RTL8376(RTL8370S)+RTL8218+RTL8231 做的16口千兆网络交换机PCB和原
NamePart TypePCB DecalValueD1DIODE_2LL341N4148_SMDD2FM240DO214ACB230AD10LED_4L_DIP3MM_X4LED_4L_DIPD11LED_6LED_DIP_3MMLED_1H2HEATSINK_2_PIN_1HeatSink_2_Pin_15x40mmH4HEATSINK_2_PIN_0HeatSink_2_Pin_15x40mmHS5SCREW_HOLEHS205SCREW_HOLEJ1CONN_PWR_5-P_0CONN_PWR_4-PJ2CON_1X2PIN_HEADER_2.54MMNC-CON_1x2J3CON_1X2PIN_HEADER_2.54MMNC-CON_1x2J4CON_1X2PIN_HEADER_2.54MMNC-CON_1x2JS1SHORT_PAD_0Short-PADL1CHOKE_0.3UHL15X8_D1.24.7uH / 6AL2CHOKE_WBDIP_D6XL10NC-Short WireL3INDUCTOR_0L14.5_7D0.6100uH/3AL4CHOKE_WBDIP_D6XL10NC-Short WireL5CHOKE_WBDIP_D6XL10NC-Short WireL6CHOKE_WBDIP_D6XL10NC-Short WirePJ1PHJ8-2ROW(2X4)_0AAR-RJ5-183-XXX.PDF_PAGE1PHJ8-2RowPJ2PHJ8-2ROW(2X4)_0AAR-RJ5-183-XXX.PDF_PAGE1PHJ8-2RowQ12N3904SOT-23NC-2N3904S1SHORT_PADSHORTxShort-ST1CON_2X2CON_2x2T21X2PINSIP\2PNC-1X2PINT3CON_4X1SIP/4PNC-CON_4x1U1IC-4X2_0SOP8APM7334KU2RT9218_SOP14_0SOP-8APW7165KEU3G5655P12USOP-8APW7172U4RTL8376S_128_7RTL8370SRTL8376_LQFP128-EPADU5RTL8218_128_7RTL8218_LQFP-128_EPADU624C02DIP8EEPROM_24C16(DIP)U7QUAD_TRANSFORMER__LFE9411D_0GTA-7201N-RU8QUAD_TRANSFORMER__LFE9411D_0GTA-7201N-RU9QUAD_TRANSFORMER__LFE9411D_0GTA-7201N-RU10QUAD_TRANSFORMER__LFE9411D_0GTA-7201N-RU11LED_S2P_BICOLORLQFP-48RTL8231_Bi-ColorY1CRYSTALXTAL325MHz/ 30ppmY2CRYSTALXTAL3NC-25MHz PCB 和原理图回复可见下载。 PCB是PADS9.5格式,原理图ORCAD16.2格式。
**** Hidden Message ***** 希望作品没有重复 好资源啊 正需要此封装~感谢 希望作品没有重复 正好需要,回复学习
