RK3288+TAS5707+ES8388+RTL8211E-VB-CG+USB4606 做的一个控制板 MINI PC&am
NamePCB DecalValuePart Type6J2USB-MICRO-4DIPMICRO-USBJP_USB-0400ASMT_7COM1J-DB9-RSCONNECTOR_DB9_GTCOM2J-DB9-RSCONNECTOR_DB9_GTCOM3J-DB9-RSCONNECTOR_DB9_GTCOM4J-DB9-RSCONNECTOR_DB9_GTD1LED-0603LEDD2SOD1231N5819DIODED3D12061N5819DIODED4SOD123NC/1N5819DIODED5D1206SD103AWDIODED13R0402ESDPSA0402V05TVSD14D-SOD123SD103AWDIODED38IC-SOT23BAV99D2-3_A_0D101D-214AANC/TVSDIODED700R0402ESDPSA0402V05TVSD701R0402ESDPSA0402V05TVSED1R0402BESDU0402-05TVSED9R0402ESD9B5VLDIODE_BI-DIR_TRIGESD4R0402EGA10603V05A1-BTVSFB1L0603DNC/SDCW2012-2-900INDUCTOR-COMFB4L06030RINDUCTORFB6L06030RINDUCTORFB16F04020RFBH2H3_8MMH3.8MMH0502H3H3_8MMH3.8MMH0502H4H3_8MMH3.8MMH0502IR1J-IR2-2.54FT-009IR_RECEIVEIR2QFN44-PT09MM-1RL8723BSRL8723J1CON30-2-DCON30BCON30B-1J2J-TFCARDTF_SD_SOCKETTF_SD_SOCKETJ3J-HDMI-1HDMI_AHDMI_AJ4J-USB-RS-V-41USB/后面板USB1J5CON4-2-VCON4*2.0CON4J6DIN004-F04G1BY-AK3P9610N9CON9J7USB-AUSB-AJ8BAT-BS-82pin电池座-BS123-F02A1BR-ACON2J10PCIE_52PIN_3ME3630 mini-PCIEZTE_ME220J12CON4-2-VACON4*2.0CON4J13CON8-2.0CON8-2.54mmCON8J14CON12-2-D1ACON12B1CON12B-1J15PJ3090-F08A1BY-APHONE JACKMICJAC4J16PJ3090-F08A1BY-AMIC JACKMICJAC4J20ANT-4天线扣ANT-4J21J-USB-RS-V-41USB/后面板USB1J44CON2-2-SCON2_0CON2_0J300CON3-2.543*2.54mmCON3-1J501J-RJ45-SMTRJ45RJ45BJ600CON2-2-S2*2mmCON2J603CON6-2.0-26*2mmCON6-1J605CON12-2-D1BCON12B1CON12B-1J700J-USB-RS-V-41USB/后面板USB1J701J-USB-RS-V-41USB/后面板USB1JV02FPC6H/0.5-S-1FH34SRJ-6S-0.5SH(50)-DK1SW-TS-C005贴片轻触开关PSW4_AK300SW3-4.5X4.5X5ANJIANL1L5X54.7uH/3.1AINDUCTOR_1L2IND-5X51uH/5AINDUCTOR_2L3IND-3X31uH/2AINDUCTOR_2L4IND-5X51uH/5AINDUCTOR_2L5IND-3X31uH/2AINDUCTOR_2L6L5X510uH/1.5AINDUCTORS_OF_FERRITE_2L7PL-0606-04522uH/1.8ALL8PL-0606-04522uH/1.8ALL9IND-3X32.2uH/1AINDUCTOR_1L10L5X54.7uH/3.1AL_PWRL11L5X54.7uH/3.1AL_PWRL12PL-0606-04522uH/1.8ALL13L5X510uH/2AL_PWRL14PL-0606-04522uH/1.8ALL15L0603220R/1AINDUCTORL16L5X54.7uH/3.1AL_PWRL17L5X510uH/2AL_PWRL100L5X54.7uH/3.1AL_PWRL714L04020RL-1Q1SOT232N7002KMOSFET_NQ2SOT232N7002KMOSFET_NQ3IC-SOT23MMBT3904NPNQ5IC-SOT23MMBT3904NPNQ6IC-SOT23PNP-BECPNP-BEC_2Q7IC-SOT23MEM2307M3GEPMOSQ8SOT23NC/2N7002KMOSFET_NQ9IC-SOT23MMBT3904NPN-BEC_1Q10IC-SOT23MMBT3904NPN-BEC_1Q11IC-SOT23MMBT3904NPNQ13IC-SOT23MMBT3904NPNQ22SOT23NC/WPM2015MOSFET_PQ23IC-SOT23MMBT3904NPNQ26SOT23NC/MMBT3904NPN-BEC_1Q301IC-SOT23MMBT3904NPN-BECQ302IC-SOT23MMBT3904NPN-BECSW100SW-DRS01船型开关SW_SIP2T1MARKMARKTESTT501IC-PSF-2447S558_5999_T3H5008TT1714T-0-7TESTTESTPOINT1U1BGA636_1MCU_RK3288BGA636_1U2FBGA96-10X14DDR3_128MX16BITFBGA96-10X14U3FBGA96-10X14DDR3_128MX16BITFBGA96-10X14U4FBGA96-10X14/2DDR3_128MX16BITFBGA96-10X14/2U5FBGA96-10X14/2DDR3_128MX16BITFBGA96-10X14/2U6QFN68-7X7RK808RK808_0U7INAND_169_AeMMCINAND_169_AU8IC-SOT23-5SY8089DS8008_6U9IC-SOT23-5SY6288CAACDS8008_0U10TSOP1-48NC/NAND_FLASHNANDFLASH_0U11IC-SOT23-6MP3202DJU_MP3202U12IC-SOT23-6SY8120B8120B1U13IC-SOT23-6SY8120B8120B1U14IC-SOT23-5NCSGM2032U15IC-SOT23-6MP1471MP1471AU16SLP2510P8RClamp0524PA/ESD5304DS8008_9U17SLP2510P8RClamp0524PA/ESD5304DS8008_9U18SO16MAX3232MAX3232U19IC-SOT23-5SY6288CAACDS8008_0U20QFN48-6X6RTL8211E-VB-CGRTL8169S_2U21IC-SOT23-5NCSGM2032U22SO16MAX3232MAX3232U23IC-SOT23-6MP1471MP1471AU24IC-SOT23-6MP1470MP1471AU25PQFP48-050-0707LHTAS5707TAS5707_0U26IC-SOT23-5NC/SY6288CAACDS8008_0U27SOT25SY6280AAC/WS4601LPW5206HU28TSSOP_8LM4890TSSOP_8U30IC-SSOP20-7.8X7.2WK2124WK2124U32IC-QFN28-4X4ES8388ES8388U51IC-SOT23-6MP1471MP1471AU601IC-QFP48-7X7-1USB4606USIM1MC041-F06S1BRSIM_CARDY1CRY2_6R90X1R40X1R3032.768KHzCRYSTAL_2P_1GY2CRY-D322524M-20ppmCRYSTAL-4_1Y3CRY-D322525MHz-30ppmCRYSTAL-4_0_2Y4CRY-D322511.0592MHz-20ppmCRYSTAL-4_0_2Y8X28824MHZX_B PCB文件共享。没原理图。回复可见
**** Hidden Message ***** 谢谢分享RK3288+TAS5707+ES8388+RTL8211E-VB-CG+USB4606 做的一个控制板 MINI PCPCB文件 高大上。
