一个车用TFT LCD显示屏解决方案
车用TFT LCD显示屏解决方案 kvgs $ | | | | | | Bill of Materials | Connectors | | | SourceData From: | SAT0059E2.PrjPCB | | | Project: | | SAT0059E2.PrjPCB | | | Variant: | | None | | | | | | | | | | Creation Date: | 2017/10/20 星期五 | 下午 9:26:49 | | | | Print Date: | 43028 | 43028.91208 | | | | | | | | | | | | | | | | Footprint | Comment | LibRef | Designator | Description | Quantity | | Printed Circuit Board | PCB | !PCB1 | PrintedCircuit Board | 1 | 1210 | C3225X7R1C226M | C3225X7R1C226M | C1 | CAP, CERM, 22uF, 16V,+/-20%, X7R, 1210 | 1 | 0603 | C1608X7R1H104K | C1608X7R1H104K | C2, C7, C8 | CAP, CERM, 0.1uF, 50V,+/-10%, X7R, 0603 | 3 | 1206 | GRM31CR72E104KW03L | GRM31CR72E104KW03L | C3,C80 | CAP, CERM, 0.1uF, 250V,+/-10%, X7R, 1206 | 2 | 0402 | C1005X7R1C473K | C1005X7R1C473K | C4, C5, C16, C17, C68, C69,C78, C79 | CAP, CERM, 0.047uF, 16V,+/-10%, X7R, 0402 | 8 | 0603 | 0603YC104JAT2A | 0603YC104JAT2A | C6, C9, C27,C33, C36, C38, C39, C43, C56, C75, C77 | CAP, CERM, 0.1uF, 16V,+/-5%, X7R, 0603 | 11 | 0603 | GCM188R71H104KA57B | GCM188R71H104KA57B | C10,C20, C21, C47, C48 | CAP, CERM, 0.1uF, 50V,+/-10%, X7R, 0603 | 5 | 0805_HV | EMK212BJ475KG-T | EMK212BJ475KG-T | C11,C44 | CAP, CERM, 4.7uF, 16V,+/-10%, X5R, 0805 | 2 | 0805_HV | GRM21BR71A475KA73L | GRM21BR71A475KA73L | C12, C15, C24, C29, C32,C34, C37, C40, C41 | CAP, CERM, 4.7uF, 10V,+/-10%, X7R, 0805 | 9 | 0805 | GCM188R71H104KA57B | GCM188R71H104KA57B | C14 | CAP, CERM, 0.1uF, 50V,+/-10%, X7R, 0603 | 1 | 2220 | C5750X7R1H106M | C5750X7R1H106M | C18 | CAP, CERM, 10uF, 50V,+/-20%, X7R, 2220 | 1 | 0402 | GRM155R61C104KA88D | GRM155R61C104KA88D | C19, C22, C71, C73 | CAP, CERM, 0.1uF, 16V,+/-10%, X5R, 0402 | 4 | 1206 | 12061C104KAT2A | 12061C104KAT2A | C23, C26, C28, C58, C64, C66 | CAP, CERM, 0.1uF, 100V,+/-10%, X7R, 1206 | 6 | 0805_HV | C0805C225K4RACTU | C0805C225K4RACTU | C25,C60 | CAP, CERM, 2.2uF, 16V,+/-10%, X7R, 0805 | 2 | 2220 | C5750X7S2A106M | C5750X7S2A106M | C30, C31, C35, C45, C49, C51,C54, C57 | CAP, CERM, 10uF, 100V,+/-20%, X7S, 2220 | 8 | CAPSMT_62_HA0 | EMZA630ADA470MHA0G | EMZA630ADA470MHA0G | C42,C74 | CAP, AL, 47uF, 63V, +/-20%,0.7 ohm, SMD | 2 | 0603 | 06035A221JAT2A | 06035A221JAT2A | C46 | CAP, CERM, 220pF, 50V,+/-5%, C0G/NP0, 0603 | 1 | 0402 | UMK105B7222KV-F | Capacitor | C50,C55 | CAP CER 2200PF 50V 10% X7R 0402 | 2 | 0805_HV | GRM21BR71A106KE51L | GRM21BR71A106KE51L | C52, C65,C70 | CAP, CERM, 10uF, 10V,+/-10%, X7R, 0805 | 3 | 0402 | C1005X5R1A104K | C1005X5R1A104K | C53, C59, C61 | CAP, CERM, 0.1uF, 10V,+/-10%, X5R, 0402 | 3 | 0603 | GRM1885C2A470JA01D | GRM1885C2A470JA01D | C62 | CAP, CERM, 47pF, 100V,+/-5%, C0G/NP0, 0603 | 1 | 0805_HV | GRM21BR61C106KE15L | GRM21BR61C106KE15L | C63 | CAP, CERM, 10uF, 16V,+/-10%, X5R, 0805 | 1 | 0603 | GRM188R72A102KA01D | GRM188R72A102KA01D | C67 | CAP, CERM, 1000pF, 100V,+/-10%, X7R, 0603 | 1 | 0603 | GRM188R71E105KA12D | GRM188R71E105KA12D | C72,C76 | CAP, CERM, 1uF, 25V, +/-10%,X7R, 0603 | 2 | 0603 | 06031C222JAT2A | 06031C222JAT2A | C81,C82, C83, C84 | CAP, CERM, 2200pF, 100V,+/-5%, X7R, 0603 | 4 | 0603 | C1608C0G1E472J | C1608C0G1E472J | C85 | CAP, CERM, 4700pF, 25V,+/-5%, C0G/NP0, 0603 | 1 | 0603 | GRM188R71C393KA01D | GRM188R71C393KA01D | C86 | CAP, CERM, 0.039uF, 16V,+/-10%, X7R, 0603 | 1 | SOD-123 | 1N5819HW-7-F | 1N5819HW-7-F | D1 | Diode, Schottky, 40V, 1A, SOD-123 | 1 | SMB | MBRS260T3G | MBRS260T3G | D2 | Diode,Schottky, 60V, 2A, SMB | 1 | TO-277[SMPC] | D_SCHOT_SS5P10_ | D_SCHOT_SS5P10_ | D3 | Diode, High Current,Schottky Barrier, 5A, 100V | 1 | SML-P1_YELLOW-GREEN | SML-P12MTT86 | SML-P12MTT86 | D4 | LED,Yellow/green, SMD | 1 | LED_SMLP12_Yellow | SML-P12YTT86 | SML-P12YTT86 | D5 | LED,Yellow, SMD | 1 | LED_SMLP12_ORANGE | SML-P12DTT86 | SML-P12DTT86 | D6 | LED,Orange, SMD | 1 | SML-P1_GREEN | SML-P12PTT86 | SML-P12PTT86 | D7,D8 | LED, Green,SMD | 2 | Fiducial10-20 | Fiducial | Fiducial | FID1, FID2, FID3, FID4, FID5,FID6 | Fiducialmark. There is nothing to buy ormount. | 6 | NYPMS 440 0025 PH | NY PMS 440 0025 PH | NY PMS 440 0025 PH | H1, H2, H3 | MachineScrew, Round, #4-40 x 1/4, Nylon, Philips panhead | 3 | Keystone5000 | 5000 | 5000 | ISET, SW, TP1, TP3, VBOOST | Test Point, Miniature, Red, TH | 5 | Rosenberger_D4S20G-400A5 | D4S20G-400A5-Z | D4S20G-400A5-Z | J1 | RIGHTANGLE PLUG FOR PCB | 1 | PhoenixConact_1727010 | 1727010 | 1727010 | J2, J3, J7 | Conn Term Block, 2POS, 3.81mm PCB | 3 | CONN_90120-0122 | 90120-0122 | 90120-0122 | J4 | Header, 100mil, 2x1, Tin plated,TH | 1 | TSW-102-07-G-S | TSW-102-07-G-S | TSW-102-07-G-S | J5, J6 | Header,TH, 100mil, 2x1, Gold plated, 230 mil above insulator | 2 | CONN_PEC02SAAN | PEC02SAAN | PEC02SAAN | J8 | Header, 100mil, 2x1, Tin plated,TH | 1 | HDR-100_1X6 | HEADER_HMTSW-106-07-X-230 | HEADER_HMTSW-106-07-X-230 | J9 | Header, 6 pin, 100mil Space,Gold Tail | 1 | CONN_851-43-006-20-001000 | 851-43-006-20-001000 | 851-43-006-20-001000 | J10 | Receptacle, 50mil, 6x1, R/A, TH | 1 | Samtec_QRM8-026-02.0-L-D-A | QRM8-026-02.0-L-D-A | QRM8-026-02.0-L-D-A | J11 | Slimbody GND plane Socket 2x26, 2mm body height, Ag on contact, Alignment, SMD | 1 | SLF10145 | SLF10145T-5R6M3R2-PF | SLF10145T-5R6M3R2-PF | L1 | Inductor,Shielded, Ferrite, 5.6uH, 3.8A, 0.0264 ohm, SMD | 1 | LPS4018 | LPS4018-332MLB | LPS4018-332MLB | L2, L7 | Inductor,Shielded Drum Core, Ferrite, 3.3uH, 1.9A, 0.08 ohm, SMD | 2 | IND_DLW21S | DLW21SN900HQ2L | DLW21SN900HQ2L | L3 | Coupled inductor,0.28A, 0.41 ohm, +/-25%, SMD | 1 | 0603 | BLM18SG121TN1D | BLM18SG121TN1D | L4, L5 | 3A Ferrite Bead, 120 ohm @100MHz, SMD | 2 | IHLP-5050FD | IHLP5050FDER220M5A | IHLP5050FDER220M5A | L6 | Inductor,Shielded, Powdered Iron, 22uH, 5.5A, 0.0313 ohm, SMD | 1 | Keystone5004 | 5004 | 5004 | LOCK, MCLK, PASS, SCL, SDA, TP2 | Test Point, Miniature, Yellow, TH | 6 | PowerPAK_SO-8L | SQJ461EP | SQJ461EP | Q1 | MOSFET, P-CH, -60V, 30A,PowerPAK_SO-8L | 1 | DPAK | IPD25N06S4L-30 | IPD25N06S4L-30 | Q2 | MOSFET,N-CH, 60V, 25A, DPAK | 1 | 1210M | MCR25JZHJ000 | MCR25JZHJ000 | R1 | RES,0 ohm, 5%, 0.25W, 1210 | 1 | 0402 | CRCW040249R9FKED | CRCW040249R9FKED | R2,R83, R84, R85, R86, R87, R88, R89, R90, R91, R92, R93, R94, R95, R96, R97,R98, R99, R100, R101, R102, R103, R104, R105, R106 | RES, 49.9 ohm, 1%, 0.063W, 0402 | 25 | 0603 | RC0603JR-075K1L | RC0603JR-075K1L | R3 | RES,5.1k ohm, 5%, 0.1W, 0603 | 1 | 0603 | RC0603JR-071K6L | RC0603JR-071K6L | R4 | RES,1.6k ohm, 5%, 0.1W, 0603 | 1 | 0603 | CRCW060310K0JNEA | CRCW060310K0JNEA | R5, R77, R78, R81, R111, R113,R114 | RES,10k ohm, 5%, 0.1W, 0603 | 7 | 0402 | CRCW04026K49FKED | CRCW04026K49FKED | R6,R7, R71, R72 | RES, 6.49k ohm, 1%, 0.063W, 0402 | 4 | 0603 | CRCW06030000Z0EA | CRCW06030000Z0EA | R8, R12, R13,R15, R23, R24, R44, R58, R59, R69, R80 | RES,0 ohm, 5%, 0.1W, 0603 | 11 | 0603 | CRCW060313K0JNEA | CRCW060313K0JNEA | R9,R22, R61, R74 | RES,13k ohm, 5%, 0.1W, 0603 | 4 | 0402 | CRCW04022K70JNED | CRCW04022K70JNED | R10, R16, R65, R73 | RES, 2.7k ohm, 5%, 0.063W, 0402 | 4 | 0603 | CRCW060336K0JNEA | CRCW060336K0JNEA | R11 | RES,36k ohm, 5%, 0.1W, 0603 | 1 | 0402 | CRCW04023K30JNED | CRCW04023K30JNED | R14, R17, R18, R63, R64, R70 | RES, 3.3k ohm, 5%, 0.063W, 0402 | 6 | 0402 | CRCW040210K0JNED | CRCW040210K0JNED | R19, R33,R42, R43, R48, R51, R54, R56, R60, R109, R110 | RES, 10k ohm, 5%, 0.063W, 0402 | 11 | 1210M | ERJ14RSJR12U | ERJ14RSJR12U | R20 | RES, 0.12 ohm, 5%, 0.25W, 1210 | 1 | 0402 | CRCW0402768KFKED | CRCW0402768KFKED | R21, R62 | RES, 768k ohm, 1%, 0.063W, 0402 | 2 | 0603 | RC0603FR-0718KL | RC0603FR-0718KL | R25 | RES, 18.0k ohm, 1%, 0.1W, 0603 | 1 | 0603 | CRCW060315K4FKEA | CRCW060315K4FKEA | R26 | RES, 15.4k ohm, 1%, 0.1W, 0603 | 1 | 0603 | CRCW06039K09FKEA | CRCW06039K09FKEA | R27 | RES, 9.09k ohm, 1%, 0.1W, 0603 | 1 | 0603 | CRCW060324K3FKEA | CRCW060324K3FKEA | R28 | RES, 24.3k ohm, 1%, 0.1W, 0603 | 1 | 2412 | LVK24R020FER | LVK24R020FER | R29 | RES,0.02 ohm, 1%, 1W, 2412 | 1 | 0805_HV | CRCW080540K2FKEA | CRCW080540K2FKEA | R30 | RES, 40.2k ohm, 1%, 0.125W, 0805 | 1 | 0603 | CRCW060320K0FKEA | CRCW060320K0FKEA | R31 | RES, 20.0k ohm, 1%, 0.1W, 0603 | 1 | 0603 | CRCW0603200RFKEA | CRCW0603200RFKEA | R32 | RES,200 ohm, 1%, 0.1W, 0603 | 1 | 0603 | CRCW0603100RFKEA | CRCW0603100RFKEA | R34,R40 | RES,100 ohm, 1%, 0.1W, 0603 | 2 | 0603 | CRCW060347K0JNEA | CRCW060347K0JNEA | R35 | RES,47k ohm, 5%, 0.1W, 0603 | 1 | 0402 | CRCW040233K0JNED | CRCW040233K0JNED | R36, R37, R38, R39, R47, R50 | RES, 33k ohm, 5%, 0.063W, 0402 | 6 | 0402 | CRCW040247K0JNED | CRCW040247K0JNED | R41, R49 | RES, 47k ohm, 5%, 0.063W, 0402 | 2 | 0402 | CRCW0402330RJNED | CRCW0402330RJNED | R45, R46, R53 | RES, 330 ohm, 5%, 0.063W, 0402 | 3 | 2512M | CRA2512-FZ-R025ELF | CRA2512-FZ-R025ELF | R52 | RES,0.025 ohm, 1%, 3W, 2512 | 1 | 0603 | RC0603JR-070RL | RC0603JR-070RL | R55, R112 | RES,0 ohm, 5%, 0.1W, 0603 | 2 | 0603 | CRCW060310R0FKEA | CRCW060310R0FKEA | R57 | RES,10.0 ohm, 1%, 0.1W, 0603 | 1 | 0402 | CRCW0402487RFKED | CRCW0402487RFKED | R66,R68 | RES, 487 ohm, 1%, 0.063W, 0402 | 2 | 0402 | CRCW0402220RJNED | CRCW0402220RJNED | R67,R107, R108 | RES, 220 ohm, 5%, 0.063W, 0402 | 3 | 0603 | RC0603FR-0712K4L | RC0603FR-0712K4L | R75 | RES, 12.4k ohm, 1%, 0.1W, 0603 | 1 | 0402 | CRCW04023K00JNED | CRCW04023K00JNED | R76 | RES, 3.0k ohm, 5%, 0.063W, 0402 | 1 | 0603 | CRCW06032M00FKEA | CRCW06032M00FKEA | R79 | RES, 2.00Meg ohm, 1%, 0.1W, 0603 | 1 | 0603 | RC0603FR-07750KL | RC0603FR-07750KL | R82 | RES,750k ohm, 1%, 0.1W, 0603 | 1 | 0805_HV | NCP21XQ102J03RA | NCP21XQ102J03RA | RT1 | Thermistor NTC, 1.0k ohm, 5%,0805 | 1 | SW_219-3LPST | 219-3LPST | 219-3LPST | S1 | Switch, Slide, SPST 3 poles, SMT | 1 | SW_SKRKAEE010 | SKRKAEE010 | SKRKAEE010 | S2,S3 | Switch,Push Button, SMD | 2 | Keystone5001 | 5001 | 5001 | TP11,TP12, TP13 | Test Point, Miniature, Black, TH | 3 | DGQ0010A_N | LM25011MY/NOPB | LM25011MY/NOPB | U1 | 42V2A Constant On-Time Switching Regulator With Adjustable Current Limit,DGQ0010A | 1 | RGP0020D | DRV2667RGP | DRV2667RGP | U2, U8 | PiezoHaptic Driver with Boost, Digital Front End, and Internal Waveform Memory,RGP0020D | 2 | DS90UH926QSQ/NOPB | DS90UH926QSQ/NOPB | DS90UH926QSQ/NOPB | U3 | IC SERIAL/DESERIAL 24 BIT 60-LLP | 1 | RSE0010A | TS3USB221AQRSERQ1 | TS3USB221AQRSERQ1 | U4, U6 | AutomotiveCatalog ESD Protected, High-Speed USB 2.0 (480-Mbps) 1:2 Multiplexer /Demultiplexer Switch, 16 ohm RON, 2.5 to 3.3V, -40 to 125 degC, 10-Pin UQFN(RSE), Green (RoHS & no Sb/Br) | 2 | DSG0008A | TPS22965DSG | TPS22965DSG | U5 | SingleChannel, Ultra-Low Resistance Load Switch, DSG0008A | 1 | RHA0040B | MSP430F2252TRHA | MSP430F2252TRHA | U7 | Mixed Signal MicroController,RHA0040B | 1 | VFP0032B_N | LP8860QVFPRQ1 | LP8860QVFPRQ1 | U9 | LOWEMI, High Performance 4-Channel LED Driver for Automotive Lighting, VFP0032B | 1 | | | | | | 264 |
