12层 PM5377+PM5369+MPC8270+XC6SLX100FG676+PM5370 做的大型主板PCB
REFDESCOMP_DEVICE_TYPESYM_NAMED1BMR464BMR464D2CY2305SO8_CY2305D3BMR464BMR464D4HY57V561620TSOP54_HY57V561620CD5HY57V561620TSOP54_HY57V561620CD6ADM1070ADM1070D7XC6SLX100FG676FPGA676D8MPC8270TBGA480_MPC8280D9IRF3717SO8_IRF3717AD1028F128J3TSOP56_28F128D11KS8721BLLQFP48_KS8721BLD12HR601680SMTA16_HR601680D13IDT74ALVCH162245TSSOP48_IDT74ALVCH162245PAD14IDT74ALVCH162244TSSOP48_IDT74ALVCH162244PAD15PMB8818TPMB8818RD16PMB8818TPMB8818RD17IDT74ALVCH162244TSSOP48_IDT74ALVCH162244PAD18IDT74ALVCH162245TSSOP48_IDT74ALVCH162245PAD19SST39VF040PLCC32-SKTD20DS1721-SO8_IRF7413ASO8_IRF7413AD21ZL30116CABGA100_ZL30116D22IDT74ALVCH162245TSSOP48_IDT74ALVCH162245PAD23IDT74ALVCH162244TSSOP48_IDT74ALVCH162244PAD24AQY280SAQY280SD25PMB8818TPMB8818RD26PMB8818TPMB8818RD27IDT74ALVCH162245TSSOP48_IDT74ALVCH162245PAD29HY57V561620TSOP54_HY57V561620CD30HY57V561620TSOP54_HY57V561620CD32IMP811SOT4_IMP811D34KS8721BLLQFP48_KS8721BLD35KS8721BLLQFP48_KS8721BLD36IDT74ALVCH162244TSSOP48_IDT74ALVCH162244PAD37IDT74ALVCH162244TSSOP48_IDT74ALVCH162244PAD38SP3232-TSSOP16_SP3232TSSOP16_SP3232E8LED-DIP2-LEDDIP2-LEDE9LED-DIP2-LEDDIP2-LEDG1OSC_100MHZSMD0705_OSCG2E3179-OSC10_E3179_20MOSC10_E3179_20MG3OSC_100MHZSMD0705_OSCG425M_CRYSTALSMD0705_OSCG525M_CRYSTALSMD0705_OSCG6OSC_100MHZSMD0705_OSCH1THREE_LEDTHREE_LEDH24LED-LED0805LED0805J0ERNI_114401CON12_ERNI114401J1ERNI_114401CON12_ERNI114401J2ERNI114538ERNI114538J3ERNI_973032CON80_ERNI973032J4ERNI_973032CON80_ERNI973032J5ERNI_973032CON80_ERNI973032J6ERNI_973032CON80_ERNI973032J7ERNI_973032CON80_ERNI973032J8ERNI_973032CON80_ERNI973032J9JTAGCONCONNECTOR6VJ10JP10J10J11JINGUJIANJINGUJIANJ13JINGUJIANJINGUJIANK1SWITCHSW_4P_2L60FERRITEBEAD0805_REST2TESTPOINT_SMTTPCIR24T15HR601680SMTA16_HR601680T16HR601680SMTA16_HR601680U1PKB4204PKB4204PIU2PM5369PM5369_NEWU3PM5369PM5369_NEWU4PM5369PM5369_NEWU5PM5369PM5369_NEWU6PM5370PM5370_NEWU7MC100LVEP111TQFP32U8XCF16PXCF16PU9PM5377-PM5377_NEWPM5377_NEWU10PCA9541DPCA9541DU11DS92LV010ATMSO8NBU12DS1825UDS1825UU13DS1825UDS1825UV1DIODE-SMAT70ASMAT70AV2DIODE-SMAT70ASMAT70AV3SMAT70ASMAT70AV4DIODE-SMAT70ASMAT70AV5DIODE-SMAT70ASMAT70AV6DIODE-SMAT70ASMAT70AV7DIODE-SMAT70ASMAT70AX1SOCKET16CON16_DIP16X2CON_SIP3CON_SIP3PX3CON_SIP3CON_SIP3PX4JP10J10X6CON_SIP3CON_SIP3PX7MTHOLE-MHOLE_5MM_3_5MMMHOLE_5MM_3_5MM PCB文件共享。没有原理图。
**** Hidden Message ***** 看看 谢谢老吴分享 看看再说 吴老大 牛了
