采用BCM20737A1KML2G设计的BCM92073X_LE_TAG4 Evaluation and Debug Kit原理
4层Pins(522)
**** Hidden Message *****
Bill of Material ReportSYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_TOLCOMP_CLASSREFDESTRACEINV_F_ANTENNA_1_TRACE_INV_F_ANTENNAINV_F_ANTENNA ICA1CAPC1608_IS0603QCAP_CAPC1608_IS0603Q_DISCRETE_0.9000 MM_4.7UF4.7uF DISCRETEC1CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.6350 MM_0.1UF0.1uF DISCRETEC2CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.6350 MM_0.1UF0.1uF DISCRETEC3CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.6350 MM_0.1UF0.1uF DISCRETEC4CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.6350 MM_0.1UF0.1uF DISCRETEC5CAPC2012_IS0805QCAP_CAPC2012_IS0805Q_DISCRETE_1.4500 MM_47UF47uF DISCRETEC6CAPC2012_IS0805QCAP_CAPC2012_IS0805Q_DISCRETE_1.4500 MM_47UF47uF DISCRETEC7CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.5500 MM_2.2UF2.2uF DISCRETEC8CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.5500 MM_1UF1uF DISCRETEC9CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.5500 MM_0.01UF0.01uF DISCRETEC10CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.5500 MM_10PF10pF DISCRETEC11CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.5500 MM_0.01UF0.01uF DISCRETEC12CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.5500 MM_0.01UF0.01uF DISCRETEC13CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.5500 MM_1.8PF1.8pF DISCRETEC14CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.5500 MM_1.8PF1.8pF DISCRETEC15CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.5500 MM_1.8PF (DNI)1.8pF (DNI) DISCRETEC16CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.5500 MM_1.8PF (DNI)1.8pF (DNI) DISCRETEC17CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.6100 MM_15PF15pF DISCRETEC18CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.6100 MM_15PF15pF DISCRETEC19CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.5500 MM_12PF12pF DISCRETEC20CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.5500 MM_12PF12pF DISCRETEC21CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.5500 MM_150PF150pF DISCRETEC22CAPC1608_IS0603QCAP_CAPC1608_IS0603Q_DISCRETE_0.9000 MM_4.7UF4.7uF DISCRETEC23CAPC1608_IS0603QCAP_CAPC1608_IS0603Q_DISCRETE_1.0000 MM_10UF10uF DISCRETEC24CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.7000 MM_10UF10uF DISCRETEC25CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.5500 MM_0.1UF0.1uF DISCRETEC26CAPC1608_IS0603QCAP_CAPC1608_IS0603Q_DISCRETE_0.9500 MM_4.7UF4.7uF DISCRETEC28CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.6350 MM_0.1UF0.1uF DISCRETEC29CAPC2012_IS0805QCAP_CAPC2012_IS0805Q_DISCRETE_1.4500 MM_22UF22uF DISCRETEC30CAPC2012_IS0805QCAP_CAPC2012_IS0805Q_DISCRETE_1.4500 MM_22UF22uF DISCRETEC31CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.7000 MM_10UF10uF DISCRETEC34CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.6350 MM_0.1UF0.1uF DISCRETEC37CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.5500 MM_0.1UF0.1uF DISCRETEC54CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.6350 MM_0.1UF0.1uF DISCRETEC58CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.6350 MM_0.1UF0.1uF DISCRETEC59CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.6500 MM_4.7UF4.7uF DISCRETEC60CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.6350 MM_0.1UF0.1uF DISCRETEC61CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.6350 MM_0.1UF0.1uF DISCRETEC62CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.6350 MM_0.1UF0.1uF DISCRETEC63CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.6350 MM_0.1UF0.1uF DISCRETEC64CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.5500 MM_1UF1uF DISCRETEC66CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.6350 MM_0.1UF0.1uF DISCRETEC68CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.6350 MM_0.1UF0.1uF DISCRETEC69LEDC1608QDIO-LED_LEDC1608Q_0.9000 MM_LTST-C190CKTLTST-C190CKT ICD1LEDS4_KING_APTB1615QLED-DUAL-RED1-GRN2_LEDS4_KING_APTB1615Q_DISCRETE_0.9000MM_APTB1615SURKCGKC-F01APTB1615SURKCGKC-F01 DISCRETED3FUSC1005_IS0402QDIO-TVS-BIPOLAR-2_FUSC1005_IS0402Q_DISCRETE_0.6000 MM_10V10V DISCRETED4FUSC1005_IS0402QDIO-TVS-BIPOLAR-2_FUSC1005_IS0402Q_DISCRETE_0.6000 MM_10V10V DISCRETED5FUSC1005_IS0402QDIO-TVS-BIPOLAR-2_FUSC1005_IS0402Q_DISCRETE_0.6000 MM_10V10V DISCRETED6FUSC1005_IS0402QDIO-TVS-BIPOLAR-2_FUSC1005_IS0402Q_DISCRETE_0.6000 MM_10V10V DISCRETED7INDC1005_IS0402QFB_INDC1005_IS0402Q_DISCRETE_0.6000 MM_120OHMS120Ohms DISCRETEFB1INDC1005_IS0402QFB_INDC1005_IS0402Q_DISCRETE_0.6000 MM_120OHMS120Ohms DISCRETEFB2INDC1005_IS0402QFB_INDC1005_IS0402Q_DISCRETE_0.6000 MM_600OHMS600Ohms DISCRETEFB3IPX_20279-001E-01RF-2GND-J_IPX_20279-001E-01_IO_1.2450 MM_20279-001E-0420279-001E-04 IOJ1CTST254PSS4PLG-4-J_CTST254PSS4_IO_8.8900 MM_PBC04SAANPBC04SAAN IOJ2TYCO_1981568-1USB-5P-6SH-J_TYCO_1981568-1_IO_2.5100 MM_1981568-11981568-1 IOJ7CTST254PSS4PLG-4-J_CTST254PSS4_IO_8.8900 MM_PBC04SAANPBC04SAAN IOJ8CTST254PSS4PLG-4-J_CTST254PSS4_IO_8.8900 MM_PBC04SAANPBC04SAAN IOJ9CTST254PDS18PLG-18-ODD-EVEN-J_CTST254PDS18_IO_8.8900 MM_S-M-.100-2X9S-M-.100-2X9 IOJ10CTST254PDS18PLG-18-ODD-EVEN-J_CTST254PDS18_IO_8.8900 MM_S-M-.100-2X9 (DNI)S-M-.100-2X9 (DNI) IOJ11CTST254PSS2HDR1X2-J_CTST254PSS2_IO_8.8900 MM_PBC02SAANPBC02SAAN IOJ12CTST254PDS18PLG-18-ODD-EVEN-J_CTST254PDS18_IO_8.8900 MM_S-M-.100-2X9 (DNI)S-M-.100-2X9 (DNI) IOJ13INDS2_TDK_VLS201610CXQIND-SHIELDED-NO-DOT_INDS2_TDK_VLS201610CXQ_DISCRETE_1.0000MM_10UH10uH DISCRETEL1INDS2_MUR_LQM21NQIND_INDS2_MUR_LQM21NQ_DISCRETE_1.4500 MM_4.7UH4.7uH DISCRETEL2SPKRS2_MUR_PKLCS1212QSPEAKER_SPKRS2_MUR_PKLCS1212Q_IO_3.0000 MM_PKLCS1212E4001-R1PKLCS1212E4001-R1 IOLS1SOT23_B_E_CNPN_SOT23_B_E_C_DISCRETE_1.5600 MM_2SC2712-Y,LF2SC2712-Y,LF DISCRETEQ1SOT883_SC-101_B_E_CPNP_SOT883_SC-101_B_E_C_DISCRETE_0.5000 MM_PBSS3540MPBSS3540M DISCRETEQ3RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_10K10K DISCRETER1RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_00 DISCRETER2RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_00 DISCRETER3RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_00 DISCRETER4RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_00 DISCRETER5RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_1K1K DISCRETER6RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_1K1K DISCRETER7RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_10K10K DISCRETER8RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_00 DISCRETER9RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_100K100K DISCRETER10RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_470470 DISCRETER11RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_10K (DNI)10K (DNI) DISCRETER12RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_00 DISCRETER13RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_5.6K5.6K DISCRETER14RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_10K10K DISCRETER15RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_10K10K DISCRETER16RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_10K10K DISCRETER17RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_4.7K4.7K DISCRETER18RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_4.7K4.7K DISCRETER19RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_200200 DISCRETER22RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_10K10K DISCRETER23INDC1005_IS0402QIND-DOT-1_INDC1005_IS0402Q_DISCRETE_0.3500 MM_2.7NH2.7nH DISCRETER24RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_00 DISCRETER25RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_0 (DNI)0 (DNI) DISCRETER26RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_0 (DNI)0 (DNI) DISCRETER27RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_10M10M DISCRETER28RESC1608_IS0603QRES_RESC1608_IS0603Q_DISCRETE_0.6000 MM_00 DISCRETER29RESC1005_IS0402Q_OPT_ABRES-OPT-B-A_RESC1005_IS0402Q_OPT_AB_DISCRETE_0.4000 MM_10K10K DISCRETER30RESC1005_IS0402Q_OPT_ABRES-OPT-A-B_RESC1005_IS0402Q_OPT_AB_DISCRETE_0.4000 MM_10K10K DISCRETER31RESC1005_IS0402Q_OPT_ABRES-OPT-B-A_RESC1005_IS0402Q_OPT_AB_DISCRETE_0.4000 MM_10K10K DISCRETER32RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_00 DISCRETER39RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_4.7K4.7K DISCRETER40RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_4.7K4.7K DISCRETER41RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_00 DISCRETER50RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_00 DISCRETER51RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_00 DISCRETER59RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_200 (DNI)200 (DNI) DISCRETER60RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_200 (DNI)200 (DNI) DISCRETER61RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_0 (DNI)0 (DNI) DISCRETER62RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_10K10K DISCRETER63RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_10K10K DISCRETER64RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_10K10K DISCRETER65RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_10K (DNI)10K (DNI) DISCRETER66RESC1005_IS0402Q_OPT_ABRES-OPT-B-A_RESC1005_IS0402Q_OPT_AB_DISCRETE_0.4000 MM_00 DISCRETERD5RESC1005_IS0402Q_OPT_ABRES-OPT-B-A_RESC1005_IS0402Q_OPT_AB_DISCRETE_0.4000 MM_00 DISCRETERD6RESC1005_IS0402Q_OPT_ABRES-OPT-A-B_RESC1005_IS0402Q_OPT_AB_DISCRETE_0.4000 MM_00 DISCRETERD7RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_360K360K DISCRETERFB1RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_240K240K DISCRETERFB2SWPBS4_CK_KMR2XXGSWITCH-PB-13-24_SWPBS4_CK_KMR2XXG_DISCRETE_2.1000 MM_KMR221GLFSKMR221GLFS DISCRETESW1SWPBS4_CK_KMR2XXGSWITCH-PB-13-24_SWPBS4_CK_KMR2XXG_DISCRETE_2.1000 MM_KMR221GLFSKMR221GLFS DISCRETESW2SWPBS4_CK_KMR2XXGSWITCH-PB-13-24_SWPBS4_CK_KMR2XXG_DISCRETE_2.1000 MM_KMR221GLFSKMR221GLFS DISCRETESW3SWSLS3_ALPS_SSSS811101SWITCH-SPDT-CP2NC3NO1-4SHLD_SWSLS3_ALPS_SSSS811101_DISCRETE_1.4000MM_SSSS811101SSSS811101 DISCRETESW4SWSLS3_ALPS_SSSS811101SWITCH-SPDT-CP2NC3NO1-4SHLD_SWSLS3_ALPS_SSSS811101_DISCRETE_1.4000MM_SSSS811101SSSS811101 DISCRETESW5SWDPS8_OMRON_A6H-4102SW-DIP-4_SWDPS8_OMRON_A6H-4102_DISCRETE_1.9500 MM_A6H-4101A6H-4101 DISCRETESW6SWDPS16_ITT_TDA08H0SK1SW-DIP-8_SWDPS16_ITT_TDA08H0SK1_DISCRETE_2.3000 MM_TDA08H0SB1TDA08H0SB1 DISCRETESW8SWDPS8_OMRON_A6H-4102SW-DIP-4_SWDPS8_OMRON_A6H-4102_DISCRETE_1.9500 MM_A6H-4101A6H-4101 DISCRETESW9TP_SMD_030RDTP_TP_SMD_030RD_IO__TP-SMT-030-RNDTP-SMT-030-RND IOTP5TP_SMD_030RDTP_TP_SMD_030RD_IO__TP-SMT-030-RNDTP-SMT-030-RND IOTP6TP_SMD_030RDTP_TP_SMD_030RD_IO__TP-SMT-030-RNDTP-SMT-030-RND IOTP7TP_SMD_030RDTP_TP_SMD_030RD_IO__TP-SMT-030-RNDTP-SMT-030-RND IOTP8TP_SMD_030RDTP_TP_SMD_030RD_IO__TP-SMT-030-RNDTP-SMT-030-RND IOTP9TP_SMD_030RDTP_TP_SMD_030RD_IO__TP-SMT-030-RNDTP-SMT-030-RND IOTP11TP_SMD_030RDTP_TP_SMD_030RD_IO__TP-SMT-030-RNDTP-SMT-030-RND IOTP12TP_SMD_030RDTP_TP_SMD_030RD_IO__TP-SMT-030-RNDTP-SMT-030-RND IOTP13TP_SMD_030RDTP_TP_SMD_030RD_IO__TP-SMT-030-RNDTP-SMT-030-RND IOTP14TSOP65P640_8_D300N24XX512-DIL8_TSOP65P640_8_D300N_IC_1.2000 MM_24FC512-I/ST24FC512-I/ST ICU1QFN50P500X500_32_HS370_BCMBCM20736A1KML2G-W1000-27301_QFN50P500X500_32_HS370_BCM_IC_1.0000MM_BCM20737A1KML2GBCM20737A1KML2G ICU2SOIC127P600_8_D490NMX25U4033E-DIL8_SOIC127P600_8_D490N_IC_1.7500MM_MX25U4033EM1I-12GMX25U4033EM1I-12G ICU3SON55P200X180_6_USP-6ELQXC9265-DFN6H_SON55P200X180_6_USP-6ELQ_IC_0.4000MM_XC9265B1214R-GXC9265B1214R-G ICU4SON50P200X180_6_USP-6CQXC9236-ADJ-DFN6H_SON50P200X180_6_USP-6CQ_IC_0.6100 MM_XC9236_ADJXC9236_ADJ ICU5QFN50P400X400_24_HS280NUSB-CP2105-QFN24H_QFN50P400X400_24_HS280N_IC_0.8000MM_CP2105-F01-GMCP2105-F01-GM ICU6MODS6_ST_HLGA-6LNHTS221-LGA6_MODS6_ST_HLGA-6LN_IC_1.0000 MM_HTS221HTS221 ICU8QFN50P160X160_8_MAC08AQVOLT-XLATOR-FXM2IC102_QFN50P160X160_8_MAC08AQ_IC_0.5590MM_FXM2IC102FXM2IC102 ICU9QFN60P250X250_10_ST-LGA-10LNLPS25HB-LGA10_QFN60P250X250_10_ST-LGA-10LN_IC_0.8000MM_LPS25HBTRLPS25HBTR ICU10LGA50P300X250_14_ST-LGA14NLSM6DS3-LGA14_LGA50P300X250_14_ST-LGA14N_IC_0.8600 MM_LSM6DS3LSM6DS3 ICU15QFN50P200X200_12_ST_LGA-12QLIS3MDL-LGA12_QFN50P200X200_12_ST_LGA-12Q_IC_1.0000 MM_LIS3MDLTRLIS3MDLTR ICU16XTALS4_3M2X2M5XTAL-1G3G_XTALS4_3M2X2M5_DISCRETE_0.9000 MM_24.000MHZ24.000MHz DISCRETEY1XTALS2_ABR_ABS07QXTAL_XTALS2_ABR_ABS07Q_DISCRETE_0.9000 MM_0.03277MHZ0.03277MHz DISCRETEY2BATHS3_KEY_3002QBATTERY-HOLDER-P2N1_BATHS3_KEY_3002Q_DISCRETE_4.2100 MM_3002TR3002TR DISCRETEZB1 谢谢分享! 谢谢分享! 是博通公司的作品吗?
