SC7731C+SR3533G+SC2663H+SR2319A 6层1介盲孔埋孔只能手机PCB和原理
NamePart TypePCB DecalValueANT0401NC-PAD-RFANT-2X3NC-PAD-RFANT-2X3ANT0402NC-PAD-RFANT-2X3NC-PAD-RFANT-2X3ANT0403NC-PAD-RFANT-2X3NC-PAD-RFANT-2X3ANT7201NC-PAD-RFANT-2X3NC-PAD-RFANT-2X3ANT7202NC-PAD-RFANT-2X3NC-PAD-RFANT-2X3ANT7203ALP-3041511P17-RN01ALP-3041511P17-RN01CON301BATYC-3504S1-TPXXBATYC-3504S1-TPXXBAT004-D390YCON302HEADER_4_1ALP-BAT030-15ACON5100CAM_FPC_23PCAM_FPC_23PD4100DIODE-SCHOTTKY-WSB5503W-2/TRSOD-323D6100DIODE-ZENER-PZ3D5V1HSOD_2513_H110FB3100BEAD-600-OHM-100MHZ-0402SL0402-S600ohm@100MHz 500mAFB3101BEAD-600-OHM-100MHZ-0402SL0402-S600ohm@100MHz 500mAFB3102BEAD-600-OHM-100MHZ-0402SL0402-S600ohm@100MHz 500mAFB3105BEAD-600-OHM-100MHZ-0402SL0402-S600ohm@100MHz 500mAFB3112BEAD-1K-OHM-100MHZ-250MA-0402SL04021000ohm@100MHzFB4100BEAD-470-OHM-100MHZ-0.5A-0603SL0603-S470ohm@100MHz 500mAFD6201NC-FIDUCIALMARKPAD-FID(NF)FD6202NC-FIDUCIALMARKPAD-FID(NF)FD6203NC-FIDUCIALMARKPAD-FID(NF)FD6204NC-FIDUCIALMARKPAD-FID(NF)J0402CON-RF-SWITCH-MM8430-2610RA1CON-RF-SWITCH-MM8430-2610RA1J3100PJ23-05AB03-01PJ23-05AB03-01PJ23-05AB03-01J4101LCM-FPC-20PLCM-FPC-20PJ4102FP243AH-0XXG1XMCON-FPC-BL115E-06RL-TANDJ5100CAM_FPC_26PCAM_FPC_26POK-14F-24PIN-04J5201FPC-0.8MM-6PINFPC-0.8MM-6PINJ6200U06-6B05F25C-AU06-6B05F25CU06-6B05F25CJ6300FPC-1.0MM-5PINFPC-1.0MM-5PINJ6301FPC-1.0MM-5PINFPC-1.0MM-5PINJ6401S77-0B20F31AS77-0B20F31AS77-0B20F31AJ6600SUB_15PINSUB_15PINL0300IND-POWER-2.2UH-SPH252012H2R2MTIND-POWER-SPH25202.2uHL0301IND-POWER-1.0UH-MLP2520W1R0MIND_POW_MLP2520_H1001.0uHL0302IND-POWER-2.2UH-SPH252012H2R2MTIND-POWER-SPH25202.2uHL0303IND-POWER-1.0UH-MLP2520W1R0MIND_POW_MLP2520_H1001.0uHL0305IND-POWER-2.2UH-SPH252012H2R2MTIND-POWER-SPH25202.2uH(NF)L0400IND-NF-0402IND-NF-0402NFL0401IND-CER-10NH-0.3-0201-SDCL0603Q-02SL020110nHL0402IND-CER-5.6NH-3%-0201-LQP03TN-00SL02015.6nHL0403IND-CER-2.4NH-0.3-0201-SDCL0603Q-02B01SL02012.4nH(NF)L0404IND-CER-2.2NH-0.3-0201-SDCL0603Q-02B01SL02012.2nHL0405IND-CER-5.1NH-0.3-0201-SDCL0603Q-02SL02015.1nHL0406IND-CER-4.7NH-3%-0201-LQP03TN-00SL02014.7nHL0407IND-CER-3.3NH-0.1-0201-LQP03TN-00SL02013.3nHL0408IND-CER-6.8NH-3%-0201-LQP03TN-00SL02016.8nHL0409IND-CER-18NH-3%-0201-LQP03TN-00SL020118nHL0410IND-NF-0201IND-NF-0201NFL0411IND-CER-5.1NH-0.3-0201-SDCL0603Q-02B01SL02015.1nHL0412CAP-1PF-0201SC02011.0pFL0417IND-CER-5.6NH-3%-0201-LQP03TN-00SL02015.6nH(NF)L0419IND-NF-0201IND-NF-0201NFL0420IND-NF-0201IND-NF-0201NFL0421IND-CER-10NH-0.3-0201-SDCL0603Q-02SL020110nHL0422CAP-56PF-0201SC020156pFL0423IND-NF-0201IND-NF-0201NFL0424IND-NF-0201IND-NF-0201NFL0425IND-CER-5.1NH-0.3-0201-SDCL0603Q-02SL02015.1nH(NF)L0468IND-CER-3.3NH-0.1-0201-LQP03TN-00SL02013.3nHL4100IND-POWER-10UH-SWPA3012S100MTIND-POWER-SWPA3010uHL7201IND-CER-2.4NH-0.3-0201-SDCL0603Q-02B01SL02012.4nH(NF)L7208IND-CER-120NH-0402SL0402120nHL7216CAP-3.3PF-0201SC02013.3pFL7225IND-NF-0201IND-NF-0201NFL7226IND-NF-0201IND-NF-0201NFL7228IND-CER-8.2NH-3%-0201-LQP03TN-00SL02018.2nHL7239IND-CER-1.5NH-0.3-0201-SDCL0603Q-02SL02011.5nHMIC3100MIC-1.0-2MIC-1.0-2MLV3100MLV-AVLC5S02050SMLV0402(NF)MLV3101MLV-AVLC5S02050SMLV0402(NF)MLV3116MLV-AVLC5S02050SMLV0402(NF)MLV3117MLV-AVLC5S02050SMLV0402(NF)MLV3118MLV-AVLC5S02050SMLV0402(NF)MLV4100MLV-AVLC5S02050SMLV0402(NF)MLV4101MLV-AVLC5S02050SMLV0402(NF)MLV4102MLV-AVLC5S02050SMLV0402(NF)MLV4103MLV-AVLC5S02050SMLV0402(NF)MLV4104MLV-AVLC5S02050SMLV0402(NF)MLV4105MLV-AVLC5S02050SMLV0402(NF)MLV6300MLV-AVLC5S02050SMLV0402(NF)MLV6301MLV-AVLC5S02050SMLV0402(NF)MLV6302MLV-AVLC5S02050SMLV0402(NF)MLV6303MLV-AVLC5S02050SMLV0402(NF)P401RFTEST-PAD-A-1RFTEST-PAD-A-1RF_TESTQ6103FET-P_DIODE-MC2511DFN3X2REC3100REV-11MMREV-11MMSW6300SW_IT-1100AANPLS10IT-1100AANPTL1NC-PROBE-PAD-D2.0-1.0MMNC-PROBE-PAD-D2.0-1.0MMTL2NC-PROBE-PAD-D2.0-1.0MMNC-PROBE-PAD-D2.0-1.0MMTL3NC-PROBE-PAD-D2.0-1.0MMNC-PROBE-PAD-D2.0-1.0MMTL4104NC-PROBE-PAD-D2.0-1.0MMNC-PROBE-PAD-D2.0-1.0MMTL4105NC-PROBE-PAD-D2.0-1.0MMNC-PROBE-PAD-D2.0-1.0MMTL4106NC-PROBE-PAD-D2.0-1.0MMNC-PROBE-PAD-D2.0-1.0MMTL6200NC-PROBE-PAD-D2.0-1.0MMNC-PROBE-PAD-D2.0-1.0MMTL6201NC-PROBE-PAD-D2.0-1.0MMNC-PROBE-PAD-D2.0-1.0MMTL6202NC-PROBE-PAD-D2.0-1.0MMNC-PROBE-PAD-D2.0-1.0MMTL6203TP-S070-PROBE-050TP_S070_PROBE_050TL6204TP-S070-PROBE-050TP_S070_PROBE_050TL6301NC-PROBE-PAD-D2.0-1.0MMNC-PROBE-PAD-D2.0-1.0MMTL6302NC-PROBE-PAD-D2.0-1.0MMNC-PROBE-PAD-D2.0-1.0MMTL6303NC-PROBE-PAD-D2.0-1.0MMNC-PROBE-PAD-D2.0-1.0MMTP9RF-SOLD-TPRF-SOLD-TPTVS3100TVS-ESD9L5.0ST5GTVS-ESD9L5.0ST5GTVS4102TVS-ESD5Z5.0T1GSOD-523NFTVS6200TVS-ESD5Z7.0T1GSOD-523(NF)U0100ASIC-SC7731C-600-0.4BGA_600_P040_1330X1210_H090U0400RF-SW+PA-SC2663HPQFN_28_P073X075_600X600_T387_H095U0402RF-SAW-DUPLEX-SAYEY1G95HA0F0AFILTER_8_180X140_H060TxRx:1950/2140MHzU0403RF-SAW-DUPLEX-SAYEY1G88CA0B0AFILTER_8_180X140_H060TxRx:1880/1960MHzU0404RF-BALUN-LFB21914MDZ2D326RF-BALUN-LFB21914MDZ2D326U0405RF-TRANSCEIVER-SR3533GBGAS_49_P040_330X330_H079_SR3533GU0406RF-PA-SC2671HRF-PA-SPRD-3X3-10PINU0407RF-PA-SC2672HRF-PA-SPRD-3X3-10PINU0409RF-PA-SC2678HRF-PA-SPRD-3X3-10PINU0410RF-SAW-DUPLEX-SAYEY897MHA0F0AFILTER_8_180X140_H060TxRx:897.5/942.5MHzU0501MEM-LPDDR3+EMMC-KMQN1000SM-B316BGA_221_P050_1150X1300_H100U1601MXC6255XCMXC6255XCMXC6255XCU1604IC-BMA250-LGA2X2MM_12PSENSOR/BMA250BMA250U4105POWER-DC2DC-KTD257EHD-TRSOT23-6U5202SENSOR-MOTION-ST480MFSENSOR-MOTION-ST480MFU7200BT+WIFI+FM+GPS-SR2351CBT+WIFI+FM+GPS-SR2351U7202RF-SAW-LFB212G45CL1D172RF-SAW-LFB212G45CL1D172U7203RF-SAW-SAFFB1G57KE0F0ARF-SAW-1.1X0.91575.42MHzU7204RF-LNA-GPS-BGU7005RF-LNA-GPS-BGU7005U7206RF-SW+PA-2.4G-SR2319ARF-SW+PA-2.4G-SR2319AVR2001ESD_/_TVS_/_5PF_/_0402VR0402VR0402VR6201MLV-AVLC5S02050SMLV0402VR6202MLV-AVLC5S02050SMLV0402VR6203MLV-AVLC5S02050SMLV0402X0200XTAL-CRYSTAL-32.768K-Q-SC32S0322070AAAFXTAL_CC_320X150_H08532.768KHzX0401XTAL-DCXO-26M-DSX221GXTAL-CRYSTAL-252026MHz(NF)Y7200XTAL-TCXO-26MHZ-1XXB26000MABOSC_CC_250X200_H090_KDS26MHz PCB和原理图一起打包。回复可见
**** Hidden Message ***** 多谢老吴 学习学习咯 学习学习 谢谢分享 好资料。谢谢。
回 老吴 的帖子
老吴:PCB和原理图一起打包。回复可见[内容隐藏]
(2018-08-08 17:35) images/back.gif
不错,学习。
