最新RK3326 AI智能语音方案PCB文件共享-4层方案PCB
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEANT6100ANT_1P1G_ANTPCB_44R00X11R00_DSRANT4411DRANTPCB_44R00X11R00_DSRANT6101ANT_1P2G_ANT_JACK_ANT_JACKANT_JACKANT_JACKBT2001BATT3_BAT3_2R54_BAT3_2R54BAT3_2R54BAT3_2R54CM7100CM_C_MTM-C_100UF/25V100uF/25VMTM-CCM7101CM_C_MTM-C_100UF/25V100uF/25VMTM-CD2001DIODE_DO_214AC_SS32SS32DO_214ACD2003DIODE_SOD_323_B5819WSB5819WSSOD_323D4100DIODE BI_DIRTRIG_ESD0402_ESD54ESD5451NESD0402D4101DIODE_SOD_323_1N4148WS1N4148WSSOD_323D9100DIODE BI_DIRTRIG_ESD0402_ESD54ESD5451NESD0402ED9105DIODE BI_DIRTRIG_ESD0402_ESD_1ESD5471XESD0402ED9106DIODE BI_DIRTRIG_ESD0402_ESD_1ESD5471XESD0402F2000FUSE_F8050_JK-SMD200LJK-SMD200LF8050FB2500INDUCTORCOM_L0603D_90R-100M90R-100ML0603DFB4600BEAD_L0603_180R-100M180R-100ML0603FB4700BEAD_L0603_180R-100M180R-100ML0603H9900HOLE_HOLE_C3R20_C6R00_HOLE_3R20HOLE_3R20HOLE_C3R20_C6R00H9901HOLE_HOLE_C3R20_C6R00_HOLE_3R20HOLE_3R20HOLE_C3R20_C6R00H9902HOLE_HOLE_C3R20_C6R00_HOLE_3R20HOLE_3R20HOLE_C3R20_C6R00H9903HOLE_HOLE_C3R20_C6R00_HOLE_3R20HOLE_3R20HOLE_C3R20_C6R00IR9200IR_RECEIVE_1_IR-SIR8B39_OQSS-R1OQSS-R12IR-SIR8B39J2000DCJACK_3P_DC3_DC_0007_5P_DC-000DC-0007-5PDC3_DC_0007_5PJ2100JACK_1500_0_CNN2_2R00_6R30X4R90JACK_1500_2PCNN2_2R00_6R30X4R90X6R30_VJ2500USB20_MICRO_USB20MICRO5_MU05_10USB20_microUSB20MICRO5_MU05_10MGF_TJ4600CMK-CB0077-FV1_2_CON30M_2X15_0RAXT530124CON30M_2X15_0R40_V_SMTJ4601OK-14GM030-04_CON30F_2X15_0R40_OK-14GM030-04CON30F_2X15_0R40_OK_14F030_04J4700OV2659_FPC24L_1X24_0R50_DOWN_OVOV2659FPC24L_1X24_0R50_DOWNJ5100FPC_MIPI/LVDS_FPC30R_0R50_UP_3030PIN FPC CONFPC30R_0R50_UPJ7000PHONEJACK_6P_PJ6_D3R50_PJ35106SPJ35106SY-P10PJ6_D3R50_PJ35106SY-P10J7100JACK_1500_0_CNN2_2R00_6R30X4R90JACK_1500_2PCNN2_2R00_6R30X4R90X6R30_VJ7101JACK_1500_0_CNN2_2R00_6R30X4R90JACK_1500_2PCNN2_2R00_6R30X4R90X6R30_VJ7201LCD_HITACHI_TX05D99VM1AAA_1_CNN30PIN FPC CONCNN30_1R00_FP05SL_VJ7202LCD_HITACHI_TX05D99VM1AAA_1_CNN30PIN FPC CONCNN30_1R00_FP05SL_VJ9100TFCARD_SOCKET_TF9_CKT01_009D_TFTF-CKT01-009DTF9_CKT01_009DJ9600USB20_MICRO_USB20MICRO5_MU05_10USB20_microUSB20MICRO5_MU05_10MGF_TJ9901GND_GATE_CON2_1X2_5R08_DIP_GND_GND_GATECON2_1X2_5R08_DIPJ9902GND_GATE_CON2_1X2_5R08_DIP_GND_GND_GATECON2_1X2_5R08_DIPL2000INDUCTORS OFFERRITE_IND_4040303.3uHIND_404030L2001INDUCTORS OFFERRITE_IND_6060283.3uHIND_606028L2100INDUCTORS OFFERRITE_IND_252010470nHIND_252010L2101INDUCTORS OFFERRITE_IND_252010470nHIND_252010L2102INDUCTORS OFFERRITE_IND_252010470nHIND_252010L2103INDUCTORS OFFERRITE_IND_252010470nHIND_252010L2104INDUCTORS OFFERRITE_IND_252010470nHIND_252010L6004RESISTOR_R0805_330NH330nHR0805L6100INDUCTOR_L0402_DNPDNPL0402L6101INDUCTOR_L0402_DNPDNPL0402L6102INDUCTORS OFFERRITE_IND_3030124.7uHIND_303012L7100INDUCTORS OFFERRITE_IND_80804015uHIND_808040L7101INDUCTORS OFFERRITE_IND_80804015uHIND_808040L7102INDUCTORS OFFERRITE_IND_80804015uHIND_808040L7103INDUCTORS OFFERRITE_IND_80804015uHIND_808040L7104INDUCTORS OFFERRITE_IND_11111415uHIND_111114_DIPL7105INDUCTORS OFFERRITE_IND_11111415uHIND_111114_DIPL7106INDUCTORS OFFERRITE_IND_11111415uHIND_111114_DIPL7107INDUCTORS OFFERRITE_IND_11111415uHIND_111114_DIPLED2001LED_LED0603_LED_BLUELED_BlueLED0603LED2003LED_LED0603_LED_REDLED_REDLED0603LED9600LED_LED0603_LED_REDLED_REDLED0603M9900MARK_MARK_MARKMARKMARKM9901MARK_MARK_MARKMARKMARKM9902MARK_MARK_MARKMARKMARKM9903MARK_MARK_MARKMARKMARKM9904MARK_MARK_MARKMARKMARKM9905MARK_MARK_MARKMARKMARKQ2000MOSFETN_SOT_23_WNM3003-3/TRWNM3003-3/TRSOT_23Q2001MOSFETN_SOT_23_WNM3003-3/TRWNM3003-3/TRSOT_23Q2002MOSFETP_SOT_23_WPM3407-3/TRWPM3407-3/TRSOT_23Q2500MOSFETN_SOT_23_WNM2016-3/TRWNM2016-3/TRSOT_23Q6100MOSFETN_SOT_323_2SK30182SK3018SOT_323Q6101MOSFETN_SOT_323_2SK30182SK3018SOT_323Q6102MOSFETN_SOT_323_2SK30182SK3018SOT_323Q7100MOSFETN_SOT_323_WNM6002-3/TRWNM6002-3/TRSOT_323Q7201MOSFETN_SOT_323_2SK30182SK3018SOT_323SMTSO9900SMTSO_SMTSO_M3_C4R1_C6R0_L10R0_SMTSO30100CTJSMTSO_M3_C4R1_C6R0_L10R0SMTSO9901SMTSO_SMTSO_M3_C4R1_C6R0_L10R0_SMTSO30100CTJSMTSO_M3_C4R1_C6R0_L10R0SMTSO9906SMTSO_SMTSO_M3_C4R1_C6R0_L10R0_SMTSO30100CTJSMTSO_M3_C4R1_C6R0_L10R0SMTSO9907SMTSO_SMTSO_M3_C4R1_C6R0_L10R0_SMTSO30100CTJSMTSO_M3_C4R1_C6R0_L10R0SW2000KEY_5PIN_SW5_6R20X6R20X2R50_PWRPWRONSW5_6R20X6R20X2R50SW2005KEY_5PIN_SW5_6R20X6R20X2R50_RECRecoverySW5_6R20X6R20X2R50SW2100KEY_5PIN_SW5_6R20X6R20X2R50_RESRESETSW5_6R20X6R20X2R50SW4100SWPUSHBUTTON_SMT2_6R00X3R50X4RMaskromSMT2_6R00X3R50X4R20U1000MCU_RK3326_BGA418_14R00X14R00X1RK3326BGA418_14R00X14R00X1R24U2000DCDC_SY8113_SOT_23_6_SY8113BSY8113BSOT_23_6U2001CHARGER_BQ24133_QFN24_5R65X3R65BQ24133QFN24_5R65X3R65X1R00_TU2002LDO_PT5108_1_SOT_89_3_SGM2203-5SGM2203-5.0SOT_89_3U2100RK809_QFN68_7R00X7R00X0R80_T_RKRK809QFN68_7R00X7R00X0R80_TU2500ESD_ESDA6V8UL_SOT_23_ESD5302FESD5302FSOT_23U2507SWITCH_SY6280_SOT_23_5_SY6280AASY6280AACSOT_23_5U3000DDR3_16BIT_FBGA96_14R00X11R00X1K4B4G1646QFBGA96_14R00X11R00X1R20U3001DDR3_16BIT_FBGA96_14R00X11R00X1K4B4G1646QFBGA96_14R00X11R00X1R20U4000NANDFLASH_TSOP48_TSOP48_18R40X1H27UBG8T2DTR-BCTSOP48_18R40X12R10X1R20U4100INAND_EMMC_169_2L_BGA169_18R00XKLMAG2GEAC-B031BGA169_18R00X14R00X1R20_2LU6100MODULE_AP6XXX_MD44_AP6XXX_AP621AP6212MD44_AP6XXXU7100TPA3110_TSSOP28_9R70X4R40X1R20_TPA3110TSSOP28_9R70X4R40X1R20_TU7200SECURE_ATSHA204A_SOP8_5R00X4R00ATSHA204A-SSHDA-TSOP8_5R00X4R00X1R75U9010AL3006_0_MODULE-8_TMD27723TMD27723MODULE-8U9600INTERFACE_FT232RL_SSOP28_10R20XFT232RLSSOP28_10R20X5R30X2R00U9601ESD_ESDA6V8UL_SOT_23_ESD5302FESD5302FSOT_23U9602SWITCH_FSUSB30MUX_MSOP10_3R00X3FSUSB30MUXMSOP10_3R00X3R00X1R10Y1100CRYSTAL_4P_CRY4_3R20X2R50X0R80_24MHzCRY4_3R20X2R50X0R80Y2100CRYSTAL_2P_1G_CRY2_6R90X1R40X1R32.768KHzCRY2_6R90X1R40X1R30Y6100CRYSTAL_4P_CRY4_3R20X2R50X0R8_126MHzCRY4_3R20X2R50X0R80 PCB文件。没有拿到原理图。仅做参考学习。回复可见下载
**** Hidden Message *****
可以参考论坛已有的 这个PDF原理图。我看了 应该是配对的。由于是PDF 的没办法 100%核对
原理图地址 http://bbs.ntpcb.com/read-htm-tid-133482.html 太厉害了!!! 有原理图就好了
回 老吴 的帖子
老吴:PCB文件。没有拿到原理图。仅做参考学习。回复可见下载[内容隐藏]
....... (2019-04-02 18:10) images/back.gif
谢谢分享 谢谢分享 谢谢分享最新RK3326 AI智能语音方案PCB文件 加油
