ZYNQ XC7Z030-1FBG676I 做的一个板子PCB和原理图共享
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMECF1CAP NP_C0603_4.7UF4.7ufC0603CF2CAP NP_C0402_0.47UF0.47ufC0402D31N5408_RET_D_1N54011N5401RET_DD41N5408_RET_D_1N54081N5408RET_DD5LED_0805_LEDLED805FB1INDUCTORTORROID_L0603_120OHM@1120ohm@100MHzL0603J1CON16A_HEADER8X2_CON16ACON16AHEADER8X2J2GE_RJ45_GE_RJ45_GE_RJ45GE_RJ45GE_RJ45J3FPGA_JTAG_JTAG-X_FPGA_JTAGFPGA_JTAGJTAG-XJ4CON20A_LED10X2_CON20ACON20ALED10X2J5CON20A_LED10X2_CON20ACON20ALED10X2J6CON8_HEADER4X2_CON8CON8HEADER4X2J7CON2_POWER2E_CON2CON2POWER2EJ8CON8_HEADER4X2_CON8CON8HEADER4X2J9CONN SOCKET3_JUMP3_CONN SOCKETCONN SOCKET 3JUMP3L1L680_LVS303010_2.2UH2.2uHLVS303010L2L680_L0603_120OHM@100MHZ120OHM@100MHzL0603L3INDUCTORFERRITE_L0603_CIZHUCIZHUL0603L5L680_CDRH6D38NP_5R_2.2UH5000MA2.2uH 5000mACDRH6D38NP_5RL6L680_CDRH6D38NP_5R_2.2UH5000MA2.2uH 5000mACDRH6D38NP_5RL7L680_CDRH6D38NP_5R_2.2UF5000MA2.2uF 5000mACDRH6D38NP_5RL8L680_CDRH6D38NP_5R_2.2UH5000MA2.2uH 5000mACDRH6D38NP_5RL9INDUCTORFERRITE_L0603_ FERRITEFERRITEL0603P1BATTERY_BATTERYSMALL_BATTERYBATTERYBATTERYSMALLP2HCPL-5631_DIP8_3_HCPL-5631HCPL-5631DIP8_3P3CONNECTORDB15_DB15_T_CONNECTORCONNECTOR DB15DB15_TP4CONNECTORDB15_DB15_T_CONNECTORCONNECTOR DB15DB15_TP5HCPL-5631_DIP8_3_HCPL-5631HCPL-5631DIP8_3P6HCPL-5631_DIP8_3_HCPL-5631HCPL-5631DIP8_3P7HPL-263L_DIP8_3_HPL-263LHPL-263LDIP8_3Q13DK4B_B-4_3DK4B3DK4BB-4Q23DK4B_B-4_3DK4B3DK4BB-4SW1SW_SB_SWSWSBSW2CON16B_KEY8X2_CON16BCON16BKEY8X2SW3CON16B_KEY8X2_CON16BCON16BKEY8X2SW4CON16B_KEY8X2_CON16BCON16BKEY8X2SW5CON16B_KEY8X2_CON16BCON16BKEY8X2SW6SW_SB_SWSWSBSW7SW_SB_SWSWSBU1MAX1270AEAI_SSOP28_MAX1270AEAIMAX1270AEAISSOP28U2CA3140_SOIC8_CA3140CA3140SOIC8U3TPS51200DRCR_TPS51200DRCR_TPS51TPS51200DRCRTPS51200DRCRU4DS3231_SO16W_DS3231DS3231SO16WU5RTL8211E_RTL8211_QFN48_8169SB8169SBRTL8211_QFN48U6MT29F32G08AECBBH1_VBGA100_MT29FMT29F32G08AECBBH1VBGA100U7XC7Z030-1FBG676I_FBG676_(S1+S2+XC7Z030-1FBG676IFBG676U8CA3140_SOIC8_CA3140CA3140SOIC8U9TCM811TERCTR_TCM811TERCTR_TCM81TCM811TERCTRTCM811TERCTRU11TLV62130RGT_TLV62130RGT_TLV6213TLV62130RGTTLV62130RGTU12TLV62130RGT_TLV62130RGT_TLV6213TLV62130RGTTLV62130RGTU13TLV62130RGT_TLV62130RGT_TLV6213TLV62130RGTTLV62130RGTU14TLV62130RGT_TLV62130RGT_TLV6213TLV62130RGTTLV62130RGTU15SPX3819M5-3-3_SOT-23-5_SPX3819MSPX3819M5-1-8SOT-23-5U16SPX3819M5-3-3_SOT-23-5_SPX381_1SPX3819M5-3-0SOT-23-5U17MAX3490_SOIC_8_MAX3490MAX3490SOIC_8U18MAX3490_SOIC_8_MAX3490MAX3490SOIC_8U19DS96F175ME_LCC20_DS96F175MEDS96F175MELCC20U20DS96F174ME_LCC20_DS96F174MEDS96F174MELCC20U21W25Q256FV_0_MLP8_W25Q256FVW25Q256FVMLP8U22MAX3232_TSSOP16_MAX3232max3232TSSOP16U23TXS0102DCU_TSSOP8_TXS0102DCUTXS0102DCUTSSOP8U24USB3320C-EZK_6_USB3320C_USB3320USB3320C-EZK_6USB3320CU25LMZ13608_TZA11A_LMZ13608LMZ13608TZA11AUM1MT41K128M16JT_BGA_96P_31_524X29MT41K128M16JTBGA_96P_31_524X295_C14UM2MT41K128M16JT_BGA_96P_31_524X29MT41K128M16JTBGA_96P_31_524X295_C14X1OSC_OSC5X7_50MHZ50MHzOSC5X7X2OSC_OSC5X7_33.33MHZ33.33MHzOSC5X7XS1USBCON_USBPORT_USBCONUSBCONUSBPORTY1CRYSTAL_CRYSTAL_25MHZ25MHzCRYSTALY2CRYSTAL_CRYSTAL_24MHZ24MhzCRYSTAL PCB和原理图共享。都是CADNECE16.6版本。回复可见下载
**** Hidden Message *****
回 老吴 的帖子
老吴:PCB和原理图共享。都是CADNECE16.6版本。回复可见下载[内容隐藏]
(2019-03-08 16:27) images/back.gif
厉害了 资料非常好,感谢楼主无私分享!!! 谢谢分享ZYNQ XC7Z030-1FBG676I 做的一个板子PCB和原理图 谢谢分享 挺好看的板子 这个板子干什么用的
