8903_R-TSOP14N-065-640-HX_SG | SGM89000 | R-TSOP14N-065-640-HX |
V92 | MOSFETP_4_R-SOT3N-095-280-HX_RN | RN7002 | R-SOT3N-095-280-HX |
VD4 | LED-EVERLIGHT-2006N-HX_0_R-2LED | LTST-S326TBJRKT-5A | R-2LED3020N-HX |
VD11 | LED-EVERLIGHT-2006N-HX_0_R-2LED | LTST-S326TBJRKT-5A | R-2LED3020N-HX |
VD12 | LED-EVERLIGHT-2006N-HX_0_R-2LED | LTST-S326TBJRKT-5A | R-2LED3020N-HX |
X2 | XTAL-4-1-HX_R-OSCC3225N-HX_8Z24 | 8Z24000016 | R-OSCC3225N-HX |
XP10 | USB_A_0_R-MT-WN752NW-HX_WIFI | WIFI | R-MT-WN752NW-HX |
XS1 | PHONEJACK_DCIN_M-DC-005-D200-HX | Jack_DCIN | M-DC-005-D200-HX |
XS2 | PHONE-HY350-102-HX_M-HY350-102- | HY3.5-102 | M-HY350-102-HX |
XS3 | OPTICALTX_0_M-PLT133-T6A-HX_GP | GP1FA550TZ | M-PLT133-T6A-HX |
XS10 | USB_A_0_M-USB-AF-90-HX_USB\ATY | USB\A TYPE | M-USB-AF-90-HX |
XS20 | TF-CARD-HX_0_R-TF-130310162-HX_ | TF_PUSH\TP | R-TF-130310162-HX |
XS21 | USB_A_0_M-USB-AF-90-HX_USB\ATY | USB\A TYPE | M-USB-AF-90-HX |
Z2 | CRYSTAL_M-D300-250-9000-HX_32.7 | 32.768KHz/NC | M-D300-250-9000-HX |
Z4 | XTAL-4-3-HX_1_R-OSCC7015N-HX_TM | TMXLi-130/NC | R-OSCC7015N-HX |
