拆ACTIONTEC R3000路由器
CPU1: Broadcom BCM63138 (1 GHz, 2 cores)CPU2: Quantenna QT3840BC (500 MHz, 2 cores)
FLA1: 128 MiB (Micron MT29F1G08ABAEAWP:E)
FLA2: 64 KiB (Winbond W25X05CL)
RAM1: 256 MiB (Samsung K4B2G1646E-BCK0)
RAM2: 128 MiB (ESMT M15F1G1664A-ADBG2R)
Expansion IFs: Mini PCIe, USB 2.0, USB 3.0
Mini PCIe slots: 1
USB ports: 2
WI1 module: Actiontec PEQ840H
WI1 module IF: Mini PCIe (oversized)
WI1 chip1: Quantenna QT3840BC
WI1 chip2: Quantenna QT2518B
WI1 802dot11 protocols: an+ac
WI1 MIMO config: 4x4:4
WI1 antenna connector: U.FL
WI2 chip1: Broadcom BCM43602
WI2 802dot11 protocols: bgn
WI2 MIMO config: 3x3:3
WI2 antenna connector: U.FL
ETH chip1: Broadcom BCM63138
Switch: Broadcom BCM63138
LAN speed: 10/100/1000
LAN ports: 4
WAN speed: 10/100/1000
WAN ports: 1
abgn+ac
http://img.mydigit.net/Mon_1804/88_1079167_3a9cb9fe191eb41.jpg?104http://img.mydigit.net/Mon_1804/88_1079167_5409728f8353039.jpg?39http://img.mydigit.net/Mon_1804/88_1079167_33c4eeb2e02a775.jpg?118http://img.mydigit.net/Mon_1804/88_1079167_10bf1b16fa82112.jpg?61http://img.mydigit.net/Mon_1804/88_1079167_d66d8e4da71649a.jpg?76http://img.mydigit.net/Mon_1804/88_1079167_120f05f5d0ca18b.jpg?69http://img.mydigit.net/Mon_1804/88_1079167_b5133444043a40d.jpg?84http://img.mydigit.net/Mon_1804/88_1079167_7c324e96b3aab8a.jpg?56http://img.mydigit.net/Mon_1804/88_1079167_c16e5a12e01ea72.jpg?59http://img.mydigit.net/Mon_1804/88_1079167_edd3d06e3af11ab.jpg?63
继续
http://img.mydigit.net/Mon_1804/88_1079167_54d7de55cf40535.jpg?112http://img.mydigit.net/Mon_1804/88_1079167_a65408fa14b20dd.jpg?66http://img.mydigit.net/Mon_1804/88_1079167_707187361586a73.jpg?83http://img.mydigit.net/Mon_1804/88_1079167_b02e02cb084869e.jpg?46
小芯片ZW0301 可惜就是拆了拆,能玩坏哪里或者把哪里修好了就更好了
