[/free]
超声波测距(分立元器件)原理图与PCB.zip
(151 KB, 下载次数: 54)
[free]
本主题需向作者支付 1 枚金币 才能浏览 购买主题
申请了任务,没有点开始。。。发了三个帖子不算,不知道怎么办。。。
感谢分享!
谢谢分享!
感谢分享!
自己顶一个,这个配合着程序精度可以到几个mm
![123.png 123.png](https://dl.dianzi168.net/attachment/forum/pw/Day_190406/22_14193_c628584754a34eb.png)
Comment | Description | Designator | Footprint | LibRef | Quantity |
LM358_NSC | Fast Settling DualOperational Amplifier | A1 | SO-8 | LM358_NSC | 1 |
7805 | 3-Terminal PositiveVoltage Regulator | A2 | TO220H | 7805 | 1 |
78L08 | 3-Terminal PositiveVoltage Regulator | A3 | TO92A | 78L08 | 1 |
78L05 | 3-Terminal PositiveVoltage Regulator | A4 | TO92A | 78L05 | 1 |
10u/35V | Bi-Polar Capacitor | C1, C2 | RB.1/.2 | CAP2 | 2 |
104 | Capacitor | C3, C4, C5, C6, C7,C13, C15 | 0805 | CAP | 7 |
100u/25V | Bi-Polar Capacitor | C8, C9, C10, C11, C12 | RB.1/.2 | CAP2 | 5 |
105 | Capacitor | C14 | 0805 | CAP | 1 |
100 | Capacitor | C16, C17 | 0805 | CAP | 2 |
103 | Capacitor | C18 | 0805 | CAP | 1 |
1n | Capacitor | C19 | 0805 | CAP | 1 |
10u | ElectrolyticCapacitor | C20, C28, C30 | 1206L | ELECTRO2 | 3 |
0.1 | Capacitor | C21, C22, C23, C24,C27, C29, C31 | 0805 | Cap | 7 |
10p | Capacitor | C25, C26 | 0805 | Cap | 2 |
IRF107 | Diode | D1 | 1206LN | DIODE | 1 |
FUSE | Fuse | F1 | FUSE | FUSE | 1 |
LED | HL1 | 1206LED | LED | 1 | |
LED | HL2 | LED | LED | 1 | |
RED | HL3 | 1206LED | LED | 1 | |
CON5 | Connector | J1 | X5-3.81-1 | CON5 | 1 |
CON3 | Connector | J2 | SIP3 | CON3 | 1 |
RELAY-SPDT | K1 | DELAY | RELAY-SPDT | 1 | |
T512 | Seven-SegmentDisplay, Right Hand Decimal | LED1 | SEG7x3 | DPY_7-SEG_DP | 1 |
4.7K | Resistor, Resistor,Resistor, [NoValue] | R1, R2, R3, R46 | 0805 | RES, RES, RES, RES2 | 4 |
1.5K | Resistor | R4, R5 | 0805 | RES | 2 |
10K | Potentiometer | R6 | VR | RPOT | 1 |
10K | Resistor, Resistor,Resistor, Resistor, Resistor, Resistor, [NoValue], [NoValue], [NoValue],[NoValue], [NoValue], [NoValue], [NoValue], [NoValue] | R7, R8, R9, R10, R11,R12, R16, R17, R18, R19, R20, R21, R22, R55 | 0805 | RES, RES, RES, RES,RES, RES, RES2, RES2, RES2, RES2, RES2, RES2, RES2, RES2 | 14 |
2K | Resistor, [NoValue],[NoValue], [NoValue] | R13, R41, R42, R43 | 0805 | RES, RES2, RES2, RES2 | 4 |
1k | R14, R15, R31, R32,R33, R34 | 0805 | RES2 | 6 | |
100k | R23, R24, R25, R26,R27, R28 | 0805 | RES2 | 6 | |
5k | R29, R30 | 0805 | RES2 | 2 | |
10k | Potentiometer | R35 | R3386 | POT2 | 1 |
5.1k | R36, R37 | 0805 | RES2 | 2 | |
1M | R38, R39 | 0805 | RES2 | 2 | |
300k | R40 | 0805 | RES2 | 1 | |
130k | R44 | 0805 | RES2 | 1 | |
1.2M | R45 | 0805 | RES2 | 1 | |
470 | R47, R48, R49, R50,R51, R52, R53, R54 | 0805 | RES2 | 8 | |
10 | R56 | 0805 | RES2 | 1 | |
SW-PB | S1 | SW | SW-PB | 1 | |
PC817 | Optoisolator | U1, U2 | DIP4 | OPTOISO1 | 2 |
LM358 | Fast Settling DualOperational Amplifier | U3, U4, U5, U6 | SO-8 | LM358 | 4 |
LM393 | U7 | SO-8 | LM193 | 1 | |
4049 | Inverting Hex Buffer/ Converter | U8 | SO-16 | 4049 | 1 |
STC12C54XX_QFP | U9 | TQFP32 | STC12C54XX_QFP | 1 | |
SP3232E | +5V Powered,Multi-Channel RS-232 Driver/Receiver | U10 | SO-16 | MAX232ACPE | 1 |
CMR1-04M | V1 | DO-213 | 1N4148 | 1 | |
TIP32C | PNP BJT | V2 | TO220-TIP32C | TIP32C | 1 |
BD135 | NPN BJT | V3 | TO126V | BD135 | 1 |
BD138 | PNP BJT | V4 | TO126V | BD138 | 1 |
BAS86 | V5 | 1206LN | 1N4148 | 1 | |
5V | Zener Diode | V6 | 1206LN | ZENER2 | 1 |
BC856A | PNP BJT | V7, V8, V9 | TO-92A | BC856A | 3 |
BD135 | V10 | TO-92A | BD135 | 1 | |
32M | Crystal | X1 | XTAL-T | CRYSTAL | 1 |
CON4 | Connector | XS1 | X4-3.81-1 | CON4 | 1 |
![](static/image/filetype/zip.gif)
[free]
