全网首发-瑞星微PX30 参考板 PCB文件共享(AP6212+RTL8201F+CY7C68
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEANT6000ANT_1P1G_ANTPCB_44R00X11R00_DSRANT4411DRANTPCB_44R00X11R00_DSRANT6001ANT_1P2G_ANT_JACK_ANT_JACKANT_JACKANT_JACKBT2001BATT3_BAT3_2R54_BAT3_2R54BAT3_2R54BAT3_2R54D2000DIODE_DO_214AC_SS32SS32DO_214ACD2001DIODEDOUBLE_SOT_23_BAT54CBAT54CSOT_23D8100DIODE BI_DIRTRIG_ESD0402_ESD54ESD5451NESD0402D9700DIODE_SOD_323_B5819WSB5819WSSOD_323D9701DIODE_SOD_323_B5819WSB5819WSSOD_323ED2100DIODE BI_DIRTRIG_ESD0402_ESD54ESD5451NESD0402H9904HOLE_HOLE_C3R20_C6R00_HOLE_3R20HOLE_3R20HOLE_C3R20_C6R00J2000DCJACK_3P_DC3_DC_0007_5P_DC-000DC-0007-5PDC3_DC_0007_5PJ2100CON6_1X6_CON6M_1X6_2R54_V_DIP_CCON6M_1X6_2R54_VCON6M_1X6_2R54_V_DIPJ2500USB20_MINI_USB20MIN5_USB_M5_03_USB20_miniUSB20MIN5_USB_M5_03_002J4600CMK-CB0077-FV1_2_CON30M_2X15_0RAXT530124CON30M_2X15_0R40_V_SMTJ6000CON40_2X20_CON40M_2X20_1R27_V_PB127S2GL240DTCON40M_2X20_1R27_V_PJ7000PHONEJACK_7P_PJ7_D3R50_PJ3536_PPJ-3536PJ7_D3R50_PJ3536J7001CON2_1X2_CON2M_1X2_2R00_V_P_DIPCON2M_1X2_2R00_V_P_DIPCON2M_1X2_2R00_V_P_DIPJ7600LCD_HITACHI_TX05D99VM1AAA_0_CNN30PIN FPC CONCNN30_1R00_FP05SL_VJ8100TFCARD_SOCKET_TF9_CKT01_009D_TFTF-CKT01-009DTF9_CKT01_009DJ9300CON40_2X20_CON40M_2X20_2R54_V_DP101-2x20SGF01CON40M_2X20_2R54_V_DIPJ9301CON30_2X15_CON30M_2X15_2R54_V_DP101-2x15SGF01CON30M_2X15_2R54_V_DIPJ9600USB20_MICRO_USB20MICRO5_MU05_10USB20_microUSB20MICRO5_MU05_10MGF_TJ9601JTAG_ARM_0_JTAG_ARM_JTAG_ARMJTAG_ARMJTAG_ARMJ9700USB20_MINI_USB20MIN5_USB_M5_03_USB20_miniUSB20MIN5_USB_M5_03_002J9900CON2_2_RADIATOR_38R00X38R00X10RRadiatorRADIATOR_38R00X38R00X10R00J9901GND_GATE_CON2_1X2_5R08_DIP_GND_GND_GATECON2_1X2_5R08_DIPJ9902GND_GATE_CON2_1X2_5R08_DIP_GND_GND_GATECON2_1X2_5R08_DIPJ9903GND_GATE_CON2_1X2_5R08_DIP_GND_GND_GATECON2_1X2_5R08_DIPJ9904GND_GATE_CON2_1X2_5R08_DIP_GND_GND_GATECON2_1X2_5R08_DIPJP8500RJ45_CON8_RJ45_PCB_937_LED_PCB_PCB_937_LEDRJ45_PCB_937_LEDL2000INDUCTORS OFFERRITE_IND_4040303.3uHIND_404030L2002INDUCTORS OFFERRITE_IND_4040203.3uHIND_404020L2100INDUCTORS OFFERRITE_IND_252010470nHIND_252010L2101INDUCTORS OFFERRITE_IND_252010470nHIND_252010L2102INDUCTORS OFFERRITE_IND_252010470nHIND_252010L2103INDUCTORS OFFERRITE_IND_252010470nHIND_252010L2104INDUCTORS OFFERRITE_IND_252010470nHIND_252010L6000INDUCTOR_L0402_DNPDNPL0402L6001INDUCTOR_L0402_DNPDNPL0402L6002INDUCTORS OFFERRITE_IND_3230153.3uHIND_323015LCD9701OLED096_SSD1306_1_LCD30_UG-2864OLED096_SSD1306LCD30_UG-2864HSWEG01LED2003LED_LED0603_LED_REDLED_REDLED0603LED9600LED_LED0603_LED_REDLED_REDLED0603MARK9901MARK_MARK_MARKMARKMARKMARK9902MARK_MARK_MARKMARKMARKMARK9903MARK_MARK_MARKMARKMARKMARK9904MARK_MARK_MARKMARKMARKMARK9905MARK_MARK_MARKMARKMARKMARK9906MARK_MARK_MARKMARKMARKMIC7000MIC_MIC2_4020_MIC-4020MIC-4020MIC2_4020Q2003MOSFETN_SOT_23_WNM3003-3/TRWNM3003-3/TRSOT_23Q2004MOSFETN_SOT_23_WNM2024-3/TRWNM2024-3/TRSOT_23Q2005MOSFETN_SOT_23_WNM2024-3/TRWNM2024-3/TRSOT_23Q2006MOSFETP_SOT_23_WPM3407-3/TRWPM3407-3/TRSOT_23Q2500MOSFETN_SOT_23_WNM2016-3/TRWNM2016-3/TRSOT_23Q4601MOSFETN_SOT_323_2SK30182SK3018SOT_323Q4602MOSFETN_SOT_323_2SK30182SK3018SOT_323Q6000MOSFETN_SOT_323_2SK30182SK3018SOT_323Q6001MOSFETN_SOT_323_2SK30182SK3018SOT_323S2001BR-11C-11P6KCD1-11-3P-WSW3_KCD1-11-3P-WSMTSO9901SMTSO_SMTSO_M3_C4R1_C6R0_L10R0_SMTSO30100CTJSMTSO_M3_C4R1_C6R0_L10R0SMTSO9902SMTSO_SMTSO_M3_C4R1_C6R0_L10R0_SMTSO30100CTJSMTSO_M3_C4R1_C6R0_L10R0SMTSO9903SMTSO_SMTSO_M3_C4R1_C6R0_L10R0_SMTSO30100CTJSMTSO_M3_C4R1_C6R0_L10R0SMTSO9904SMTSO_SMTSO_M3_C4R1_C6R0_L10R0_SMTSO30100CTJSMTSO_M3_C4R1_C6R0_L10R0SMTSO9905SMTSO_SMTSO_M3_C4R1_C6R0_L10R0_SMTSO30100CTJSMTSO_M3_C4R1_C6R0_L10R0SMTSO9906SMTSO_SMTSO_M3_C4R1_C6R0_L10R0_SMTSO30100CTJSMTSO_M3_C4R1_C6R0_L10R0SMTSO9907SMTSO_SMTSO_M3_C4R1_C6R0_L10R0_SMTSO30100CTJSMTSO_M3_C4R1_C6R0_L10R0SMTSO9908SMTSO_SMTSO_M2_C3R6_C6R0_L5R0_SSMTSO2050CTJSMTSO_M2_C3R6_C6R0_L5R0SMTSO9909SMTSO_SMTSO_M2_C3R6_C6R0_L5R0_SSMTSO2050CTJSMTSO_M2_C3R6_C6R0_L5R0SW2000KEY_5PIN_SW5_6R20X6R20X2R50_PWRPWRONSW5_6R20X6R20X2R50SW2100KEY_5PIN_SW5_6R20X6R20X2R50_RESRESETSW5_6R20X6R20X2R50SW4100KEY_5PIN_SW5_6R20X6R20X2R50_MASMaskromSW5_6R20X6R20X2R50SW9201KEY_5PIN_SW5_6R20X6R20X2R50_VOLVOL+/RECOVERYSW5_6R20X6R20X2R50SW9202KEY_5PIN_SW5_6R20X6R20X2R50_V_1VOL-SW5_6R20X6R20X2R50SW9203KEY_5PIN_SW5_6R20X6R20X2R50_HOMHOMESW5_6R20X6R20X2R50SW9204KEY_5PIN_SW5_6R20X6R20X2R50_ESCESCSW5_6R20X6R20X2R50SW9205KEY_5PIN_SW5_6R20X6R20X2R50_MENMENUSW5_6R20X6R20X2R50U1000PK30_0108_BGA418_52R00X52R00X43PX30BGA418_52R00X52R00X43R68_SU2000DCDC_SY8113_SOT_23_6_SY8113BSY8113BSOT_23_6U2002LDO_PT5108_1_SOT_89_3_SGM2203-5SGM2203-5.0SOT_89_3U2003CHARGER_BQ24133_QFN24_5R65X3R65BQ24133QFN24_5R65X3R65X1R00_TU2100RK809_QFN68_7R00X7R00X0R80_T_RKRK809-1QFN68_7R00X7R00X0R80_TU2500SWITCH_SY6280_SOT_23_5_SY6280AASY6280AACSOT_23_5U2501ESD_ESDA6V8UL_SOT_23_ESD5302FESD5302FSOT_23U2502ESD_ESDA6V8UL_SOT_23_ESD5302FESD5302FSOT_23U3400DDR3_16BIT_FBGA96_14R00X11R00X1256x16bitFBGA96_14R00X11R00X1R20U3401DDR3_16BIT_FBGA96_14R00X11R00X1256x16bitFBGA96_14R00X11R00X1R20U3402DDR3_16BIT_FBGA96_14R00X11R00X1256x16bitFBGA96_14R00X11R00X1R20U3403DDR3_16BIT_FBGA96_14R00X11R00X1256x16bitFBGA96_14R00X11R00X1R20U4000NANDFLASH_TSOP48_TSOP48_18R40X1H27UBG8T2DTR-BCTSOP48_18R40X12R10X1R20U4100INAND_EMMC_169_2L_BGA169_18R00XKLMAG2GEAC-B031BGA169_18R00X14R00X1R20_2LU4200SPI_FLASH_16PIN_SOIC16_10R6X10RN25Q256A13ESF40GSOIC16_10R6X10R3X2R5U6000MODULE_AP6XXX_MD44_AP6XXX_AP621AP6212MD44_AP6XXXU8000SENSOR_MMA7660FC_DFN10_3R00X3R0MMA7660FCTDFN10_3R00X3R00X0R90U8001SENSOR_AK8963C_BGA14_1R59X1R59XAK8963CBGA14_1R59X1R59X0R57U8500ETHERNET_10M100M_SOIC16_12R70X9HR601680SOIC16_12R70X9R40X6R22U8501RTL8201F_0_QFN32_5R00X5R00X1R00RTL8201FQFN32_5R00X5R00X1R00_TU9600INTERFACE_FT232RL_SSOP28_10R20XFT232RLSSOP28_10R20X5R30X2R00U9601ESD_ESDA6V8UL_SOT_23_ESD5302FESD5302FSOT_23U9602SWITCH_FSUSB30MUX_MSOP10_3R00X3FSUSB30MUXMSOP10_3R00X3R00X1R10U9603SWITCH_FSUSB30MUX_MSOP10_3R00X3FSUSB30MUXMSOP10_3R00X3R00X1R10U9700EEPROM_AT24C16_SOP8_6R20X5R00X1AT24C64N-10SCSOP8_6R20X5R00X1R75U9701CY7C68013A_0_QFN56_8R00X8R00X1RCY7C68013AQFN56_8R00X8R00X1R00U9704LDO_PT5108_SOT_23_5_PT5108E23E-PT5108E23E-33SOT_23_5U9800IN219_1_MSOP10_3R00X3R00X1R10_IINA226AIDGSTMSOP10_3R00X3R00X1R10U9801IN219_1_MSOP10_3R00X3R00X1R10_IINA226AIDGSTMSOP10_3R00X3R00X1R10U9802IN219_1_MSOP10_3R00X3R00X1R10_IINA226AIDGSTMSOP10_3R00X3R00X1R10U9803IN219_1_MSOP10_3R00X3R00X1R10_IINA226AIDGSTMSOP10_3R00X3R00X1R10U9804IN219_1_MSOP10_3R00X3R00X1R10_IINA226AIDGSTMSOP10_3R00X3R00X1R10U9805IN219_1_MSOP10_3R00X3R00X1R10_IINA226AIDGSTMSOP10_3R00X3R00X1R10U9806IN219_1_MSOP10_3R00X3R00X1R10_IINA226AIDGSTMSOP10_3R00X3R00X1R10U9807IN219_1_MSOP10_3R00X3R00X1R10_IINA226AIDGSTMSOP10_3R00X3R00X1R10U9808IN219_1_MSOP10_3R00X3R00X1R10_IINA226AIDGSTMSOP10_3R00X3R00X1R10U9809IN219_1_MSOP10_3R00X3R00X1R10_IINA226AIDGSTMSOP10_3R00X3R00X1R10U9810IN219_1_MSOP10_3R00X3R00X1R10_IINA226AIDGSTMSOP10_3R00X3R00X1R10U9811IN219_1_MSOP10_3R00X3R00X1R10_IINA226AIDGSTMSOP10_3R00X3R00X1R10U9812IN219_1_MSOP10_3R00X3R00X1R10_IINA226AIDGSTMSOP10_3R00X3R00X1R10U9813IN219_1_MSOP10_3R00X3R00X1R10_IINA226AIDGSTMSOP10_3R00X3R00X1R10U9815IN219_1_MSOP10_3R00X3R00X1R10_IINA226AIDGSTMSOP10_3R00X3R00X1R10U9820LDO_PT5108_SOT_23_5_PT5108E23E-PT5108E23E-33SOT_23_5USB2500USB20_TYPE_A_USB20A4_USB_AF_01_USB-HUB_PORTBAUSB20A4_USB_AF_01_001Y1100CRYSTAL_4P_CRY4_3R20X2R50X0R80_24MHzCRY4_3R20X2R50X0R80Y2100CRYSTAL_2P_1G_CRY2_6R90X1R40X1R32.768KHzCRY2_6R90X1R40X1R30Y6000CRYSTAL_4P_CRY4_3R20X2R50X0R8_126MHzCRY4_3R20X2R50X0R80Y8500CRYSTAL_4P_CRY4_3R20X2R50X0R8_225MHzCRY4_3R20X2R50X0R80Y9700CRYSTAL_4P_CRY4_3R20X2R50X0R80_24MHzCRY4_3R20X2R50X0R80
CPU• 四核Cortex-A35GPU• Mali-G31GPU,支持OpenGL ES3.2, Vulkan 1.0, OpenCL 2.0• 内嵌高性能2D 加速硬件多媒体• 多格式1080P 60fps视频解码 (H.265,H.264,VC-1, MPEG-1/2/4, VP8)• 1080P 视频编码,支持H.264,VP8显示• 支持RGB/LVDS/MIPI-DSI,分辨率最高1920x1080• 支持双屏异显内存• 32bits DDR4-1600/DDR3-1600/DDR3L-1600/LPDDR3-1600/LPDDR2-1066• 支持MLC NAND, eMMC 4.51,Serial Nor FLASH接口• 支持MIPI CSI及DVP Sensor接口,内置8M ISP• 支持1x8ch I2S/TDM,1x8ch PDM,2x2ch I2S/PCM• 支持100M RMII• 支持SDIO3.0,USB2.0 HOST&OTG,4路I2C,6路UART,2路SPI,8路PWM
这个板子 PCB 拿到好几个月了。一直没敢放出来。。 瑞芯微网站上都还没挂出PX30 这个CPU 型号。所以我一直没放出来。今天看到瑞芯微挂上去了。
PADS 和ALLEGRO 两个版本的参考文件。都是6层设计,没找到原理图。 新资料1个RMB
非常感谢楼主大神的分享 牛了
