老吴 发表于 2019-4-1 01:43:55
Intel Atom X7-Z8700 方案平板电脑PCB文件和原理图共享下载
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEANT1JC-442022A1Q1G_3_ANT-4D5X2D2_QQQQ-36K1GANT-4D5X2D2ANT2JC-442022A1Q1G_3_ANT-4D5X2D2_QQQQ-36K1GANT-4D5X2D2ANT3JC-442022A1Q1G_3_ANT-4D5X2D2_QQQQ-36K1GANT-4D5X2D2CN_BATCPBA206-0101F_CON6_POWER_CPBA20CPBA206-0102ECON6_POWER_CPBA206-0102ECN_BTNCONN_1_FPC6P_0D5M_Y5BAYF530635Y5B AYF530635FPC6P_0D5MCN_DLPAXF361500_0_CON10_POWER_CPBA206AXF361500CON10_POWER_CPBA206-B01CN_ECCON6_WTB_MTG2_0_1X6_P8MM_WTB_NCNC_50208-00601-0011X6_P8MM_WTBCN_HDMICONN_0_FPC30_05_17X3D2_H1D75_FHFH34SRJ-30S-0.5SHFPC30_05_17X3D2_H1D75CN_RTCSUR08T-WT-2A_ACES50278_2P_1D25_50278-00201-001ACES50278_2P_1D25CN_SPICON6_WTB_MTG2_0_1X6_P8MM_WTB_NCNC_50208-00601-0011X6_P8MM_WTBCN_SPKLSUR08T-WT-5A_0_FPC4P_0D5M_Y5BAY5B AYF530435FPC4P_0D5MCN_SPKRSUR08T-WT-5A_0_FPC4P_0D5M_Y5BAY5B AYF530435FPC4P_0D5MCN_SSDM2_KEY_B_0_NGFF_75P_0D5_H2D15_SSM3ZS067U215ABR1500NGFF_75P_0D5_H2D15_SMT_SCN_USBCON24_USB_TYPEC_1_CON24_USB_C_MDX07B024JJ1CON24_USB_C_MIDMT_AUSB0129CR1ESD9X7V_0_SMCR_1P0XP6_FBP02C_ESESD9X7V-2T/RSMCR_1P0XP6_FBP02CCR2DIO_ESD_SMCR_P6X1P0_P40H_ESD545ESD5451X-2/TRSMCR_P6X1P0_P40HCR3DIO_ESD_SMCR_P6X1P0_P40H_ESD545ESD5451X-2/TRSMCR_P6X1P0_P40HCR4DIO_ESD_SMCR_P6X1P0_P40H_ESD545ESD5451X-2/TRSMCR_P6X1P0_P40HCR5DIO_ESD_SMCR_P6X1P0_P40H_ESD545ESD5451X-2/TRSMCR_P6X1P0_P40HCR6DIO_ESD_SMCR_P6X1P0_P40H_ESD545ESD5451X-2/TRSMCR_P6X1P0_P40HCR7DIO_ESD_SMCR_P6X1P0_P40H_ESD545ESD5451X-2/TRSMCR_P6X1P0_P40HCR8ESD5344D_0_LCC10_NS_2P5X1P0_P65ESD5344D-10TRLCC10_NS_2P5X1P0_P65HCR9ESD5344D_0_LCC10_NS_2P5X1P0_P65ESD5344D-10TRLCC10_NS_2P5X1P0_P65HCR10DIO_ESD_SMCR_P6X1P0_P40H_ESD545ESD5451X-2/TRSMCR_P6X1P0_P40HCR11DIO_ESD_SMCR_P6X1P0_P40H_ESD545ESD5451X-2/TRSMCR_P6X1P0_P40HCR12DIO_ESD_SMCR_P6X1P0_P40H_ESD545ESD5451X-2/TRSMCR_P6X1P0_P40HCR13DIO_ESD_SMCR_P6X1P0_P40H_ESD545ESD5451X-2/TRSMCR_P6X1P0_P40HCR14ZENER_SOD523F_BZX584C22BZX584C22SOD523FCR15DIO_ESD_SMCR_P6X1P0_P40H_ESD545ESD5451X-2/TRSMCR_P6X1P0_P40HCR16DIO_ESD_SMCR_P6X1P0_P40H_ESD545ESD5451X-2/TRSMCR_P6X1P0_P40HCR17DIO_ESD_SMCR_P6X1P0_P40H_ESD545ESD5451X-2/TRSMCR_P6X1P0_P40HCR18DIO_ESD_SMCR_P6X1P0_P40H_ESD545ESD5451X-2/TRSMCR_P6X1P0_P40HCR19DIO_ESD_SMCR_P6X1P0_P40H_ESD531ESD5311X-2/TRSMCR_P6X1P0_P40HCR20DIO_ESD_SMCR_P6X1P0_P40H_ESD531ESD5311X-2/TRSMCR_P6X1P0_P40HCR30DIO_ESD_SMCR_P6X1P0_P40H_ESD545ESD5451X-2/TRSMCR_P6X1P0_P40HCR31DIO_ESD_SMCR_P6X1P0_P40H_ESD545ESD5451X-2/TRSMCR_P6X1P0_P40HCR32ESD9X7V_0_SMCR_1P0XP6_FBP02C__1ESD5401N-2/TRSMCR_1P0XP6_FBP02CCT1CAPT_F93_2P_H1D9_33UF/16V33uF/16VF93_2P_H1D9CT2CAPT_F93_2P_H1D9_33UF/16V33uF/16VF93_2P_H1D9CT3CAPT_F93_2P_H1D9_150UF/6V150uF/6VF93_2P_H1D9CT6CAPT_F93_2P_H1D9_150UF/6V150uF/6VF93_2P_H1D9D1DIODE_SOD323_B5819WSB5819WSSOD323D2DIODETWIN_SOT23_BAT54CBAT54CSOT23D4DIODE_SOD323_B5819WSB5819WSSOD323D5DIODE_SOD323_B5819WSB5819WSSOD323D6D_2_SOD-123_BZT52C4V3BZT52C4V3SOD-123D9DIODE_SOD323_B5819WSB5819WSSOD323D10DIODE_SOD323_B5819WSB5819WSSOD323D11DIODE_SOD323_B5819WSB5819WSSOD323D12DIODE_SOD323_B5819WSB5819WSSOD323D13DIODE_SOD323_B5819WSB5819WSSOD323D14DIODE_SOD323_B5819WSB5819WSSOD323D15DIODE_SOD323_B5819WSB5819WSSOD323D16DIODE_SOD323_B5819WSB5819WSSOD323D17DIODE_SOD323_B5819WSB5819WSSOD323D18DIODE_SOD323_B5819WSB5819WSSOD323D19DIODE_SOD323_B5819WSB5819WSSOD323D20DIODE_SOD323_B5819WSB5819WSSOD323D21DIODE_SOD323_B5819WSB5819WSSOD323D22SCHOTTKY_SOD923_0_SOD-123_B5819B5819WSOD-123D23DIODE_SOD323_B5819WSB5819WSSOD323D24DIODE_SOD323_B5819WSB5819WSSOD323D25DIODE_SOD323_NC_B5819WSNC_B5819WSSOD323D3+TESTPAD_CIR#2_0_TESTPAD_C40_NC_NC_C40TESTPAD_C40D3-TESTPAD_CIR#2_0_TESTPAD_C40_NC_NC_C40TESTPAD_C40F3FUSE_FSMD1206P150TS_F1206HI4000F1206HI4000V032TFSMD1206P150TSF4FUSE_FSMD1206P150TS_F1206HI4000F1206HI4000V032TFSMD1206P150TSFB1FERRITEBEAD_SML0402_120OHM@100120ohm@100MHz,400mASML0402FB2FERRITEBEAD_SML0402_120OHM@100120ohm@100MHz,400mASML0402FB3FERRITEBEAD_SML0402_120OHM@100120ohm@100MHz,400mASML0402FB4FERRITEBEAD_SML0402_120OHM@100120ohm@100MHz,400mASML0402FB5FERRITEBEAD_SML0402_120OHM@100120ohm@100MHz,400mASML0402FB6FERRITEBEAD_SML0402_120OHM@100120ohm@100MHz,400mASML0402FB7FERRITEBEAD_SML0402_120OHM@100120ohm@100MHz,400mASML0402FB8FERRITEBEAD_SML0402_120OHM@100120ohm@100MHz,400mASML0402FB9FERRITEBEAD_SML0402_120OHM@100120ohm@100MHz,400mASML0402FB10FERRITEBEAD_SML0402_120OHM@100120ohm@100MHz,400mASML0402FB11FERRITEBEAD_SML0402_120OHM@100120ohm@100MHz,400mASML0402FB12FB0805100ohm@100MHzSMF0603FB13FB0805100ohm@100MHzSMF0603FB14FERRITEBEAD_SML0402_120OHM@100120ohm@100MHz,400mASML0402GNDTESTPAD_CIR_0_TESTPAD_1P0X1P5_NNC_R1X1P5TESTPAD_1P0X1P5GND1TESTPAD_CIR_0_TESTPAD_1P0X1P5_NNC_R1X1P5TESTPAD_1P0X1P5L1INDUCTOR_SML2520_1P2H_4.7UH/1.34.7uH/1.3ASML2520_1P2HL2BW_4_CHOKE-DLP11SN900HL2L-4P-1_NC_EXC24CG900UCHOKE-DLP11SN900HL2L-4P-1L3BW_4_CHOKE-DLP11SN900HL2L-4P-1_NC_EXC24CG900UCHOKE-DLP11SN900HL2L-4P-1L4BW_4_CHOKE-DLP11SN900HL2L-4P-1_NC_EXC24CG900UCHOKE-DLP11SN900HL2L-4P-1L5BW_4_CHOKE-DLP11SN900HL2L-4P-1_NC_EXC24CG900UCHOKE-DLP11SN900HL2L-4P-1L6BW_3_CHOKE-DLP11SN900HL2L-4P-1_NC_DLP11TB800UL2CHOKE-DLP11SN900HL2L-4P-1L7BW_3_CHOKE-DLP11SN900HL2L-4P-1_NC_DLP11TB800UL2CHOKE-DLP11SN900HL2L-4P-1L8BW_4_CHOKE-DLP11SN900HL2L-4P-1_NC_EXC24CG900UCHOKE-DLP11SN900HL2L-4P-1L9BW_4_CHOKE-DLP11SN900HL2L-4P-1_NC_EXC24CG900UCHOKE-DLP11SN900HL2L-4P-1L10BW_4_CHOKE-DLP11SN900HL2L-4P-1_NC_EXC24CG900UCHOKE-DLP11SN900HL2L-4P-1L11BW_4_CHOKE-DLP11SN900HL2L-4P-1_NC_EXC24CG900UCHOKE-DLP11SN900HL2L-4P-1L12INDUCTOR_TMP0618_7X6D6_H1D6_TMPTMPC0618H-2R2MG-DTMP0618_7X6D6_H1D6L15INDUCTOR_TMP0618_7X6D6_H1D6_TMPTMPC0618H-2R2MG-DTMP0618_7X6D6_H1D6L16INDUCTOR_TMP0618_7X6D6_H1D6_TMPTMPC0618H-2R2MG-DTMP0618_7X6D6_H1D6L17INDUCTOR_TMP0618_7X6D6_H1D6_TMPTMPC0618H-2R2MG-DTMP0618_7X6D6_H1D6L18INDUCTOR_SML2520_1P2H_4.7UH/1.34.7uH/1.3ASML2520_1P2HL1AP11INDUCTOR_SML2520_NONC_1P0H_0.470.47uH/5ASML2520_NONC_1P0HL1AP21INDUCTOR_SML2520_NONC_1P0H_0.470.47uH/5ASML2520_NONC_1P0HL1AP31INDUCTOR_SML2520_NONC_1P0H_0.470.47uH/5ASML2520_NONC_1P0HL1AP41INDUCTOR_SML2520_NONC_1P0H_0.470.47uH/5ASML2520_NONC_1P0HL1AP51INDUCTOR_SML2520_NONC_1P0H_0.470.47uH/5ASML2520_NONC_1P0HL1AP61INDUCTOR_SML2520_NONC_1P0H_0.470.47uH/5ASML2520_NONC_1P0HL1AP71INDUCTOR_SML2520_NONC_1P0H_0.470.47uH/5ASML2520_NONC_1P0HL1AP81INDUCTOR_SML2520_1P2H_1UH/2.9A1uH/2.9ASML2520_1P2HL1AP91INDUCTOR_SML2520_NONC_1P0H_0.470.47uH/5ASML2520_NONC_1P0HL1AP101INDUCTOR_SML2520_NONC_1P0H_0.470.47uH/5ASML2520_NONC_1P0HL1AP111INDUCTOR_SML2520_1P2H_1UH/2.9A1uH/2.9ASML2520_1P2HL1AP121INDUCTOR_SML2520_NONC_1P0H_0.470.47uH/5ASML2520_NONC_1P0HLED1LED_2_LED_4P_BL-HJEGKB534S-TRB_BL-HJEGKB534S-TRBLED_4P_BL-HJEGKB534S-TRBMH1HOLEC335D185_0_HOLE_C157D71_NC_NC_HoleHOLE_C157D71MH2HOLEC335D185_0_HOLE_C157D71_NULNC_HoleHOLE_C157D71_NULMH3HOLEC335D185_0_HOLE_C157D71_NULNC_HoleHOLE_C157D71_NULMH4HOLEC335D185_0_HOLE_C157D71_NULNC_HoleHOLE_C157D71_NULMH5HOLEC335D185_0_HOLE_C157D71_NC_NC_HoleHOLE_C157D71MH6HOLEC335D185_0_HOLE_C157D71_NC_NC_HoleHOLE_C157D71MH7HOLEC335D185_0_HOLE_C157D71_NULNC_HoleHOLE_C157D71_NULMH8HOLEC335D185_0_HOLE_C157D71_NC_NC_HoleHOLE_C157D71MH9HOLEC335D185_0_HOLE_C157D71_NC_NC_HoleHOLE_C157D71MH10HOLEC335D185_0_HOLE_C157D71_NC_NC_HoleHOLE_C157D71MH11HOLEC335D185_0_HOLE_C157D71_NC_NC_HoleHOLE_C157D71MH12HOLEC335D185_0_HOLE_C157D71_NC_NC_HoleHOLE_C157D71MH13HOLEC335D185_0_HOLE_C157D71_NC_NC_HoleHOLE_C157D71MIC1MIC_SPK0415HM4H-B_0_ZTS6031_8P_ZTS6031ZTS6031_8P_3X4_H1D06MIC2MIC_SPK0415HM4H-B_0_ZTS6031_8P_ZTS6031ZTS6031_8P_3X4_H1D06MK1FMARKC_FIDICALMARK_NC_FMARKSNC_FMARKSFIDICALMARKMK2FMARKC_FIDICALMARK_NC_FMARKSNC_FMARKSFIDICALMARKMK3FMARKC_FIDICALMARK_NC_FMARKSNC_FMARKSFIDICALMARKMK4FMARKC_FIDICALMARK_NC_FMARKSNC_FMARKSFIDICALMARKPC3CAPNP_SMC0402_1UF/10V,X5R1uF/10V,X5RSMC0402PC4CAPNP_SMC0402_0.1UF/25V,X5R0.1uF/25V,X5RSMC0402PC5CAPNP_SMC0603_HI_VALUE_10UF/1610uF/16V,X5RSMC0603_HI_VALUEPC6CAPNP_SMC0603_HI_VALUE_10UF/1610uF/16V,X5RSMC0603_HI_VALUEPC7CAPNP_SMC0603_HI_VALUE_10UF/1610uF/16V,X5RSMC0603_HI_VALUEPC8CAPNP_SMC0402_0.1UF/25V,X5R0.1uF/25V,X5RSMC0402PC9CAPNP_SMC0603_HI_VALUE_22UF/6.22uF/6.3V,X5RSMC0603_HI_VALUEPC10CAPNP_SMC0603_HI_VALUE_22UF/6.22uF/6.3V,X5RSMC0603_HI_VALUEPC11CAPNP_SMC0603_HI_VALUE_22UF/6.22uF/6.3V,X5RSMC0603_HI_VALUEPC12CAPNP_SMC0603_HI_VALUE_22UF/6.22uF/6.3V,X5RSMC0603_HI_VALUEPC13CAPNP_SMC0402_27X47_4.7UF/10V,4.7uF/10V,X5RSMC0402_27X47PC14CAPNP_SMC0402_1UF/10V,X5R1uF/10V,X5RSMC0402PC15CAPNP_SMC0402_0.1UF/25V,X5R0.1uF/25V,X5RSMC0402PC16CAPNP_SMC0603_HI_VALUE_10UF/1610uF/16V,X5RSMC0603_HI_VALUEPC17CAPNP_SMC0603_HI_VALUE_10UF/1610uF/16V,X5RSMC0603_HI_VALUEPC18CAPNP_SMC0603_HI_VALUE_10UF/1610uF/16V,X5RSMC0603_HI_VALUEPC19CAPNP_SMC0402_0.1UF/25V,X5R0.1uF/25V,X5RSMC0402PC20CAPNP_SMC0603_HI_VALUE_22UF/6.22uF/6.3V,X5RSMC0603_HI_VALUEPC21CAPNP_SMC0603_HI_VALUE_22UF/6.22uF/6.3V,X5RSMC0603_HI_VALUEPC22CAPNP_SMC0603_HI_VALUE_22UF/6.22uF/6.3V,X5RSMC0603_HI_VALUEPC23CAPNP_SMC0603_HI_VALUE_22UF/6.22uF/6.3V,X5RSMC0603_HI_VALUEPC24CAPNP_SMC0402_27X47_4.7UF/10V,4.7uF/10V,X5RSMC0402_27X47PC25CAPNP_SMC0402_0.1UF/25V,X5R0.1uF/25V,X5RSMC0402PC26CAPNP_SMC0603_HI_VALUE_10UF/1610uF/16V,X5RSMC0603_HI_VALUEPC27CAPNP_SMC0603_HI_VALUE_10UF/1610uF/16V,X5RSMC0603_HI_VALUEPC28CAPNP_SMC0402_0.1UF/25V,X5R0.1uF/25V,X5RSMC0402PC29CAPNP_SMC0603_HI_VALUE_22UF/6.22uF/6.3V,X5RSMC0603_HI_VALUEPC30CAPNP_SMC0603_HI_VALUE_22UF/6.22uF/6.3V,X5RSMC0603_HI_VALUEPC31CAPNP_SMC0603_HI_VALUE_22UF/6.22uF/6.3V,X5RSMC0603_HI_VALUEPC32CAPNP_SMC0603_HI_VALUE_22UF/6.22uF/6.3V,X5RSMC0603_HI_VALUEPC33CAPNP_SMC0603_HI_VALUE_10UF/1610uF/16V,X5RSMC0603_HI_VALUEPD1DIODETWIN_SOT23_BAT54CBAT54CSOT23PD2DIODETWIN_SOT23_BAT54CBAT54CSOT23PFB1FB0805100ohm@100MHzSMF0603PFB2FB0805100ohm@100MHzSMF0603PFB3FB0805100ohm@100MHzSMF0603PFB4FB0805100ohm@100MHzSMF0603PR3R_SMR0603_0R0RSMR0603PR4R_SMR0603_0R0RSMR0603PR5R_SMR0603_0R0RSMR0603Q1NMOS_SOT723_SOT723_WNM2030-3/TRWNM2030-3/TRSOT723Q18TDSON-8_1_CON9-3_2X3_2-H0_9_QM3QM3004M3CON9-3_2X3_2-H0_9Q19TDSON-8_1_CON9-3_2X3_2-H0_9_QM3QM3004M3CON9-3_2X3_2-H0_9Q20NMOS_SOT723_SOT723_WNM2030-3/TRWNM2030-3/TRSOT723Q21TDSON-8_1_CON9-3_2X3_2-H0_9_Q_1QM3006M3CON9-3_2X3_2-H0_9Q22TDSON-8_1_CON9-3_2X3_2-H0_9_Q_1QM3006M3CON9-3_2X3_2-H0_9Q23NMOS_SOT723_SOT723_WNM2030-3/TRWNM2030-3/TRSOT723Q25NMOS_SOT723_SOT723_WNM3013-3/TRWNM3013-3/TRSOT723Q27NMOS_SOT723_SOT23_2N7002K-H2N7002K-HSOT23Q28PRPAK3_3_CON9-3_2X3_2-H0_9_QM30QM3003M3CON9-3_2X3_2-H0_9Q29PRPAK3_3_CON9-3_2X3_2-H0_9_QM30QM3003M3CON9-3_2X3_2-H0_9Q30PRPAK3_3_CON9-3_2X3_2-H0_9_QM30QM3003M3CON9-3_2X3_2-H0_9Q33PRPAK3_3_CON9-3_2X3_2-H0_9_QM30QM3003M3CON9-3_2X3_2-H0_9Q34PRPAK3_3_CON9-3_2X3_2-H0_9_QM30QM3003M3CON9-3_2X3_2-H0_9Q35NMOS_SOT723_SOT723_WNM2030-3/TRWNM2030-3/TRSOT723Q37NMOS_SOT723_SOT723_WNM3013-3/TRWNM3013-3/TRSOT723Q38NMOS_SOT723_SOT723_WNM3013-3/TRWNM3013-3/TRSOT723Q39NMOS_SOT723_SOT723_WNM3013-3/TRWNM3013-3/TRSOT723Q40NMOS_SOT723_SOT23_2N7002K-H2N7002K-HSOT23Q41NMOS_SOT723_SOT723_WNM2030-3/TRWNM2030-3/TRSOT723RXTESTPAD_CIR_0_TESTPAD_1P0X1P5_NNC_R1X1P5TESTPAD_1P0X1P5RXDTESTPAD_CIR_0_TESTPAD_1P0X1P5_NNC_R1X1P5TESTPAD_1P0X1P5SH2SHUNT_POINT_SHUNT_0805_NC_SHUNTNC_SHUNT_0805SHUNT_0805SH2VR11SHUNT_POINT_SHUNT_0402_NC_SHUNTNC_SHUNT_0402SHUNT_0402TXTESTPAD_CIR_0_TESTPAD_1P0X1P5_NNC_R1X1P5TESTPAD_1P0X1P5TXDTESTPAD_CIR_0_TESTPAD_1P0X1P5_NNC_R1X1P5TESTPAD_1P0X1P5U1BIOS_SOIC8_SOIC8_208_GD25LQ64CVGD25LQ64CVIGRSOIC8_208U2ASM1061_QFN48_0R5_7X7_EP_ASM106ASM1061QFN48_0R5_7X7_EPU3SST25LF040A_SOIC_8P_50_197X236_GD25D05BTIGSOIC_8P_50_197X236U4WIFI_BT_MODULE_12X16_LCC100_M2_7265.D2WG18VLCC100_M2_1216_COMBO_1P75HU5ALC5672_LCC48_P4MM_SQ6MM_SQ4P4DALC5672-VB-CGTLCC48_P4MM_SQ6MM_SQ4P4DIEU6PS8750B_0_QFN52_6D5X4D5_035_H07PS8750BQFN52GTR-A0QFN52_6D5X4D5_035_H075U7ESD5344D_0_LCC10_NS_2P5X1P0_P65ESD5344D-10TRLCC10_NS_2P5X1P0_P65HU8ESD5344D_0_LCC10_NS_2P5X1P0_P65ESD5344D-10TRLCC10_NS_2P5X1P0_P65HU9IT8110E_0_LQFP64_0D4_1D6_IT8110IT8110E/CXLQFP64_0D4_1D6U10BIOS_SOIC8_SOIC8_208_GD25D10BTIGD25D10BTIGSOIC8_208U11TPS51206_2_DSQ_P04_10PH08_NC_TPNC_TPS51206DSQRDSQ_P04_10PH08U12ISL9237_3_QFN32_4X4_ISL9237HRZISL9237HRZQFN32_4X4U15APL3526QBI_0_UQFN3_3_16PIN_RT72RT7291AUQFN3_3_16PIN_RT7290AU16APL3526QBI_1_UQFN3_3_16PIN_RT72RT7290AUQFN3_3_16PIN_RT7290AU18APL3526QBI_1_UQFN3_3_16PIN_RT_1RT6220AGQUFUQFN3_3_16PIN_RT7290AU23WL2801E28-5/TR_1_QFN4_PH0P625_1RT9073A-18GQZQFN4_PH0P625_1X1_H0P4U47SGM4553_SOT23_8_H1D25_SGM4553YNSGM4553YN8G/TRSOT23_8_H1D25U82KTD2511CEHD_1_TSOT23_6_BL9342BL9342TSOT23_6U3900SY6288_SOT23_5_H1D25_SGM2588AYNSGM2588AYN5G/TRSOT23_5_H1D25U3901SY6288_SOT23_5_H1D25_SGM2588AYNSGM2588AYN5G/TRSOT23_5_H1D25U3902SY6288_SOT23_5_H1D25_SGM2588AYNSGM2588AYN5G/TRSOT23_5_H1D25U1AM1K3QF4F40BM-AGCE_BGA253_P5MM_11PK3QF4F40BM-AGCFBGA253_P5MM_11P5X11_1P0HU1AM2K3QF4F40BM-AGCE_BGA253_P5MM_11PK3QF4F40BM-AGCFBGA253_P5MM_11P5X11_1P0HU1AP1WHISKEYCOVE_CHT_PMIC_A1_4_BGA24PMB6835A.P10 SLKMQBGA240_P4MM_6P095X6P495_P635HU1AS1CHT_T_FFD_PR0_REV1P3_7_BGA1380_X7-Z8700 SR27MFJ8066401715809BGA1380_P4MM_17X17_CHVY1XTAL_4P_SMY_4P_79X98_PAD37X39_220MHzSMY_4P_79X98_PAD37X39Y1AP11XTAL_2P_SMY2P_49X83_32.768KHZ32.768KHzSMY2P_49X83Y1AS11XTAL_4P_SMY_4P_79X98_PAD37X39_119.2MHzSMY_4P_79X98_PAD37X39Y1AS21XTAL_2P_SMY2P_49X83_32.768KHZ32.768KHzSMY2P_49X83
老吴 发表于 2019-4-1 01:47:27
全网首发,PCB和原理图一起打包。。这个型号技术资料网上一点都找不到。
禁止转载到其他网站或论坛。谢谢。
仅提供给技术交流学习
**** Hidden Message *****
kanxue_nmg 发表于 2019-4-1 06:52:36
单枪舞九州 发表于 2019-4-1 07:40:39
支持
907321 发表于 2019-4-1 07:44:52
经纬 发表于 2019-4-1 07:47:19
回 老吴 的帖子
老吴:全网首发,PCB和原理图一起打包。。  这个型号技术资料网上一点都找不到。
禁止转载到其他网站或论坛。谢谢。
....... (2019-04-01 01:47) images/back.gif
好东西 点赞
十月的皮皮 发表于 2019-4-1 07:51:18
谢谢分享!
学海无涯 发表于 2019-4-1 08:03:26
果然精品,高大上。
io357 发表于 2019-4-1 08:17:42
谢谢分享!
yfchen1003 发表于 2019-4-1 08:17:45
啊嘻嘻
页: [1] 2 3 4 5 6 7 8 9 10
查看完整版本: Intel Atom X7-Z8700 方案平板电脑PCB文件和原理图共享下载
