Mstar MSD7S0X 做的机顶盒PCB文件和原理图共享
NamePCB DecalValuePart TypeCOM35USBUSBCON1JACK-12P-RJ45RJ45_1X1-90DJACK-12P-RJ45CON4SCART-PB-RCABSCARTSCART-PB-RCABCON21SIP3_2D54AAAWAFER/2.0MM/1*4P/180DSIP3_2D54AAACON32CON-HDMIHDMI/90DCON-HDMID1R0402NC/CDS2C16GTH_3PFR0402D2R0402NC/CDS2C16GTH_3PFR0402D3NL-DO-214ACSMBJ15CANL-DO-214ACD4NL-DO-214ACIN5189NL-DO-214ACD25R0402NC/CDS2C16GTH_3PFR0402DT1SOT_23BAV99SOT_23DT2SOT_23BAV99SOT_23EC1RB2D5_6D3470UF/25V/LOWESRRB2D5_6D3EC2EC-5/2.5_GX100UF/16VEC-5/2.5_GXEC5C060310UF/6.3VC0603EC7C080510UF/6.3VC0805EC8RB2D5_6D3220UF/16VRB2D5_6D3EC10C06031UF/10VC0603EC15RB2D5_6D3220UF/16VRB2D5_6D3FB3L0402BEAD/20R/300MAL0402FB8L0603BEAD/6R/500MAL0603FB12L0603BEAD/30R/3000MAL0603FB14L0402BEAD/20R/300MAL0402FB16R0603FB0603/2AFB0603FB26L0603BEAD/6R/500MAL0603FT1L0603FB100RL0603H1THOTHOH2THOTHOH3THOTHOJ2IRIR/RXIRJ3TUNER_5007ATB2012_75011TUNER_JACKJ4JACK\DCJACK\DCJ6RCAAV-8.4-5ARCAAV-8.4-5AJ8RCA3X2AV-RGBRCA3X2JC16PINSIP-6P_2.06PINK2SW-4P-1102VSW-4P-1102VK3SW-4P-1102VSW-4P-1102VK4SW-4P-1102VSW-4P-1102VL1CD5310UH/2A-CD54CD53L2L5.00.3*2.2*14.5 LL5.0L3COIL-DLW21SNNC/DLW21SN900HQ2COIL-DLW21SNL4L06030RL0603L5L06030RL0603L6L06030RL0603L7L06031.8UHL0603L12COIL-DLW21SNNC/DLW21SN900HQ2COIL-DLW21SNL13COIL-DLW21SN0R/DLW21SN900HQ2COIL-DLW21SNL18CD431UH/2.7A-2520CD43L19CD431UH/2.7A-2520CD43LED1LED-3P_LED-3P_LED2LED_KHE30281BG1W25LED3641LT1R04026.8nHR0402LT2R0402270nHR0402LT3R0402270nHR0402LT4R0402270nHR0402M1HOLE-MOPTICALHOLE-MM2HOLE-MOPTICALHOLE-MM3HOLE-MOPTICALHOLE-MM4HOLE-MOPTICALHOLE-MM7HOLE-MAOPTICALHOLE-MQ1SOT23BAV99SOT23Q2SOT23MMBT3906SOT23Q3SOT23-GDSAO3401SOT23-GDSQ4SOT23MMBT3904SOT23Q5SOT23-GDSAO3401SOT23-GDSQ6SOT23MMBT3906SOT23Q7SOT23BAV99SOT23Q8SOT23BAV99SOT23Q9SOT23MMBT3904SOT23Q10SOT23MMBT3904SOT23Q13SOT23MMBT3904SOT23Q14SOT23MMBT3904SOT23Q15SOT23MMBT3904SOT23Q16SOT232N7002SOT23Q17SOT23BAV99SOT23Q18SOT23MMBT3904SOT23Q19SOT23MMBT3904SOT23Q23SOT232N7002SOT23Q27SOT_23BSGM810/DIO6810SST3SOT_23T1IC-16P-10_100BASEF1602SMGIC-16P-10_100BASETT1ATB2012_75011ATB2012_75011ATB2012_75011U1SOT23-6SY8113/3A_TSOT23-6SOT23-6U3SOT-23-5SY8088/1A_SOT23-5SOT-23-5U5SOT-23-5SY8089A/2A_SOT23-5SOT-23-5U7IC-8P-SOPL-200IC-8P-WSON-8X6MMIC-8P-SOPL-200U8IC-128P-LQFP-14X14-GMSD7S0X/LQFP128IC-128P-LQFP-14X14-GU9SOP16_LN1650FD650K/SSOP16_LN1650U11IC-10P-RCLAMP0524PNC/RCLAMP0524PIC-10P-RCLAMP0524PU12IC-10P-RCLAMP0524PNC/RCLAMP0524PIC-10P-RCLAMP0524PU16ESD-AOZ8802ANC/AOZ8802ADI_0.3PFESD-AOZ8802AU19SOT_223_5REG1117-1.8VSOT_223_5UT1QFN24MXL608QFN24X1XTAL24MXTALY1XTALS-GND24MHZ/30PPM/DIPXTALS-GND PCB和原理图共享。 不过原理图 和PCB有一些差异,不是完全匹配。仅做参考。
回复可见
**** Hidden Message ***** 谢谢分享Mstar MSD7S0X 做的机顶盒PCB文件和原理图 看看机顶盒 谢谢分享,学习一下
