三、新唐N32905U1DN开发教程:使用寄存器配置IO口
新唐单片机学习交流群:57955260,欢迎加入学习交流由于官方提供的IO口配置函数效率低,且配置比较繁琐,下面使用寄存器配置的方式来控制IO口,实现实验一的点亮LED。通过查阅N329_Design_Guide_A0.pdf第627页可以发现,IO口相关寄存器的基址为0xB8001000,由此我们定义一个宏 #define GP_BA 0xB8001000
https://img-blog.csdn.net/20180717120229618?watermark/2/text/aHR0cHM6Ly9ibG9nLmNzZG4ubmV0L2h6cWhtbHo=/font/5a6L5L2T/fontsize/400/fill/I0JBQkFCMA==/dissolve/70
根据上图寄存器的偏移量,我们对寄存器的地址进行宏定义,为了方便对IO口进行初始化,定义一个结构体,同时也要把相关变量类型重新定义一下,符合我们的使用习惯,我创建的是n3290x.h,内容如下所示:
#ifndef __N3290X_H
#define __N3290X_H
#include "stdint.h"
#ifdef __cplusplus
extern "C" {
#endif
#ifdef __cplusplus
#define __I volatile
#else
#define __I volatile const
#endif
#define __O volatile
#define __IO volatile
typedef int32_ts32;
typedef int16_t s16;
typedef int8_ts8;
typedef const int32_t sc32;/*!< Read Only */
typedef const int16_t sc16;/*!< Read Only */
typedef const int8_t sc8; /*!< Read Only */
typedef __IO int32_tvs32;
typedef __IO int16_tvs16;
typedef __IO int8_t vs8;
typedef __I int32_t vsc32;/*!< Read Only */
typedef __I int16_t vsc16;/*!< Read Only */
typedef __I int8_t vsc8; /*!< Read Only */
typedef uint32_tu32;
typedef uint16_t u16;
typedef uint8_tu8;
typedef const uint32_t uc32;/*!< Read Only */
typedef const uint16_t uc16;/*!< Read Only */
typedef const uint8_t uc8; /*!< Read Only */
typedef __IO uint32_tvu32;
typedef __IO uint16_t vu16;
typedef __IO uint8_tvu8;
typedef __I uint32_t vuc32;/*!< Read Only */
typedef __I uint16_t vuc16;/*!< Read Only */
typedef __I uint8_t vuc8; /*!< Read Only */
#define GPIOA_BASE (GP_BA + 0x00)
#define GPIOB_BASE (GPIOA_BASE+ 0x10)
#define GPIOC_BASE (GPIOB_BASE+ 0x10)
#define GPIOD_BASE (GPIOC_BASE+ 0x10)
#define GPIOE_BASE (GPIOD_BASE+ 0x10)
typedef struct
__IO uint32_t OMD;
__IO uint32_t PUEN;
__IO uint32_t DOUT;
__I uint32_t PIN;
}GPIO_TypeDef;
#define GPIOA ((GPIO_TypeDef*)(GPIOA_BASE))
#define GPIOB ((GPIO_TypeDef*)(GPIOB_BASE))
#define GPIOC ((GPIO_TypeDef*)(GPIOC_BASE))
#define GPIOD ((GPIO_TypeDef*)(GPIOD_BASE))
#define GPIOE ((GPIO_TypeDef*)(GPIOE_BASE))
#endif
GPIOx_ODM是一个32bit寄存器,控制IO口为输入或输出,每一bit控制一个IO口。当某一位为1时,配置对应的IO口为输出;当为0时,配置对应的IO口为输入。
如GPIOA->ODM = 0x00000001表示将PA0设为输出,PA的其它口均设为输入。
GPIOx_DOUT控制IO的输出为高电平或低电平,当某位为1时,表示对应的IO口输出高电平,反之输出低电平,前提是该IO口配置为输出模式。
下面贴出main.c的代码
#include "wblib.h"
#include "n3290x.h"
int main(void)
sysSetSystemClock(eSYS_UPLL, //E_SYS_SRC_CLK eSrcClk,
192000, //UINT32 u32PllKHz,
192000, //UINT32 u32SysKHz,
192000, //UINT32 u32CpuKHz,
96000, //UINT32 u32HclkKHz,
48000); //UINT32 u32ApbKHz
//PB3~PB6设为输出
GPIOB->OMD |= 0x0F<<3;
//PB3~PB6输出高电平
GPIOB->DOUT |= 0x0F<<3;
//PB3~PB6输出低电平
GPIOB->DOUT &= ~(0x0F<<3);
while(1)
}通过仿真可以看到执行GPIOB->DOUT |= 0x0F<<3;后,灯就灭了,如此,用寄存器控制LED的实验完成。
这几个都是我个人在CSDN上发布的原创文章,转到逆天论坛供大家学习 Thank you for your sharing 新唐的用的人多吗 学习了
