老吴 发表于 2018-6-12 17:35:12
再发一个英特尔嵌入式工控主板PCB文件
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEANT1RF-SMT-CONNrf-smt-connRF-SMT-CONNANT2RF-SMT-CONNrf-smt-connRF-SMT-CONNAUD1PJ-JA6341pj-ja6341PJ-JA6341BATT17PINBAT7pinbat7PINBATCAM_USB1FPC-5PIN-1_0MM-HOPELINKfpc-5pin-1_0mm-hopelinkFPC-5PIN-1_0MM-HOPELINKCAM_USB2FPC-5PIN-1_0MM-HOPELINKfpc-5pin-1_0mm-hopelinkFPC-5PIN-1_0MM-HOPELINKCOM1FPC-4PIN-1_25MMfpc-4pin-1_25mmFPC-4PIN-1_25MMCOM2FPC-4PIN-1_25MMfpc-4pin-1_25mmFPC-4PIN-1_25MMCPU_FAN1DIP_CNTR-FAN_1X3dip_cntr-fan_1x3DIP_CNTR-FAN_1X3CU1SSOP28-L SSOP28-LD1SOD123sod123SOD123D3SOD123sod123SOD123D7SOD123sod123SOD123D8SOD123sod123SOD123D11SOD123sod123SOD123D12SOD123sod123SOD123D13SOT23sot23SOT23D14SOT23sot23SOT23D15SOD323sod323SOD323DC_IN12DC-S028-C012dc-s028-c012DC-S028-C01EDP1IO-40P-1MMio-40p-1mmIO-40P-1MMF2FUSE1812fuse1812FUSE1812F3FUSE1812fuse1812FUSE1812FB2SMF0603smf0603SMF0603FB3SMF0603smf0603SMF0603H1MH250_1-C106D106Nmh250_1-c106d106nMH250_1-C106D106NH2MH250_1-C106D106Nmh250_1-c106d106nMH250_1-C106D106NH3MH250_1-C106D106Nmh250_1-c106d106nMH250_1-C106D106NH4MH250_1-C106D106Nmh250_1-c106d106nMH250_1-C106D106NH5MH250_1-C106D106Nmh250_1-c106d106nMH250_1-C106D106NHDMI1HDMI-H2-02A-A-A0hdmi-h2-02a-a-a0HDMI-H2-02A-A-A0ID_USB1FPC-4PIN-1_25MMfpc-4pin-1_25mmFPC-4PIN-1_25MMJ1CON_FLAT_SODIMM_DDR3_STDcon_flat_sodimm_ddr3_stdCON_FLAT_SODIMM_DDR3_STDL1L0603l0603L0603L2L0603l0603L0603L3L0603l0603L0603LAN1RJ45-HLJ-6041SL-88Arj45-hlj-6041sl-88aRJ45-HLJ-6041SL-88ALED2SMD_LED_0805smd_led_0805SMD_LED_0805LED3SMD_LED_0805smd_led_0805SMD_LED_0805LVDS1IO-40P-1MMio-40p-1mmIO-40P-1MMMPCIE1MINIPCIE_HALF_Lminipcie_half_lMINIPCIE_HALF_LMSATA1CON-PCIE-MINI-CARD-4MM-NUTcon-pcie-mini-card-4mm-nutCON-PCIE-MINI-CARD-4MM-NUTPCIE_H1HOLE180_120hole180_120HOLE180_120PCIE_H2HOLE180_120hole180_120HOLE180_120PD1SOD123sod123SOD123PD2SOD123sod123SOD123PD3SOD123sod123SOD123PD4SOD123sod123SOD123PD5SOD123sod123SOD123PD6SOD123sod123SOD123PL1STPI3015stpi3015STPI3015PL2SMPI_0603smpi_0603SMPI_0603PL3SMPI_0603smpi_0603SMPI_0603PL4SMPI_0603smpi_0603SMPI_0603PL5SMPI_0603smpi_0603SMPI_0603PL6SMPI_0603smpi_0603SMPI_0603PL7SMPI_0603smpi_0603SMPI_0603PL8SMPI_0603smpi_0603SMPI_0603PL12SMPI_0603smpi_0603SMPI_0603PQ1POWERPAK3D0X3D0-SO8powerpak3d0x3d0-so8POWERPAK3D0X3D0-SO8PQ6SO8_PWPso8_pwpSO8_PWPPQ7POWERPAK3D0X3D0-SO8powerpak3d0x3d0-so8POWERPAK3D0X3D0-SO8PQ25SO8_PWPso8_pwpSO8_PWPPQ34SOP8-1_27-5X6X1_75MMsop8-1_27-5x6x1_75mmSOP8-1_27-5X6X1_75MMPQ35SOP8-1_27-5X6X1_75MMsop8-1_27-5x6x1_75mmSOP8-1_27-5X6X1_75MMPQ37SOP8-1_27-5X6X1_75MMsop8-1_27-5x6x1_75mmSOP8-1_27-5X6X1_75MMPU1QFN24-TPS51125qfn24-tps51125QFN24-TPS51125PU2PQFP14-3_6X3_6MMpqfp14-3_6x3_6mmPQFP14-3_6X3_6MMPU6SOP8-1_27-DS9025sop8-1_27-ds9025SOP8-1_27-DS9025PU7PQFP14-3_6X3_6MMpqfp14-3_6x3_6mmPQFP14-3_6X3_6MMPU8SOP8-1_27-DS9025sop8-1_27-ds9025SOP8-1_27-DS9025PU9QFN40qfn40QFN40PU10SOP8-1_27-DS9025sop8-1_27-ds9025SOP8-1_27-DS9025PU11SOP8-1_27-DS9025sop8-1_27-ds9025SOP8-1_27-DS9025PU12SOP8-1_27-DS9025sop8-1_27-ds9025SOP8-1_27-DS9025RF_USB1FPC-4PIN-1_25MMfpc-4pin-1_25mmFPC-4PIN-1_25MMRT1SMR0402smr0402SMR0402RT2SMR0402smr0402SMR0402RTC1FPC2P-1_25MMfpc2p-1_25mmFPC2P-1_25MMSATA1SATA7-TFsata7-tfSATA7-TFSATA_H1HOLE180_120hole180_120HOLE180_120SATA_PWR1A2001WV-2Pa2001wv-2pA2001WV-2PSIM1SIM-SPPN08-X0-1X80_UPDATEsim-sppn08-x0-1x80_updateSIM-SPPN08-X0-1X80_UPDATESPK1FPC-4PIN-1_25MMfpc-4pin-1_25mmFPC-4PIN-1_25MMSUSCLK1TEST20test20TEST20SW1FPC-12PIN-1_0MM-HOPELINKfpc-12pin-1_0mm-hopelinkFPC-12PIN-1_0MM-HOPELINKTF1T_FLASH_CARD_01t_flash_card_01T_FLASH_CARD_01TP_USB1FPC-6PIN-0_5MMfpc-6pin-0_5mmFPC-6PIN-0_5MMTVS3LCC10_SLP10lcc10_slp10LCC10_SLP10TVS4LCC10_SLP10lcc10_slp10LCC10_SLP10TVS5LCC10_SLP10lcc10_slp10LCC10_SLP10TVS6LCC10_SLP10lcc10_slp10LCC10_SLP10TVS7LCC10_SLP10lcc10_slp10LCC10_SLP10U1BVY_27X25_1170P_01-04bvy_27x25_1170p_01-04BVY_27X25_1170P_01-04U2SOCKET8-FLASHsocket8-flashSOCKET8-FLASHU3LQFP48 LQFP48U4SOT363sot363SOT363U7QFN48_0R4_6X6_EPqfn48_0r4_6x6_epQFN48_0R4_6X6_EPU8TRAN_24PIN_1MMtran_24pin_1mmTRAN_24PIN_1MMU9SOT23_5sot23_5SOT23_5U11SOT23_5sot23_5SOT23_5U13SSOP28-25P6X278ssop28-25p6x278SSOP28-25P6X278U15SOP8-1_27-5X6X1_75MMsop8-1_27-5x6x1_75mmSOP8-1_27-5X6X1_75MMU16SSOP28-25P6X278ssop28-25p6x278SSOP28-25P6X278U19SOT363sot363SOT363U21LQFP128-0_4-16X16X1_6MMlqfp128-0_4-16x16x1_6mmLQFP128-0_4-16X16X1_6MMU22QFN50P500X500X100-29Nqfn50p500x500x100-29nQFN50P500X500X100-29NU26QFN68_8X8P04qfn68_8x8p04QFN68_8X8P04U28SOCKET8-FLASHsocket8-flashSOCKET8-FLASHU31SOP8-1_27-5X6X1_75MMsop8-1_27-5x6x1_75mmSOP8-1_27-5X6X1_75MMU48SOP8-1_27-DS9025sop8-1_27-ds9025SOP8-1_27-DS9025U51SSOP28-26-209ssop28-26-209SSOP28-26-209USB1USB3_FOXCONN_CHENBANusb3_foxconn_chenbanUSB3_FOXCONN_CHENBANUSB3USB2_FOXCONN_CHENBANusb2_foxconn_chenbanUSB2_FOXCONN_CHENBANWIFI_BT1WIFI-BT-BL-8723RB1wifi-bt-bl-8723rb1WIFI-BT-BL-8723RB1Y1XTAL3225-4xtal3225-4XTAL3225-4Y2CRYSMD6D9X1D4_4Pcrysmd6d9x1d4_4pCRYSMD6D9X1D4_4PY3XTAL3225-4xtal3225-4XTAL3225-4Y4XTAL3225-4xtal3225-4XTAL3225-4Y5XTAL3225-4xtal3225-4XTAL3225-4Y6XTAL3225-4xtal3225-4XTAL3225-4Y7XTAL3225-4xtal3225-4XTAL3225-4
老吴 发表于 2018-6-12 17:37:21
PCB文件。回复可见。
**** Hidden Message *****
tangwb123 发表于 2018-6-12 18:12:45
单枪舞九州 发表于 2018-6-12 18:48:54
支持
18565773206 发表于 2018-6-12 20:06:25
ntpcbyanli4111 发表于 2018-6-12 20:27:34
kenxjy 发表于 2018-6-12 20:41:37
cdl511 发表于 2018-6-12 20:49:06
谢谢分享,学习下.
带刀的老鼠 发表于 2018-6-12 20:49:11
bidezhi7777 发表于 2018-6-12 20:50:31
页: [1] 2 3 4 5 6 7 8 9 10
查看完整版本: 再发一个英特尔嵌入式工控主板PCB文件
