dA hcA. 6LDZ|K@ 5?>4I"ne uy<3B>3~. r*`e%`HU 89&9VX^A \|Af26 Qf=^CQ=lV yQrgOdo,w Comment | Description | Designator | Footprint | LibRef | Quantity | Antenna | Generic Antenna | ANT0, ANT1 | ANT_2.4GHz_microstrip | Antenna | 2 | Battery | Baterry standard modif | BAT1 | S2B-PH-K-S | Battery | 1 | Cap | Capacitor SMD | C0, C1, C2, C3, C4, C5, C6, C8, C9, C10, C12, C14, C15, C16, C17, C18, C19, C20, C21, C22, C23, C24, C30, C32, C36, C37, C41, C42, C43, C44, C46, C47, C48 | rlc_402_smd | Cap | 33 | Cap | Capacitor SMD | C7, C11, C13, C26, C27, C28, C33, C34, C35, C38, C40 | rlc_805_smd | Cap | 11 | Cap Pol | Polarized Capacitor (Surface Mount) | C25, C31 | CD3216-1206 | Cap Pol | 2 | Cap | Capacitor SMD | C29, C39, C45 | rlc_603_smd | Cap | 3 | LED | LED | CHARGE, RX, TX | LGM676 LED | LED | 3 | D Schottky single | Schottky Diode | D1, D2 | SOD123 | D Schottky single | 2 | Ferrite beads | Ferrite beads | FB1 | rlc_402_smd | Ferrite beads | 1 | Test Pin | Test Pin | GND | pin_0.9mm | test_pin | 1 | SMA End Launch | SMA Straight Connector | GPS_ANT | SMA END LAUNCH JACK RECEPTACLE SHORT | SMA | 1 | Test Pin | Test Pin | GPS_PPS, VDD1V2_M | pin_1mm | test_pin | 2 | Header 8 | Header, 8-Pin | J1, J1_DISP, J3, J3_DISP | HDR1X8 | Header 8 | 4 | Header 10 | Header, 10-Pin | J2, J2_DISP | HDR1X10 | Header 10 | 2 | Header 6 | Header, 6-Pin | J4, J4_DISP, J_UART | HDR1X6 | Header 6 | 3 | MS-156HF | MS-156HF Hirose RF Connector | J_ANT0, J_ANT1 | MS-156HF Hirose | MS-156HF | 2 | Inductor | Inductor SMD | L1, L2, L5, L6, L7, L8, L9, L10, L11 | rlc_402_smd | Inductor | 9 | Inductor | Inductor SMD | L4 | rlc_805_smd enlarged | Inductor | 1 | Inductor | Inductor | L12, L13 | L4818 | Inductor | 2 | Logo symbol | Schematic symbol for Logo | Logo Bot | logo_semtech_horiz_size4 | Logo | 1 | Logo symbol | Schematic symbol for Logo | Logo ESD | Logo ESD | Logo | 1 | Logo symbol | Schematic symbol for Logo | Logo Recycling1 | Logo Recycling1 | Logo | 1 | Logo symbol | Schematic symbol for Logo | Logo Semtech S | logo_semtech_horiz_size3 | Logo | 1 | Xtal | Crystal with GND pins; 4 pins | Q1 | nd2016da | Xtal GND | 1 | TCXO | TCXO | Q2 | TCXO 2.0x1.6mm | TCXO | 1 | Resistor | Resistor SMD - IEC symbol version | R1, R2, R36, R38 | rlc_603_smd | Resistor | 4 | Resistor | Resistor SMD - IEC symbol version | R3, R4, R5, R6, R11, R12, R13, R14, R15, R16, R17, R18, R19, R20, R21, R22, R23, R24, R25, R26, R27, R28, R29, R30, R31, R32, R33, R34, R35, R37, R39, R40, R41, R42, R43, R44, R45, R46, R47, R48, R49, R50, R51 | rlc_402_smd | Resistor | 43 | Resistor | Resistor SMD - IEC symbol version | R7, R8, R9, R10, R52 | rlc_201_smd | Resistor | 5 | Logo symbol | Shield - EMI Gasket - Standard Surface Mount Shields | Shield | BMIS-209-F - Shield | Shield | 1 | SX1280 | SX1280 - Ultra low power RF transceiver | U1 | vqfn24_4x4mm | SX1280 | 1 | RF Switch | CG2214M6 RF Switch | U2 | MiniMold-6 | CG2214M6 RF Switch | 1 | NC7SZ04 | NC7SZ04 - TinyLogic HS Single Inverter - Fairchild Semi | U3, U8 | SC70-5 | NC7SZ04 | 2 | SX9306 | Ultra Low Power, Smart Proximity Sensor for SAR | U4 | vqfn20_3x3mm | SX9306 | 1 | MAX-7Q GPS | MAX-7Q; U-Blox; 7 GPS/GNSS modules | U5 | MAX-7 | MAX-7Q | 1 | LTC3553 | Micropower USB Power Manager With Li-Ion Charger, LDO and Buck Regulator | U6 | vqfn20_3x3mm | LTC3553 | 1 | LTC3127 | LTC3127EDD#PBF - 1A Buck-Boost DC/DC Converter with Programmable Input Current Limit | U7 | DD10_L | LTC3127 | 1 | 74LVC1G332GW | Triple 3-Input OR Gate, 6-Pin | U9 | SOT363-6 | 74LVC1G332GW | 1 | MMA8451Q | Xtrinsic MMA8451Q 3-Axis, 14-bit/8-bit Digital Accelerometer | U10 | vqfn16_3x3mm | MMA8451Q | 1 | Jumper | Jumper Wire | VDD_RADIO | bridge_254mm | Jumper | 1 | &s`)_P[
