Amlogic S912 TVBOX DEMO板PCB文件(AP6356S+RTL8211F-CG)
NamePCB DecalValuePart Type1D1SOT-23BAT54CSOT-231D7LED0603GREEN_LEDLED06031D8LED0603BLUE_LEDLED06031EC1C3216NC/47UF_16VC32161EC2C3216NC/100UF_10VC32161J1DC-002DC-002DC-0021J2DC-005NC/DC-005DC-0051K1K_SMDRESET_KEYK_SMD1K2K_SMDALE_KEYK_SMD1Q1SOT-23PMBT3904SOT-231Q2SOT-23PMBT3904SOT-231Q4SOT-23WPM2015SOT-231Q7SOT-23AO3401SOT-231Q8SOT-23AO3401SOT-231Q9SOT-23PMBT3906SOT-231U1MP8756_QFN12MP8756GDMP8756_QFN121U2SOT23-6NC/SY8105ADCSOT23-61U3SOT23-6SY8120B1ABCSOT23-61U4SOT23-6SY8120B1ABCSOT23-61U5SOT23-5WL2803E18-5SOT23-51U6SOT23-6SY8120B1ABCSOT23-61U7SOT23-5WL2803E18-5SOT23-51U10SOT23-6SY8120B1ABCSOT23-62D2LED-D5MMNC/INFRARED_LEDLED-D5MM2J1CN-2P50-4PA2501WV-4PCN-2P50-4P2J2CN-2P00-2X20PA2005WV-N-2X20P_DEBUGCN-2P00-2X20P2J3DB9DB9/FMDB92J4CN-2P00-2X5PA2005WV-N-2X5P_DEBUGCN-2P00-2X5P2J5CN-2P00-2X20PA2005WV-N-2X20P_DEBUGCN-2P00-2X20P2J6DIP-2X2P-2MMDIP-2X2P-2MM2Q1SOT-23PMBT3904SOT-232Q2SOT-23NC/PMBT3904SOT-232Q3SOT-23PMBT3904SOT-232SW1SW-TK-TS-03PVUPDATESW-TK-TS-03PV2U2SOT-23MAX809RD/RS809RSOT-232U3DIP-IRIRM-3638N3DIP-IR2U4SMD_08_SPKSPK0415HM4H-BSMD_08_SPK2U5SMD_08_SPKSPK0415HM4H-BSMD_08_SPK2Y2Y-SMD4P322524MHZ_CL12PF_20PPMY-SMD4P32253U1BGA96-0P8MMH5TQ4G63AFR-RDCBGA96-0P8MM3U2BGA96-0P8MMH5TQ4G63AFR-RDCBGA96-0P8MM3U3BGA96-0P8MMH5TQ4G63AFR-RDCBGA96-0P8MM3U4BGA96-0P8MMH5TQ4G63AFR-RDCBGA96-0P8MM4CON1BTOB30P-MALE-0_8MMBTOB30P-MALE-STRAIGHT_0.8MMBTOB30P-MALE-0_8MM4U5TSOP-48NC/29F64G08CBACATSOP-484U7BGA169-INANDEMMC_FLASHBGA169-INAND5D1ESD0402AZ5725-01FESD04025D2ESD0402AZ5725-01FESD04025D3ESD0402AZ5725-01FESD04025D4ESD0402AZ5725-01FESD04025FB1FB1206100MHZ220OHMFB12065FB2FB0603100MHZ220OHMFB06035J1RJ45LED-LY-RGRJ45-LED-LYRGRJ45LED-LY-RG5J2RJ45_TAB-DOWN-8PRJ45_TAB-DOWN-WITH-LEDRJ45_TAB-DOWN-8P5J3T-24P-PT50MILG11T1001T-24P-PT50MIL5J4DIP-2X13P-2MMDIP2X13_2MMDIP-2X13P-2MM5J5CN-2P00-2X5PA2005WV-N-2X5P_DEBUGCN-2P00-2X5P5L1L06031.5UHL06035L2L06031.5UHL06035L3L30302.2UH_1AL30305Q1SOT-23PMBT3904SOT-235T1TS8121CH1601CGTS8121C5TP5TP3020CLKOUTTP30205U1QFN40-PT04-5X5MMRTL8211F-CGQFN40-PT04-5X5MM5Y1XT-SMD4P322525MHZ_CL12PF_10PPMXT-SMD4P32255Y2XT-49SNC/25MHZ_CL12PF_10PPMXT-49S6CON1USB-MICRO-DIPMICROUSB-MICRO-DIP6D12ESD0402AZ5325-01FESD04026F1FUSE-0805FUSE-500MAFUSE-08056F2FUSE-0805FUSE-500MAFUSE-08056FB2FB0603100MHZ220OHMFB06036FB3FB0603100MHZ220OHMFB06036J1TF-CARD-PUSHTFWF1-EBF1-1X0XTF-CARD-PUSH6J2CON4-USB-AFCON4-USB-AFCON4-USB-AF6J3CON4-USB-AFCON4-USB-AFCON4-USB-AF6J65P-2_54CON-5P-2_54MM5P-2_546L1ACM2012-2PNCACM2012-2P6L2ACM2012-2PNCACM2012-2P6L3COMMON-COIL4PNC/EXD24CD900UCOMMON-COIL4P6SW1SW-TK-TS-03PVUPDATESW-TK-TS-03PV6U1SOT23-5SY6280AACSOT23-56U4SOP65P780X200-28NGL852G-HHGXXSOP65P780X200-28N6Y1Y-SMD4P322512MHZ_CL20PF_20PPMY-SMD4P32257J1J-MS-156ACA-5036-A3-CC-SJ-MS-1567J2J-MS-156ACA-5036-A3-CC-SJ-MS-1567J3J-MS-156ACA-5036-A3-CC-SJ-MS-1567L2L30304.7UH_1A_DCR80MOHML30307Q1SOT-23NC/WPM2015SOT-237Q2SOT-23NC/WPM2015SOT-237Q3SOT-23PMBT3904SOT-237Q4SOT-23PMBT3904SOT-237U1AP62X2_13X15AP6356SAP62X2_13X157U2WF-UM02BSNC/RTL8188-EUSWF-UM02BS7Y2Y-SMD4P322537.4MHZ_16PF_10PPMY-SMD4P32259D1DFN2510P10EAZ1345-04FDFN2510P10E9D2DFN2510P10EAZ1345-04FDFN2510P10E9D3ESD0402AZ5725-01FESD04029D4ESD0402AZ5725-01FESD04029D5ESD0402AZ5725-01FESD04029FB1FB0402100MHZ220OHMFB04029FB4FB0402100MHZ220OHMFB04029FB5FB0402NC/100MHZ220OHMFB04029J1HDMI_AHDMI-DIP-TYPE-A-19PHDMI_A9L1EMI-TF2010A4XNC/SDCMA21-4-900-M1TEMI-TF2010A4X9L2EMI-TF2010A4XNC/SDCMA21-4-900-M1TEMI-TF2010A4X9Q1SOT-23NC/WPM2015SOT-239Q2SOT-23WNM2020SOT-239Q6SOT-23NC/WNM2016SOT-23AFB1FB0402100MHZ220OHMFB0402AJ1AV-HJ-313EHJ-313EAV-HJ-313EAJ2JGQ-10GQ-10JGQ-10AJ3DIP-2X10P-2MMDIP2X10_2MMDIP-2X10P-2MMAR3R040222RR0402AT1TP30GPIODV_24TP30AT2TP30GPIODV_24TP30AU2TSSOP-14-PT065DIO2133CT14TSSOP-14-PT065U1BGA483_0P65GXM_S912BGA483_0P65VC1C0402100PFC0402VC2C040227PF_5%_NPOC0402VC3C0402100PFC0402VD1ESD0402AZ5725-01FESD0402VL1L06031.8UHL0603 PCB文件。没原理图。 回复可见下载
**** Hidden Message ***** 谢谢坛主分享 真是厉害了,啥时候才能达到这种水平 我的为什么就不能这么好看
