STM32F746NGH6 开发板PCB和原理图 AD格式原理图 CADstar格式PCB
CommentPatternQuantityComponents9013-SOT23SOT233T1, T2, T3BAT60JFILMSOD323/A5D1, D2, D3, D4, D6BLM18PG121SN1D0603L3L2, L6, L7EMIF02-USB03F2Flip Chip1U18ESDA14V2-2BF3BGA4_1X11D7F201-1*06MGF-W1-BAF201-1*06MGF-W1-BA1CN5F201-1*08MGF-W1-BAF201-1*08MGF-W1-BA2CN4, CN6F201-1*10MGF-W1-BAF201-1*10MGF-W1-BA1CN7F206A-2*04MGF-ASSM-104-L-DH1CN2FCM1608KF-601T030603L3L1, L4, L5FPU330ZH-BT1D3-CAFPU330ZH-BT1D3-CA1P1Header 4Header 41CN8HR961160CRJ45_HR961160C1CN9Jumper 2 pinsSIP2/2.542JP3, JP4LAN8742A-CZ-TRQFN24_0R5_4X41U9LD_BICOLOR_CMSHSMF-A2011LD7LD1117S18TRSOT-2231U13LD1117S50TRSOT-2231U6LD39050PU33RDFN6_3x31U7LD3985M33RSOT-23-5L1U12LED, green0603D3LD1, LD4, LD5LED, red0603D3LD2, LD3, LD6MP34DT01HCLGA4_3X42U20, U21MT48LC4M32B2B5-6A(MICRON)FBGA90_0R8_8X131U4N25Q128A13EF840E (MICRON)V-PDFN-8 8x61U3NX3215SA-32.768KXTAL_2SM_3R2X1R51X3NX3225GD-8.00MXTAL_2SM_3R2X2R51X4NZ2520SB-24.00MOSC_4SM_2R5X2R01X1NZ2520SB-25.00MOSC_4SM_2R5X2R01X2PJ3028B-3_BEPJ3028B1CN11PJ3028B-3_GRPJ3028B1CN10PJS008-2003MSD_PJS0081CN3RCA_SMDRCA_SMD1CN1RK043FN48H-CT672BRK043FN48H1U19ST890CDRSO-81U8STLD40DPURQFN8_0R65_3X3_ST1U10STM32F103CBT6QFP48 7x71U14STM32F746NGH6BGA216_0R8_13X13_SKT1U5STMPS2141STRSOT23-5L1U16STMPS2151STRSOT23-5L1U17STPS1L40MDO216-AA1D5SW-PUSH-CMS_BLACKBP1CMS1B2SW-PUSH-CMS_BLUEBP1CMS1B1Test point 1 pin with holeSIP1/2.541TP3TPSMDTEST-1MM2TP1, TP2TSM-102-01-x-SHSL_12_SMD_032_21JP2TSM-104-01-x-DVTSM-104-01-x-DV1JP1USB3320C-EZKQFN32_0R5_5X51U15USB-MICRO-ABUSB-MICRO-AB1CN13USB-MINI-typeBUSB-MINI-B-SMD1CN14USBULC6-2F3BGA4_1X11D8WM8994ECS/RBGA72_0R5_4R5X41U11 由于没装 CADSTAR 所以PCB截图是用PADS VX2.2 转换了。同时附件里面也有转换的PADS2.2格式文件一起打包。
这个软件用得多吗? 看看、! 谢谢分享
