老吴 发表于 2018-6-14 00:38:22
MT7620AE+MT7662+SKY85601 方案路由器PCB 原理图BOM共享
NamePCB DecalPart TypeC1C680UF6.3V/D8H11C680UF6.3V/D8H11C2C0402C0402C7C100UF25V/D6.3H11.5C100UF25V/D6.3H11.5CON1COAXIAL/SMD/CON/V/I-PEXCOAXIAL/SMD/CON/V/I-PEXCON2COAXIAL/SMD/CON/V/I-PEXCOAXIAL/SMD/CON/V/I-PEXCON3COAXIAL/SMD/CON/V/I-PEX/W08-5801COAXIAL/SMD/CON/V/I-PEX/W08-5801CON4COAXIAL/SMD/CON/V/I-PEX/W08-5801COAXIAL/SMD/CON/V/I-PEX/W08-5801D1VARISTOR/SMD/TVM5B150L103RYVARISTOR/SMD/TVM5B150L103RYH1DR52DR52H2DR52DR52H3DR52X62DR52X62H4DR52X62DR52X62J1DC-JACK/3P/DIP/R/JD003-PFDC-JACK/3P/DIP/R/JD003-PFJ2DIP4/P2.54DIP4/P2.54J13DIP7X2/P2.54DIP7X2/P2.54J44CON10P/SMD/R/F/7SDCN-B0-1X14CON10P/SMD/R/F/7SDCN-B0-1X14JP1DIP5X2/P2.54DIP5X2/P2.54JP2DIP5X2/P2.54DIP5X2/P2.54L4L/IND/SMD/LVS5045L/IND/SMD/LVS5045L35L/IND/DIP/D6H14L/IND/DIP/D6H14L36L/IND/DIP/D6H14L/IND/DIP/D6H14L642L/IND/SMD/LVS5045L/IND/SMD/LVS5045L643L/IND/SMD/LVS5045L/IND/SMD/LVS5045L644L0603L0603L645L0603L0603L646L/IND/SMD/LVS5045L/IND/SMD/LVS5045LA16L/IND/SMD/VLS252012EL/IND/SMD/VLS252012EQ1LNA/SOT-343/SMD/BF776LNA/SOT-343/SMD/BF776Q2LNA/SOT-343/SMD/BF776LNA/SOT-343/SMD/BF776S2SW/4P/DIP/TS02-CN-PFSW/4P/DIP/TS02-CN-PFS3SW/4P/DIP/TS02-CN-PFSW/4P/DIP/TS02-CN-PFSHA1SHIELDING/MPCIE/2H/T2SHIELDING/MPCIE/2H/T2U1MT7620AE2/TFBGA265/P0.65/B0.3/11X11MT7620AE2/TFBGA265/P0.65/B0.3/11X11U6SOT-23-6/SMD/P0.95/APM2701ACSOT-23-6/SMD/P0.95/APM2701ACU8SOT89/SMDSOT89/SMDU9SOIC8/SMD/P1.27/AT24C04B-08BSOIC8/SMD/P1.27/AT24C04B-08BU11CRYS/SMD/D3.2X2.5/E3SB40/HOSONICCRYS/SMD/D3.2X2.5/E3SB40/HOSONICU12TRANSFORMER/20P/DIP/HN2066CGTRANSFORMER/20P/DIP/HN2066CGU13RJ45/32P/DIP/R/N3642-001RJ45/32P/DIP/R/N3642-001U14TRANSFORMER/20P/DIP/HN2066CGTRANSFORMER/20P/DIP/HN2066CGU15RJ45/8P/DIP/R/N3612-002RJ45/8P/DIP/R/N3612-002U16TRANSFORMER/16P/DIP/HN1674CGTRANSFORMER/16P/DIP/HN1674CGU18SOIC8/SMD/P1.27/AT26DF321SOIC8/SMD/P1.27/AT26DF321U21SKY85601SKY85601U22WBGA84/SMD/P0.8/W9751G6IBWBGA84/SMD/P0.8/W9751G6IBU33CRYS/DIP/D5X10.6/GB2000025/ECERACRYS/DIP/D5X10.6/GB2000025/ECERAU626SOT223-3/SMD/P2.3/AX1007SOT223-3/SMD/P2.3/AX1007U627SOT-143/SMD/G693SOT-143/SMD/G693U630TSON6/SMD/P0.65/UPG2179TBTSON6/SMD/P0.65/UPG2179TBU631TSON6/SMD/P0.65/UPG2179TBTSON6/SMD/P0.65/UPG2179TBU632SOT-353SOT-353U634SOP8/SMD/P1.27/IT7653SOP8/SMD/P1.27/IT7653U635SOP8/SMD/P1.27/IT7653SOP8/SMD/P1.27/IT7653U636SOP8/SMD/P1.27/IT7653SOP8/SMD/P1.27/IT7653U637BPF20125/MURATA-KIMBPF20125/MURATA-KIMU638BPF20125/MURATA-KIMBPF20125/MURATA-KIMU639SKY85601SKY85601UA4MT7662/WSQFN76/SMD/P0.4/9X9/SMT7662/WSQFN76/SMD/P0.4/9X9/SUA5CRYS/SMD/D3.2X2.5/E3SB40/HOSONICCRYS/SMD/D3.2X2.5/E3SB40/HOSONICUC1C0402C0402UC2C0402C0402USB1USB/4P/DIP/ATOM/AUSB/4P/DIP/ATOM/A
老吴 发表于 2018-6-14 00:39:27
PCB原理图BOM。回复可见。
**** Hidden Message *****
bidezhi7777 发表于 2018-6-14 02:37:28
marktsui 发表于 2018-6-14 07:11:38
summer稳 发表于 2018-6-14 07:58:32
似水流年 发表于 2018-6-14 08:03:07
似水流年 发表于 2018-6-14 08:05:37
yfhaotian168 发表于 2018-6-14 08:13:36
hk386 发表于 2018-6-14 08:19:01
aj8889 发表于 2018-6-14 08:27:33
页: [1] 2 3 4 5 6 7 8 9 10
查看完整版本: MT7620AE+MT7662+SKY85601 方案路由器PCB 原理图BOM共享
